commit be0bd3160165e42783d8215f426e41c07179c08a upstream.
If GSO packet is segmented and its segments are properly queued,
we call consume_skb() instead of kfree_skb() to be drop monitor
friendly.
Fixes: 3e4f8b7873709 ("macvtap: Perform GSO on forwarding path.")
Cc: Vlad Yasevich <vyasevic@redhat.com>
Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
[ Upstream commit 93161922c658c714715686cd0cf69b090cb9bf1d ]
Syzkaller found several variants of the lockup below by setting negative
values with the TUNSETSNDBUF ioctl. This patch adds a sanity check
to both the tun and tap versions of this ioctl.
watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [repro:2389]
Modules linked in:
irq event stamp: 329692056
hardirqs last enabled at (329692055): [<ffffffff824b8381>] _raw_spin_unlock_irqrestore+0x31/0x75
hardirqs last disabled at (329692056): [<ffffffff824b9e58>] apic_timer_interrupt+0x98/0xb0
softirqs last enabled at (35659740): [<ffffffff824bc958>] __do_softirq+0x328/0x48c
softirqs last disabled at (35659731): [<ffffffff811c796c>] irq_exit+0xbc/0xd0
CPU: 0 PID: 2389 Comm: repro Not tainted 4.14.0-rc7 #23
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff880009452140 task.stack: ffff880006a20000
RIP: 0010:_raw_spin_lock_irqsave+0x11/0x80
RSP: 0018:ffff880006a27c50 EFLAGS: 00000282 ORIG_RAX: ffffffffffffff10
RAX: ffff880009ac68d0 RBX: ffff880006a27ce0 RCX: 0000000000000000
RDX: 0000000000000001 RSI: ffff880006a27ce0 RDI: ffff880009ac6900
RBP: ffff880006a27c60 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 000000000063ff00 R12: ffff880009ac6900
R13: ffff880006a27cf8 R14: 0000000000000001 R15: ffff880006a27cf8
FS: 00007f4be4838700(0000) GS:ffff88000cc00000(0000) knlGS:0000000000000000
CR2: 0000000020101000 CR3: 0000000009616000 CR4: 00000000000006f0
Call Trace:
prepare_to_wait+0x26/0xc0
sock_alloc_send_pskb+0x14e/0x270
? remove_wait_queue+0x60/0x60
tun_get_user+0x2cc/0x19d0
? __tun_get+0x60/0x1b0
tun_chr_write_iter+0x57/0x86
__vfs_write+0x156/0x1e0
vfs_write+0xf7/0x230
SyS_write+0x57/0xd0
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x7f4be4356df9
RSP: 002b:00007ffc18101c08 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f4be4356df9
RDX: 0000000000000046 RSI: 0000000020101000 RDI: 0000000000000005
RBP: 00007ffc18101c40 R08: 0000000000000001 R09: 0000000000000001
R10: 0000000000000001 R11: 0000000000000293 R12: 0000559c75f64780
R13: 00007ffc18101d30 R14: 0000000000000000 R15: 0000000000000000
Fixes: 33dccbb050bb ("tun: Limit amount of queued packets per device")
Fixes: 20d29d7a916a ("net: macvtap driver")
Signed-off-by: Craig Gallek <kraig@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 837585a5375c38d40361cfe64e6fd11e1addb936 ]
When IFF_VNET_HDR is enabled, a virtio_net header must precede data.
Data length is verified to be greater than or equal to expected header
length tun->vnet_hdr_sz before copying.
Macvtap functions read the value once, but unless READ_ONCE is used,
the compiler may ignore this and read multiple times. Enforce a single
read and locally cached value to avoid updates between test and use.
Signed-off-by: Willem de Bruijn <willemb@google.com>
Suggested-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 8e2ad4113ce4671686740f808ff2795395c39eef ]
The stack expects link layer headers in the skb linear section.
Macvtap can create skbs with llheader in frags in edge cases:
when (IFF_VNET_HDR is off or vnet_hdr.hdr_len < ETH_HLEN) and
prepad + len > PAGE_SIZE and vnet_hdr.flags has no or bad csum.
Add checks to ensure linear is always at least ETH_HLEN.
At this point, len is already ensured to be >= ETH_HLEN.
For backwards compatiblity, rounds up short vnet_hdr.hdr_len.
This differs from tap and packet, which return an error.
