path: root/drivers/net/fs_enet/Makefile
2008-07-16fs_enet: Remove !CONFIG_PPC_CPM_NEW_BINDING codeKumar Gala
Now that arch/ppc is gone we always define CONFIG_PPC_CPM_NEW_BINDING so we can remove all the code associated with !CONFIG_PPC_CPM_NEW_BINDING. Also fixed some asm/of_platform.h to linux/of_platform.h (and of_device.h) Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-14[FS_ENET]: Fix module build.Jochen Friedrich
If fs_enet is build as module, on PPC_CPM_NEW_BINDING platforms mii-fec/mii-bitbang should be build as module, as well. On other platforms, mii-fec/mii-bitbang must be included into the main module. Otherwise some symbols remain undefined. Additionally, fs_enet uses libphy, so add a select PHYLIB. Building modules, stage 2. MODPOST 5 modules ERROR: "fs_scc_ops" [drivers/net/fs_enet/fs_enet.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-19[PATCH] FS_ENET: use PAL for mii managementVitaly Bordug
This patch should update the fs_enet infrastructure to utilize Phy Abstraction Layer subsystem. Along with the above, there are apparent bugfixes, overhaul and improvements. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-10-28Add fs_enet ethernet network driver, for several embedded platforms.Pantelis Antoniou
