Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
Get rid of users of of_platform_driver in drivers/net. The
of_platform_{,un}register_driver functions are going away, so the
users need to be converted to using the platform_bus_type directly.
commit 1e4e0767ecb1 (Fix locking on fec_mpc52xx driver) assumed IRQ are
enabled when an IRQ handler is called.
It is not the case anymore (IRQF_DISABLED is deprecated), so we can use
regular spin_lock(), no need for spin_lock_irqsave().
Tested-by: Jean-Michel Hautbois <jhautbois@gmail.com>
Cc: Asier Llano <a.llano@ziv.es>
Cc: Grant Likely <grant.likely@secretlab.ca>
The driver name and bus address for a net_device can normally be found
through the driver model now. Instead of requiring drivers to provide
this information redundantly through the ethtool_ops::get_drvinfo
operation, use the driver model to do so if the driver does not define
the operation. Since ETHTOOL_GDRVINFO no longer requires the driver
to implement any operations, do not require net_device::ethtool_ops to
be set either.
Remove implementations of get_drvinfo and ethtool_ops that provide
only this information.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
The phy_mii_ioctl() function unnecessarily throws away the original ifreq.
We need access to the ifreq in order to support PHYs that can perform
hardware time stamping.
Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl().
This is unnecessary since phylib will check the command in any case.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Error path in mpc52xx_fec_probe() is broken.
We must free everything that we've allocated.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Merging in current state of Linus' tree to deal with merge conflicts and
build failures in vio.c after merge.
drivers/i2c/busses/i2c-cpm.c
drivers/i2c/busses/i2c-mpc.c
drivers/net/gianfar.c
Also fixed up one line in arch/powerpc/kernel/vio.c to use the
correct node pointer.
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
The following structure elements duplicate the information in
'struct device.of_node' and so are being eliminated. This patch
makes all readers of these elements use device.of_node instead.
(struct of_device *)->node
(struct dev_archdata *)->prom_node (sparc)
(struct dev_archdata *)->of_node (powerpc & microblaze)
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
eth_type_trans(skb, netdev) does the "skb->dev = netdev;"
initialization, we can remove it from various network drivers.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
Fix the locking scheme on the fec_mpc52xx driver. This device can
receive IRQs from three sources; the FEC itself, the tx DMA, and the
rx DMA. Mutual exclusion was handled by taking a spin_lock() in the
critical regions, but because the handlers are run with IRQs enabled,
spin_lock() is insufficient and the driver can end up interrupting
a critical region anyway from another IRQ.
Asier Llano discovered that this occurs when an error IRQ is raised
in the middle of handling rx irqs which resulted in an sk_buff memory
leak.
In addition, locking is spotty at best in the driver and inspection
revealed quite a few places with insufficient locking.
This patch is based on Asier's initial work, but reworks a number of
things so that locks are held for as short a time as possible, so
that spin_lock_irqsave() is used everywhere, and so the locks are
dropped when calling into the network stack (because the lock only
protects the hardware interface; not the network stack).
Boot tested on a lite5200 with an NFS root. Has not been performance
tested.
Signed-off-by: Asier Llano <a.llano@ziv.es>
Not as fancy as coccinelle. Checkpatch errors ignored.
Compile tested allyesconfig x86, not all files compiled.
grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \
perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\
done
The MDIO bus cannot be accessed at interrupt context, but on an FEC
error, the fec_mpc52xx driver reset function also tries to reset the
PHY. Since the error is detected at IRQ context, and the PHY functions
try to sleep, the kernel ends up panicking.
Resetting the PHY on an FEC error isn't even necessary. This patch
solves the problem by removing the PHY reset entirely.
Signed-off-by: John Bonesio <bones@secretlab.ca>
The NETPOLL API requires that interrupts remain disabled in
netpoll_send_skb(). The use of "A functions set" in the NETPOLL API
callbacks causes the interrupts to get enabled and can lead to kernel
instability.
The solution is to use "B functions set" to prevent the irqs from
getting enabled while in netpoll_send_skb().
A functions set:
local_irq_disable()/local_irq_enable()
spin_lock_irq()/spin_unlock_irq()
spin_trylock_irq()/spin_unlock_irq()
B functions set:
local_irq_save()/local_irq_restore()
spin_lock_irqsave()/spin_unlock_irqrestore()
spin_trylock_irqsave()/spin_unlock_irqrestore()
Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com>
Acked-by: Matt Mackall <mpm@selenic.com>
Manual merge of:
drivers/net/fec_mpc52xx.c
So far, MPC512x used mpc512x_find_ips_freq() to get the bus frequency,
while MPC52xx used mpc52xx_find_ipb_freq(). Despite the different
clock names (IPS vs. IPB) the code was identical.
Use common code for both processor families.
The patch reworks the MPC5200 Fast Ethernet Controller (FEC) driver to
use the of_mdio infrastructure for registering PHY devices from data out
openfirmware device tree, and eliminates the assumption that the PHY
for the FEC is always attached to the FEC's own MDIO bus. With this
patch, the FEC can use a PHY attached to any MDIO bus if it is described
in the device tree.