Fixes b9fb9ee07e67 ("macvtap: add GSO/csum offload support")
This patch is a cleanup to make following patch easier to
review.
Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA
from (struct socket)->flags to a (struct socket_wq)->flags
to benefit from RCU protection in sock_wake_async()
To ease backports, we rename both constants.
Two new helpers, sk_set_bit(int nr, struct sock *sk)
and sk_clear_bit(int net, struct sock *sk) are added so that
following patch can change their implementation.
macvtap_do_read code calls macvtap_put_user while it might be set up
to wait for the user. This results in the following warning:
Jun 23 16:25:26 galen kernel: ------------[ cut here ]------------
Jun 23 16:25:26 galen kernel: WARNING: CPU: 0 PID: 30433 at kernel/sched/core.c:
7286 __might_sleep+0x7f/0x90()
Jun 23 16:25:26 galen kernel: do not call blocking ops when !TASK_RUNNING; state
=1 set at [<ffffffff810f1c1f>] prepare_to_wait+0x2f/0x90
Jun 23 16:25:26 galen kernel: CPU: 0 PID: 30433 Comm: cat Not tainted 4.1.0-rc6+
#11
Jun 23 16:25:26 galen kernel: Call Trace:
Jun 23 16:25:26 galen kernel: [<ffffffff817f76ba>] dump_stack+0x4c/0x65
Jun 23 16:25:26 galen kernel: [<ffffffff810a07ca>] warn_slowpath_common+0x8a/0xc
0
Jun 23 16:25:26 galen kernel: [<ffffffff810a0846>] warn_slowpath_fmt+0x46/0x50
Jun 23 16:25:26 galen kernel: [<ffffffff810f1c1f>] ? prepare_to_wait+0x2f/0x90
Jun 23 16:25:26 galen kernel: [<ffffffff810cdc1f>] __might_sleep+0x7f/0x90
Jun 23 16:25:26 galen kernel: [<ffffffff811f8e15>] might_fault+0x55/0xb0
Jun 23 16:25:26 galen kernel: [<ffffffff810fab9d>] ? trace_hardirqs_on_caller+0x fd/0x1c0
Jun 23 16:25:26 galen kernel: [<ffffffff813f639c>] copy_to_iter+0x7c/0x360
Jun 23 16:25:26 galen kernel: [<ffffffffa052da86>] macvtap_do_read+0x256/0x3d0 [macvtap]
Jun 23 16:25:26 galen kernel: [<ffffffff810f20e0>] ? prepare_to_wait_event+0x110/0x110
Jun 23 16:25:26 galen kernel: [<ffffffffa052dcab>] macvtap_read_iter+0x2b/0x50 [macvtap]
Jun 23 16:25:26 galen kernel: [<ffffffff81247f2e>] __vfs_read+0xae/0xe0
Jun 23 16:25:26 galen kernel: [<ffffffff81248526>] vfs_read+0x86/0x140
Jun 23 16:25:26 galen kernel: [<ffffffff812493b9>] SyS_read+0x49/0xb0
Jun 23 16:25:26 galen kernel: [<ffffffff8180182e>] system_call_fastpath+0x12/0x76
Jun 23 16:25:26 galen kernel: ---[ end trace 22e33f67e70c0c2a ]---
Make sure thet we call finish_wait() if we have the skb to process
before trying to actually process it.
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
We don't have fraglist support in TAP_FEATURES. This will lead
software segmentation of gro skb with frag list. Fixes by having
frag list support in TAP_FEATURES.
With this patch single session of netperf receiving were restored from
about 5Gb/s to about 12Gb/s on mlx4.
Fixes a567dd6252 ("macvtap: simplify usage of tap_features")
Cc: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Upon TUNSETSNDBUF, macvtap reads the requested sndbuf size into
a local variable u.
commit 39ec7de7092b ("macvtap: fix uninitialized access on
TUNSETIFF") changed its type to u16 (which is the right thing to
do for all other macvtap ioctls), breaking all values > 64k.
The value of TUNSETSNDBUF is actually a signed 32 bit integer, so
the right thing to do is to read it into an int.
