path: root/drivers/net/irda/Kconfig
2014-10-03drivers/net/irda/Kconfig: Let SH_IRDA depend on HAS_IOMEMChen Gang
SH_IRDA needs HAS_IOMEM, so depend on it. The related error(with allmodconfig under um): CC [M] drivers/net/irda/sh_irda.o drivers/net/irda/sh_irda.c: In function ‘sh_irda_probe’: drivers/net/irda/sh_irda.c:776:2: error: implicit declaration of function ‘ioremap_nocache’ [-Werror=implicit-function-declaration] self->membase = ioremap_nocache(res->start, resource_size(res)); ^ drivers/net/irda/sh_irda.c:776:16: warning: assignment makes pointer from integer without a cast [enabled by default] self->membase = ioremap_nocache(res->start, resource_size(res)); ^ drivers/net/irda/sh_irda.c:821:2: error: implicit declaration of function ‘iounmap’ [-Werror=implicit-function-declaration] iounmap(self->membase); ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-14irda: sh_irda: Enable driver compilation with COMPILE_TESTLaurent Pinchart
This helps increasing build testing coverage. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-06net: irda: ep7211-sir: Remove driverAlexander Shiyan
This patch removes old and unsupported CLPS711X IrDA driver. Support for IrDA for CLPS711X serial port now provided by commit 4a33f1f59abd (serial: clps711x: Add support for N_IRDA line discipline), so IrDA-mode can be turned ON with "irattach" tool through "irtty" driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-09irda: fixup SH_SIR position on KconfigKuninori Morimoto
SH_SIR is not Dongle Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-01-22drivers/net/irda: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Samuel Ortiz <samuel@sortiz.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-22Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull first batch of arm-soc cleanups from Olof Johansson: "These cleanups are basically all over the place. The idea is to collect changes with minimal impact but large number of changes so we can avoid them from distracting in the diffstat in the other series. A significant number of lines get removed here, in particular because the ixp2000 and ixp23xx platforms get removed. These have never been extremely popular and have fallen into disuse over time with no active maintainer taking care of them. The u5500 soc never made it into a product, so we are removing it from the ux500 platform. Many good cleanups also went into the at91 and omap platforms, as has been the case for a number of releases." Trivial modify-delete conflicts in arch/arm/mach-{ixp2000,ixp23xx} * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (152 commits) ARM: clps711x: Cleanup IRQ handling ARM clps711x: Removed unused header mach/time.h ARM: clps711x: Added note about support EP731x CPU to Kconfig ARM: clps711x: Added missing register definitions ARM: clps711x: Used own subarch directory for store header file Dove: Fix Section mismatch warnings ARM: orion5x: ts78xx debugging changes ARM: orion5x: remove PM dependency from ts78xx ARM: orion5x: ts78xx fix NAND resource off by one ARM: orion5x: ts78xx whitespace cleanups Orion5x: Fix Section mismatch warnings Orion5x: Fix warning: struct pci_dev declared inside paramter list ARM: clps711x: Combine header files into one for clps711x-targets ARM: S3C24XX: Use common macro to define resources on mach-qt2410.c ARM: S3C24XX: Use common macro to define resources on mach-osiris.c ARM: EXYNOS: Adapt to cpuidle core time keeping and irq enable ARM: S5PV210: Use common macro to define resources on mach-smdkv210.c ARM: S5PV210: Use common macro to define resources on dev-audio.c ARM: S5PC100: Use common macro to define resources on dev-audio.c ARM: S5P64X0: Use common macro to define resources on dev-audio.c ...
