path: root/drivers/net/ixgbe
2010-08-13e100/e1000*/igb*/ixgb*: Add missing read memory barrierJeff Kirsher
commit 2d0bb1c1f4524befe9f0fcf0d0cd3081a451223f upstream. Based on patches from Sonny Rao and Milton Miller... Combined the patches to fix up clean_tx_irq and clean_rx_irq. The PowerPC architecture does not require loads to independent bytes to be ordered without adding an explicit barrier. In ixgbe_clean_rx_irq we load the status bit then load the packet data. With packet split disabled if these loads go out of order we get a stale packet, but we will notice the bad sequence numbers and drop it. The problem occurs with packet split enabled where the TCP/IP header and data are in different descriptors. If the reads go out of order we may have data that doesn't match the TCP/IP header. Since we use hardware checksumming this bad data is never verified and it makes it all the way to the application. This bug was found during stress testing and adding this barrier has been shown to fix it. The bug can manifest as a data integrity issue (bad payload data) or as a BUG in skb_pull(). This was a nasty bug to hunt down, if people agree with the fix I think it's a candidate for stable. Previously Submitted to e1000-devel only for ixgbe http://marc.info/?l=e1000-devel&m=126593062701537&w=3 We've now seen this problem hit with other device drivers (e1000e mostly) So I'm resubmitting with fixes for other Intel Device Drivers with similar issues. CC: Milton Miller <miltonm@bga.com> CC: Anton Blanchard <anton@samba.org> CC: Sonny Rao <sonnyrao@us.ibm.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-21ixgbe/igb: catch invalid VF settingsAndy Gospodarek
Some ixgbe cards put an invalid VF device ID in the PCIe SR-IOV capability. The ixgbe driver is only valid for PFs or non SR-IOV hardware. It seems that the same problem could occur on igb hardware as well, so if we discover we are trying to initialize a VF in ixbge_probe or igb_probe, print an error and exit. Based on a patch for ixgbe from Chris Wright <chrisw@sous-sol.org>. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Cc: Chris Wright <chrisw@sous-sol.org> Acked-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-02net: decreasing real_num_tx_queues needs to flush qdiscJohn Fastabend
Reducing real_num_queues needs to flush the qdisc otherwise skbs with queue_mappings greater then real_num_tx_queues can be sent to the underlying driver. The flow for this is, dev_queue_xmit() dev_pick_tx() skb_tx_hash() => hash using real_num_tx_queues skb_set_queue_mapping() ... qdisc_enqueue_root() => enqueue skb on txq from hash ... dev->real_num_tx_queues -= n ... sch_direct_xmit() dev_hard_start_xmit() ndo_start_xmit(skb,dev) => skb queue set with old hash skbs are enqueued on the qdisc with skb->queue_mapping set 0 < queue_mappings < real_num_tx_queues. When the driver decreases real_num_tx_queues skb's may be dequeued from the qdisc with a queue_mapping greater then real_num_tx_queues. This fixes a case in ixgbe where this was occurring with DCB and FCoE. Because the driver is using queue_mapping to map skbs to tx descriptor rings we can potentially map skbs to rings that no longer exist. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29ixgbe: skip non IPv4 packets in ATR filterGuillaume Gaudonville
In driver ixgbe, ixgbe_atr may cause crashes for non-ipv4 packets. Just add a test to check skb->protocol. It may crash on short packets due to ip_hdr() access. Signed-off-by: Guillaume Gaudonville <guillaume.gaudonville@6wind.com> Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29ixgbe: disable tx engine before disabling tx laserJohn Fastabend
Disabling the tx laser while receiving DMA requests can hang the device. After this occurs the device is in a bad state. The GPIO bit never clears when PCI master access is disabled and a reboot is required to get the device in a good state again. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29ixgbe: fix panic when shutting down system with WoL enabledAndy Gospodarek
This patch added to 2.6.34: commit 5f6c01819979afbfec7e0b15fe52371b8eed87e8 Author: Jesse Brandeburg <jesse.brandeburg@intel.com> Date: Wed Apr 14 16:04:23 2010 -0700 ixgbe: fix bug with vlan strip in promsic mode among other things added a function called ixgbe_vlan_filter_enable. This new function wants to access and set some rx_ring parameters, but adapter->rx_ring has already been freed. This simply moves the free until after the access and makes __ixgbe_shutdown look more like ixgbe_remove. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16ixgbe: add comment on SFP+ ID for Active DADon Skidmore
These comments were forgotten in the initial patch to add this functionality. This patch corrects that. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-13ixgbe: fix automatic LRO/RSC settings for low latencyAndy Gospodarek
