path: root/drivers/net/macvlan.c
2011-03-21macvlan: Fix use after free of struct macvlan_port.Eric W. Biederman
When the macvlan driver was extended to call unregisgter_netdevice_queue in 23289a37e2b127dfc4de1313fba15bb4c9f0cd5b, a use after free of struct macvlan_port was introduced. The code in dellink relied on unregister_netdevice actually unregistering the net device so it would be safe to free macvlan_port. Since unregister_netdevice_queue can just queue up the unregister instead of performing the unregiser immediately we free the macvlan_port too soon and then the code in macvlan_stop removes the macaddress for the set of macaddress to listen for and uses memory that has already been freed. To fix this add a reference count to track when it is safe to free the macvlan_port and move the call of macvlan_port_destroy into macvlan_uninit which is guaranteed to be called after the final macvlan_port_close. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-16net: introduce rx_handler results and logic around thatJiri Pirko
This patch allows rx_handlers to better signalize what to do next to it's caller. That makes skb->deliver_no_wcard no longer needed. kernel-doc for rx_handler_result is taken from Nicolas' patch. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14macvlan : fix checksums error when we are in bridge modeDaniel Lezcano
When the lower device has offloading capabilities, the packets checksums are not computed. That leads to have any macvlan port in bridge mode to not work because the packets are dropped due to a bad checksum. If the macvlan is in bridge mode, the packet is forwarded to another macvlan port and reach the network stack where it looks for a checksum but this one was not computed due to the offloading of the lower device. In this case, we have to set the packet with CHECKSUM_UNNECESSARY when it is forwarded to a bridged port and restore the previous value of ip_summed when the packet goes to the lowerdev. Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Patrick McHardy <kaber@trash.net> Cc: Andrian Nord <nightnord@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22macvlan: Introduce 'passthru' mode to takeover the underlying deviceSridhar Samudrala
With the current default 'vepa' mode, a KVM guest using virtio with macvtap backend has the following limitations. - cannot change/add a mac address on the guest virtio-net - cannot create a vlan device on the guest virtio-net - cannot enable promiscuous mode on guest virtio-net To address these limitations, this patch introduces a new mode called 'passthru' when creating a macvlan device which allows takeover of the underlying device and passing it to a guest using virtio with macvtap backend. Only one macvlan device is allowed in passthru mode and it inherits the mac address from the underlying device and sets it in promiscuous mode to receive and forward all the packets. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> ------------------------------------------------------------------------- Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-16macvlan: lockless tx pathEric Dumazet
macvlan is a stacked device, like tunnels. We should use the lockless mechanism we are using in tunnels and loopback. This patch completely removes locking in TX path. tx stat counters are added into existing percpu stat structure, renamed from rx_stats to pcpu_stats. Note : this reverts commit 2c11455321f37 (macvlan: add multiqueue capability) Note : rx_errors converted to a 32bit counter, like tx_dropped, since they dont need 64bit range. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Ben Greear <greearb@candelatech.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-17netns: keep vlan slaves on master netns moveDavid Lamparter
previously, if a vlan master device was moved from one network namespace to another, all 802.1q and macvlan slaves were deleted. we can use dev->reg_state to figure out whether dev_change_net_namespace is happening, since that won't set dev->reg_state NETREG_UNREGISTERING. so, this changes 8021q and macvlan to ignore NETDEV_UNREGISTER when reg_state is not NETREG_UNREGISTERING. Signed-off-by: David Lamparter <equinox@diac24.net> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-27macvlan: Fix rx counters update in macvlan_handle_frame()Sridhar Samudrala
Fix macvlan_handle_frame() to update the rx counters based on the return value of the vlan->receive call. Updated the patch to not do any packet count drops when the interface is down based on Herber'ts comments. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x_main.c Merge bnx2x bug fixes in by hand... :-/ Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-22macvtap: Limit packet queue lengthHerbert Xu