Fixes: 39ec7de7092b ("macvtap: fix uninitialized access on TUNSETIFF")
Reported-by: Mark A. Peloquin
Bisected-by: Matthew Rosato <mjrosato@linux.vnet.ibm.com>
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Matthew Rosato <mjrosato@linux.vnet.ibm.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
Network header is set with offset ETH_HLEN but it is not true for VLAN
(multiple-)tagged and results in checksum issues in lower devices.
v2: leave skb->protocol untouched (thx Vlad), comment added
v3: moved after skb_probe_transport_header() call (thx Toshiaki)
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
Pull networking fixes from David Miller:
1) Missing list head init in bluetooth hidp session creation, from Tedd
Ho-Jeong An.
2) Don't leak SKB in bridge netfilter error paths, from Florian
Westphal.
3) ipv6 netdevice private leak in netfilter bridging, fixed by Julien
Grall.
4) Fix regression in IP over hamradio bpq encapsulation, from Ralf
Baechle.
5) Fix race between rhashtable resize events and table walks, from Phil
Sutter.
6) Missing validation of IFLA_VF_INFO netlink attributes, fix from
Daniel Borkmann.
7) Missing security layer socket state initialization in tipc code,
from Stephen Smalley.
8) Fix shared IRQ handling in boomerang 3c59x interrupt handler, from
Denys Vlasenko.
9) Missing minor_idr destroy on module unload on macvtap driver, from
Johannes Thumshirn.
10) Various pktgen kernel thread races, from Oleg Nesterov.
11) Fix races that can cause packets to be processed in the backlog even
after a device attached to that SKB has been fully unregistered.
From Julian Anastasov.
12) bcmgenet driver doesn't account packet drops vs. errors properly,
fix from Petri Gynther.
13) Array index validation and off by one fix in DSA layer from Florian
Fainelli
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (66 commits)
can: replace timestamp as unique skb attribute
ARM: dts: dra7x-evm: Prevent glitch on DCAN1 pinmux
can: c_can: Fix default pinmux glitch at init
can: rcar_can: unify error messages
can: rcar_can: print request_irq() error code
can: rcar_can: fix typo in error message
can: rcar_can: print signed IRQ #
can: rcar_can: fix IRQ check
net: dsa: Fix off-by-one in switch address parsing
net: dsa: Test array index before use
net: switchdev: don't abort unsupported operations
net: bcmgenet: fix accounting of packet drops vs errors
cdc_ncm: update specs URL
Doc: z8530book: Fix typo in API-z8530-sync-txdma-open.html
net: inet_diag: always export IPV6_V6ONLY sockopt for listening sockets
bridge: mdb: allow the user to delete mdb entry if there's a querier
net: call rcu_read_lock early in process_backlog
net: do not process device backlog during unregistration
bridge: fix potential crash in __netdev_pick_tx()
net: axienet: Fix devm_ioremap_resource return value check
Destroy minor_idr on module_exit, reclaiming the allocated memory.
This was detected by the following semantic patch (written by Luis Rodriguez
<mcgrof@suse.com>)
<SmPL>
@ defines_module_init @
declarer name module_init, module_exit;
declarer name DEFINE_IDR;
identifier init;
module_init(init);
@ defines_module_exit @
identifier exit;
module_exit(exit);
@ declares_idr depends on defines_module_init && defines_module_exit @
identifier idr;
DEFINE_IDR(idr);
@ on_exit_calls_destroy depends on declares_idr && defines_module_exit @
identifier declares_idr.idr, defines_module_exit.exit;
exit(void)
idr_destroy(&idr);
@ missing_module_idr_destroy depends on declares_idr && defines_module_exit && !on_exit_calls_destroy @
exit(void)
+idr_destroy(&idr);
</SmPL>
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Pull virtio/vhost cross endian support from Michael Tsirkin:
"I have just queued some more bugfix patches today but none fix
regressions and none are related to these ones, so it looks like a
good time for a merge for -rc1.
The motivation for this is support for legacy BE guests on the new LE
hosts. There are two redeeming properties that made me merge this:
- It's a trivial amount of code: since we wrap host/guest accesses
anyway, almost all of it is well hidden from drivers.
- Sane platforms would never set flags like VHOST_CROSS_ENDIAN_LEGACY,
and when it's clear, there's zero overhead (as some point it was
tested by compiling with and without the patches, got the same
stripped binary).
