Don't read from free'd memory after calling netif_rx(). docopy is used as
a boolean (0 and 1) so unsigned int is sufficient.
Coverity bug #928
Signed-off-by: Eugene Teo <eugene.teo@eugeneteo.net>
This patch fixes 2 bugs in the USB-IrDA code.
The first one is a buffer overrun in the RX path. We are now using
IRDA_SKB_MAX_MTU when initializing the Rx URB.
The second one is a potential stack recursion when unplugging the USB
dongle. It seems that first we get the Rx URB with a generic error
code, and after a while the Rx URB comes again with a "disconnect"
error code. Since we are resubmitting the Rx URB immediately after
receiving the first error one, we might enter an endless loop.
When getting an error Rx URB, the patch defers the Rx URB resubmitting
so that it gives us a chance to catch the disconnect one, in case the
dongle has juts been unplugged.
Tested against 2.6.16-rc2.
Patch from Jean Tourrilhes
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com>
Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com>
Jean-Luc Leger <reiga@dspnet.fr.eu.org> reported this alternative
dependency on a non-existing symbol.
EXPORT_SYMBOL's do nowadays belong to the files where the actual
functions are.
Moving the module_init/module_exit to the file with the actual functions
has the advantage of saving a few bytes due to the removal of two
functions.
Acked-by: Jean Tourrilhes <jt@hpl.hp.com>
The API and code have been through various bits of initial review by
serial driver people but they definitely need to live somewhere for a
while so the unconverted drivers can get knocked into shape, existing
drivers that have been updated can be better tuned and bugs whacked out.
This replaces the tty flip buffers with kmalloc objects in rings. In the
normal situation for an IRQ driven serial port at typical speeds the
behaviour is pretty much the same, two buffers end up allocated and the
kernel cycles between them as before.
When there are delays or at high speed we now behave far better as the
buffer pool can grow a bit rather than lose characters. This also means
that we can operate at higher speeds reliably.
For drivers that receive characters in blocks (DMA based, USB and
especially virtualisation) the layer allows a lot of driver specific
code that works around the tty layer with private secondary queues to be
removed. The IBM folks need this sort of layer, the smart serial port
people do, the virtualisers do (because a virtualised tty typically
operates at infinite speed rather than emulating 9600 baud).
Finally many drivers had invalid and unsafe attempts to avoid buffer
overflows by directly invoking tty methods extracted out of the innards
of work queue structs. These are no longer needed and all go away. That
fixes various random hangs with serial ports on overflow.
The other change in here is to optimise the receive_room path that is
used by some callers. It turns out that only one ldisc uses receive room
except asa constant and it updates it far far less than the value is
read. We thus make it a variable not a function call.
I expect the code to contain bugs due to the size alone but I'll be
watching and squashing them and feeding out new patches as it goes.
Because the buffers now dynamically expand you should only run out of
buffering when the kernel runs out of memory for real. That means a lot of
the horrible hacks high performance drivers used to do just aren't needed any
more.
Description:
tty_insert_flip_char is an old API and continues to work as before, as does
tty_flip_buffer_push() [this is why many drivers dont need modification]. It
does now also return the number of chars inserted
There are also
tty_buffer_request_room(tty, len)
which asks for a buffer block of the length requested and returns the space
found. This improves efficiency with hardware that knows how much to
transfer.
and tty_insert_flip_string_flags(tty, str, flags, len)
to insert a string of characters and flags
For a smart interface the usual code is
len = tty_request_buffer_room(tty, amount_hardware_says);
tty_insert_flip_string(tty, buffer_from_card, len);
More description!
At the moment tty buffers are attached directly to the tty. This is causing a
lot of the problems related to tty layer locking, also problems at high speed
and also with bursty data (such as occurs in virtualised environments)
I'm working on ripping out the flip buffers and replacing them with a pool of
dynamically allocated buffers. This allows both for old style "byte I/O"
devices and also helps virtualisation and smart devices where large blocks of
data suddenely materialise and need storing.
So far so good. Lots of drivers reference tty->flip.*. Several of them also
call directly and unsafely into function pointers it provides. This will all
break. Most drivers can use tty_insert_flip_char which can be kept as an API
but others need more.
At the moment I've added the following interfaces, if people think more will
be needed now is a good time to say
int tty_buffer_request_room(tty, size)
Try and ensure at least size bytes are available, returns actual room (may be
zero). At the moment it just uses the flipbuf space but that will change.