This patch added to 2.6.34: commit f8d1dcaf88bddc7f282722ec1fdddbcb06a72f18 Author: Jesse Brandeburg <jesse.brandeburg@intel.com> Date: Tue Apr 27 01:37:20 2010 +0000 ixgbe: enable extremely low latency introduced a feature where LRO (called RSC on the hardware) was disabled automatically when setting rx-usecs to 0 via ethtool. Some might not like the fact that LRO was disabled automatically, but I'm fine with that. What I don't like is that LRO/RSC is automatically enabled when rx-usecs is set >0 via ethtool. This would certainly be a problem if the device was used for forwarding and it was determined that the low latency wasn't needed after the device was already forwarding. I played around with saving the state of LRO in the driver, but it just didn't seem worthwhile and would require a small change to dev_disable_lro() that I did not like. This patch simply leaves LRO disabled when setting rx-usecs >0 and requires that the user enable it again. An extra informational message will also now appear in the log so users can understand why LRO isn't being enabled as they expect. Inconsistency of LRO setting first noticed by Stanislaw Gruszka. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> CC: Stanislaw Gruszka <sgruszka@redhat.com> CC: stable@kernel.org Tested-by: Stephen Ko <stephen.s.ko@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-13ixgbe: fix for race with 8259(8|9) during shutdownDon Skidmore
There is a small window where the watchdog could be running as the interface is brought down on a NIC with two ports wired back to back. If ixgbe_update_status is then called can lead to a panic. This patch allows the update to bail if we are in that condition. This issue was orignally reported and fix proposed by Akihiko Saitou. CC: Akihiko Saitou <asaitou@users.sourceforge.net> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04ixgbe: only check pfc bits in hang logic if pfc is enabledJohn Fastabend
Only check pfc bits in hang logic if PFC is enabled. Previously, if DCB was enabled but PFC was disabled the incorrect pause bits would be checked. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03ixgbe: return IXGBE_ERR_RAR_INDEX when out of rangeJeff Kirsher
Based on original patch from Shirley Ma <xma@us.ibm.com> Return IXGBE_ERR_RAR_INDEX when RAR index is out of range, instead of returning IXGBE_SUCCESS. CC: Shirley Ma <xma@us.ibm.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-20ixgbe:add support for a new 82599 10G Base-T deviceMallikarjuna R Chilakala
This adds support for a new copper device for 82599, device id 0x151c. This 82599 10GBase-T device uses the PHY's internal temperature sensor to guard against over-temp conditions. In this scenario the PHY will be put in a low power mode and link will no longer be able to transmit or receive any data. When this occurs, the over-temp interrupt is latched and driver logs this error message. A HW reset or power cycle is required to clear this status. Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18ixgbe: add support for active DA cablesDon Skidmore
This patch adds support of active DA cables. This is renaming and adding some PHY type enumerations. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18ixgbe: dcb, do not tag tc_prio_control framesJohn Fastabend
The network stack indicate packets should not be DCB tagged by setting the priority to TC_PRIO_CONTROL. One usage for this is lldp frames which are not suppossed to be tagged. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18ixgbe: fix ixgbe_tx_is_paused logicJohn Fastabend
The TFCS bits show the current XON state. Meaning that the device is paused if these bits are 0. This fixes the logic to work as it was intended. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18ixgbe: always enable vlan strip/insert when DCB is enabledYi Zou
when DCB mode is on, we want the HW VLAN stripping to be always enabled. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18ixgbe: remove some redundant code in setting FCoE FIP filterYi Zou
The ETQS setup for FIP out side the if..else is enough for the ETQS setup for FIP, so remove redundant code. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddpYi Zou
Make sure we point to the right offset of the fc_frame_header when VLAN header exists and HW has VLAN stripping disabled. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-18ixgbe: fix header len when unsplit packet overflows to data bufferShannon Nelson
When in packet split mode, packet type is not recognized, and the packet is larger than the header size, the 82599 overflows the packet into the data area, but doesn't set the HDR_LEN field. We can safely assume the length is the current header size. This fixes an obscure corner case that can be triggered by non-ip packet headers or (more likely) by disabling the L2 packet recognition. Signed-off-by: Shannon Nelson <shannon.nelson@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-13ixgbe: Refactor common code between 82598 & 82599 to accommodate new hardwareMallikarjuna R Chilakala
