path: root/drivers/net/irda/sir-dev.h
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-05-09[IRDA]: Switching to a workqueue for the SIR workChristoph Hellwig
Since sir_kthread.c pretty much duplicates the workqueue functionality, we'd better switch. The SIR fsm has been merged into sir_dev.c and thus sir_kthread.c is deleted. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-10[IRDA]: kill drivers/net/irda/sir_core.cAdrian Bunk
EXPORT_SYMBOL's do nowadays belong to the files where the actual functions are. Moving the module_init/module_exit to the file with the actual functions has the advantage of saving a few bytes due to the removal of two functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
