path: root/drivers/net/fs_enet
2011-04-21powerpc: Fix multicast problem in fs_enet driverAndrea Galbusera
mac-fec.c was setting individual UDP address registers instead of multicast group address registers when joining a multicast group. This prevented from correctly receiving UDP multicast packets. According to datasheet, replaced hash_table_high and hash_table_low with grp_hash_table_high and grp_hash_table_low respectively. Also renamed hash_table_* with grp_hash_table_* in struct fec declaration for 8xx: these registers are used only for multicast there. Tested on a MPC5121 based board. Build tested also against mpc866_ads_defconfig. Signed-off-by: Andrea Galbusera <gizero@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28dt/net: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/net. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-11-01of/net: Move of_get_mac_address() to a common source file.David Daney
There are two identical implementations of of_get_mac_address(), one each in arch/powerpc/kernel/prom_parse.c and arch/microblaze/kernel/prom_parse.c. Move this function to a new common file of_net.{c,h} and adjust all the callers to include the new header. Signed-off-by: David Daney <ddaney@caviumnetworks.com> [grant.likely@secretlab.ca: protect header with #ifdef] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-06drivers/net/fs_enet/fs_enet-main.c: Add of_node_put to avoid memory leakJulia Lawall
In this case, a device_node structure is stored in another structure that is then freed without first decrementing the reference count of the device_node structure. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression x; identifier f; position p1,p2; @@ x@p1->f = \(of_find_node_by_path\|of_find_node_by_name\|of_find_node_by_phandle\|of_get_parent\|of_get_next_parent\|of_get_next_child\|of_find_compatible_node\|of_match_node\|of_find_node_by_type\|of_find_node_with_property\|of_find_matching_node\|of_parse_phandle\|of_node_get\)(...); ... when != of_node_put(x) kfree@p2(x) @script:python@ p1 << r.p1; p2 << r.p2; @@ cocci.print_main("call",p1) cocci.print_secs("free",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02of/net: fs_enet/mii-bitbang.c: fix build breakageAnatolij Gustschin
Fixes build error caused by the OF device_node pointer being moved into struct device Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-31Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-05-31Merge branch 'master' of ↵David S. Miller
2010-05-29fs_enet: Adjust BDs after tx errorMark Ware
This patch fixes an occasional transmit lockup in the mac-fcc which occurs after a tx error. The test scenario had the local port set to autoneg and the other end fixed at 100FD, resulting in a large number of late collisions. According to the MPC8280RM 30.10.1.3 (also 8272RM 29.10.1.3), after a tx error occurs, TBPTR may sometimes point beyond BDs still marked as ready. This patch walks back through the BDs and points TBPTR to the earliest one marked as ready. Tested on a custom board with a MPC8280. Signed-off-by: Mark Ware <mware@elphinstone.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-27fs_enet: add FEC TX buffer alignment workaround for MPC5121Anatolij Gustschin
MPC5121 FEC requeries 4-byte alignmnent for TX data buffers. This patch is a work around that copies misaligned tx packets to an aligned skb before sending. Signed-off-by: John Rigby <jcrigby@gmail.com> Signed-off-by: Piotr Ziecik <kosmo@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-27fs_enet: Add support for MPC512x to fs_enet driverAnatolij Gustschin
Extend the fs_enet driver to support MPC512x FEC. Enable it with CONFIG_FS_ENET_MPC5121_FEC option. Signed-off-by: John Rigby <jcrigby@gmail.com> Signed-off-by: Piotr Ziecik <kosmo@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-27fs_enet: use dev_xxx instead of printkAnatolij Gustschin
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part4Jiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14net: Fix OF platform drivers coldplug/hotplug when compiled as modulesAnton Vorontsov
Some OF platform drivers are missing module device tables, so they won't load automatically on boot. This patch fixes the issue by adding proper MODULE_DEVICE_TABLE() macros to the drivers. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwmc3200wifi/netdev.c net/wireless/scan.c
2009-07-22fs_enet: Revive fixed link supportAnton Vorontsov
Since commit aa73832c5a80d6c52c69b18af858d88fa595dd3c ("Rework fs_enet driver to use of_mdio infrastructure") the fixed-link support is broken in the fs_enet driver. This patch fixes the support by removing a check for phy_node, and adding a call to of_phy_connect_fixed_link(). Also set netdev parent device via SET_NETDEV_DEV() call, this is needed so that OF MDIO core could find a node pointer for a device. Plus, fix "if (IS_ERR(phydev))" check, in case of errors, of_phy_connect() returns NULL, not ERR_PTR as phy_connect(). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-17fs_enet/mii-fec.c: fix MII speed calculationWolfgang Denk
The MII speed calculation was based on the CPU clock (ppc_proc_freq), but for MPC512x we must use the bus clock instead. This patch makes it use the correct clock and makes sure we don't clobber reserved bits in the MII_SPEED register. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: <netdev@vger.kernel.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-28fs_enet: Remove dead codeKumar Gala