Maybe we could create a Kconfig symbol to enforce the second point:
prevent people from enabling it eg on x86. I will look into this"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
virtio-pci: alloc only resources actually used.
macvtap/tun: cross-endian support for little-endian hosts
vhost: cross-endian support for legacy devices
virtio: add explicit big-endian support to memory accessors
vhost: introduce vhost_is_little_endian() helper
vringh: introduce vringh_is_little_endian() helper
macvtap: introduce macvtap_is_little_endian() helper
tun: add tun_is_little_endian() helper
virtio: introduce virtio_is_little_endian() helper
Macvtap should be compatible with tuntap for
maximum number of queues.
commit 'baf71c5c1f80d82e92924050a60b5baaf97e3094 (tuntap:
Increase the number of queues in tun.)' removes
the limitations and increases number of queues in tuntap.
Now, Its safe to increase number of queues in Macvtap as well.
This patch also modifies 'macvtap_del_queues' function
to avoid extra memory allocation in stack.
Changes from v1->v2 :
Michael S. Tsirkin, Jason Wang :
Better way to use linked list to
avoid use of extra memory in stack.
Sergei Shtylyov : Specify dependent commit's summary.
Signed-off-by: Pankaj Gupta <pagupta@redhat.com>
The VNET_LE flag was introduced to fix accesses to virtio 1.0 headers
that are always little-endian. It can also be used to handle the special
case of a legacy little-endian device implemented by a big-endian host.
Let's add a flag and ioctls for big-endian devices as well. If both flags
are set, little-endian wins.
Since this is isn't a common usecase, the feature is controlled by a kernel
config option (not set by default).
Both macvtap and tun are covered by this patch since they share the same
API with userland.
Signed-off-by: Greg Kurz <gkurz@linux.vnet.ibm.com>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
The current memory accessors logic is:
- little endian if little_endian
- native endian (i.e. no byteswap) if !little_endian
If we want to fully support cross-endian vhost, we also need to be
able to convert to big endian.
Instead of changing the little_endian argument to some 3-value enum, this
patch changes the logic to:
- big endian if !little_endian
The native endian case is handled by all users with a trivial helper. This
patch doesn't change any functionality, nor it does add overhead.
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Fix missing copy_from_user in macvtap SIOCSIFHWADDR ioctl.
Signed-off-by: Justin Cormack <justin@netbsd.org>
The macvtap driver tries to emulate all the ioctls supported by a normal
tun/tap driver, however it was missing the generic SIOCGIFHWADDR and
SIOCSIFHWADDR ioctls to get and set the mac address that are supported
by tun/tap. This patch adds these.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
1) Fix verifier memory corruption and other bugs in BPF layer, from
Alexei Starovoitov.
2) Add a conservative fix for doing BPF properly in the BPF classifier
of the packet scheduler on ingress. Also from Alexei.
3) The SKB scrubber should not clear out the packet MARK and security
label, from Herbert Xu.
4) Fix oops on rmmod in stmmac driver, from Bryan O'Donoghue.
5) Pause handling is not correct in the stmmac driver because it
doesn't take into consideration the RX and TX fifo sizes. From
Vince Bridgers.
6) Failure path missing unlock in FOU driver, from Wang Cong.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits)
net: dsa: use DEVICE_ATTR_RW to declare temp1_max
netns: remove BUG_ONs from net_generic()
IB/ipoib: Fix ndo_get_iflink
sfc: Fix memcpy() with const destination compiler warning.
altera tse: Fix network-delays and -retransmissions after high throughput.
net: remove unused 'dev' argument from netif_needs_gso()
act_mirred: Fix bogus header when redirecting from VLAN
inet_diag: fix access to tcp cc information
tcp: tcp_get_info() should fetch socket fields once
net: dsa: mv88e6xxx: Add missing initialization in mv88e6xxx_set_port_state()
skbuff: Do not scrub skb mark within the same name space
Revert "net: Reset secmark when scrubbing packet"
bpf: fix two bugs in verification logic when accessing 'ctx' pointer
bpf: fix bpf helpers to use skb->mac_header relative offsets
stmmac: Configure Flow Control to work correctly based on rxfifo size
stmmac: Enable unicast pause frame detect in GMAC Register 6
stmmac: Read tx-fifo-depth and rx-fifo-depth from the devicetree
stmmac: Add defines and documentation for enabling flow control
stmmac: Add properties for transmit and receive fifo sizes
stmmac: fix oops on rmmod after assigning ip addr
In commit 04ffcb255f22 ("net: Add ndo_gso_check") Tom originally
added the 'dev' argument to be able to call ndo_gso_check().
