path: root/drivers/net/hippi
2018-06-12treewide: kmalloc() -> kmalloc_array()Kees Cook
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This patch replaces cases of: kmalloc(a * b, gfp) with: kmalloc_array(a * b, gfp) as well as handling cases of: kmalloc(a * b * c, gfp) with: kmalloc(array3_size(a, b, c), gfp) as it's slightly less ugly than: kmalloc_array(array_size(a, b), c, gfp) This does, however, attempt to ignore constant size factors like: kmalloc(4 * 1024, gfp) though any constants defined via macros get caught up in the conversion. Any factors with a sizeof() of "unsigned char", "char", and "u8" were dropped, since they're redundant. The tools/ directory was manually excluded, since it has its own implementation of kmalloc(). The Coccinelle script used for this was: // Fix redundant parens around sizeof(). @@ type TYPE; expression THING, E; @@ ( kmalloc( - (sizeof(TYPE)) * E + sizeof(TYPE) * E , ...) | kmalloc( - (sizeof(THING)) * E + sizeof(THING) * E , ...) ) // Drop single-byte sizes and redundant parens. @@ expression COUNT; typedef u8; typedef __u8; @@ ( kmalloc( - sizeof(u8) * (COUNT) + COUNT , ...) | kmalloc( - sizeof(__u8) * (COUNT) + COUNT , ...) | kmalloc( - sizeof(char) * (COUNT) + COUNT , ...) | kmalloc( - sizeof(unsigned char) * (COUNT) + COUNT , ...) | kmalloc( - sizeof(u8) * COUNT + COUNT , ...) | kmalloc( - sizeof(__u8) * COUNT + COUNT , ...) | kmalloc( - sizeof(char) * COUNT + COUNT , ...) | kmalloc( - sizeof(unsigned char) * COUNT + COUNT , ...) ) // 2-factor product with sizeof(type/expression) and identifier or constant. @@ type TYPE; expression THING; identifier COUNT_ID; constant COUNT_CONST; @@ ( - kmalloc + kmalloc_array ( - sizeof(TYPE) * (COUNT_ID) + COUNT_ID, sizeof(TYPE) , ...) | - kmalloc + kmalloc_array ( - sizeof(TYPE) * COUNT_ID + COUNT_ID, sizeof(TYPE) , ...) | - kmalloc + kmalloc_array ( - sizeof(TYPE) * (COUNT_CONST) + COUNT_CONST, sizeof(TYPE) , ...) | - kmalloc + kmalloc_array ( - sizeof(TYPE) * COUNT_CONST + COUNT_CONST, sizeof(TYPE) , ...) | - kmalloc + kmalloc_array ( - sizeof(THING) * (COUNT_ID) + COUNT_ID, sizeof(THING) , ...) | - kmalloc + kmalloc_array ( - sizeof(THING) * COUNT_ID + COUNT_ID, sizeof(THING) , ...) | - kmalloc + kmalloc_array ( - sizeof(THING) * (COUNT_CONST) + COUNT_CONST, sizeof(THING) , ...) | - kmalloc + kmalloc_array ( - sizeof(THING) * COUNT_CONST + COUNT_CONST, sizeof(THING) , ...) ) // 2-factor product, only identifiers. @@ identifier SIZE, COUNT; @@ - kmalloc + kmalloc_array ( - SIZE * COUNT + COUNT, SIZE , ...) // 3-factor product with 1 sizeof(type) or sizeof(expression), with // redundant parens removed. @@ expression THING; identifier STRIDE, COUNT; type TYPE; @@ ( kmalloc( - sizeof(TYPE) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | kmalloc( - sizeof(TYPE) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | kmalloc( - sizeof(TYPE) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | kmalloc( - sizeof(TYPE) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(TYPE)) , ...) | kmalloc( - sizeof(THING) * (COUNT) * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | kmalloc( - sizeof(THING) * (COUNT) * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | kmalloc( - sizeof(THING) * COUNT * (STRIDE) + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) | kmalloc( - sizeof(THING) * COUNT * STRIDE + array3_size(COUNT, STRIDE, sizeof(THING)) , ...) ) // 3-factor product with 2 sizeof(variable), with redundant parens removed. @@ expression THING1, THING2; identifier COUNT; type TYPE1, TYPE2; @@ ( kmalloc( - sizeof(TYPE1) * sizeof(TYPE2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | kmalloc( - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2)) , ...) | kmalloc( - sizeof(THING1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | kmalloc( - sizeof(THING1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(THING1), sizeof(THING2)) , ...) | kmalloc( - sizeof(TYPE1) * sizeof(THING2) * COUNT + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) | kmalloc( - sizeof(TYPE1) * sizeof(THING2) * (COUNT) + array3_size(COUNT, sizeof(TYPE1), sizeof(THING2)) , ...) ) // 3-factor product, only identifiers, with redundant parens removed. @@ identifier STRIDE, SIZE, COUNT; @@ ( kmalloc( - (COUNT) * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | kmalloc( - COUNT * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | kmalloc( - COUNT * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | kmalloc( - (COUNT) * (STRIDE) * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) | kmalloc( - COUNT * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | kmalloc( - (COUNT) * STRIDE * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | kmalloc( - (COUNT) * (STRIDE) * (SIZE) + array3_size(COUNT, STRIDE, SIZE) , ...) | kmalloc( - COUNT * STRIDE * SIZE + array3_size(COUNT, STRIDE, SIZE) , ...) ) // Any remaining multi-factor products, first at least 3-factor products, // when they're not all constants... @@ expression E1, E2, E3; constant C1, C2, C3; @@ ( kmalloc(C1 * C2 * C3, ...) | kmalloc( - (E1) * E2 * E3 + array3_size(E1, E2, E3) , ...) | kmalloc( - (E1) * (E2) * E3 + array3_size(E1, E2, E3) , ...) | kmalloc( - (E1) * (E2) * (E3) + array3_size(E1, E2, E3) , ...) | kmalloc( - E1 * E2 * E3 + array3_size(E1, E2, E3) , ...) ) // And then all remaining 2 factors products when they're not all constants, // keeping sizeof() as the second factor argument. @@ expression THING, E1, E2; type TYPE; constant C1, C2, C3; @@ ( kmalloc(sizeof(THING) * C2, ...) | kmalloc(sizeof(TYPE) * C2, ...) | kmalloc(C1 * C2 * C3, ...) | kmalloc(C1 * C2, ...) | - kmalloc + kmalloc_array ( - sizeof(TYPE) * (E2) + E2, sizeof(TYPE) , ...) | - kmalloc + kmalloc_array ( - sizeof(TYPE) * E2 + E2, sizeof(TYPE) , ...) | - kmalloc + kmalloc_array ( - sizeof(THING) * (E2) + E2, sizeof(THING) , ...) | - kmalloc + kmalloc_array ( - sizeof(THING) * E2 + E2, sizeof(THING) , ...) | - kmalloc + kmalloc_array ( - (E1) * E2 + E1, E2 , ...) | - kmalloc + kmalloc_array ( - (E1) * (E2) + E1, E2 , ...) | - kmalloc + kmalloc_array ( - E1 * E2 + E1, E2 , ...) ) Signed-off-by: Kees Cook <keescook@chromium.org>
2018-05-18hippi: fix spelling mistake: "Framming" -> "Framing"Colin Ian King
Trivial fix to spelling mistake in printk message text Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-12-13hippi: Fix a Fix a possible sleep-in-atomic bug in rr_closeJia-Ju Bai
The driver may sleep under a spinlock. The function call path is: rr_close (acquire the spinlock) free_irq --> may sleep To fix it, free_irq is moved to the place without holding the spinlock. This bug is found by my static analysis tool(DSAC) and checked by my code review. Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-11-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Files removed in 'net-next' had their license header updated in 'net'. We take the remove from 'net-next'. Signed-off-by: David S. Miller <davem@davemloft.net>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27drivers/net: hippi: Convert timers to use timer_setup()Kees Cook
In preparation for unconditionally passing the struct timer_list pointer to all timer callbacks, switch to using the new timer_setup() and from_timer() to pass the timer pointer explicitly. Cc: Jes Sorensen <jes@trained-monkey.org> Cc: linux-hippi@sunsite.dk Cc: netdev@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-09-21drivers: net: hippi: use setup_timer() helper.Allen Pais
Use setup_timer function instead of initializing timer with the function and data fields. Signed-off-by: Allen Pais <allen.lkml@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-16networking: make skb_push & __skb_push return void pointersJohannes Berg