2012-05-13ARM: clps711x: Combine header files into one for clps711x-targetsAlexander Shiyan
Current ARM7 Cirrus Logic product line contains only 3 cpu. EP7312 - Fully functional. EP7309 - Missing SDRAM interface. EP7311 - Missing DAI. It makes no sense to separate the header files to identify these differences, it is only necessary to keep in mind the presence or lack of any features of a specific CPU when writing code. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-04-27NET: smsc-ircc2: mark non-experimentalLinus Walleij
This has been used by me and others for ages, let's stop calling it experimental. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-18Fix "the the" in various KconfigMasanari Iida
Fix typo "the the" in various Kconfig. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-07NET: sa11x0-ir: convert sa11x0-ir driver to use DMA engine APIRussell King
Convert the sa11x0 IrDA driver to use the sa11x0 DMA engine driver rather than our own platform specific DMA API. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-08net/irda: convert au1k_ir to platform driver.Manuel Lauss
Moderate driver cleanup: convert to platform driver, get rid of board-specific code. Driver loads and runs on a DB1100 board. But since I have no other IrDA hardware to exchange data with I can't say whether it really sends and receives. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: netdev@vger.kernel.org To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2877/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits) MIPS: O32: Provide definition of registers ta0 .. ta3. MIPS: perf: Add Octeon support for hardware perf. MIPS: perf: Add support for 64-bit perf counters. MIPS: perf: Reorganize contents of perf support files. MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c MIPS: Add accessor macros for 64-bit performance counter registers. MIPS: Add probes for more Octeon II CPUs. MIPS: Add more CPU identifiers for Octeon II CPUs. MIPS: XLR, XLS: Add comment for smp setup MIPS: JZ4740: GPIO: Check correct IRQ in demux handler MIPS: JZ4740: GPIO: Simplify IRQ demuxer MIPS: JZ4740: Use generic irq chip MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines MIPS: Alchemy: kill au1xxx.h header MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep MIPS: Alchemy: Redo PCI as platform driver MIPS: Alchemy: more base address cleanup MIPS: Alchemy: rewrite USB platform setup. MIPS: Alchemy: abstract USB block control register access ... Fix up trivial conflicts in: arch/mips/alchemy/devboards/db1x00/platform.c drivers/ide/Kconfig drivers/mmc/host/au1xmmc.c drivers/video/Kconfig sound/mips/Kconfig
2011-10-24MIPS: Alchemy: remove all CONFIG_SOC_AU1??? definesManuel Lauss
Now that no driver any longer depends on the CONFIG_SOC_AU1??? symbols, it's time to get rid of them: Move some of the platform devices to the boards which can use them, Rename a few (unused) constants in the header, Replace them with MIPS_ALCHEMY in the various Kconfig files. Finally delete them altogether from the Alchemy Kconfig file. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2707/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-11Fix file references in Kconfig filesJohann Felix Soden
This patch fixes file references to moved or deleted files outside of Documentation/. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-06net/irda: Add SuperH IrDA driver supportKuninori Morimoto
This is very simple driver for SuperH Mobile IrDA which support SIR/MIR/FIR. This patch add only SIR support for now. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02net/irda: sh_sir: Add SuperH IrDA driverKuninori Morimoto
This is very simple IrDA SIR driver for SuperH. This driver was tested by irdaping/ircp on SH7724 EcoVec24 board Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13irda: new Blackfin on-chip SIR IrDA driverGraff Yang
Signed-off-by: Graff Yang <graff.yang@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-06-09irda: net/irda build fix: mcs7780Ingo Molnar
-tip testing found the following build error: drivers/built-in.o: In function `mcs_receive_irq': mcs7780.c:(.text+0x4e429): undefined reference to `crc32_le' drivers/built-in.o: In function `mcs_hard_xmit': mcs7780.c:(.text+0x4e9af): undefined reference to `crc32_le' with: http://redhat.com/~mingo/misc/config-Sun_Jun__8_22_56_14_CEST_2008.bad the reason is a missing enablement of the CRC32 library in the Kconfig. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Irport removal - part 1Adrian Bunk
