[ Upstream commit 92ff42645028fa6f9b8aa767718457b9264316b4 ]
Packets that don't have dest mac as the mac of the master device should
not be entertained by the IPvlan rx-handler. This is mostly true as the
packet path mostly takes care of that, except when the master device is
a virtual device. As demonstrated in the following case -
ip netns add ns1
ip link add ve1 type veth peer name ve2
ip link add link ve2 name iv1 type ipvlan mode l2
ip link set dev iv1 netns ns1
ip link set ve1 up
ip link set ve2 up
ip -n ns1 link set iv1 up
ip addr add 192.168.10.1/24 dev ve1
ip -n ns1 addr 192.168.10.2/24 dev iv1
ping -c2 192.168.10.2
<Works!>
ip neigh show dev ve1
ip neigh show 192.168.10.2 lladdr <random> dev ve1
<Still works! Wrong!!>
This patch adds that missing check in the IPvlan rx-handler.
Reported-by: Amit Sikka <amit.sikka@ericsson.com>
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
[ Upstream commit a98a4ebc8c61d20f0150d6be66e0e65223a347af ]
Current codes don't use skb->mark to assign flowi4_mark, it would
make the policy route rule with fwmark doesn't work as expected.
Signed-off-by: Gao Feng <gfree.wind@vip.163.com>
[ Upstream commit ca29fd7cce5a6444d57fb86517589a1a31c759e1 ]
When process the outbound packet of ipv6, we should assign the master
device to output device other than input device.
Signed-off-by: Keefe Liu <liuqifa@huawei.com>
Acked-by: Mahesh Bandewar <maheshb@google.com>
This patch adds a tap character device driver that is based on the
IP-VLAN network interface, called ipvtap. An ipvtap device can be created
in the same way as an ipvlan device, using 'type ipvtap', and then accessed
using the tap user space interface.
Signed-off-by: Sainath Grandhi <sainath.grandhi@intel.com>
There are three functions which would invoke the ipvlan_count_rx. They
are ipvlan_process_multicast, ipvlan_rcv_frame, and ipvlan_nf_input.
The former two functions already use the ipvlan directly before
ipvlan_count_rx, and ipvlan_nf_input gets the ipvlan from
ipvl_addr->master, it is not possible to be NULL too.
So the ipvlan pointer check is unnecessary in ipvlan_count_rx.
Signed-off-by: Gao Feng <fgao@ikuai8.com>
In an IPvlan setup when master is set in loopback mode e.g.
ethtool -K eth0 set loopback on
where eth0 is master device for IPvlan setup.
The failure is caused by the faulty logic that determines if the
packet is from TX-path vs. RX-path by just looking at the mac-
addresses on the packet while processing multicast packets.
In the loopback-mode where this crash was happening, the packets
that are sent out are reflected by the NIC and are processed on
the RX path, but mac-address check tricks into thinking this
packet is from TX path and falsely uses dev_forward_skb() to pass
packets to the slave (virtual) devices.
This patch records the path while queueing packets and eliminates
logic of looking at mac-addresses for the same decision.
kernel BUG at include/linux/skbuff.h:1737!
Call Trace:
[<ffffffff921fbbc2>] dev_forward_skb+0x92/0xd0
[<ffffffffc031ac65>] ipvlan_process_multicast+0x395/0x4c0 [ipvlan]
[<ffffffffc031a9a7>] ? ipvlan_process_multicast+0xd7/0x4c0 [ipvlan]
[<ffffffff91cdfea7>] ? process_one_work+0x147/0x660
[<ffffffff91cdff09>] process_one_work+0x1a9/0x660
[<ffffffff91ce086d>] worker_thread+0x11d/0x360
[<ffffffff91ce0750>] ? rescuer_thread+0x350/0x350
[<ffffffff91ce960b>] kthread+0xdb/0xe0
[<ffffffff91c05c70>] ? _raw_spin_unlock_irq+0x30/0x50
[<ffffffff91ce9530>] ? flush_kthread_worker+0xc0/0xc0
[<ffffffff92348b7a>] ret_from_fork+0x9a/0xd0
Fixes: ba35f8588f47 ("ipvlan: Defer multicast / broadcast processing to a work-queue")
CC: Eric Dumazet <edumazet@google.com>
1) netif_rx() / dev_forward_skb() should not be called from process
context.
