path: root/drivers/net/jazzsonic.c
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-15Jazzsonic: Fix warning about unused variable.Ralf Baechle
Caused by "[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()" aka 0795af5729b18218767fab27c44b1384f72dc9ad. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10remove setup of platform device from jazzsonic.cThomas Bogendoerfer
remove setup platform device from jazzsonic, which is done in arch code now Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-04SONIC interrupt handlingFinn Thain
Install the built-in macsonic interrupt handler on both IRQs when using via_alt_mapping. Otherwise the rare interrupt that still comes from the nubus slot will wedge the nubus. $ cat /proc/interrupts auto 2: 89176 via2 auto 3: 744367 sonic auto 4: 0 scc auto 6: 318363 via1 auto 7: 0 NMI mac 9: 119413 framebuffer vbl mac 10: 1971 ADB mac 14: 198517 timer mac 17: 89104 nubus mac 19: 72 Mac ESP SCSI mac 56: 629 sonic mac 62: 1142593 ide0 Version 1 of this patch had a bug where a nubus sonic card would register two interrupt handlers. Only a built-in sonic needs both. Versions 2 and 3 needed some cleanups, as Raylynn Knight and Christoph Hellwig pointed out (thanks). Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04SONIC: small fix and cleanupFinn Thain
Fix a potential problem in the timeout handling: don't free the DMA buffers before resetting the chip. Also a trivial cleanup. Bring macsonic and jazzsonic into sync. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-01[PATCH] jazzsonic: Fix platform device codeRalf Baechle
Use platform_driver_unregister not driver_unregister to unregister a struct platform_driver. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-12-01[PATCH] jazzsonic: Fix build error.Ralf Baechle
jazz_sonnic_device -> jazz_sonic_device Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-09[DRIVER MODEL] Convert platform drivers to use struct platform_driverRussell King
This allows us to eliminate the casts in the drivers, and eventually remove the use of the device_driver function pointer methods for platform device drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-05[DRIVER MODEL] Fix jazzsonicRussell King
Release code in driver modules is a potential cause of oopsen. The device may be in use by a userspace process, which will keep a reference to the device. If the module is unloaded, the module text will be freed. Subsequently, when the last reference is dropped, the release code will be called, which no longer exists. Use generic platform device allocation/release code in modules. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-23[PATCH] macsonic/jazzsonic network drivers updateFinn Thain
The purpose of this patch: - Adopt the DMA API (jazzsonic, macsonic & core driver). - Adopt the driver model (macsonic). This part was cribbed from jazzsonic. As a consequence, macsonic once again works as a module. Driver model is also used by the DMA calls. - Support 16 bit cards (macsonic & core driver, also affects jazzsonic) This code was adapted from the mac68k linux 2.2 kernel, where it has languished for a long time. - Support more 32-bit mac cards (macsonic) Also from mac68k repo. - Zero-copy buffer handling (core driver) Provides a nice performance improvement. The new algorithm incidentally helped to replace the old Jazz DMA code. The patch was tested on a variety of macs (several 32-bit quadra built-in NICs, a 16-bit LC PDS NIC and a 16-bit comm-slot NIC), and also on MIPS Jazz. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