This patch removes IrPORT and the old dongle drivers (all off them have replacement drivers). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IrDA]: Kingsun KS-959 IrDA USB driverAlex Villacís Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. First, it uses control URBs for data transfer, instead of bulk or interrupt transfers; the only interrupt endpoint exposed seems to be a dummy to prevent the interface from being rejected. Second, it uses obfuscation and padding at the USB traffic level, for no apparent reason other than to make reverse engineering harder (full details on obfuscation in comments at beginning of source). Although it is advertised as a "4 Mbps FIR dongle", it apparently loses packets at speeds greater than 57600 bps. On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4959 . The Windows driver that is used normally to control this dongle has a filename of KS-959.SYS . Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IrDA]: Kingsun Dazzle IrDA USB driverAlex Villacís Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. Just like the Kingsun/Donshine dongle, it exposes two interrupt endpoints. Reception is performed through direct reads from the input endpoint. Transmission requires splitting the IrDA frames into 8-byte segments, in which the first byte encodes how many of the remaining 7 bytes are used as data. Speed change is made with a control URB just like the one in cypress_m8, and it seems to support up to 115200 bps. On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4100 Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[IrDA]: TOSHIBA_FIR depends on virt_to_busStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[IrDA]: EP7211 IR driver port to the latest SIR APISamuel Ortiz
The EP7211 SIR driver was the only one left without a new SIR API port. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[IrDA]: KingSun/DonShine USB IrDA dongle support.Alex Villac�s Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. In addition, it uses interrupt endpoints instead of bulk ones as the rest of USB IrDA dongles supported by Linux (just to be different?) and data reads need to be parsed to extract the valid bytes before being unwrapped (details in the comment at the start of the source). No speed commands have been discovered for this dongle, and I suspect it does not have any at all. On plugin, this dongle reports vendor and device IDs: 0x07c0:0x4200 . The Windows driver that is used normally to control this dongle has a filename of DSIR620.SYS . Signed-off-by: Alex Villac�s Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IrDA]: irda-usb needs firmware loaderSamuel Ortiz
With the inclusion of the stir421x code, we now need to select FW_LOADER whenever we try to build the irda-usb code. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[IrDA]: Fix the AU1000 FIR dependenciesAdrian Bunk
AU1000 FIR is broken, it should depend on SOC_AU1000. Spotted by Jean-Luc Leger. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IRDA]: Initial support for MCS7780 based donglesSamuel Ortiz
The MosChip MCS7780 chipset is an IrDA USB bridge that doesn't conform with the IrDA-USB standard and thus needs its separate driver. Tested on an actual MCS7780 based dongle. Original implementation by Brian Pugh <bpugh@cs.pdx.edu> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-25[IRDA]: *_DONGLE should depend on IRTTY_SIRSamuel Ortiz
If a SIR dongle is built in the kernel while IRTTY_SIR is built as a module, kernel compilation will fail. Thus, the SIR dongle config should depend on the IRTTY_SIR. Closes kernel bug# 6512 (http://bugzilla.kernel.org/show_bug.cgi?id=6512) Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IRDA]: TOIM3232 dongle supportDavid Basden
Here goes a patch for supporting TOIM3232 based serial IrDA dongles. The code is based on the tekram dongle code. It's been tested with a TOIM3232 based IRWave 320S dongle. It may work for TOIM4232 dongles, although it's not been tested. Signed-off-by: David Basden <davidb-irda@rcpt.to> Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-17[PATCH] trivial: fix spelling errors in KconfigsJon Mason
This patch corrects a few spelling and grammar errors found in drivers/net Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-10[IRDA] DONGLE_OLD: remove dependency on non-existing symbolAdrian Bunk
Jean-Luc Leger <reiga@dspnet.fr.eu.org> reported this alternative dependency on a non-existing symbol. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28[ARM] 2897/2: PXA2xx IRDA supportNicolas Pitre
Patch from Nicolas Pitre This is the PXA2xx common IRDA driver, plus platform support for Lubbock and Mainstone. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-12[PATCH] IrDA: IrDA: Fix CONFIG_VIA_FIR typo (double `those')Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] ISA DMA Kconfig fixes - part 4 (irda)Al Viro
* net/irda/irda_device.c::irda_setup_dma() made conditional on ISA_DMA_API (it uses helpers in question and irda is usable on platforms that don't have them at all - think of USB IRDA, for example). * irda drivers that depend on ISA DMA marked as dependent on ISA_DMA_API Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] x86_64: Make IRDA devices are not really ISA devices not depend on ↵Andi Kleen
CONFIG_ISA This allows to use them on x86-64 Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
