I211 with a blank iNVM uses a different PCI ID. Hack the driver to load
despite i211 data sheet claiming tools only, not for driver.
Please note that the existing driver hacks concerning NVM validation
skipping and Ethernet MAC address assignment equally apply.
Tested on initial samples of Apalis T30 1GB V1.0A.
Revise Ethernet MAC address assignment: should now handle up to two
instances of custom user MACs (2nd one with a 0x100000 offset). This
way customer does not have to worry about NVM on a secondary Ethernet
on the carrier board and still gets a valid official MAC address from
us (e.g. analogous to how we did it on our Protea carrier board).
The following commit actually missed adding the new files:
7925180aee227f3de7af4a8cbad1c4b203a9132e
Springville with a blank Flash uses a different PCI ID. Hack the driver
to load despite i210 data sheet claiming tools only, not for driver.
Hack the driver to skip NVM validation on Apalis T30 for now.
Hack the driver to use a hard-code MAC address on Apalis T30 for now.
This patch adds new initialization functions and device support
for i210 and i211 devices.
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
82580 and later parts did not have low power setting functions. This patch
adds the specific functions, pointers and assignments for these low
power settings.
This patch fixes a problem where WOL would fail on second port of i350
device.
Reported-by: Martin Wilck <martin.wilck@ts.fujitsu.com>
Reported-by: Stefan Assmann<sassmann@redhat.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
after review of all intel drivers, found several instances where
drivers had the incorrect pattern of:
memory mapped write();
delay();
which should always be:
write flush(); /* aka memory mapped read */
delay();
explanation:
The reason for including the flush is that writes can be held
(posted) in PCI/PCIe bridges, but the read always has to complete
synchronously and therefore has to flush all pending writes to a
device. If a write is held and followed by a delay, the delay
means nothing because the write may not have reached hardware
(maybe even not until the next read)
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Remove duplicated #include('s) in
drivers/net/igb/igb_main.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
On this chipset it is required to configure the MPHY block for loopback tests. If MPHY is not configured then all loopback tests will report failures.
Signed-off-by: Robert Healy <robert.healy@intel.com>
- unify vlan and nonvlan rx path
- kill adapter->vlgrp and igb_vlan_rx_register
- allow to turn on/off rx/tx vlan accel via ethtool (set_features)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
This patch changes the serdes link code to support a forced mode for
some hardware, based on bit set in EEPROM.
This patch updates the copyright on the igb driver files to 2011.
Register writes followed by a delay are required to have a flush
before the delay in order to commit the values to the register. Without
the flush, the code following the delay may not function correctly.
Reported-by: Tong Ho <tong.ho@ericsson.com>
Reported-by: Guenter Roeck <guenter.roeck@ericsson.com>
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
The PCIE capability offset is saved during PCI bus walking. It will
remove an unnecessary search in the PCI configuration space if this
value is referenced instead of reacquiring it.
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Private rx_csum flags are now duplicate of netdev->features & NETIF_F_RXCSUM.
Removing this needs deeper surgery.
Things noticed:
- HW VLAN acceleration probably can be toggled, but it's left as is
- the resets on RX csum offload change can probably be avoided
- there is A LOT of copy-and-pasted code here
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
net/netfilter/ipvs/ip_vs_core.c
This patch changes the way versioning is done for igb in the kernel by
removing the number after the "k." It has been determined that just the
"k" is sufficient to identify a kernel version and the following number
was used in an inconsistent manner.
When SR-IOV is enabled, i350 devices fail to pass traffic. This is due to
the driver attempting to enable RSS on the PF device, which is not
supported by the i350.
When max_vfs is specified on an i350 adapter, set the number of RSS queues
to 1.
This issue affects 2.6.39 as well.
CC: stable@kernel.org
Signed-off-by: Mitch Williams <mitch.a.williams@intel.com>
After discovering that wide use of prefetch on modern CPUs
could be a net loss instead of a win, net drivers which were
relying on the implicit inclusion of prefetch.h via the list
headers showed up in the resulting cleanup fallout. Give
them an explicit include via the following $0.02 script.
#!/bin/bash
MANUAL=""
for i in `git grep -l 'prefetch(.*)' .` ; do
grep -q '<linux/prefetch.h>' $i
if [ $? = 0 ] ; then
continue
fi
( echo '?^#include <linux/?a'
echo '#include <linux/prefetch.h>'
echo .
echo w
echo q
) | ed -s $i > /dev/null 2>&1
if [ $? != 0 ]; then
echo $i needs manual fixup
MANUAL="$i $MANUAL"
fi
done
echo ------------------- 8\<----------------------
echo vi $MANUAL
Signed-off-by: Paul <paul.gortmaker@windriver.com>
[ Fixed up some incorrect #include placements, and added some
non-network drivers and the fib_trie.c case - Linus ]
Based on patch from Stephen Hemminger.
