path: root/drivers/net/fec_mpc52xx.c
2008-06-11fec_mpc52xx: MPC52xx_MESSAGES_DEFAULT: 2nd NETIF_MSG_IFDOWN => IFUPRoel Kluin
Duplicate NETIF_MSG_IFDOWN, 2nd should be NETIF_MSG_IFUP Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Sylvain Munaut <tnt@246tNt.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-01[POWERPC] mpc5200: Allow for fixed speed MII configurationsGrant Likely
Various improvements for configuring the MPC5200 MII link from the device tree: * Look for 'current-speed' property for fixed speed MII links * Look for 'fsl,7-wire-mode' property for boards using the 7 wire mode * move definition of private data structure out of the header file Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfgang Grandegger <wg@grandegger.com>
2008-04-29[POWERPC] mpc5200: Fix FEC error handling on FIFO errorsSascha Hauer
The error handling for the mpc5200 fec interrupt is broken. The intended behaviour is like this: * If one of FEC_IEVENT_RFIFO_ERROR and FEC_IEVENT_XFIFO_ERROR happens, the datasheet says (MPC5200B User's Guide R1.2, p. 14-13): "When this occurs, software must ensure both the FIFO Controller and BestComm are soft-reset". * On any other error (non-TFINT) interrupt, just issue a debug message. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-16phy: Change mii_bus id field to a stringAndy Fleming
Having the id field be an int was making more complex bus topologies excessively difficult. For now, just convert it to a string, and change all instances of "bus->id = val" to snprintf(id, MII_BUS_ID_LEN, "%x", val). Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-03[POWERPC] Fix MPC5200 (not B!) device tree so FEC ethernet worksRené Bürgel
This gets the FEC ethernet driver working again on the lite5200 platform. The FEC driver is also compatible with the MPC5200, not only with the MPC5200B, so this adds a suitable entry to the driver's match list. Furthermore this adds the settings for the PHY in the dts file for the Lite5200. Note, that this is not exactly the same as in the Lite5200B, because the PHY is located at f0003000:01 for the 5200, and at :00 for the 5200B. This was tested on a Lite5200 and a Lite5200B, both booted a kernel via tftp and mounted the root via nfs successfully. Signed-off-by: René Bürgel <r.buergel@unicontrol.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-26[POWERPC] mpc5200: normalize compatible property bindingsGrant Likely
Update MPC5200 drivers to also look for compatible properties in the form "fsl,mpc5200-*" to better conform to open firmware generic names recommended practice as published here: http://www.openfirmware.org/1275/practice/gnames/gnamv14a.html This patch should *not* break compatibility with older device trees which do not use the 'fsl,' prefix. The drivers will still bind against the older names also. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-12-22fec_mpc52xx: write in C...Al Viro
If you need to find a difference between addresses of two struct members, subtract offsetof() or cast addresses to char * and subtract those if you prefer it that way. Doing that same with s/char */u32/, OTOH... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-04Fix memory corruption in fec_mpc52xxJon Smirl
The mpc5200 fec driver is corrupting memory. This patch fixes two bugs where the wrong skb was being referenced. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Domen Puncer <domen.puncer@telargo.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01SET_NETDEV_DEV() in fec_mpc52xx.cDavid Woodhouse
This helps to allow the Fedora installer to use the built-in Ethernet on the Efika for a network install. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-01Fix region size check in mpc5200 FEC driverGrant Likely
Driver shouldn't complain if the register range is larger than what it expects. This works around failures with some device trees. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-29FEC - fast ethernet controller for mpc52xxDomen Puncer
Driver for ethernet on mpc5200/mpc5200b SoCs (FEC). Signed-off-by: Domen Puncer <domen.puncer@telargo.com> Acked-by: Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