It seems like a historic accident that these return unsigned char *, and in many places that means casts are required, more often than not. Make these functions return void * and remove all the casts across the tree, adding a (u8 *) cast only where the unsigned char pointer was used directly, all done with the following spatch: @@ expression SKB, LEN; typedef u8; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; @@ - *(fn(SKB, LEN)) + *(u8 *)fn(SKB, LEN) @@ expression E, SKB, LEN; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; type T; @@ - E = ((T *)(fn(SKB, LEN))) + E = fn(SKB, LEN) @@ expression SKB, LEN; identifier fn = { skb_push, __skb_push, skb_push_rcsum }; @@ - fn(SKB, LEN)[0] + *(u8 *)fn(SKB, LEN) Note that the last part there converts from push(...)[0] to the more idiomatic *(u8 *)push(...). Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-16networking: introduce and use skb_put_data()Johannes Berg
A common pattern with skb_put() is to just want to memcpy() some data into the new space, introduce skb_put_data() for this. An spatch similar to the one for skb_put_zero() converts many of the places using it: @@ identifier p, p2; expression len, skb, data; type t, t2; @@ ( -p = skb_put(skb, len); +p = skb_put_data(skb, data, len); | -p = (t)skb_put(skb, len); +p = skb_put_data(skb, data, len); ) ( p2 = (t2)p; -memcpy(p2, data, len); | -memcpy(p, data, len); ) @@ type t, t2; identifier p, p2; expression skb, data; @@ t *p; ... ( -p = skb_put(skb, sizeof(t)); +p = skb_put_data(skb, data, sizeof(t)); | -p = (t *)skb_put(skb, sizeof(t)); +p = skb_put_data(skb, data, sizeof(t)); ) ( p2 = (t2)p; -memcpy(p2, data, sizeof(*p)); | -memcpy(p, data, sizeof(*p)); ) @@ expression skb, len, data; @@ -memcpy(skb_put(skb, len), data, len); +skb_put_data(skb, data, len); (again, manually post-processed to retain some comments) Reviewed-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix multiqueue in stmmac driver on PCI, from Andy Shevchenko. 2) cdc_ncm doesn't actually fully zero out the padding area is allocates on TX, from Jim Baxter. 3) Don't leak map addresses in BPF verifier, from Daniel Borkmann. 4) If we randomize TCP timestamps, we have to do it everywhere including SYN cookies. From Eric Dumazet. 5) Fix "ethtool -S" crash in aquantia driver, from Pavel Belous. 6) Fix allocation size for ntp filter bitmap in bnxt_en driver, from Dan Carpenter. 7) Add missing memory allocation return value check to DSA loop driver, from Christophe Jaillet. 8) Fix XDP leak on driver unload in qed driver, from Suddarsana Reddy Kalluru. 9) Don't inherit MC list from parent inet connection sockets, another syzkaller spotted gem. Fix from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits) dccp/tcp: do not inherit mc_list from parent qede: Split PF/VF ndos. qed: Correct doorbell configuration for !4Kb pages qed: Tell QM the number of tasks qed: Fix VF removal sequence qede: Fix XDP memory leak on unload net/mlx4_core: Reduce harmless SRIOV error message to debug level net/mlx4_en: Avoid adding steering rules with invalid ring net/mlx4_en: Change the error print to debug print drivers: net: wimax: i2400m: i2400m-usb: Use time_after for time comparison DECnet: Use container_of() for embedded struct Revert "ipv4: restore rt->fi for reference counting" net: mdio-mux: bcm-iproc: call mdiobus_free() in error path net: ethernet: ti: cpsw: adjust cpsw fifos depth for fullduplex flow control ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf net: cdc_ncm: Fix TX zero padding stmmac: pci: split out common_default_data() helper stmmac: pci: RX queue routing configuration stmmac: pci: TX and RX queue priority configuration stmmac: pci: set default number of rx and tx queues ...