Some of the following MAC functions are moved from 82598 & 82599 specific hardware files to common.[ch] to accommodate new silicon changes. Also fixed some white space issues * get_san_mac_addr, check_link, set_vmdq, clear_vmdq, clear_vfta, * set_vfta, fc_enable, init_uta_tables Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-13ixgbe: Use bool flag to see if the packet unmapping is delayed in HWRSCMallikarjuna R Chilakala
We can't use zero magic "bad" value to check if IXGBE_RSC_CB(skb)->dma is valid. It is only valid in x86/arm/m68k/alpha architectures and in spark, powerPC and other architectures it should be ~0. As per Benjamin Herrenschmidt feedback use a bool flag to decide if the packet unmapping is delayed in hardware RSC till EOP is reached Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-13ixgbe: fix setting of promisc mode when using mac-vlansEmil Tantilov
Introduce uc_set_promisc flag to fix enabling of promisc mode when exceeding the number of supported RAR entries. Issue discovered by Ben Greear when using mac-vlans. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06ixgbe: Streamline MC filter setup for VFsGreg Rose
The driver was calling the set Rx mode function for every multicast filter set by the VF. When starting many VMs where each might have multiple VLAN interfaces this would result in the function being called hundreds or even thousands of times. This is unnecessary for the case of the imperfect filters used in the MTA and has been streamlined to be more efficient. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06ixgbe: Remove unneeded register writes in VF VLAN setupGreg Rose
The driver is unnecessarily writing values to VLAN control registers. These writes already done elsewhere and are superfluous here. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05ixgbe: Add support for VF MAC and VLAN configurationGreg Rose
Add support for the "ip link set" and "ip link show" commands that allow configuration of the virtual functions' MAC and port VLAN via user space command line. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05ixgbe: Add boolean parameter to ixgbe_set_vmolrGreg Rose
Add a boolean parameter to ixgbe-set_vmolr so that the caller can specify whether the pool should accept untagged packets. Required for a follow on patch to enable administrative configuration of port VLAN for virtual functions. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-03Revert "ixgbe: disable MSI-X by default on certain Cisco adapters"David S. Miller
This reverts commit d5ffd75a27fade39ba5df3b07290c5a2c297b9bd. As requested by Jeff Kircher. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: disable MSI-X by default on certain Cisco adaptersNicholas Nunley
Due to an errata in 82598 parts MSI-X needs to be disabled in certain ixgbe devices designed to transfer peer-to-peer traffic on the PCIe bus. This patch sets the default interrupt type to MSI rather than MSI-X for specific Cisco ixgbe adapters. Signed-off-by: Nicholas Nunley <nicholasx.d.nunley@intel.com> Acked-by: John Ronciak <john.ronciak@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: add registers etc. printout code just before resetting adaptersTaku Izumi
This patch adds registers (,tx/rx rings' status and so on) printout code just before resetting adapters. This will be helpful for detecting the root cause of adapters reset. Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com> Signed-off-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: use DMA API instead of PCI DMA functionsNick Nunley
Signed-off-by: Nicholas Nunley <nicholasx.d.nunley@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: Properly display 1 gig downshift warning for backplaneAnjali Singhai
Description: When using Intel smartspeed, the patch displays a warning when the link down shifts to 1 Gig. Signed-off-by: Anjali Singhai <anjali.singhai@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: cleanup ethtool autoneg inputDon Skidmore
The way we were setting autoneg via ethtool was inconstant with that of our other drivers. It will change the following: If autoneg is off: >ethtool -a eth0 Pause parameters for eth0: Autonegotiate: off RX: off TX: off Before: >ethtool -A eth0 autoneg on >ethtool -a eth0 Pause parameters for eth0: Autonegotiate: off RX: off TX: off Now: >ethtool -A eth0 autoneg on >ethtool -a eth0 Pause parameters for eth0: Autonegotiate: on RX: on TX: on Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: ixgbe_down needs to stop dev_watchdogJohn Fastabend
