path: root/drivers/net/ipg.h
2008-01-28ipg: fix checkpatch reported errorsPekka Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2008-01-28ipg: naming convention fixesPekka Enberg
This changes some camel-case names to follow proper kernel naming convention. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28ipg: remove some internal commentsPekka Enberg
This removes some now useless comments that were added when the driver was developed out-of-tree. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2008-01-28ipg: remove commented out codePekka Enberg
2008-01-28ipg: remove driver versionPekka Enberg
The driver is in mainline now so there's no need to maintain a separate version number. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2008-01-28ipg: remove IPG_DEV_KFREE_SKB macroPekka Enberg
2008-01-28ipg: remove boolean macrosPekka Enberg
2008-01-28ipg: remove old contact informationPekka Enberg
Remove old comment as up-to-date contact information is in MAINTAINERS. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2007-10-25drivers/net/ipg.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make ipg_nic_get_stats() static - move DefaultPhyParam[] from ipg.h to ipg.c and make it static Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-14ipg: endianness annotationsAl Viro
2007-10-10[IPG]: add IP1000A driver to kernel treeFrancois Romieu
Signed-off-by: Jesse Huang <jesse@icplus.com.tw> Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