2017-05-08format-security: move static strings to constKees Cook
While examining output from trial builds with -Wformat-security enabled, many strings were found that should be defined as "const", or as a char array instead of char pointer. This makes some static analysis easier, by producing fewer false positives. As these are all trivial changes, it seemed best to put them all in a single patch rather than chopping them up per maintainer. Link: http://lkml.kernel.org/r/20170405214711.GA5711@beast Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Jes Sorensen <jes@trained-monkey.org> [runner.c] Cc: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@armlinux.org.uk> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Daniel Vetter <daniel.vetter@intel.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Cc: Sean Paul <seanpaul@chromium.org> Cc: David Airlie <airlied@linux.ie> Cc: Yisen Zhuang <yisen.zhuang@huawei.com> Cc: Salil Mehta <salil.mehta@huawei.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Jiri Slaby <jslaby@suse.com> Cc: Patrice Chotard <patrice.chotard@st.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Felipe Balbi <felipe.balbi@linux.intel.com> Cc: Jarod Wilson <jarod@redhat.com> Cc: Florian Westphal <fw@strlen.de> Cc: Antonio Quartulli <a@unstable.cc> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Kejian Yan <yankejian@huawei.com> Cc: Daode Huang <huangdaode@hisilicon.com> Cc: Qianqian Xie <xieqianqian@huawei.com> Cc: Philippe Reynes <tremyfr@gmail.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Christian Gromm <christian.gromm@microchip.com> Cc: Andrey Shvetsov <andrey.shvetsov@k2l.de> Cc: Jason Litzinger <jlitzingerdev@gmail.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-05-08net/hippi/rrunner: use memdup_userGeliang Tang
Use memdup_user() helper instead of open-coding to simplify the code. Signed-off-by: Geliang Tang <geliangtang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-20net: use core MTU range checking in misc driversJarod Wilson
firewire-net: - set min/max_mtu - remove fwnet_change_mtu nes: - set max_mtu - clean up nes_netdev_change_mtu xpnet: - set min/max_mtu - remove xpnet_dev_change_mtu hippi: - set min/max_mtu - remove hippi_change_mtu batman-adv: - set max_mtu - remove batadv_interface_change_mtu - initialization is a little async, not 100% certain that max_mtu is set in the optimal place, don't have hardware to test with rionet: - set min/max_mtu - remove rionet_change_mtu slip: - set min/max_mtu - streamline sl_change_mtu um/net_kern: - remove pointless ndo_change_mtu hsi/clients/ssi_protocol: - use core MTU range checking - remove now redundant ssip_pn_set_mtu ipoib: - set a default max MTU value - Note: ipoib's actual max MTU can vary, depending on if the device is in connected mode or not, so we'll just set the max_mtu value to the max possible, and let the ndo_change_mtu function continue to validate any new MTU change requests with checks for CM or not. Note that ipoib has no min_mtu set, and thus, the network core's mtu > 0 check is the only lower bounds here. mptlan: - use net core MTU range checking - remove now redundant mpt_lan_change_mtu fddi: - min_mtu = 21, max_mtu = 4470 - remove now redundant fddi_change_mtu (including export) fjes: - min_mtu = 8192, max_mtu = 65536 - The max_mtu value is actually one over IP_MAX_MTU here, but the idea is to get past the core net MTU range checks so fjes_change_mtu can validate a new MTU against what it supports (see fjes_support_mtu in fjes_hw.c) hsr: - min_mtu = 0 (calls ether_setup, max_mtu is 1500) f_phonet: - min_mtu = 6, max_mtu = 65541 u_ether: - min_mtu = 14, max_mtu = 15412 phonet/pep-gprs: - min_mtu = 576, max_mtu = 65530 - remove redundant gprs_set_mtu CC: netdev@vger.kernel.org CC: linux-rdma@vger.kernel.org CC: Stefan Richter <stefanr@s5r6.in-berlin.de> CC: Faisal Latif <faisal.latif@intel.com> CC: linux-rdma@vger.kernel.org CC: Cliff Whickman <cpw@sgi.com> CC: Robin Holt <robinmholt@gmail.com> CC: Jes Sorensen <jes@trained-monkey.org> CC: Marek Lindner <mareklindner@neomailbox.ch> CC: Simon Wunderlich <sw@simonwunderlich.de> CC: Antonio Quartulli <a@unstable.cc> CC: Sathya Prakash <sathya.prakash@broadcom.com> CC: Chaitra P B <chaitra.basappa@broadcom.com> CC: Suganath Prabu Subramani <suganath-prabu.subramani@broadcom.com> CC: MPT-FusionLinux.pdl@broadcom.com CC: Sebastian Reichel <sre@kernel.org> CC: Felipe Balbi <balbi@kernel.org> CC: Arvid Brodin <arvid.brodin@alten.se> CC: Remi Denis-Courmont <courmisch@gmail.com> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-12PCI: Remove DEFINE_PCI_DEVICE_TABLE macro useBenoit Taine