2) ipvlan_count_rx() should be called with preemption disabled.
3) We should check if ipvlan->dev is up before feeding packets
to netif_rx()
4) We need to prevent device from disappearing if some packets
are in the multicast backlog.
5) One kfree_skb() should be a consume_skb() eventually
a work-queue")
Cc: Mahesh Bandewar <maheshb@google.com>
In a typical IPvlan L3 setup where master is in default-ns and
each slave is into different (slave) ns. In this setup egress
packet processing for traffic originating from slave-ns will
hit all NF_HOOKs in slave-ns as well as default-ns. However same
is not true for ingress processing. All these NF_HOOKs are
hit only in the slave-ns skipping them in the default-ns.
IPvlan in L3 mode is restrictive and if admins want to deploy
iptables rules in default-ns, this asymmetric data path makes it
impossible to do so.
This patch makes use of the l3_rcv() (added as part of l3mdev
enhancements) to perform input route lookup on RX packets without
changing the skb->dev and then uses nf_hook at NF_INET_LOCAL_IN
to change the skb->dev just before handing over skb to L4.
CC: David Ahern <dsa@cumulusnetworks.com>
Reviewed-by: David Ahern <dsa@cumulusnetworks.com>
The earlier patch c3aaa06d5a63 (ipvlan: scrub skb before routing
in L3 mode.) did this but only for TX path in L3 mode. This
patch extends it for both the modes for TX/RX path.
1. scope correction for few functions that are used in single file.
2. Adjust variables that are used in fast-path to fit into single cacheline
3. Update rcv_frame() to skip shared check for frames coming over wire
Scrub skb before hitting the iptable hooks to ensure packets hit
these hooks. Set the xnet param only when the packet is crossing the
ns boundry so if the IPvlan slave and master belong to the same ns,
the param will be set to false.
CC: Cong Wang <xiyou.wangcong@gmail.com>
ipvlan_handle_frame is a rx_handler, and when it returns a value other
than RX_HANDLER_CONSUMED (here, NET_RX_DROP aka RX_HANDLER_ANOTHER),
__netif_receive_skb_core expects that the skb still exists and will
process it further, but we just freed it.
Fixes: 2ad7bf363841 ("ipvlan: Initial check-in of the IPVLAN driver.")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Pass a **skb to ipvlan_rcv_frame so that if skb_share_check returns a
new skb, we actually use it during further processing.
It's safe to ignore the new skb in the ipvlan_xmit_* functions, because
they call ipvlan_rcv_frame with local == true, so that dev_forward_skb
is called and always takes ownership of the skb.
In the ipv4 outbound path of an ipvlan device in l3 mode, the ifindex is
being grabbed from dev_get_iflink. This works for the physical device
case, since as the documentation of that function notes: "Physical
interfaces have the same 'ifindex' and 'iflink' values.". However, if
the master device is a veth, and the pairs are in separate net
namespaces, the route lookup will fail with -ENODEV due to outer veth
pair being in a separate namespace from the ipvlan master/routing
namespace.
ns0 | ns1 | ns2
veth0a--|--veth0b--|--ipvl0
In ipvlan_process_v4_outbound(), a packet sent from ipvl0 in the above
configuration will pass fl.flowi4_oif == veth0a to
ip_route_output_flow(), but *net == ns1.
Notice also that ipv6 processing is not using iflink. Since there is a
discrepancy in usage, fixup both v4 and v6 case to use local dev
variable.
