The nsc ircc driver uses 'timeval', which we try to remove in the kernel
because all 32-bit time types will break in the year 2038.
This patch also changes do_gettimeofday() to ktime_get() accordingly,
since ktime_get returns a ktime_t, but do_gettimeofday returns a
struct timeval, and the other reason is that ktime_get() uses
the monotonic clock.
This patch uses ktime_us_delta to get the elapsed time, and in this
way it no longer needs to check for the overflow, because
ktime_us_delta returns time difference of microsecond.
Signed-off-by: Chunyan Zhang <zhang.chunyan@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Convert IRDA drivers to use already existing net_device_stats structure
in network device. This is a pre-cursor to conversion to net_device
ops. Compile tested only.
This is necessary to set the dongle type on the nsc driver in order to get
it to work correctly. Thinkpads all appear to use dongle type 9. This
patch defaults nsc devices with an IBM PnP descriptor to use type 9.
Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org>
Signed-off-by: Ben Collins <ben.collins@canonical.com>
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
This patch brings the nsc-ircc code to a more up to date power
management scheme, following the current device model.
Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz>
Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com>
infrastructure for it.
Let it rip!