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet kernel coding style guidelines. This issue was reported by checkpatch. A simplified version of the semantic patch that makes this change is as follows (http://coccinelle.lip6.fr/): // <smpl> @@ identifier i; declarer name DEFINE_PCI_DEVICE_TABLE; initializer z; @@ - DEFINE_PCI_DEVICE_TABLE(i) + const struct pci_device_id i[] = z; // </smpl> [bhelgaas: add semantic patch] Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-01-16drivers/net: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. This covers everything under drivers/net except for wireless, which has been submitted separately. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-10net: hippi: remove unnecessary pci_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-22net/hippi/rrunner: Use module_pci_driver to register driverPeter Hüwe
Removing some boilerplate by using module_pci_driver instead of calling register and unregister in the otherwise empty init/exit functions. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-10rrunner.c: fix possible memory leak in rr_init_one()David Oostdyk
In the event that register_netdev() failed, the rrpriv->evt_ring allocation would have not been freed. Signed-off-by: David Oostdyk <daveo@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-22drivers/net/hippi: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Jes Sorensen <jes@trained-monkey.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-07drivers/net: fix up function prototypes after __dev* removalsGreg Kroah-Hartman
The __dev* removal patches for the network drivers ended up messing up the function prototypes for a bunch of drivers. This patch fixes all of them back up to be properly aligned. Bonus is that this almost removes 100 lines of code, always a nice surprise. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-03hippi: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Jes Sorensen <jes@trained-monkey.org> Cc: linux-hippi@sunsite.dk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-16hippi: fix printk format in rrunner.cRandy Dunlap
Fix printk format warning (from i386 build): drivers/net/hippi/rrunner.c:146:9: warning: format '%08llx' expects type 'long long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Jes Sorensen <jes@trained-monkey.org> Cc: linux-hippi@sunsite.dk Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-07rrunner: stop using net_device.{base_addr, irq}.Francois Romieu
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-01-31drivers/net: Remove unnecessary k.alloc/v.alloc OOM messagesJoe Perches
alloc failures use dump_stack so emitting an additional out-of-memory message is an unnecessary duplication. Remove the allocation failure messages. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-09net: drivers/net/hippi/Kconfig should be sourcedPaul Bolle
Commit ff5a3b509e ("hippi: Move the HIPPI driver") moved the HIPPI driver into drivers/net/hippi. It didn't source drivers/net/hippi/Kconfig though, so it didn't make all necessary Kconfig changes. So let drivers/net/kconfig source HIPPI's Kconfig file. [ Fix syntax error at the end of HIPP's Kconfig file. -DaveM ] Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27hippi: Move the HIPPI driverJeff Kirsher
Move the HIPPI driver into drivers/net/hippi/ and make the necessary Kconfig and Makefile changes. CC: Jes Sorensen <jes@wildopensource.com> CC: Jes Sorensen <jes@trained-monkey.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