There is a small race between when the tx queues are stopped and when netif_carrier_off() is called in ixgbe_down. If the dev_watchdog() timer fires during this time it is possible for a false tx timeout to occur. This patch moves the netif_carrier_off() so that it is called before the tx queues are stopped preventing the dev_watchdog timer from detecting false tx timeouts. The race is seen occosionally when FCoE or DCB settings are being configured or changed. Testing note, running ifconfig up/down will not reproduce this issue because dev_open/dev_close call dev_deactivate() and then dev_activate(). Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: fix bug when EITR=0 causing no writebacksJesse Brandeburg
writebacks can be held indefinitely by hardware if EITR=0, when combined with TXDCTL.WTHRESH=8. When EITR=0, WTHRESH should be set back to zero. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgbe: enable extremely low latencyJesse Brandeburg
82598/82599 can support EITR == 0, which allows for the absolutely lowest latency setting in the hardware. This disables writeback batching and anything else that relies upon a delayed interrupt. This patch enables the feature of "override" when a user sets rx-usecs to zero, the driver will respect that setting over using RSC, and automatically disable RSC. If rx-usecs is used to set the EITR value to 0, then the driver should disable LRO (aka RSC) internally until EITR is set to non-zero again. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-27ixgbe: Power down PHY during driver resetsPeter Waskiewicz
The PHY laser is still on during driver init. It's allowing garbage to hit our FIFO, which eventually can cause the entire device to die. Power down the laser while setting up the device, and re-enable the laser before getting link. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14ixgbe: fix bug with vlan strip in promsic modeJesse Brandeburg
The ixgbe driver was setting up 82598 hardware correctly, so that when promiscuous mode was enabled hardware stripping was turned off. But on 82599 the logic to disable/enable hardware stripping is different, and the code was not updated correctly when the hardware vlan stripping was enabled as default. This change comprises the creation of two new helper functions and calling them from the right locations to disable and enable hardware stripping of vlan tags at appropriate times. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-27ixgbe: Do not run all Diagnostic offline tests when VFs are activeGreg Rose
When running the offline diagnostic tests check to see if any VFs are online. If so then only run the link test. This is necessary because the VFs running in guest VMs aren't aware of when the PF is taken offline for a diagnostic test. Also put a message to the system log telling the system administrator to take the VFs offline manually if (s)he wants to run a full diagnostic. Return 1 on each of the tests not run to alert the user of the condition. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: convert to use netdev_for_each_mc_addrJiri Pirko
Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: filter FIP frames into the FCoE offload queuesChris Leech
During FCF solicitation, the switch is supposed to pad the solicited advertisement out to the endpoints specified maximum FCoE frame size. That means that we need to receive FIP frames that are larger than the standard MTU. To make sure the receive queue is configured correctly, we should be filtering FIP traffic into the FCoE queues. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: Priority tag FIP framesRobert Love
Currently FIP (FCoE Initialization Protocol) frames are going untagged. This causes various problems with FCFs (switches) that have negotiated a priority over dcbx. This patch tags FIP frames with the same priority as the FCoE frames. Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: Don't allow user buffer count to exceed 256Robert Love
If the user buffer count was 256 the shift would place a 1 in the offset region leading to errors. It also overwrites the uers buffer list. This patch makes sure that at most 256 user buffers are allowed for DDP and the buffer count is masked properly such that it doesn't overwrite the offset when shifting the bits. Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Frank Zhang <frank_1.zhang@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: cleanup maximum number of tx queuesJohn Fastabend
In the last patch I missed an unecessary min_t comparison. This patch removes it, the path allocates at most 72 tx queues for 82599 and 24 for 82598 there is no need for this check. Additionally this sets MAX_[TX|RX]_QUEUES to 72. Which is used as the size for the tx/rx_ring arrays. There is no reason to have more tx_rings/rx_rings then num_tx_queues. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: Change where clear_to_send_flag is reset to zero.Greg Rose
The clear_to_send flag is being cleared before the call to ping all the VFs. It should be called after pinging all the VFs. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