Tested this with l3 ipvlan on top of veth, as well as with single
physical interface in the top namespace.
Signed-off-by: Brenden Blanco <bblanco@plumgrid.com>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
Compute net once in ipvlan_process_v4_outbound and
ipvlan_process_v6_outbound and store it in a variable so that net does
not need to be recomputed next time it is used.
Stop hidding the sk parameter with an inline helper function and make
all of the callers pass it, so that it is clear what the function is
doing.
It is confusing and silly hiding a parameter so modify all of
the callers to pass in the appropriate socket or skb->sk if
no socket is known.
In tx path rcu_read_lock_bh() is held, so we need rcu_deference_bh().
This fixes the following warning:
[ INFO: suspicious RCU usage. ]
4.1.0-rc1+ #1007 Not tainted
drivers/net/ipvlan/ipvlan.h:106 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by dhclient/1076:
#0: (rcu_read_lock_bh){......}, at: [<ffffffff817e8d84>] rcu_lock_acquire+0x0/0x26
stack backtrace:
CPU: 2 PID: 1076 Comm: dhclient Not tainted 4.1.0-rc1+ #1007
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
0000000000000001 ffff8800d381bac8 ffffffff81a4154f 000000003c1a3c19
ffff8800d4d0a690 ffff8800d381baf8 ffffffff810b849f ffff880117d41148
ffff880117d40000 ffff880117d40068 0000000000000156 ffff8800d381bb18
Call Trace:
[<ffffffff81a4154f>] dump_stack+0x4c/0x65
[<ffffffff810b849f>] lockdep_rcu_suspicious+0x107/0x110
[<ffffffff8165a522>] ipvlan_port_get_rcu+0x47/0x4e
[<ffffffff8165ad14>] ipvlan_queue_xmit+0x35/0x450
[<ffffffff817ea45d>] ? rcu_read_unlock+0x3e/0x5f
[<ffffffff810a20bf>] ? local_clock+0x19/0x22
[<ffffffff810b4781>] ? __lock_is_held+0x39/0x52
[<ffffffff8165b64c>] ipvlan_start_xmit+0x1b/0x44
[<ffffffff817edf7f>] dev_hard_start_xmit+0x2ae/0x467
[<ffffffff817ee642>] __dev_queue_xmit+0x50a/0x60c
[<ffffffff817ee7a7>] dev_queue_xmit_sk+0x13/0x15
[<ffffffff81997596>] dev_queue_xmit+0x10/0x12
[<ffffffff8199b41c>] packet_sendmsg+0xb6b/0xbdf
[<ffffffff810b5ea7>] ? mark_lock+0x2e/0x226
[<ffffffff810a1fcc>] ? sched_clock_cpu+0x9e/0xb7
[<ffffffff817d56f9>] sock_sendmsg_nosec+0x12/0x1d
[<ffffffff817d7257>] sock_sendmsg+0x29/0x2e
[<ffffffff817d72cc>] sock_write_iter+0x70/0x91
[<ffffffff81199563>] __vfs_write+0x7e/0xa7
[<ffffffff811996bc>] vfs_write+0x92/0xe8
[<ffffffff811997d7>] SyS_write+0x47/0x7e
[<ffffffff81a4d517>] system_call_fastpath+0x12/0x6f
Acked-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
All structures used in traffic forwarding are rcu-protected:
ipvl_addr, ipvl_dev and ipvl_port. Thus we can unhash addresses
without synchronization. We'll anyway hash it back into the same
bucket: in worst case lockless lookup will scan hash once again.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Processing multicast / broadcast in fast path is performance draining
and having more links means more cloning and bringing performance
down further.
Broadcast; in particular, need to be given to all the virtual links.
Earlier tricks of enabling broadcast bit for IPv4 only interfaces are not
really working since it fails autoconf. Which means enabling broadcast
for all the links if protocol specific hacks do not have to be added into
the driver.
