This patch adds functions and functions pointers to accommodate
differences between NVM interfaces and options for i350 devices,
82580 devices and the rest.
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
This patch adds the EEE feature for i350 devices, enabled by default.
This patch adds full support for SR-IOV by enabling the PF side.
VF side has already been committed.
This patch enables support for Intel i340 Quad Port Fiber Adapter.
Add support for the anti-spoofing feature in the HW. Packets from
VF devices with spoofed MAC addresses or VLAN tags will be blocked
and an event generated. When the watchdog task runs it will call a
function to check if any spoof events occurred. If an event was
detected then a warning message is dumped to the system log.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
This patch does the following:
1. Changes the existing supported device id's so now DH89xxCC is not supported when EEPROM is not read.
2. Adds two more device ids for DH89xxCC in backplane mode and SFP.
3. Driver now initializes previously possibly uninitialized value in igb_reset_mdicnfg_82580().
Signed-off-by: Joseph Gasparakis <joseph.gasparakis@intel.com>
This patch adds support for the Intel(r) DH89xxCC series. The new
device will be using Intel(r) i347-AT4 and Marvell(r) M88E1322 and
M88E1112 PHYs. Support for these devices has also been added here.
This patch addresses an issue seen on 82580 in which the MDICNFG
register will be reset during a single function reset and as a
result we will be unable to communicate with the PHY. To correct
the issue, added a call to reset_mdicnfg just prior to the first
access of the MDICNFG register in sgnii_uses_mdio.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
On a reset the MDICNFG.Destination and MDICNFG.COM_MDIO
register fields are not restored to the EEPROM default.
This patch modifies the reset code to read the EEPROM
and restore the default values.
Signed-off-by: Nicholas Nunley <nicholas.d.nunley@intel.com>
This patch adds support for external MDIO PHYs, in addition to
the standard SFP support for SGMII PHYs over the I2C interface.
82580 NICs can have up to 4 functions. This fixes phy accesses
to use the correct locks for functions 2 and 3.
Signed-off-by: Nicholas Nunley <nicholasx.d.nunley@intel.com>
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch adds support for the the I350 Gigabit network connection which
is the follow-on part to the 82580.
CC: James Hearn <james.r.hearn@intel.com>
This change removes the extra configuration we were doing on the mdicnfg
register which should be set by EEPROM and which we should not need to
write again afterwards. This code was a holdover from some earlier
development work that was being done on a board with an incomplete EEPROM
and is no longer needed now that the production EEPROMs are in place.
This changes the behavior of the driver to power down the link
when the associated interface is down, unless management is enabled.
Checking the EEPROM APME state unnecessarily prevents the link from
shutting down. The standard power down routines should be
sufficient to determine whether the serdes link can power down
when going into D3.
We were forcing the PCS link up in error when we are in KX mode. We should
only be disabling autoneg, not forcing the link up.
This patch adds support for the 82580 MAC.
This patch moves the generic portion of the copper link setup into a
seperate function in e1000_phy.c. This helps to reduce the size of
copper_link_setup_82575 and make it a bit more readable.
This patch allows us to treat the alternate mac address as though it is the
physical address on the adapter. This is accomplished by letting the
alt_mac_address function to only fail on an NVM error. If no errors occur
and the alternate mac address is not present then RAR0 is read as the
default mac address.
This patch adds the device ID necessary to support the 82576NS SerDes
adapter.
In order to support functions such as vlan tag stripping when SR-IOV is
enabled any given packet must match at least one filter. However in the
case of promiscous mode being enabled on the PF the traffic routed to it
may not match any filters and is just sent to the PF by default. In order
to make certain that this traffic is processed we can set all bits in the
UTA registers to create a pseudo promiscous mode filter that accepts all
packets.
The current implementation of sgmii support isn't correctly locking the
interfaces for reads/writes. This change pulls the read/write
functionality out of 82575.c and moves it to phy.c. In addition it
replaces the implementation in 82575.c with one that uses locking around
the relocated i2c interface calls.
