path: root/drivers/net/ftmac100.c
2011-04-29net: ftmac100: fix scheduling while atomic during PHY link status changeAdam Jaremko
Signed-off-by: Adam Jaremko <adam.jaremko@gmail.com> Acked-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-18ftmac100: use resource_size()Dan Carpenter
The calculation is off-by-one. It should be "end - start + 1". This patch fixes it to use resource_size() instead. Oddly, the code already uses resource size correctly a couple lines earlier when it calls request_mem_region() for this memory. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14ftmac100: use GFP_ATOMIC allocations where neededEric Dumazet
When running in softirq context, we should use GFP_ATOMIC allocations instead of GFP_KERNEL ones. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Po-Yu Chuang <ratbert@faraday-tech.com> Acked-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-03net: add Faraday FTMAC100 10/100 Ethernet driverPo-Yu Chuang
FTMAC100 Ethernet Media Access Controller supports 10/100 Mbps and MII. This driver has been working on some ARM/NDS32 SoC's including Faraday A320 and Andes AG101. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
