path: root/drivers/net/mlx4/cmd.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-07-06mlx4_core: Handle multi-physical function devicesYevgeny Petrilin
MT26468 (PCI ID 0x6764) devices can expose multiple physical functions. The current driver only handles the primary physical function. For other functions, the QUERY_FW firmware command will fail with the CMD_STAT_MULTI_FUNC_REQ error code. Don't try to drive such devices, but print a message saying the driver is skipping those devices rather than just "QUERY_FW command failed." Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> [ Rather than keeping unsupported devices bound to the driver, simply print a more informative error message and exit - Roland ] Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-25mlx4: Update/add Mellanox Technologies copyright lines to mlx4 driver filesJack Morgenstein
Update existing Mellanox copyright lines to 2008, and add such lines to files where they are missing. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-07-22mlx4_code: Add missing FW status return codeJack Morgenstein
Add ICM_ERROR firmware status code. In mapping to errnos, -ENFILE seems closest. This is in preparation for providing more detailed log info using mlx4_err() in low-level driver when a non-zero status is returned. Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-04-16mlx4_core: Move opening brace of function onto a new lineRoland Dreier
2007-10-09mlx4_core: Use mmiowb() to avoid firmware commands getting jumbled upRoland Dreier
Firmware commands are sent to the HCA by writing multiple words to a command register block. Access to this block of registers is serialized with a mutex. However, on large SGI systems writes to the register block may be reordered within the system interconnect and reach the HCA in a different order than they were issued (even with the mutex). Fix this by adding an mmiowb() before dropping the mutex. This bug was observed with real workloads with the similar FW command code in the mthca driver, and adding the mmiowb() as in commit 66547550 ("IB/mthca: Use mmiowb() to avoid firmware commands getting jumbled up") was confirmed to fix the problems, so we should add the same fix to mlx4. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-10-09mlx4_core: Use enum value GO_BIT_TIMEOUT_MSECSDotan Barak
Rename GO_BIT_TIMEOUT to GO_BIT_TIMEOUT_MSECS for clarity, and actually use it as the go bit timeout (instead of having the define but then ignoring it and using a hard-coded 10 * HZ for the actual timeout). Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-07-20mlx4_core: Change command token on timeoutRoland Dreier
The FW command token is currently only updated on a command completion event. This means that on command timeout, the same token will be reused for new command, which results in a mess if the timed out command *does* eventually complete. This is the same change as the patch for mthca from Michael S. Tsirkin <mst@dev.mellanox.co.il> that was just merged. It seems sensible to avoid gratuitous differences in FW command processing between mthca and mlx4. Signed-off-by: Roland Dreier <rolandd@cisco.com>
2007-05-08IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adaptersRoland Dreier
Add an InfiniBand driver for Mellanox ConnectX adapters. Because these adapters can also be used as ethernet NICs and Fibre Channel HBAs, the driver is split into two modules: mlx4_core: Handles low-level things like device initialization and processing firmware commands. Also controls resource allocation so that the InfiniBand, ethernet and FC functions can share a device without stepping on each other. mlx4_ib: Handles InfiniBand-specific things; plugs into the InfiniBand midlayer. Signed-off-by: Roland Dreier <rolandd@cisco.com>