CONFIG_DUET doesn't exist anymore, remove all the code that exists to support it. [ Simplify fs_init() even further -DaveM ] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27net: Rework fs_enet driver to use of_mdio infrastructureGrant Likely
This patch simplifies the driver by making use of more common code. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16Merge branch 'master' of ↵David S. Miller
2009-04-13drivers/net: replace BUG() with BUG_ON() if possibleAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-11fs_enet: convert to netdev_opsAlexander Beregalov
Reported-by: Subrata Modak <subrata@linux.vnet.ibm.com> Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14powerpc/fs_enet: Add missing irq free in error path.Mike Ditto
If something goes wrong attaching to phy driver, we weren't freeing the IRQ. Signed-off-by: Mike Ditto <mditto@consentry.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-03fs_enet: fix pollingAlexey Dobriyan
1. compile fix for irqreturn_t type change 2. restore ->poll_controller after CONFIG_PPC_CPM_NEW_BINDING transition Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27net: convert more to %pMJohannes Berg
A number of places still use %02x:...:%02x because it's in debug statements or for no real reason. Make a few of them use %pM. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08phylib: move to dynamic allocation of struct mii_busLennert Buytenhek
This patch introduces mdiobus_alloc() and mdiobus_free(), and makes all mdio bus drivers use these functions to allocate their struct mii_bus'es dynamically. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-08phylib: rename mii_bus::dev to mii_bus::parentLennert Buytenhek
In preparation of giving mii_bus objects a device tree presence of their own, rename struct mii_bus's ->dev argument to ->parent, since having a 'struct device *dev' that points to our parent device conflicts with introducing a 'struct device dev' representing our own device. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-09-24fs-enet: remove code associated with !CONFIG_PPC_MERGEKumar Gala
Now that arch/ppc is gone we don't need CONFIG_PPC_MERGE anymore remove the dead code associated with !CONFIG_PPC_MERGE. With this change the pre_request_irq() and post_free_irq() calls became nops so they have been removed. Also removed fs_request_irq() and fs_free_irq() and just called request_irq() and free_irq(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-27fs_enet: Fix SCC Ethernet on CPM2, and crash in fs_enet_rx_napi()Heiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07net/fs_enet: remove redundant messages for performanceLi Yang
Currently when we do a packet flood to the Ethernet port, the console reports error every time when a packet is dropped. This is too redundant and cost performance. Remove message for this type of event. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (82 commits) ipw2200: Call netif_*_queue() interfaces properly. netxen: Needs to include linux/vmalloc.h [netdrvr] atl1d: fix !CONFIG_PM build r6040: rework init_one error handling r6040: bump release number to 0.18 r6040: handle RX fifo full and no descriptor interrupts r6040: change the default waiting time r6040: use definitions for magic values in descriptor status r6040: completely rework the RX path r6040: call napi_disable when puting down the interface and set lp->dev accordingly. mv643xx_eth: fix NETPOLL build r6040: rework the RX buffers allocation routine r6040: fix scheduling while atomic in r6040_tx_timeout r6040: fix null pointer access and tx timeouts r6040: prefix all functions with r6040 rndis_host: support WM6 devices as modems at91_ether: use netstats in net_device structure sfc: Create one RX queue and interrupt per CPU package by default sfc: Use a separate workqueue for resets sfc: I2C adapter initialisation fixes ...
2008-07-22netdev: bunch of drivers: avoid WARN at net/core/dev.c:1328Anton Vorontsov
The drivers were touching net queue before it has been started, so without this patch, the drivers will potentially WARN at net/core/dev.c:1328. I don't have the hardware for the drivers below, so this patch is untested, and thus should be carefully peer reviewed. tc35815.c au1000_eth.c bfin_mac.c macb.c ^ The four drivers are using phylib, they're calling netif_start_queue() in open() callback. So trivially remove netif_tx_schedule_all(). Phylib will handle netif_carrier_*(). cpmac.c fec_mpc52xx.c fs_enet/fs_enet-main.c sh_eth.c ^ The same as above, but these were also needlessly calling netif_carrier_*() functions. So removed queue calls and also remove carrier calls, since phylib will handle it. fs_enet-main.c also didn't call netif_start_queue() at open(), this is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22Merge commit 'origin/master'Benjamin Herrenschmidt
Manually fixed up: drivers/net/fs_enet/fs_enet-main.c
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-17netdev: Convert all drivers away from netif_schedule().David S. Miller
They logically all want to trigger a schedule for all device TX queues. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-16fs_enet: Remove !CONFIG_PPC_CPM_NEW_BINDING codeKumar Gala
Now that arch/ppc is gone we always define CONFIG_PPC_CPM_NEW_BINDING so we can remove all the code associated with !CONFIG_PPC_CPM_NEW_BINDING. Also fixed some asm/of_platform.h to linux/of_platform.h (and of_device.h) Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-14Merge commit 'origin/HEAD' into test-mergeBenjamin Herrenschmidt
Manual fixup of include/asm-powerpc/pgtable-ppc64.h
