The doorbell register was being unconditionally swapped. In x86, that
meant it was being swapped to BE and written to the descriptor and to
memory, depending on the case of blue frame support or writing to
doorbell register. On PPC, this meant it was being swapped to LE and
then swapped back to BE while writing to the register. But in the blue
frame case, it was being written as LE to the descriptor.
The fix is not to swap doorbell unconditionally, write it to the
register as BE and convert it to BE when writing it to the descriptor.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Reported-by: Richard Hendrickson <richhend@us.ibm.com>
Cc: Eli Cohen <eli@dev.mellanox.co.il>
Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
For older FW versions, when a Mac address removed from Mac table,
we should set 0 for reference count for the corresponding Mac index.
Fixes a bug where removing Mac from the table still left that entry as
invalid.
Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il>
Tested-by: Roland Dreier <roland@purestorage.com>
For older FW versions, fixing the usage of per port Mac table.
For each port we must define the base QP number, which is passed
to the HW.
Setting the correct value in SET_PORT FW command to enable the steering.
Reported-by: Roland Dreier <roland@purestorage.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (26 commits)
IB/qib: Defer HCA error events to tasklet
mlx4_core: Bump the driver version to 1.0
RDMA/cxgb4: Use printk_ratelimited() instead of printk_ratelimit()
IB/mlx4: Support PMA counters for IBoE
IB/mlx4: Use flow counters on IBoE ports
IB/pma: Add include file for IBA performance counters definitions
mlx4_core: Add network flow counters
mlx4_core: Fix location of counter index in QP context struct
mlx4_core: Read extended capabilities into the flags field
mlx4_core: Extend capability flags to 64 bits
IB/mlx4: Generate GID change events in IBoE code
IB/core: Add GID change event
RDMA/cma: Don't allow IPoIB port space for IBoE
RDMA: Allow for NULL .modify_device() and .modify_port() methods
IB/qib: Update active link width
IB/qib: Fix potential deadlock with link down interrupt
IB/qib: Add sysfs interface to read free contexts
IB/mthca: Remove unnecessary read of PCI_CAP_ID_EXP
IB/qib: Remove double define
IB/qib: Remove unnecessary read of PCI_CAP_ID_EXP
Many features were added to this driver, so the driver version should change too.
Signed-off-by: Dotan Barak <dotanb@dev.mellanox.co.il>
Signed-off-by: Roland Dreier <roland@purestorage.com>
- unify vlan and nonvlan path
- kill priv->vlgrp and mlx4_en_vlan_rx_register
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
ConnectX devices support a set of flow counters that can be attached
to a set containing one or more QPs. Each such counter tracks receive
and transmit packets and bytes of these QPs. This patch queries the
device to check support for counters, handles initialization of the
HCA to enable counters, and initializes a bitmap allocator to control
counter allocations. Derived from patch by Eli Cohen <eli@mellanox.co.il>.
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.co.il>
Query another dword containing up to 32 extended device capabilities
and merge it into struct mlx4_caps.flags. Update the code that
handles the current extended device capabilities (e.g UDP RSS, WoL,
vep steering, etc) to use the extended device cap flags field instead
of a field per extended capability. Initial patch done by Eli Cohen
The latest firmware adds a second dword containing more device flags,
so extend the device capabilities flags field from 32 to 64 bits.
The PCIE capability offset is saved during PCI bus walking. It will
remove an unnecessary search in the PCI configuration space if this
value is referenced instead of reacquiring it.
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Commit 725c89997e03d71b09ea3c17c997da0712b9d835 (mlx4_en: Reporting HW revision
in ethtool -i) added code to read the revision ID from the PCI configuration
register while it's already stored by PCI subsystem in the 'revision' field of
'struct pci_dev'...
While at it, move the code being changed a bit in order to not break the
initialization sequence.
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script (and a little editing):
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
Acked-By: Chris Snook <chris.snook@gmail.com>
Acked-by: Jon Mason <jdmason@kudzu.us>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: David Dillow <dave@thedillows.org>
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
This makes sure the ethtool's set_settings() callback of network
drivers don't ignore the 16 most significant bits when ethtool calls
their set_settings().
All drivers compiled with make allyesconfig on x86_64 have been
updated.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits)
net: Add support for SMSC LAN9530, LAN9730 and LAN89530
mlx4_en: Restoring RX buffer pointer in case of failure
mlx4: Sensing link type at device initialization
ipv4: Fix "Set rt->rt_iif more sanely on output routes."