Mark Wagner reported OOM symptoms when sending UDP traffic over a macvtap link to a kvm receiver. This appears to be caused by the fact that macvtap packet queues are unlimited in length. This means that if the receiver can't keep up with the rate of flow, then we will hit OOM. Of course it gets worse if the OOM killer then decides to kill the receiver. This patch imposes a cap on the packet queue length, in the same way as the tuntap driver, using the device TX queue length. Please note that macvtap currently has no way of giving congestion notification, that means the software device TX queue cannot be used and packets will always be dropped once the macvtap driver queue fills up. This shouldn't be a great problem for the scenario where macvtap is used to feed a kvm receiver, as the traffic is most likely external in origin so congestion notification can't be applied anyway. Of course, if anybody decides to complain about guest-to-guest UDP packet loss down the track, then we may have to revisit this. Incidentally, this patch also fixes a real memory leak when macvtap_get_queue fails. Chris Wright noticed that for this patch to work, we need a non-zero TX queue length. This patch includes his work to change the default macvtap TX queue length to 500. Reported-by: Mark Wagner <mwagner@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-09net: Get rid of rtnl_link_stats64 / net_device_stats unionBen Hutchings
In commit be1f3c2c027cc5ad735df6a45a542ed1db7ec48b "net: Enable 64-bit net device statistics on 32-bit architectures" I redefined struct net_device_stats so that it could be used in a union with struct rtnl_link_stats64, avoiding the need for explicit copying or conversion between the two. However, this is unsafe because there is no locking required and no lock consistently held around calls to dev_get_stats() and use of the statistics structure it returns. In commit 28172739f0a276eb8d6ca917b3974c2edb036da3 "net: fix 64 bit counters on 32 bit arches" Eric Dumazet dealt with that problem by requiring callers of dev_get_stats() to provide storage for the result. This means that the net_device::stats64 field and the padding in struct net_device_stats are now redundant, so remove them. Update the comment on net_device_ops::ndo_get_stats64 to reflect its new usage. Change dev_txq_stats_fold() to use struct rtnl_link_stats64, since that is what all its callers are really using and it is no longer going to be compatible with struct net_device_stats. Eric Dumazet suggested the separate function for the structure conversion. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07net: fix 64 bit counters on 32 bit archesEric Dumazet
There is a small possibility that a reader gets incorrect values on 32 bit arches. SNMP applications could catch incorrect counters when a 32bit high part is changed by another stats consumer/provider. One way to solve this is to add a rtnl_link_stats64 param to all ndo_get_stats64() methods, and also add such a parameter to dev_get_stats(). Rule is that we are not allowed to use dev->stats64 as a temporary storage for 64bit stats, but a caller provided area (usually on stack) Old drivers (only providing get_stats() method) need no changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-28macvlan: 64 bit rx countersEric Dumazet
Use u64_stats_sync infrastructure to implement 64bit stats. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15macvlan: use rx_handler_data pointer to store macvlan_port pointer V2Jiri Pirko
Register macvlan_port pointer as rx_handler data pointer. As macvlan_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a macvlan port. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-15net: add rx_handler data pointerJiri Pirko
Add possibility to register rx_handler data pointer along with a rx_handler. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-07macvlan: use call_rcu for port freeJiri Pirko
Use call_rcu rather than synchronize_rcu. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02net: replace hooks in __netif_receive_skb V5Jiri Pirko
What this patch does is it removes two receive frame hooks (for bridge and for macvlan) from __netif_receive_skb. These are replaced them with a single hook for both. It only supports one hook per device because it makes no sense to do bridging and macvlan on the same device. Then a network driver (of virtual netdev like macvlan or bridge) can register an rx_handler for needed net device. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-24macvlan: do proper cleanup in macvlan_common_newlink() V2Jiri Pirko
Fixes possible memory leak. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-16net: congestion notifications are not dropped packetsEric Dumazet