Then later, when generalizing this in commit 5f35227ea34b
("net: Generalize ndo_gso_check to ndo_features_check")
Jesse removed the call to ndo_gso_check() in netif_needs_gso()
by calling the new ndo_features_check() in a different place.
This made the 'dev' argument unused.
Remove the unused argument and go back to the code as before.
Cc: Tom Herbert <therbert@google.com>
Cc: Jesse Gross <jesse@nicira.com>
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
drivers/net/ethernet/rocker/rocker.c
The rocker commit was two overlapping changes, one to rename
the ->vport member to ->pport, and another making the bitmask
expression use '1ULL' instead of plain '1'.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Brian reported crashes using IPv6 traffic with macvtap/veth combo.
I tracked the crashes in neigh_hh_output()
-> memcpy(skb->data - HH_DATA_MOD, hh->hh_data, HH_DATA_MOD);
Neighbour code assumes headroom to push Ethernet header is
at least 16 bytes.
It appears macvtap has only 14 bytes available on arches
where NET_IP_ALIGN is 0 (like x86)
Effect is a corruption of 2 bytes right before skb->head,
and possible crashes if accessing non existing memory.
This fix should also increase IPv4 performance, as paranoid code
in ip_finish_output2() wont have to call skb_realloc_headroom()
Reported-by: Brian Rak <brak@vultr.com>
Tested-by: Brian Rak <brak@vultr.com>
drivers/net/vxlan.c
drivers/vhost/net.c
include/linux/if_vlan.h
net/core/dev.c
The net/core/dev.c conflict was the overlap of one commit marking an
existing function static whilst another was adding a new function.
In the include/linux/if_vlan.h case, the type used for a local
variable was changed in 'net', whereas the function got rewritten
to fix a stacked vlan bug in 'net-next'.
In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next'
overlapped with an endainness fix for VHOST 1.0 in 'net'.
In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter
in 'net-next' whereas in 'net' there was a bug fix to pass in the
correct network namespace pointer in calls to this function.
This reverts commit 3d0ad09412ffe00c9afa201d01effdb6023d09b4.
Now that GSO functionality can correctly track if the fragment
id has been selected and select a fragment id if necessary,
we can re-enable UFO on tap/macvap and virtio devices.
This reverts commit 5188cd44c55db3e92cd9e77a40b5baa7ed4340f7.
Now that GSO layer can track if fragment id has been selected
and can allocate one if necessary, we don't need to do this in
tap and macvtap. This reverts most of the code and only keeps
the new ipv6 fragment id generation function that is still needed.
Fixes: 3d0ad09412ff (drivers/net: Disable UFO through virtio)
The same macros are used for rx as well. So rename it.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Use TUNSETVNETLE/TUNGETVNETLE instead.
flags field in ifreq is only 16 bit wide, but
we read it as a 32 bit value.
If userspace doesn't zero-initialize unused fields,
this will lead to failures.
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
Note that the code _using_ ->msg_iter at that point will be very
unhappy with anything other than unshifted iovec-backed iov_iter.
We still need to convert users to proper primitives.
Reviewed-by: Jason Wang <jasowang@redhat.com>
To be more friendly with drop monitor, we should only call kfree_skb() when
the packets were dropped and use consume_skb() in other cases.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
allows to switch macvtap and tun from ->aio_write() to ->write_iter()
When mergeable buffer is used, vnet_hdr_sz is greater than sizeof struct
virtio_net_hdr. So we need advance the iov iterators in this case.
Fixes 6c36d2e26cda1ad3e2c4b90dd843825fc62fe5b4 ("macvtap: Use iovec iterators")
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch removes the use of skb_copy_datagram_const_iovec in
favour of the iovec iterator-based skb_copy_datagram_iter.
When VLAN is in use in macvtap_put_user, we end up setting
csum_start to the wrong place. The result is that the whoever
ends up doing the checksum setting will corrupt the packet instead
of writing the checksum to the expected location, usually this
means writing the checksum with an offset of -4.
This patch fixes this by adjusting csum_start when VLAN tags are
detected.
Fixes: f09e2249c4f5 ("macvtap: restore vlan header on user read")
Cc: stable@vger.kernel.org
Cheers,
UFO is now disabled on all drivers that work with virtio net headers,
but userland may try to send UFO/IPv6 packets anyway. Instead of
sending with ID=0, we should select identifiers on their behalf (as we
used to).
