path: root/drivers/net/ipg.h
2010-03-30drivers/net/ipg: Remove invalid IPG_DDEBUG_MSG uses, neatenJoe Perches
Some no longer valid IPG_DDEBUG_MSG uses are removed Validate IPG_DDEBUG_MSG arguments when not #defined Neaten #defines marco/macro typo correction Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-12trivial: fix typo milisecond/millisecond for documentation and source comments.Martin Olsson
Signed-off-by: Martin Olsson <martin@minimum.se> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-08-14[netdrvr] remove unnecessary #includeHuang Weiyi
The drivers below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. drivers/net/acenic.c drivers/net/bnx2x_link.c drivers/net/bnx2x_main.c drivers/net/cpmac.c drivers/net/gianfar_sysfs.c drivers/net/ipg.h drivers/net/ppp_mppe.c drivers/net/pppol2tp.c drivers/net/r6040.c drivers/net/sh_eth.c drivers/net/sky2.c drivers/net/tehuti.h drivers/net/typhoon.c This patch removes the said #include <linux/version.h>. Signed-off-by: Huang Weiyi <hwy@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ipg: run-time configurable jumbo frame supportPekka Enberg
Make jumbo frame support configurable via ifconfig mtu option as suggested by Stephen Hemminger. Cc: Stephen Hemminger <stephen.hemminger@vyatta.com> Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ipg: per-device max_rxframe_sizePekka Enberg
Add a ->max_rxframe member to struct ipg_nic_private and convert the users of IPG_MAX_RXFRAME_SIZE to use it instead to enable per-device jumbo frame configuration. Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ipg: per-device rxsupport_sizePekka Enberg
Add a ->max_rxframe member to struct ipg_nic_private and convert the users of IPG_RXSUPPORT_SIZE to use it instead to enable per-device jumbo frame configuration. Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ipg: per-device rxfrag_sizePekka Enberg
Add a ->max_rxframe member to struct ipg_nic_private and convert the users of IPG_RXFRAG_SIZE to use it instead to enable per-device jumbo frame configuration. Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ipg: remove jumbo frame #ifdef from mtuPekka Enberg
Remove JUMBO_FRAME #ifdef from dev->mtu setting in ipg_nic_open() so that we can make IPG_TXFRAG_SIZE configurable. Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ipg: always compile in jumbo frame supportPekka Enberg
Add a ->is_jumbo boolean to struct ipg_nic_private and fix up ipg_interrupt_handler() to call the jumbo frame version of ipg_nic_rx() if the boolean is set to true. Also remove the JUMBO_FRAME #ifdefs so we can always compile in support for jumbo frames. Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28ipg: fix checkpatch reported errorsPekka Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2008-01-28ipg: naming convention fixesPekka Enberg
This changes some camel-case names to follow proper kernel naming convention. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28ipg: remove some internal commentsPekka Enberg
This removes some now useless comments that were added when the driver was developed out-of-tree. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2008-01-28ipg: remove commented out codePekka Enberg
2008-01-28ipg: remove driver versionPekka Enberg
The driver is in mainline now so there's no need to maintain a separate version number. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2008-01-28ipg: remove IPG_DEV_KFREE_SKB macroPekka Enberg
2008-01-28ipg: remove boolean macrosPekka Enberg
2008-01-28ipg: remove old contact informationPekka Enberg
Remove old comment as up-to-date contact information is in MAINTAINERS. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Sorbica Shieh <sorbica@icplus.com.tw> Cc: Jesse Huang <jesse@icplus.com.tw>
2007-10-25drivers/net/ipg.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make ipg_nic_get_stats() static - move DefaultPhyParam[] from ipg.h to ipg.c and make it static Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-14ipg: endianness annotationsAl Viro
2007-10-10[IPG]: add IP1000A driver to kernel treeFrancois Romieu
Signed-off-by: Jesse Huang <jesse@icplus.com.tw> Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