Repeated calls without characters being added are not cumulative. (ie if you
call it with 1, 1, 1, and then 4 you'll have four characters of space. The
other functions will also try and grow buffers in future but this will be a
more efficient way when you know block sizes.
int tty_insert_flip_char(tty, ch, flag)
As before insert a character if there is room. Now returns 1 for success, 0
for failure.
int tty_insert_flip_string(tty, str, len)
Insert a block of non error characters. Returns the number inserted.
int tty_prepare_flip_string(tty, strptr, len)
Adjust the buffer to allow len characters to be added. Returns a buffer
pointer in strptr and the length available. This allows for hardware that
needs to use functions like insl or mencpy_fromio.
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
This patch contains the following cleanups:
- make a needlessly global function static
- remove the unneeded global function irport_probe
Cc: Jeff Garzik <jgarzik@pobox.com>
Since version 4.1 the gcc is warning about ignored attributes. This patch is
using the equivalent attribute on the struct instead of on each of the
structure or union members.
GCC Manual:
"Specifying Attributes of Types
packed
This attribute, attached to struct or union type definition, specifies
that
each member of the structure or union is placed to minimize the memory
required. When attached to an enum definition, it indicates that the
smallest integral type should be used.
Specifying this attribute for struct and union types is equivalent to
specifying the packed attribute on each of the structure or union
members."
Signed-off-by: Jan Blunck <jblunck@suse.de>
Cc: Dave Jones <davej@codemonkey.org.uk>
It is no longer needed, so let's remove it, saving a bit of memory.
Since few people need the support anymore, this moves the legacy
pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h.
This allows us to eliminate the casts in the drivers, and eventually
remove the use of the device_driver function pointer methods for
platform device drivers.
Two missing unlocks, as noted by Ted Unangst <tedu@coverity.com>
Manual #include fixups for clashes - there may be some unnecessary
smsc-ircc2 - avoid closing network device when suspending; just release
interrupt and disable DMA ourselves. Also make sure to reset chip when
resuming.
Cc: Jean Tourrilhes <jt@bougret.hpl.hp.com>
Patch from Richard Purdie
Update the PXA irda driver to match the recent platform device
suspend/resume level changes.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
In PM v1, all devices were called at SUSPEND_DISABLE level. Then
all devices were called at SUSPEND_SAVE_STATE level, and finally
SUSPEND_POWER_DOWN level. However, with PM v2, to maintain
compatibility for platform devices, I arranged for the PM v2
suspend/resume callbacks to call the old PM v1 suspend/resume
callbacks three times with each level in order so that existing
drivers continued to work.
Since this is obsolete infrastructure which is no longer necessary,
we can remove it. Here's an (untested) patch to do exactly that.
Minor manual fixups for gfp_t clashes.
Patch from Nicolas Pitre
This is the PXA2xx common IRDA driver, plus platform support
for Lubbock and Mainstone.
Signed-off-by: Nicolas Pitre <nico@cam.org>
A bunch of create_proc_dir_entry() calls creating directories had crept
in since the last sweep; converted to proc_mkdir().
Use schedule_timeout_interruptible() instead of
set_current_state()/schedule_timeout() to reduce kernel size.
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
29 July 2005, Cambridge, MA:
This afternoon Alan Stern submitted a patch to remove the URB_ASYNC_UNLINK
flag from the Linux kernel. Mr. Stern explained, "This flag is a relic
from an earlier, less-well-designed system. For over a year it hasn't
been used for anything other than printing warning messages."
An anonymous spokesman for the Linux kernel development community
commented, "This is exactly the sort of thing we see happening all the
time. As the kernel evolves, support for old techniques and old code can
be jettisoned and replaced by newer, better approaches. Proprietary
operating systems do not have the freedom or flexibility to change so
quickly."
Mr. Stern, a staff member at Harvard University's Rowland Institute who
works on Linux only as a hobby, noted that the patch (labelled as548) did
not update two files, keyspan.c and option.c, in the USB drivers' "serial"
subdirectory. "Those files need more extensive changes," he remarked.
"They examine the status field of several URBs at times when they're not
supposed to. That will need to be fixed before the URB_ASYNC_UNLINK flag
is removed."