This patch defers all (incoming as well as outgoing) multicast traffic to
a work-queue leaving only the unicast traffic in the fast-path. Now if we
need to apply any additional tricks to further reduce the impact of this
(multicast / broadcast) type of traffic, it can be implemented while
processing this work without affecting the fast-path.
drivers/net/usb/asix_common.c
drivers/net/usb/sr9800.c
drivers/net/usb/usbnet.c
include/linux/usb/usbnet.h
net/ipv4/tcp_ipv4.c
net/ipv6/tcp_ipv6.c
The TCP conflicts were overlapping changes. In 'net' we added a
READ_ONCE() to the socket cached RX route read, whilst in 'net-next'
Eric Dumazet touched the surrounding code dealing with how mini
sockets are handled.
With USB, it's a case of the same bug fix first going into net-next
and then I cherry picked it back into net.
The goal of this patch is to prepare the removal of the iflink field. It
introduces a new ndo function, which will be implemented by virtual interfaces.
There is no functional change into this patch. All readers of iflink field
now call dev_get_iflink().
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
When an ipvlan interface is down, its addresses are not on the hash list.
Fix checks for existence of addresses not to depend on the hash list, walk
through all interface addresses instead.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
Adding and removing to the 'ipvlans' list is already done using _rcu list
operations.
When ipvlan interface with IP addresses attached is brought down and then
deleted, the assigned addresses are deleted twice from the address hash
list, first on the interface down and second on the link deletion.
Similarly, when an address is added while the interface is down, it is added
second time once the interface is brought up.
When the interface is down, the addresses should be kept off the hash list
for performance reasons. Ensure this is true, which also fixes the double add
problem. To fix the double free, check whether the address is hashed before
removing it.
Reported-by: Dan Williams <dcbw@redhat.com>
They are all either written once or extremly rarely (e.g. from init
code), so we can move them to the .data..read_mostly section.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
The ip6_route_output() always returns a valid dst pointer unlike in IPv4
case. So the validation has to be different from the IPv4 path. Correcting
that error in this patch.
This was picked up by a static checker with a following warning -
drivers/net/ipvlan/ipvlan_core.c:380 ipvlan_process_v6_outbound()
warn: 'dst' isn't an ERR_PTR
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This driver is very similar to the macvlan driver except that it
uses L3 on the frame to determine the logical interface while
functioning as packet dispatcher. It inherits L2 of the master
device hence the packets on wire will have the same L2 for all
the packets originating from all virtual devices off of the same
master device.
This driver was developed keeping the namespace use-case in
mind. Hence most of the examples given here take that as the
base setup where main-device belongs to the default-ns and
virtual devices are assigned to the additional namespaces.
The device operates in two different modes and the difference
in these two modes in primarily in the TX side.
(a) L2 mode : In this mode, the device behaves as a L2 device.
TX processing upto L2 happens on the stack of the virtual device
associated with (namespace). Packets are switched after that
into the main device (default-ns) and queued for xmit.
RX processing is simple and all multicast, broadcast (if
applicable), and unicast belonging to the address(es) are
delivered to the virtual devices.
(b) L3 mode : In this mode, the device behaves like a L3 device.
TX processing upto L3 happens on the stack of the virtual device
associated with (namespace). Packets are switched to the
main-device (default-ns) for the L2 processing. Hence the routing
table of the default-ns will be used in this mode.
RX processins is somewhat similar to the L2 mode except that in
this mode only Unicast packets are delivered to the virtual device
while main-dev will handle all other packets.
The devices can be added using the "ip" command from the iproute2
package -
ip link add link <master> <virtual> type ipvlan mode [ l2 | l3 ]
Cc: Eric Dumazet <edumazet@google.com>
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Laurent Chavey <chavey@google.com>
Cc: Tim Hockin <thockin@google.com>
Cc: Brandon Philips <brandon.philips@coreos.com>
Cc: Pavel Emelianov <xemul@parallels.com>
