Just tyops.
This reverts commit e5cb966c0838e4da43a3b0751bdcac7fe719f7b4.
It causes new build regressions with gcc-4.2 which is
pretty common on non-x86 platforms.
Reported-by: James Bottomley <James.Bottomley@HansenPartnership.com>
No need to duplicate these defines now that the common Blackfin code has
unified these for all UART devices.
Cc: Samuel Ortiz <samuel@sortiz.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
- kenrel -> kernel
- whetehr -> whether
- ttt -> tt
- sss -> ss
Fix build warnings like the following:
WARNING: drivers/net/built-in.o(.data+0x12434): Section mismatch in reference from the variable madgemc_driver to the variable .init.data:madgemc_adapter_ids
And add some consts to EISA device ID tables along the way.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
via-ircc has been passing a NULL pointer to DMA allocation functions,
which is completely invalid and results in a BUG on PowerPC. Now
that we always have the device pointer available, pass it in.
Reference: http://bugs.debian.org/619450
Reported-by: Andrew Buckeridge <andrewb@bgc.com.au>
Tested-by: Andrew Buckeridge <andrewb@bgc.com.au> [against 2.6.32]
via-ircc still maintains its own array of device pointers in Linux 2.4
style. Worse, it always uses index 0, so it will crash if there are
multiple suitable devices in the system.
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
Signed-off-by: Alan Cox <alan@linux.intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (41 commits)
sctp: user perfect name for Delayed SACK Timer option
net: fix can_checksum_protocol() arguments swap
Revert "netlink: test for all flags of the NLM_F_DUMP composite"
gianfar: Fix misleading indentation in startup_gfar()
net/irda/sh_irda: return to RX mode when TX error
net offloading: Do not mask out NETIF_F_HW_VLAN_TX for vlan.
USB CDC NCM: tx_fixup() race condition fix
ns83820: Avoid bad pointer deref in ns83820_init_one().
ipv6: Silence privacy extensions initialization
bnx2x: Update bnx2x version to 1.62.00-4
bnx2x: Fix AER setting for BCM57712
bnx2x: Fix BCM84823 LED behavior
bnx2x: Mark full duplex on some external PHYs
bnx2x: Fix BCM8073/BCM8727 microcode loading
bnx2x: LED fix for BCM8727 over BCM57712
bnx2x: Common init will be executed only once after POR
bnx2x: Swap BCM8073 PHY polarity if required
iwlwifi: fix valid chain reading from EEPROM
ath5k: fix locking in tx_complete_poll_work
ath9k_hw: do PA offset calibration only on longcal interval
sh_irda can not use RX/TX in same time,
but this driver didn't return to RX mode when TX error occurred.
This patch care xmit error case to solve this issue.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
Now that the common header is sane, we can drop the transitional cruft.
We're in the process of cleaning up the global Blackfin namespace, so the
bfin_sir driver needs to pull in the serial header explicitly now.
This does add a little transitional cruft to keep things compiling, but a
follow up patch in this series will cull that.
This fixes the following warning:
drivers/net/irda/smsc-ircc2.o(.data+0x18): Section mismatch in reference from the variable smsc_ircc_pnp_driver to the function .init.text:smsc_ircc_pnp_probe()
The variable smsc_ircc_pnp_driver references
the function __init smsc_ircc_pnp_probe()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
Tested with linux-next (next-20101231)
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
Using static const generally increases object text and decreases data size.
It also generally decreases overall object size.
flush_scheduled_work() is on its way out. This patch contains simple
conversions to replace flush_scheduled_work() usage with direct
cancels and flushes.
Directly cancel the used works on driver detach and flush them in
other cases.
The conversions are mostly straight forward and the only dangers are,
* Forgetting to cancel/flush one or more used works.
* Cancelling when a work should be flushed (ie. the work must be
executed once scheduled whether the driver is detaching or not).
I've gone over the changes multiple times but it would be much
appreciated if you can review with the above points in mind.
Cc: Jay Cliburn <jcliburn@gmail.com>
Cc: Michael Chan <mchan@broadcom.com>
Cc: Divy Le Ray <divy@chelsio.com>
Cc: e1000-devel@lists.sourceforge.net
Cc: Vasanthy Kolluri <vkolluri@cisco.com>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Andrew Gallatin <gallatin@myri.com>
Cc: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com>
Cc: Matt Carlson <mcarlson@broadcom.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: netdev@vger.kernel.org
It looks to me as if the second value of rate_err_array is intended
to be a decimal 625. However, with a leading 0 it becomes an octal
constant, and as such evaluates to a decimal 405.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
Get rid of init_MUTEX[_LOCKED]() and use sema_init() instead.
Acked-by: "David S. Miller" <davem@davemloft.net>
LKML-Reference: <20100907125055.651362456@linutronix.de>
Test whether index exceeds fw->size before reading the element
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
Signed-off-by: Thomas Weber <weber@corscience.de>
dev_alloc_skb allocates some memory, so that memory should be freed before
leaving the function in an error case.
Corrected some typos in a nearby comment as well.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression x;
expression E;
identifier f1;
iterator I;
x = dev_alloc_skb(...);
<... when != x
when != true (x == NULL || ...)
when != if (...) { <+...x...+> }
when != I (...) { <+...x...+> }
x == NULL
x == E
x->f1
* return ...;
// </smpl>
Indent the branch of an if.
The semantic match that finds this problem is as follows:
// <smpl>
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
// </smpl>
devel-stable
drivers/net/irda/sh_irda.c
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Use for_each_pci_dev() to simplify the code.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
platform_get_irq_byname() can return negative results, it is not seen to
unsigned irq. Make it signed.
cleanup patch.
Use new __packed annotation in drivers/net/
Anomaly 05000230 (over sampling of the UART STOP bit) applies only when
the peripheral is operating in UART mode. So drop the anomaly handling
in the IRDA code.
Signed-off-by: Graf Yang <graf.yang@analog.com>
switch and while statements don't need semicolons at end of statement
[ Fixup minor conflicts with recent wimax merge... -DaveM ]
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
This is very simple driver for SuperH Mobile IrDA
which support SIR/MIR/FIR.
This patch add only SIR support for now.
On sh_sir_probe function, there was a possibility that
iounmap is executed even though self->membase was NULL when error case.
This patch modify it.
On sh_sir_open function, there was a possibility that
err variable didn't have value even though it is return value.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Includes a minor consistency improvement between two related
debug messages.
Signed-off-by: Frans Pop <elendil@planet.nl>
CONFIG_USE_INTERNAL_TIMER seems to be the remainings of some experiment.
It is explicitely #undef-ed as not working, only referenced from one
source file and rather aged.
Hereby cleaning it from the kernel tree.
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
Acked-by: Roel Kluin <roel.kluin@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits)
bridge: ensure to unlock in error path in br_multicast_query().
drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages
sky2: Avoid rtnl_unlock without rtnl_lock
ipv6: Send netlink notification when DAD fails
drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant
ipconfig: Handle devices which take some time to come up.
mac80211: Fix memory leak in ieee80211_if_write()
mac80211: Fix (dynamic) power save entry
ipw2200: use kmalloc for large local variables
ath5k: read eeprom IQ calibration values correctly for G mode
ath5k: fix I/Q calibration (for real)
ath5k: fix TSF reset
ath5k: use fixed antenna for tx descriptors
libipw: split ieee->networks into small pieces
mac80211: Fix sta_mtx unlocking on insert STA failure path
rt2x00: remove KSEG1ADDR define from rt2x00soc.h
net: add ColdFire support to the smc91x driver
asix: fix setting mac address for AX88772
ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}.
net: Fix dev_mc_add()