Tested on Freescale Lite5200b eval board
Acked-by: Andy Fleming <afleming@freescale.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (54 commits)
glge: remove unused #include <version.h>
dnet: remove unused #include <version.h>
tcp: miscounts due to tcp_fragment pcount reset
tcp: add helper for counter tweaking due mid-wq change
hso: fix for the 'invalid frame length' messages
hso: fix for crash when unplugging the device
fsl_pq_mdio: Fix compile failure
fsl_pq_mdio: Revive UCC MDIO support
ucc_geth: Pass proper device to DMA routines, otherwise oops happens
i.MX31: Fixing cs89x0 network building to i.MX31ADS
tc35815: Fix build error if NAPI enabled
hso: add Vendor/Product ID's for new devices
ucc_geth: Remove unused header
gianfar: Remove unused header
kaweth: Fix locking to be SMP-safe
net: allow multiple dev per napi with GRO
r8169: reset IntrStatus after chip reset
ixgbe: Fix potential memory leak/driver panic issue while setting up Tx & Rx ring parameters
ixgbe: fix ethtool -A|a behavior
ixgbe: Patch to fix driver panic while freeing up tx & rx resources
The FEC Ethernet device isn't always attached to a phy. Be careful
not to dereference phy_device if it is NULL. Also eliminates an
unnecessary extra function from the ioctl path.
Reported-by: Henk Stegeman <henk.stegeman@gmail.com>
Since not using net_device_ops gets you shunned out the cool crowd,
this patch modifies the fec_mpc52xx Ethernet driver to provide the
management hooks via a struct net_device_ops.
The driver triggers a BUG_ON() when allocating DMA buffers because the
arch/powerpc dma_ops aren't in the net_device's struct device. This
patch fixes the problem by using the parent of_device which does have
the correct dma_ops set.
Reviewed-by: Becky Bruce <beckyb@kernel.crashing.org>
There is no reason for the PSC UART driver or the Ethernet driver
to require a device_type property. The compatible value is sufficient
to uniquely identify the device. Remove it from the driver.
The whole 'port-number' scheme for assigning numbers to PSC uarts was
always rather half baked and just adds complexity. Remove it from the
driver. After this patch is applied, PSC UART numbers are simply
assigned from the order they are found in the device tree (just like
all the other devices). Userspace can query sysfs to determine what
ttyPSC number is assigned to each PSC instance.
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
Implement polling for 5200FEC to make netconsole work. Tested on
Phytec pcm030 and Efika.
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
The drivers were touching net queue before it has been started, so
without this patch, the drivers will potentially WARN at
net/core/dev.c:1328.
I don't have the hardware for the drivers below, so this patch is
untested, and thus should be carefully peer reviewed.
tc35815.c
au1000_eth.c
bfin_mac.c
macb.c
^ The four drivers are using phylib, they're calling netif_start_queue()
in open() callback. So trivially remove netif_tx_schedule_all().
Phylib will handle netif_carrier_*().
cpmac.c
fec_mpc52xx.c
fs_enet/fs_enet-main.c
sh_eth.c
^ The same as above, but these were also needlessly calling
netif_carrier_*() functions. So removed queue calls and also remove
carrier calls, since phylib will handle it. fs_enet-main.c also didn't
call netif_start_queue() at open(), this is fixed now.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
They logically all want to trigger a schedule for all device
TX queues.
Duplicate NETIF_MSG_IFDOWN, 2nd should be NETIF_MSG_IFUP
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Acked-by: Sylvain Munaut <tnt@246tNt.com>
Various improvements for configuring the MPC5200 MII link from the
device tree:
* Look for 'current-speed' property for fixed speed MII links
* Look for 'fsl,7-wire-mode' property for boards using the 7 wire mode
* move definition of private data structure out of the header file
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
The error handling for the mpc5200 fec interrupt is broken. The intended
behaviour is like this:
* If one of FEC_IEVENT_RFIFO_ERROR and FEC_IEVENT_XFIFO_ERROR happens,
the datasheet says (MPC5200B User's Guide R1.2, p. 14-13): "When this
occurs, software must ensure both the FIFO Controller and BestComm are
soft-reset".
* On any other error (non-TFINT) interrupt, just issue a debug message.
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Having the id field be an int was making more complex bus topologies
excessively difficult. For now, just convert it to a string, and
change all instances of "bus->id = val" to
snprintf(id, MII_BUS_ID_LEN, "%x", val).
Signed-off-by: Andy Fleming <afleming@freescale.com>
This gets the FEC ethernet driver working again on the lite5200
platform.
The FEC driver is also compatible with the MPC5200, not only with the
MPC5200B, so this adds a suitable entry to the driver's match list.
Furthermore this adds the settings for the PHY in the dts file for the
Lite5200. Note, that this is not exactly the same as in the
Lite5200B, because the PHY is located at f0003000:01 for the 5200, and
at :00 for the 5200B. This was tested on a Lite5200 and a Lite5200B,
both booted a kernel via tftp and mounted the root via nfs
successfully.
Signed-off-by: René Bürgel <r.buergel@unicontrol.de>
Update MPC5200 drivers to also look for compatible properties in the
form "fsl,mpc5200-*" to better conform to open firmware generic names
recommended practice as published here:
http://www.openfirmware.org/1275/practice/gnames/gnamv14a.html
This patch should *not* break compatibility with older device trees
which do not use the 'fsl,' prefix. The drivers will still bind against
the older names also.
If you need to find a difference between addresses of two
struct members, subtract offsetof() or cast addresses to
char * and subtract those if you prefer it that way. Doing
that same with s/char */u32/, OTOH...
Signed-off-by: Jeff Garzik <jeff@garzik.org>
The mpc5200 fec driver is corrupting memory. This patch fixes two bugs
where the wrong skb was being referenced.
Acked-by: Domen Puncer <domen.puncer@telargo.com>
This helps to allow the Fedora installer to use the built-in Ethernet on
the Efika for a network install.
Driver shouldn't complain if the register range is larger than what
it expects. This works around failures with some device trees.
Driver for ethernet on mpc5200/mpc5200b SoCs (FEC).
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
Acked-by: Dale Farnsworth <dale@farnsworth.org>