Fixes: 916e4cf46d02 ("ipv6: reuse ip6_frag_id from ip6_ufo_append_data")
IPv6 does not allow fragmentation by routers, so there is no
fragmentation ID in the fixed header. UFO for IPv6 requires the ID to
be passed separately, but there is no provision for this in the virtio
net protocol.
Until recently our software implementation of UFO/IPv6 generated a new
ID, but this was a bug. Now we will use ID=0 for any UFO/IPv6 packet
passed through a tap, which is even worse.
Unfortunately there is no distinction between UFO/IPv4 and v6
features, so disable UFO on taps and virtio_net completely until we
have a proper solution.
We cannot depend on VM managers respecting the tap feature flags, so
keep accepting UFO packets but log a warning the first time we do
this.
Add ndo_gso_check which a device can define to indicate whether is
is capable of doing GSO on a packet. This funciton would be called from
the stack to determine whether software GSO is needed to be done. A
driver should populate this function if it advertises GSO types for
which there are combinations that it wouldn't be able to handle. For
instance a device that performs UDP tunneling might only implement
support for transparent Ethernet bridging type of inner packets
or might have limitations on lengths of inner headers.
Signed-off-by: Tom Herbert <therbert@google.com>
In macvtap device delete and open calls can race and
this causes a list curruption of the vlan queue_list.
The race intself is triggered by the idr accessors
that located the vlan device. The device is stored
into and removed from the idr under both an rtnl and
a mutex. However, when attempting to locate the device
in idr, only a mutex is taken. As a result, once cpu
perfoming a delete may take an rtnl and wait for the mutex,
while another cput doing an open() will take the idr
mutex first to fetch the device pointer and later take
an rtnl to add a queue for the device which may have
just gotten deleted.
With this patch, we now hold the rtnl for the duration
of the macvtap_open() call thus making sure that
open will not race with delete.
CC: Michael S. Tsirkin <mst@redhat.com>
CC: Jason Wang <jasowang@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
The following is a problematic configuration:
VM1: virtio-net device connected to macvtap0@eth0
VM2: e1000 device connect to macvtap1@eth0
The problem is is that virtio-net supports checksum offloading
and thus sends the packets to the host with CHECKSUM_PARTIAL set.
On the other hand, e1000 does not support any acceleration.
For small TCP packets (and this includes the 3-way handshake),
e1000 ends up receiving packets that only have a partial checksum
set. This causes TCP to fail checksum validation and to drop
packets. As a result tcp connections can not be established.
Commit 3e4f8b787370978733ca6cae452720a4f0c296b8
fixes this issue for large packets wthat will end up undergoing GSO.
This commit adds a check for the non-GSO case and attempts to
compute the checksum for partially checksummed packets in the
non-GSO case.
CC: Daniel Lezcano <daniel.lezcano@free.fr>
CC: Patrick McHardy <kaber@trash.net>
CC: Andrian Nord <nightnord@gmail.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Vlad Yasevich <vyasevic@redhat.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
This covers everything under drivers/net except for wireless, which
has been submitted separately.
drivers/net/ethernet/intel/i40e/i40e_main.c
drivers/net/macvtap.c
Both minor merge hassles, simple overlapping changes.
Changing name of function as part of making the hash in skbuff to be
generic property, not just for receive path.
Since now macvlan and macvtap use the same receive and
forward handlers, we can remove them completely and use
netif_rx and dev_forward_skb() directly.
Macvtap device currently doesn not allow a user to capture
traffic on due to the fact that it steals the packets
from the network stack before the skb->dev is set correctly
on the receive side, and that use uses macvlan transmit
path directly on the send side. As a result, we never
get a change to give traffic to the taps while the correct
device is set in the skb.
This patch makes macvtap device behave almost exaclty like
macvlan. On the send side, we switch to using dev_queue_xmit().
On the receive side, to deliver packets to macvtap, we now
use netif_rx and dev_forward_skb just like macvlan. The only
differnce now is that macvtap has its own rx_handler which is
attached to the macvtap netdev. It is here that we now steal
the packet and provide it to the socket.
As a result, we can now capture traffic on the macvtap device:
tcpdump -i macvtap0
It also gives us the abilit to add tc actions to the macvtap
device and actually utilize different bandwidth management
queues on output.