Greg Kroah-Hartman, the kernel maintainer responsible for overseeing all
of Linux's USB drivers, did not respond to our inquiries or return our
calls. His only comment was "Applied, thanks."
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch removes CONFIG_PCI_NAMES.
I noticed a strange return value in smsc_ircc_init in
drivers/net/irda/smsc_ircc2.c in rc4-mm1.
When reaching the line "if (ircc_fir > 0 && ircc_sir > 0)", ret is 0. So I
don't see the point of setting it to 0 in the "else" case. >From what I
see in 2.6.12 it should probably be set to -ENODEV at the begining of the
"else" case. The attached patch does this.
Note that I didn't actually see any breakage caused by this.
Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org>
Cc: Dmitry Torokhov <dtor_core@ameritech.net>
IRDA: smsc-ircc2 - do not over-use void * pointers, use specific
types wherever possible.
Cc: Jean Tourrilhes <jt@hpl.hp.com>
IRDA: smsc-ircc2 - use netdev_priv() instead of accessing pointer
directly.
IRDA: smsc-ircc2 - add sysfs support (platform device and driver) and
switch power management to the new scheme.
IRDA: smsc-ircc2 - cleanup - do not pass around iobase, it can be
retrieved from smsc_ircc_cb structure.
IRDA: smsc-ircc2 - remove excessive typedefs.
IRDA: smsc-ircc2 - remove home-grown DIM macro, use ARRAY_SIZE intead.
Also fix out-of-bound array access.
IRDA: smsc-ircc2 - some formatting changes for better readability.
IRDA: smsc-ircc2 - whitespace fixes.
This adds type-checking to pm_message_t, so that people can't confuse it
with int or u32. It also allows us to fix "disk yoyo" during suspend (disk
spinning down/up/down).
[We've tried that before; since that cpufreq problems were fixed and I've
tried make allyes config and fixed resulting damage.]
Signed-off-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Alexander Nyberg <alexn@telia.com>
Fix remaining bits of u32 vs. pm_message confusion. Should not break
anything.
1. Establish a simple API for process freezing defined in linux/include/sched.h:
frozen(process) Check for frozen process
freezing(process) Check if a process is being frozen
freeze(process) Tell a process to freeze (go to refrigerator)
thaw_process(process) Restart process
frozen_process(process) Process is frozen now
2. Remove all references to PF_FREEZE and PF_FROZEN from all
kernel sources except sched.h
3. Fix numerous locations where try_to_freeze is manually done by a driver
4. Remove the argument that is no longer necessary from two function calls.
5. Some whitespace cleanup
6. Clear potential race in refrigerator (provides an open window of PF_FREEZE
cleared before setting PF_FROZEN, recalc_sigpending does not check
PF_FROZEN).
This patch does not address the problem of freeze_processes() violating the rule
that a task may only modify its own flags by setting PF_FREEZE. This is not clean
in an SMP environment. freeze(process) is therefore not SMP safe!
Signed-off-by: Christoph Lameter <christoph@lameter.com>
tty_register_ldisc(N_FOO, NULL) => tty_unregister_ldisc(N_FOO)
* net/irda/irda_device.c::irda_setup_dma() made conditional on
ISA_DMA_API (it uses helpers in question and irda is usable on
platforms that don't have them at all - think of USB IRDA, for
example).
* irda drivers that depend on ISA DMA marked as dependent on
ISA_DMA_API
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
This is the first of a few installments of PM API updates to match the
recent switch to "pm_message_t". This installment primarily affects
USB device drivers (for USB interfaces), and it changes the handful of
drivers which currently implement suspend methods:
- <linux/usb.h> and usbcore, signature change
- Some drivers only changed the signature, net effect this just
shuts up "sparse -Wbitwise":
* hid-core
* stir4200
- Two network drivers did that, and also grew slightly more
featureful suspend code ... they now properly shut down
their activities. (As should stir4200...)
* pegasus
* usbnet
Note that the Wake-On-Lan (WOL) support in pegasus doesn't yet work; looks
to me like it's missing a request to turn it on, vs just configuring it.
The ASIX code in usbnet also has WOL hooks that are ready to use; untested.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Index: gregkh-2.6/drivers/net/irda/stir4200.c
This fixes remaining u32s in drivers/ net.
CONFIG_ISA
This allows to use them on x86-64
Signed-off-by: Andi Kleen <ak@suse.de>
infrastructure for it.
Let it rip!