Convert igb driver to use new set_phys_id ethtool interface.
CC: Stephen Hemminger <shemminger@vyatta.com>
Recent commits have changed how EEPROM size is checked and if the size
word is misconfigured, the driver will fail to load. This patch adds a
check for invalid size word in the EEPROM and uses default size instead
for 82576 parts.
Reported-by: Stefan Assmann <sassmann@redhat.com>
This makes sure that one cannot request a 99Mbps full-duplex and get a
100Mbps half-duplex configuration in return due to the way the
speed/duplex parameters are handled internally.
Tested: e1000 works
Signed-off-by: David Decotigny <decot@google.com>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
This makes sure the ethtool's set_settings() callback of network
drivers don't ignore the 16 most significant bits when ethtool calls
their set_settings().
All drivers compiled with make allyesconfig on x86_64 have been
updated.
The code for thermal sensor checking should be wrapped into a function.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
Comment spelling fix.
This feature adds messaging to the link status change to notify
the user if the device returned from a downshift or power off
event due to the Thermal Sensor feature in i350 parts. Feature
is only available on internal copper ports.
Hardware timestamping for Intel 82580 didn't work in either 2.6.36 or
2.6.37. Comparing it to Intel's igb-2.4.12 I found that the
timecounter_init clock/counter initialization was done too early.
Signed-off-by: Anders Berggren <andfers@halon.se>
This patch updates igb version to 3.0.6.
This patch add DMA Coalescing which is a power-saving feature that
coalesces DMA writes in order to stay in a low-power state as much
as possible. Feature is disabled by default.
This patch adds functions and functions pointers to accommodate
differences between NVM interfaces and options for i350 devices,
82580 devices and the rest.
This patch adds the EEE feature for i350 devices, enabled by default.
This patch adds statistics output for OS2BMC feature which is configured
by eeprom on capable devices.
This fix changes the remaining calls to strncpy that have not yet
been changed to use the "sizeof(buf) - 1" syntax rather than just
a number for buffer size.
This fixes the reg_pattern_test so that the test does not fail
on i350 parts.
Currently there's no warning printed when max_vfs > 7 is specified with
igb and the maximum of 7 is silently enforced. This patch prints a
warning and informs the user of the actions taken.
Signed-off-by: Stefan Assmann <sassmann@redhat.com>
This will synchronize the version with the out of tree driver which
shares its functionality.
This fix updates copyright information to include current year 2011.
Implemented igb_ndo_set_vf_bw function which is being used
by iproute2 tool. In addition, updated igb_ndo_get_vf_config function
to show the actual rate limit to the user.
The rate limitation can be configured only when the link is up.
The rate limit value can be ranged between 0 and actual
link speed measured in Mbps. A value of '0' disables the rate limit for
this specific VF.
iproute2 usage will be 'ip link set ethX vf Y rate Z'.
After the command is made, the rate will be changed instantly.
To view the current rate limit, use 'ip link show ethX'.
The rates will be zeroed only upon driver reload or a link speed change.
This feature is being supported only by 82576 device.
Signed-off-by: Lior Levy <lior.levy@intel.com>
This patch adds full support for SR-IOV by enabling the PF side.
VF side has already been committed.
This patch enables support for Intel i340 Quad Port Fiber Adapter.
Add support for the anti-spoofing feature in the HW. Packets from
VF devices with spoofed MAC addresses or VLAN tags will be blocked
and an event generated. When the watchdog task runs it will call a
function to check if any spoof events occurred. If an event was
detected then a warning message is dumped to the system log.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
This patch does the following:
1. Changes the existing supported device id's so now DH89xxCC is not supported when EEPROM is not read.
2. Adds two more device ids for DH89xxCC in backplane mode and SFP.
3. Driver now initializes previously possibly uninitialized value in igb_reset_mdicnfg_82580().
Signed-off-by: Joseph Gasparakis <joseph.gasparakis@intel.com>
Print a warning message to the system log when the VF attempts to
override administratively set MAC/VLAN configuration.
The vf flags were being overwritten causing the flag that indicates
that the PF has set the VF MAC address to get cleared. This would
allow the VF to override the MAC address assigned by the Host VMM
using the ip link set command.
All three drivers use flush_scheduled_work() similarly during driver
detach. Replace it with explicit cancels.
Cc: e1000-devel@lists.sourceforge.net
Cc: netdev@vger.kernel.org
New adapters will have part numbers stored in string format rather than
simple hex format. This function will read part number formats in either
hex or string.