The current approach is just using a ?: type mechanism to set the phy
locking bit. This if fine for now but limits us to only 2. Switch to a
nested if statement for future compatiblity with more than 2 phys.
This update corrects the driver so that it handles duplex for serdes links
correctly instead of just forcing full duplex always.
There is a temp variable in the stats clearing path that isn't needed since
the results from the stats read can be immediately discared. Since it
isn't needed we might as well just drop it from the function call.
Our SGMII phy code was incomplete in that it was not actually placing the
phy in SGMII mode and as a result the PHY was not able to establish a link
when connected to a non serdes link partner. This patch updates the code
to combine the SGMII/serdes PCS init and to add the necessary reset.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
The igb driver is currently initializing the mailbox function pointers
after the phy. This causes issues as the phy init will return from the
function early if there is no phy present.
To resolve this I have moved the function pointer init to a location prior
to the phy initialization so that serdes based adapters can also make use
of SR-IOV.
This patch adds support for a new 82576 mezzanine adapter.
This update cleans up the receive address register initialization. The
main purpose of this is to clean out some redundancy that was introduced
due to having multiple ways of setting the receive address registers.
Instead of having a specialized function to set one register and one to set
all of them it makes more sense to just go through the list calling the
function that is needed to set the individual registers.
This patch moves all of the multicast addresses out of the free Receive
address registers and instead programs them all into the multicast table
array. As a result the multicast filtering may not be as precise, but it
also greatly reduces the overhead for multicast addresses.
The 82575 and 82576 hardware can both experience data corruption issues if
a pci-e completion arrives after the timeout value. In order to avoid this
we need to increase the timeout value while pci-e master is disabled.
The igb driver was overwritting the LED settings that were configured via
EEPROM. This is not correct behavior as the LED settings are meant to be
configured by EEPROM and not changed. This change removes the code that
was setting the LED behavior on the interface.
Since igb_configure_pcs_link always returns 0 there isn't really much point
to checking for the result so it is best just to change this to a void so
we can properly ignore the return result.
There was a serdes power down workaround that was originally added for
82576 fiber. However it has also been found that this workaround is needed
for serdes connections as well. In addition it is also needed for 82575
serdes so we we need to remove the checks restricting it to 82576.
The current igb driver only supports copper and serdes. The fiber media
type is a holdover from earlier NICs as the current nics supported by igb
all use serdes when communicating over a fiber connection. As a result we
can remove media type fiber without losing any functionality.
The igb driver was defaulting to using the lock for pci-e function 0 for
all of the phys due to the fact that the lan id was not being set prior to
initialization. This change makes it so that the function id is set prior
to checking for the phy id.
Add support for 82576 copper adapter and necessary code to restrict wol for
quad port adapter to first port.
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Adding device id to support 82576NS dual port copper
NIC.
This patch adds the support to handle requests from the VF to perform
operations such as completing resets, setting/reading mac address, adding
vlans, adding multicast addresses, setting rlpml, and general
communications between the PF and all VFs.
Update the version number to 1.3.16 and update copyright dates for 2009.
There isn't much point in having the _82575 hanging off the end of this
function since there aren't any other version of this function running
around within this driver. This also allows for a bit of whitespace
cleanup due to a shorter function name.
All of the nvm ops have the tag _nvm added to the end which is redundant
since all of the calls to the ops have to go through the nvm ops struct
anyway.
This patch renames write_phy_reg to write_reg and read_phy_reg to read_reg.
It seems redundant to call out phy in an operation that is part of the
phy_ops struct.
This patch makes dev_spec a union and simplifies it so that it does not
require dynamic allocation and freeing in the driver.
drivers/net/Kconfig
When using sgmii the link was not being properly passed up to the driver
from the underlying link management functions. This change corrects it so
that get_link_status is cleared when a link has been found.
