path: root/drivers/net/irda
2011-08-11net/irda: sh_sir: tidyup compile warningKuninori Morimoto
This patch tidyup below warning ${LINUX}/drivers/net/irda/sh_sir.c:514:6: warning: 'val' may be used uninitialized in this function Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/irda: sh_sir: add missing headerKuninori Morimoto
This patch fixup below build error on sh_sir sh_sir.c: In function 'sh_sir_write': sh_sir.c:127:2: error: implicit declaration of function 'iowrite16' sh_sir.c: In function 'sh_sir_read': sh_sir.c:132:2: error: implicit declaration of function 'ioread16' sh_sir.c: At top level: sh_sir.c:561:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'sh_sir_irq' sh_sir.c: In function 'sh_sir_probe': sh_sir.c:727:2: error: implicit declaration of function 'ioremap_nocache' sh_sir.c:727:16: warning: assignment makes pointer from integer without a cast sh_sir.c:762:2: error: implicit declaration of function 'request_irq' sh_sir.c:762:23: error: 'sh_sir_irq' undeclared (first use in this function) sh_sir.c:762:23: note: each undeclared identifier is reported only once for each function it appears in sh_sir.c:762:35: error: 'IRQF_DISABLED' undeclared (first use in this function) sh_sir.c:776:2: error: implicit declaration of function 'iounmap' sh_sir.c: At top level: sh_sir.c:436:13: warning: 'sh_sir_clear_all_err' defined but not used sh_sir.c:474:12: warning: 'sh_sir_is_which_phase' defined but not used sh_sir.c:490:13: warning: 'sh_sir_tx' defined but not used sh_sir.c:540:13: warning: 'sh_sir_rx' defined but not used Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-11net/irda: sh_irda: add missing headerKuninori Morimoto
This patch fixup below build error on sh_irda sh_irda.c: In function 'sh_irda_write': sh_irda.c:174: error: implicit declaration of function 'iowrite16' sh_irda.c: In function 'sh_irda_read': sh_irda.c:184: error: implicit declaration of function 'ioread16' sh_irda.c: At top level: sh_irda.c:492: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'sh_irda_irq' sh_irda.c: In function 'sh_irda_probe': sh_irda.c:776: error: implicit declaration of function 'ioremap_nocache' sh_irda.c:776: warning: assignment makes pointer from integer without a cast sh_irda.c:811: error: implicit declaration of function 'request_irq' sh_irda.c:811: error: 'sh_irda_irq' undeclared (first use in this function) sh_irda.c:811: error: (Each undeclared identifier is reported only once sh_irda.c:811: error: for each function it appears in.) sh_irda.c:811: error: 'IRQF_DISABLED' undeclared (first use in this function) sh_irda.c:825: error: implicit declaration of function 'iounmap' Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-03irda: use PCI_VENDOR_ID_*Jon Mason
Use PCI_VENDOR_ID_* from pci_ids.h instead of creating #define locally. Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-06-24treewide: transciever/transceiver spelling fixesJoe Perches
Just tyops. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-21irda: fix smsc-ircc2 section mismatch warningRandy Dunlap
Fix section mismatch warning: WARNING: drivers/net/irda/smsc-ircc2.o(.devinit.text+0x1a7): Section mismatch in reference from the function smsc_ircc_pnp_probe() to the function .init.text:smsc_ircc_open() Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21net: remove mm.h inclusion from netdevice.hAlexey Dobriyan
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually). To prevent mm.h inclusion via other channels also extract "enum dma_data_direction" definition into separate header. This tiny piece is what gluing netdevice.h with mm.h via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h". Removal of mm.h from scatterlist.h was tried and was found not feasible on most archs, so the link was cutoff earlier. Hope people are OK with tiny include file. Note, that mm_types.h is still dragged in, but it is a separate story. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-05drivers/net: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-31Revert "net: fix section mismatches"David S. Miller
This reverts commit e5cb966c0838e4da43a3b0751bdcac7fe719f7b4. It causes new build regressions with gcc-4.2 which is pretty common on non-x86 platforms. Reported-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24net/irda: convert bfin_sir to common Blackfin UART headerMike Frysinger
No need to duplicate these defines now that the common Blackfin code has unified these for all UART devices. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-18net: fix section mismatchesMichał Mirosław
Fix build warnings like the following: WARNING: drivers/net/built-in.o(.data+0x12434): Section mismatch in reference from the variable madgemc_driver to the variable .init.data:madgemc_adapter_ids And add some consts to EISA device ID tables along the way. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-03-30via-ircc: Pass PCI device pointer to dma_{alloc, free}_coherent()Ben Hutchings
via-ircc has been passing a NULL pointer to DMA allocation functions, which is completely invalid and results in a BUG on PowerPC. Now that we always have the device pointer available, pass it in. Reference: http://bugs.debian.org/619450 Reported-by: Andrew Buckeridge <andrewb@bgc.com.au> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Tested-by: Andrew Buckeridge <andrewb@bgc.com.au> [against 2.6.32] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30via-ircc: Use pci_{get, set}_drvdata() instead of static pointer variableBen Hutchings
via-ircc still maintains its own array of device pointers in Linux 2.4 style. Worse, it always uses index 0, so it will crash if there are multiple suitable devices in the system. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17tiocmset: kill the file pointer argumentAlan Cox
Doing tiocmget was such fun we should do tiocmset as well for the same reasons Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (41 commits) sctp: user perfect name for Delayed SACK Timer option net: fix can_checksum_protocol() arguments swap Revert "netlink: test for all flags of the NLM_F_DUMP composite" gianfar: Fix misleading indentation in startup_gfar() net/irda/sh_irda: return to RX mode when TX error net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan. USB CDC NCM: tx_fixup() race condition fix ns83820: Avoid bad pointer deref in ns83820_init_one(). ipv6: Silence privacy extensions initialization bnx2x: Update bnx2x version to 1.62.00-4 bnx2x: Fix AER setting for BCM57712 bnx2x: Fix BCM84823 LED behavior bnx2x: Mark full duplex on some external PHYs bnx2x: Fix BCM8073/BCM8727 microcode loading bnx2x: LED fix for BCM8727 over BCM57712 bnx2x: Common init will be executed only once after POR bnx2x: Swap BCM8073 PHY polarity if required iwlwifi: fix valid chain reading from EEPROM ath5k: fix locking in tx_complete_poll_work ath9k_hw: do PA offset calibration only on longcal interval ...