vlan/macvlan start_xmit() can inform caller of congestion with NET_XMIT_CN return value. This doesnt mean packet was dropped. Increment normal stat counters instead of tx_dropped. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-15net: adjust handle_macvlan to pass port struct to hookJiri Pirko
Now there's null check here and also again in the hook. Looking at bridge bits which are simmilar, port structure is rcu_dereferenced right away in handle_bridge and passed to hook. Looks nicer. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: move address list functions to a separate fileJiri Pirko
+little renaming of unicast functions to be smooth with multicast ones Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18net: forbid underlaying devices to change its typeJiri Pirko
It's not desired for underlaying devices to change type. At the time, there is for example possible to have bond with changed type from Ethernet to Infiniband as a port of a bridge. This patch fixes this. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03macvlan: allow multiple driver backendsArnd Bergmann
This makes it possible to hook into the macvlan driver from another kernel module. In particular, the goal is to extend it with the macvtap backend that provides a tun/tap compatible interface directly on the macvlan device. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03net: maintain namespace isolation between vlan and real deviceArnd Bergmann
In the vlan and macvlan drivers, the start_xmit function forwards data to the dev_queue_xmit function for another device, which may potentially belong to a different namespace. To make sure that classification stays within a single namespace, this resets the potentially critical fields. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16macvlan: add GRO bit to features maskPatrick Mullaney
Allow macvlan devices to support GRO. Signed-off-by: Patrick Mullaney <pmullaney@novell.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03netdevice: provide common routine for macvlan and vlan operstate managementPatrick Mullaney
Provide common routine for the transition of operational state for a leaf device during a root device transition. Signed-off-by: Patrick Mullaney <pmullaney@novell.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-26macvlan: export macvlan mode through netlinkArnd Bergmann
In order to support all three modes of macvlan at runtime, extend the existing netlink protocol to allow choosing the mode per macvlan slave interface. This depends on a matching patch to iproute2 in order to become accessible in user land. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26macvlan: implement bridge, VEPA and private modeArnd Bergmann
This allows each macvlan slave device to be in one of three modes, depending on the use case: MACVLAN_PRIVATE: The device never communicates with any other device on the same upper_dev. This even includes frames coming back from a reflective relay, where supported by the adjacent bridge. MACVLAN_VEPA: The new Virtual Ethernet Port Aggregator (VEPA) mode, we assume that the adjacent bridge returns all frames where both source and destination are local to the macvlan port, i.e. the bridge is set up as a reflective relay. Broadcast frames coming in from the upper_dev get flooded to all macvlan interfaces in VEPA mode. We never deliver any frames locally. MACVLAN_BRIDGE: We provide the behavior of a simple bridge between different macvlan interfaces on the same port. Frames from one interface to another one get delivered directly and are not sent out externally. Broadcast frames get flooded to all other bridge ports and to the external interface, but when they come back from a reflective relay, we don't deliver them again. Since we know all the MAC addresses, the macvlan bridge mode does not require learning or STP like the bridge module does. Based on an earlier patch "macvlan: Reflect macvlan packets meant for other macvlan devices" by Eric Biederman. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Cc: Eric Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-26macvlan: cleanup rx statisticsArnd Bergmann
We have very similar code for rx statistics in two places in the macvlan driver, with a third one being added in the next patch. Consolidate them into one function to improve overall readability of the driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-23macvlan: fix gso_max_size settingPatrick McHardy
gso_max_size must be set based on the value of the underlying device to support devices not using the full 64k. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17macvlan: Precise RX stats accountingEric Dumazet
