This patch adds new initialization functions and device support
for i210 and i211 devices.
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
On this chipset it is required to configure the MPHY block for loopback tests. If MPHY is not configured then all loopback tests will report failures.
Signed-off-by: Robert Healy <robert.healy@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
This patch changes the serdes link code to support a forced mode for
some hardware, based on bit set in EEPROM.
This patch updates the copyright on the igb driver files to 2011.
This feature adds messaging to the link status change to notify
the user if the device returned from a downshift or power off
event due to the Thermal Sensor feature in i350 parts. Feature
is only available on internal copper ports.
This patch add DMA Coalescing which is a power-saving feature that
coalesces DMA writes in order to stay in a low-power state as much
as possible. Feature is disabled by default.
This patch adds functions and functions pointers to accommodate
differences between NVM interfaces and options for i350 devices,
82580 devices and the rest.
This patch adds the EEE feature for i350 devices, enabled by default.
This patch adds statistics output for OS2BMC feature which is configured
by eeprom on capable devices.
Implemented igb_ndo_set_vf_bw function which is being used
by iproute2 tool. In addition, updated igb_ndo_get_vf_config function
to show the actual rate limit to the user.
The rate limitation can be configured only when the link is up.
The rate limit value can be ranged between 0 and actual
link speed measured in Mbps. A value of '0' disables the rate limit for
this specific VF.
iproute2 usage will be 'ip link set ethX vf Y rate Z'.
After the command is made, the rate will be changed instantly.
To view the current rate limit, use 'ip link show ethX'.
The rates will be zeroed only upon driver reload or a link speed change.
This feature is being supported only by 82576 device.
Signed-off-by: Lior Levy <lior.levy@intel.com>
New adapters will have part numbers stored in string format rather than
simple hex format. This function will read part number formats in either
hex or string.
This patch adds support for the Intel(r) DH89xxCC series. The new
device will be using Intel(r) i347-AT4 and Marvell(r) M88E1322 and
M88E1112 PHYs. Support for these devices has also been added here.
Signed-off-by: Joseph Gasparakis <joseph.gasparakis@intel.com>
On a reset the MDICNFG.Destination and MDICNFG.COM_MDIO
register fields are not restored to the EEPROM default.
This patch modifies the reset code to read the EEPROM
and restore the default values.
Signed-off-by: Nicholas Nunley <nicholas.d.nunley@intel.com>
This patch adds support for external MDIO PHYs, in addition to
the standard SFP support for SGMII PHYs over the I2C interface.
82580 NICs can have up to 4 functions. This fixes phy accesses
to use the correct locks for functions 2 and 3.
Signed-off-by: Nicholas Nunley <nicholasx.d.nunley@intel.com>
This change corrects the fact that we were not reporting Gen2 link speeds
when we were in fact connected at Gen2 rates.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
This patch adds support for the the I350 Gigabit network connection which
is the follow-on part to the 82580.
CC: James Hearn <james.r.hearn@intel.com>
Adaptive IFS support has been included in the igb driver since its
initial release, but it is not a feature on any igb NICs. This patch
removes it from the driver.
This changes the behavior of the driver to power down the link
when the associated interface is down, unless management is enabled.
This patch makes use of the 82580 PHY and MAC support added and adds a set
of supported device IDs for said hardware.
This patch adds support for the 82580 MAC.
The code for the hw timestamping is a bit bulky and making some of the
functions difficult to read. In order to clean things up a bit I am moving
the timestamping operations into seperate functions.
Our SGMII phy code was incomplete in that it was not actually placing the
phy in SGMII mode and as a result the PHY was not able to establish a link
when connected to a non serdes link partner. This patch updates the code
to combine the SGMII/serdes PCS init and to add the necessary reset.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
The 82575 and 82576 hardware can both experience data corruption issues if
a pci-e completion arrives after the timeout value. In order to avoid this
we need to increase the timeout value while pci-e master is disabled.
Originally from: Vlad Yasevich <vladislav.yasevich@hp.com>
This patch, both the driver portion and the sctp code was
modified by Jesse Brandeburg and is
Copyright(c) 2009 Intel Corporation.
Thanks go to Vlad for starting this work.
Intel 82576 chipset supports SCTP checksum offloading. This
patch enables this functionality in the driver. A new NETIF
feature is introduced for SCTP checksum offload. If the driver
supports CRC32c checksum, it can set this feature flag. The
hardware can offload both transmit and receive.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
The igb driver was being incorrectly setup to only allow disabling receive
checksum if multiqueue was disabled. This change corrects that so that
RXCSUM is configured regardless of queue configuration.
We need to support wol on the second port for situations such as when the
lan ports are on the motherboard itself.
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
This patch adds the support to handle requests from the VF to perform
operations such as completing resets, setting/reading mac address, adding
vlans, adding multicast addresses, setting rlpml, and general
communications between the PF and all VFs.
Add the pf portion of vmdq support. This provides enough support so that
VMDq is enabled, and the pf is functional without enabling vfs.
This patch removes all of the unused defines from the .h files contained in
igb. For some defines there was a use and so I plugged them into the correct
locations.
Both TX and RX hardware time stamping are implemented. Due to
hardware limitations it is not possible to verify reliably which
packet was time stamped when multiple were pending for sending; this
could be solved by only allowing one packet marked for hardware time
stamping into the queue (not implemented yet).
RX time stamping relies on the flag in the packet descriptor which
marks packets that were time stamped. In "all packet" mode this flag
is not set. TODO: also support that mode (even though it'll suffer
from race conditions).
Signed-off-by: John Ronciak <john.ronciak@intel.com>
Signed-off-by: Patrick Ohly <patrick.ohly@intel.com>
Update the version number to 1.3.16 and update copyright dates for 2009.
Add a counter for dma out of sync errors reported via interrupt.
Instead of pulling the mac address from EEPROM it is easier to pull it from
the RAL/RAH registers and then just copy it into the address structures.
This patch removes tx head writeback as it was found to not provide a
significant improvement in tx performance and on some systems has been seen
to cause a performance degredation due to partial cache line writes.
There is a reference to a Buffer Size extention bit that is unneded by
82575/82576 hardware. Since it is not needed it should be removed from the
code.
This patch changes the PCS configuration for serdes so that the flow
control options change be set via the ethtool -A option.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
This patch resolves an issue seen on 82575 adapters with managability
pass-thru enabled, which could cause the system to panic.
Various cosmetic cleanups. Comment fixes. Eliminate the hw part out
of the hw_dbg macro since it's always used.
We are pleased to announce a new Gigabit Ethernet product and its
driver to the linux community. This product is the Intel(R) 82575
Gigabit Ethernet adapter family. Physical adapters will be available
to the public soon. These adapters come in 2- and 4-port versions
(copper PHY) currently. Other variants will be available later.
The 82575 chipset supports significantly different features that
warrant a new driver. The descriptor format is (just like the
ixgbe driver) different. The device can use multiple MSI-X vectors
and multiple queues for both send and receive. This allows us to
optimize some of the driver code specifically as well compared to
the e1000-supported devices.
This version of the igb driver no lnger uses fake netdevices and
incorporates napi_struct members for each ring to do the multi-
queue polling. multi-queue is enabled by default and the driver
supports NAPI mode only.
All the namespace collisions should be gone in this version too. The
register macro's have been condensed to improve readability.
