path: root/drivers/net/irda/Kconfig
2010-04-06net/irda: Add SuperH IrDA driver supportKuninori Morimoto
This is very simple driver for SuperH Mobile IrDA which support SIR/MIR/FIR. This patch add only SIR support for now. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-02net/irda: sh_sir: Add SuperH IrDA driverKuninori Morimoto
This is very simple IrDA SIR driver for SuperH. This driver was tested by irdaping/ircp on SH7724 EcoVec24 board Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13irda: new Blackfin on-chip SIR IrDA driverGraff Yang
Signed-off-by: Graff Yang <graff.yang@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-06-09irda: net/irda build fix: mcs7780Ingo Molnar
-tip testing found the following build error: drivers/built-in.o: In function `mcs_receive_irq': mcs7780.c:(.text+0x4e429): undefined reference to `crc32_le' drivers/built-in.o: In function `mcs_hard_xmit': mcs7780.c:(.text+0x4e9af): undefined reference to `crc32_le' with: http://redhat.com/~mingo/misc/config-Sun_Jun__8_22_56_14_CEST_2008.bad the reason is a missing enablement of the CRC32 library in the Kconfig. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Irport removal - part 1Adrian Bunk
This patch removes IrPORT and the old dongle drivers (all off them have replacement drivers). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IrDA]: Kingsun KS-959 IrDA USB driverAlex Villacís Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. First, it uses control URBs for data transfer, instead of bulk or interrupt transfers; the only interrupt endpoint exposed seems to be a dummy to prevent the interface from being rejected. Second, it uses obfuscation and padding at the USB traffic level, for no apparent reason other than to make reverse engineering harder (full details on obfuscation in comments at beginning of source). Although it is advertised as a "4 Mbps FIR dongle", it apparently loses packets at speeds greater than 57600 bps. On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4959 . The Windows driver that is used normally to control this dongle has a filename of KS-959.SYS . Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IrDA]: Kingsun Dazzle IrDA USB driverAlex Villacís Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. Just like the Kingsun/Donshine dongle, it exposes two interrupt endpoints. Reception is performed through direct reads from the input endpoint. Transmission requires splitting the IrDA frames into 8-byte segments, in which the first byte encodes how many of the remaining 7 bytes are used as data. Speed change is made with a control URB just like the one in cypress_m8, and it seems to support up to 115200 bps. On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4100 Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[IrDA]: TOSHIBA_FIR depends on virt_to_busStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-21[IrDA]: EP7211 IR driver port to the latest SIR APISamuel Ortiz
The EP7211 SIR driver was the only one left without a new SIR API port. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[IrDA]: KingSun/DonShine USB IrDA dongle support.Alex Villac�s Lasso
This dongle does not follow the usb-irda specification, so it needs its own special driver. In addition, it uses interrupt endpoints instead of bulk ones as the rest of USB IrDA dongles supported by Linux (just to be different?) and data reads need to be parsed to extract the valid bytes before being unwrapped (details in the comment at the start of the source). No speed commands have been discovered for this dongle, and I suspect it does not have any at all. On plugin, this dongle reports vendor and device IDs: 0x07c0:0x4200 . The Windows driver that is used normally to control this dongle has a filename of DSIR620.SYS . Signed-off-by: Alex Villac�s Lasso <a_villacis@palosanto.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IrDA]: irda-usb needs firmware loaderSamuel Ortiz
With the inclusion of the stir421x code, we now need to select FW_LOADER whenever we try to build the irda-usb code. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[IrDA]: Fix the AU1000 FIR dependenciesAdrian Bunk
AU1000 FIR is broken, it should depend on SOC_AU1000. Spotted by Jean-Luc Leger. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IRDA]: Initial support for MCS7780 based donglesSamuel Ortiz
The MosChip MCS7780 chipset is an IrDA USB bridge that doesn't conform with the IrDA-USB standard and thus needs its separate driver. Tested on an actual MCS7780 based dongle. Original implementation by Brian Pugh <bpugh@cs.pdx.edu> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-25[IRDA]: *_DONGLE should depend on IRTTY_SIRSamuel Ortiz
If a SIR dongle is built in the kernel while IRTTY_SIR is built as a module, kernel compilation will fail. Thus, the SIR dongle config should depend on the IRTTY_SIR. Closes kernel bug# 6512 (http://bugzilla.kernel.org/show_bug.cgi?id=6512) Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IRDA]: TOIM3232 dongle supportDavid Basden
Here goes a patch for supporting TOIM3232 based serial IrDA dongles. The code is based on the tekram dongle code. It's been tested with a TOIM3232 based IRWave 320S dongle. It may work for TOIM4232 dongles, although it's not been tested. Signed-off-by: David Basden <davidb-irda@rcpt.to> Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-17[PATCH] trivial: fix spelling errors in KconfigsJon Mason
This patch corrects a few spelling and grammar errors found in drivers/net Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-01-10[IRDA] DONGLE_OLD: remove dependency on non-existing symbolAdrian Bunk
Jean-Luc Leger <reiga@dspnet.fr.eu.org> reported this alternative dependency on a non-existing symbol. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28[ARM] 2897/2: PXA2xx IRDA supportNicolas Pitre
Patch from Nicolas Pitre This is the PXA2xx common IRDA driver, plus platform support for Lubbock and Mainstone. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-12[PATCH] IrDA: IrDA: Fix CONFIG_VIA_FIR typo (double `those')Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] ISA DMA Kconfig fixes - part 4 (irda)Al Viro
* net/irda/irda_device.c::irda_setup_dma() made conditional on ISA_DMA_API (it uses helpers in question and irda is usable on platforms that don't have them at all - think of USB IRDA, for example). * irda drivers that depend on ISA DMA marked as dependent on ISA_DMA_API Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] x86_64: Make IRDA devices are not really ISA devices not depend on ↵Andi Kleen
CONFIG_ISA This allows to use them on x86-64 Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