2011-01-18net/irda/sh_irda: return to RX mode when TX errorKuninori Morimoto
sh_irda can not use RX/TX in same time, but this driver didn't return to RX mode when TX error occurred. This patch care xmit error case to solve this issue. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-10net/irda: bfin_sir: back out transitional definesMike Frysinger
Now that the common header is sane, we can drop the transitional cruft. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-10net/irda: bfin_sir: pull in serial headers for definesMike Frysinger
We're in the process of cleaning up the global Blackfin namespace, so the bfin_sir driver needs to pull in the serial header explicitly now. This does add a little transitional cruft to keep things compiling, but a follow up patch in this series will cull that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-03smsc-ircc2: Fix section mismatch derived from smsc_ircc_pnp_probe()Sedat Dilek
This fixes the following warning: drivers/net/irda/smsc-ircc2.o(.data+0x18): Section mismatch in reference from the variable smsc_ircc_pnp_driver to the function .init.text:smsc_ircc_pnp_probe() The variable smsc_ircc_pnp_driver references the function __init smsc_ircc_pnp_probe() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Tested with linux-next (next-20101231) Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-21drivers/net/*/: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. Signed-off-by: Joe Perches <joe@perches.com>
2010-12-12drivers/net: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is on its way out. This patch contains simple conversions to replace flush_scheduled_work() usage with direct cancels and flushes. Directly cancel the used works on driver detach and flush them in other cases. The conversions are mostly straight forward and the only dangers are, * Forgetting to cancel/flush one or more used works. * Cancelling when a work should be flushed (ie. the work must be executed once scheduled whether the driver is detaching or not). I've gone over the changes multiple times but it would be much appreciated if you can review with the above points in mind. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: e1000-devel@lists.sourceforge.net Cc: Vasanthy Kolluri <vkolluri@cisco.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com> Cc: Matt Carlson <mcarlson@broadcom.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Shreyas Bhatewara <sbhatewara@vmware.com> Cc: netdev@vger.kernel.org
2010-11-21SuperH IrDA: correct Baud rate error correctionNicolas Kaiser
It looks to me as if the second value of rate_err_array is intended to be a decimal 625. However, with a leading 0 it becomes an octal constant, and as such evaluates to a decimal 405. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-12irda: Semaphore cleanupThomas Gleixner
Get rid of init_MUTEX[_LOCKED]() and use sema_init() instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: "David S. Miller" <davem@davemloft.net> LKML-Reference: <20100907125055.651362456@linutronix.de>
2010-10-11irda: Test index before read in stir421x_patch_device()Roel Kluin
Test whether index exceeds fw->size before reading the element Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-23Fix typo: configuation => configurationThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-25drivers/net/irda: Eliminate memory leakJulia Lawall
dev_alloc_skb allocates some memory, so that memory should be freed before leaving the function in an error case. Corrected some typos in a nearby comment as well. A simplified version of the semantic match that finds this problem is: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ local idexpression x; expression E; identifier f1; iterator I; @@ x = dev_alloc_skb(...); <... when != x when != true (x == NULL || ...) when != if (...) { <+...x...+> } when != I (...) { <+...x...+> } ( x == NULL | x == E | x->f1 ) ...> * return ...; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-16drivers/net/irda: Adjust confusing if indentationJulia Lawall
Indent the branch of an if. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces4@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p1) cocci.print_secs("after",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-06Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/genesis-2.6 into ↵Russell King
devel-stable Conflicts: drivers/net/irda/sh_irda.c
2010-08-04net/irda/sh_irda: Modify clk_get lookupsKuninori Morimoto
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-07-21drivers/net/irda: use for_each_pci_dev()Kulikov Vasiliy
Use for_each_pci_dev() to simplify the code. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15drivers: irda: fix sign bugKulikov Vasiliy
platform_get_irq_byname() can return negative results, it is not seen to unsigned irq. Make it signed. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-23net/irda: bfin_sir: IRDA is not affected by anomaly 05000230Graf Yang
Anomaly 05000230 (over sampling of the UART STOP bit) applies only when the peripheral is operating in UART mode. So drop the anomaly handling in the IRDA code. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