With multi queue devices, its possible that several cpus call macvlan RX routines simultaneously for the same macvlan device. We update RX stats counter without any locking, so we can get slightly wrong counters. One possible fix is to use percpu counters, to get precise accounting and also get guarantee of no cache line ping pongs between cpus. Note: this adds 16 bytes (32 bytes on 64bit arches) of percpu data per macvlan device. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13vlan/macvlan: propagate transmission state to upper layersPatrick McHardy
Both vlan and macvlan devices usually don't use a qdisc and immediately queue packets to the underlying device. Propagate transmission state of the underlying device to the upper layers so they can react on congestion and/or inform the sending process. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08net: Support specifying the network namespace upon device creation.Eric W. Biederman
There is no good reason to not support userspace specifying the network namespace during device creation, and it makes it easier to create a network device and pass it to a child network namespace with a well known name. We have to be careful to ensure that the target network namespace for the new device exists through the life of the call. To keep that logic clear I have factored out the network namespace grabbing logic into rtnl_link_get_net. In addtion we need to continue to pass the source network namespace to the rtnl_link_ops.newlink method so that we can find the base device source network namespace. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com>
2009-10-28net: add a list_head parameter to dellink() methodEric Dumazet
Adding a list_head parameter to rtnl_link_ops->dellink() methods allow us to queue devices on a list, in order to dismantle them all at once. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-03macvlan: add multiqueue capabilityEric Dumazet
macvlan devices are currently not multi-queue capable. We can do that defining rtnl_link_ops method, get_tx_queues(), called from rtnl_create_link() This new method gets num_tx_queues/real_num_tx_queues from lower device. macvlan_get_tx_queues() is a copy of vlan_get_tx_queues(). Because macvlan_start_xmit() has to update netdev_queue stats only (and not dev->stats), I chose to change tx_errors/tx_aborted_errors accounting to tx_dropped, since netdev_queue structure doesnt define tx_errors / tx_aborted_errors. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01macvlan: Use compare_ether_addr_64bits()Eric Dumazet
To speedup ether addresses compares, we can use compare_ether_addr_64bits() (all operands are guaranteed to be at least 8 bytes long) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert pseudo drivers to netdev_tx_tStephen Hemminger
These are all drivers that don't touch real hardware. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-11drivers/net/macvlan.c: fix cloning of tagged VLAN interfacessg.tweak@gmail.com
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13348 akpm: the reporter disappeared, so I typed it in again. It is not possible to make clone of tagged VLAN interface to be used as mac-based vlan interfave. How reproducible: Use any 802.1q tagged vlan interface, e.g. eth2.700 and clone it: ip link add link eth2.700 address 00:04:75:cb:38:09 macvlan0 type macvlan ip link set dev macvlan0 up ip addr add 10.195.1.1/24 dev macvlan0 So far, so good. Now try to ping anything via macvlan0: ping 10.195.1.2 Actual results: For every attempted packet tx kernel writes to console: ------------[ cut here ]------------ WARNING: at net/8021q/vlan_dev.c:254 vlan_dev_hard_header+0x36/0x126 [8021q]() Hardware name: M22ES Modules linked in: arptable_filter arp_tables bridge veth macvlan arc4 ecb ppp_mppe ppp_async crc_ccitt ppp_generic slhc autofs4 sunrpc 8021q garp stp ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 xt_state nf_conntrack xt_tcpudp x_tables dm_mirror dm_region_hash dm_log dm_multipath dm_mod sbs sbshc lp floppy snd_intel8x0 joydev snd_seq_dummy snd_intel8x0m snd_ac97_codec ide_cd_mod ac97_bus snd_seq_oss cdrom snd_seq_midi_event serio_raw snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss parport_pc snd_pcm parport battery 8139cp snd_timer i2c_sis96x ac button snd rtc_cmos rtc_core 8139too soundcore rtc_lib mii i2c_core pcspkr snd_page_alloc pata_sis libata sd_mod scsi_mod ext3 jbd ehci_hcd ohci_hcd uhci_hcd [last unloaded: ip_tables] Pid: 0, comm: swapper Tainted: G W 2.6.29.3 #1 Call Trace: [<c0425f48>] warn_slowpath+0x60/0x9f [<c0425f6f>] warn_slowpath+0x87/0x9f [<dffb850d>] vlan_dev_hard_header+0x0/0x126 [8021q] [<dffb8543>] vlan_dev_hard_header+0x36/0x126 [8021q] [<dffb850d>] vlan_dev_hard_header+0x0/0x126 [8021q] [<df83155d>] macvlan_hard_header+0x3c/0x47 [macvlan] [<df831521>] macvlan_hard_header+0x0/0x47 [macvlan] [<c062bf3f>] arp_create+0xef/0x1ff [<c062c08c>] arp_send+0x3d/0x54 [<c062c916>] arp_solicit+0x16c/0x177 [<c05fadd2>] neigh_timer_handler+0x227/0x269 [<c05fabab>] neigh_timer_handler+0x0/0x269 [<c042ce4d>] run_timer_softirq+0xf0/0x141 [<c0429e5a>] __do_softirq+0x76/0xf8 [<c0429de4>] __do_softirq+0x0/0xf8 <IRQ> [<c044fb67>] handle_level_irq+0x0/0xad [<c0429db7>] irq_exit+0x35/0x62 [<c04046bb>] do_IRQ+0xdf/0xf4 [<c04035a7>] common_interrupt+0x27/0x2c [<c04079c5>] default_idle+0x2a/0x3d [<c0401bb6>] cpu_idle+0x57/0x70 Macvlan driver always uses standard ethernet header length for all types of interface to which it is linked. This patch fixes this problem. Reported-by: <sg.tweak@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18net: release dst entry in dev_hard_start_xmit()Eric Dumazet
One point of contention in high network loads is the dst_release() performed when a transmited skb is freed. This is because NIC tx completion calls dev_kree_skb() long after original call to dev_queue_xmit(skb). CPU cache is cold and the atomic op in dst_release() stalls. On SMP, this is quite visible if one CPU is 100% handling softirqs for a network device, since dst_clone() is done by other cpus, involving cache line ping pongs. It seems right place to release dst is in dev_hard_start_xmit(), for most devices but ones that are virtual, and some exceptions. David Miller suggested to define a new device flag, set in alloc_netdev_mq() (so that most devices set it at init time), and carefuly unset in devices which dont want a NULL skb->dst in their ndo_start_xmit(). List of devices that must clear this flag is : - loopback device, because it calls netif_rx() and quoting Patrick : "ip_route_input() doesn't accept loopback addresses, so loopback packets already need to have a dst_entry attached." - appletalk/ipddp.c : needs skb->dst in its xmit function - And all devices that call again dev_queue_xmit() from their xmit function (as some classifiers need skb->dst) : bonding, vlan, macvlan, eql, ifb, hdlc_fr Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21net: factor out ethtool invocation of vlan/macvlan driversPatrick McHardy
2009-04-17vlan/macvlan: fix NULL pointer dereferences in ethtool handlersPatrick McHardy
Check whether the underlying device provides a set of ethtool ops before checking for individual handlers to avoid NULL pointer dereferences. Reported-by: Art van Breemen <ard@telegraafnet.nl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13macvlan: Deterministic ingress packet deliveryEric Biederman
Changing the mac address when a macvlan device is up will leave the device on the wrong hash chain making it impossible to receive packets. There is no checking of the mac address set on the macvlan. Allowing a misconfiguration to grab packets from the the underlying device or another macvlan. To resolve these problems I update the hash table of macvlans when the mac address of a macvlan changes, and when updating the hash table I verify that the new mac address is usable. The result is well defined and predictable if not perfect handling of mac vlan mac addresses. To keep the code clear I have created a set of hash table maintenance in macvlan so I am not open coding the hash function and the logic needed to update the hash table all over the place. Signed-off-by: Eric Biederman <ebiederm@aristanetworks.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13macvlan: Support creating macvlans from macvlansEric Biederman
When running in a network namespace whose only link to the outside world is a macvlan device, not being able to create another macvlan is a real pain. So modify macvlan creation to allow automatically forward a creation of a macvlan on a macvlan to become a creation of a macvlan on the underlying network device. Signed-off-by: Eric Biederman <ebiederm@aristanetworks.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c drivers/net/smc91x.c
2008-11-26macvlan: don't broadcast PAUSE frames to macvlan devicesPatrick McHardy
PAUSE frames are only relevant for the real device, broadcasting them to all macvlan devices can cause a significant load increase. Reported-by: Ben Greear <greearb@candelatech.com> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19macvlan: convert to net_device_opsStephen Hemminger
Convert to net_device_ops function table. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29macvlan: add support for ethtool get settingsStephen Hemminger
If macvlan's are used, it is useful to propgate speed and other settings from underlying device up for application usage. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