MAINTAINERS: add entry for Xen network backend
be2net: Fix suspend/resume operation
be2net: Rename some struct members for clarity
pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev
dsa/mv88e6131: add support for mv88e6085 switch
ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2)
be2net: Fix a potential crash during shutdown.
bna: Fix for handling firmware heartbeat failure
can: mcp251x: Allow pass IRQ flags through platform data.
smsc911x: fix mac_lock acquision before calling smsc911x_mac_read
iwlwifi: accept EEPROM version 0x423 for iwl6000
rt2x00: fix cancelling uninitialized work
rtlwifi: Fix some warnings/bugs
p54usb: IDs for two new devices
wl12xx: fix potential buffer overflow in testmode nvs push
zd1211rw: reset rx idle timer from tasklet
If not done, second attempt to open the RX ring would cause memory corruption.
When bringing the port up, performing a SENSE_PORT command
To try and check to which physical link type (IB or Ethernet) the physical
port is connected.
In case there is no valid link partner, the port will come up as its
supported default.
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
On error path kfree() should get pointer to memory allocated by
kmalloc() not the address of variable holding it (which is on stack).
Signed-off-by: Mariusz Kozlowski <mk@lab.zgora.pl>
We should reduce the number of reserved completion queues from the total
number of entries. Since the queue size is power of two, not reducing the
reserved entries, caused a double queue size, which may lead to allocation
failures in some cases.
In case of allocation failure, tried to use the promiscuous QP
entry that was previously freed.
Now freeing this entry only in case we will not put it back to the list
of promiscuous entries.
Reported-by: Dan Carpenter <error27@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
xfrm: Restrict extended sequence numbers to esp
xfrm: Check for esn buffer len in xfrm_new_ae
xfrm: Assign esn pointers when cloning a state
xfrm: Move the test on replay window size into the replay check functions
netdev: bfin_mac: document TE setting in RMII modes
drivers net: Fix declaration ordering in inline functions.
cxgb3: Apply interrupt coalescing settings to all queues
net: Always allocate at least 16 skb frags regardless of page size
ipv4: Don't ip_rt_put() an error pointer in RAW sockets.
net: fix ethtool->set_flags not intended -EINVAL return value
mlx4_en: Fix loss of promiscuity
tg3: Fix inline keyword usage
tg3: use <linux/io.h> and <linux/uaccess.h> instead <asm/io.h> and <asm/uaccess.h>
net: use CHECKSUM_NONE instead of magic number
Net / jme: Do not use legacy PCI power management
myri10ge: small rx_done refactoring
bridge: notify applications if address of bridge device changes
ipv4: Fix IP timestamp option (IPOPT_TS_PRESPEC) handling in ip_options_echo()
can: c_can: Fix tx_bytes accounting
can: c_can_platform: fix irq check in probe
The mlx4_en driver uses the combination stop_port/start_port
in a number of places. Unfortunately that causes any promiscuous
mode settings on the hardware to be lost.
This patch fixes that problem.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (56 commits)
route: Take the right src and dst addresses in ip_route_newports
ipv4: Fix nexthop caching wrt. scoping.
ipv4: Invalidate nexthop cache nh_saddr more correctly.
net: fix pch_gbe section mismatch warning
ipv4: fix fib metrics
mlx4_en: Removing HW info from ethtool -i report.
net_sched: fix THROTTLED/RUNNING race
drivers/net/a2065.c: Convert release_resource to release_region/release_mem_region
drivers/net/ariadne.c: Convert release_resource to release_region/release_mem_region
bonding: fix rx_handler locking
myri10ge: fix rmmod crash
mlx4_en: updated driver version to 1.5.4.1
mlx4_en: Using blue flame support
mlx4_core: reserve UARs for userspace consumers
mlx4_core: maintain available field in bitmap allocator
mlx4: Add blue flame support for kernel consumers
mlx4_en: Enabling new steering
mlx4: Add support for promiscuous mode in the new steering model.
mlx4: generalization of multicast steering.
mlx4_en: Reporting HW revision in ethtool -i
Avoiding abuse of ethtool_drvinfo.driver field.
HW specific info can be retrieved using lspci.
Doorbell is used according to usage of BlueFlame.
For Blue Flame to work in Ethernet mode QP number should have 0
at bits 6,7.
Allocating range of QPs accordingly.
Do not allow a kernel consumer to allocate a UAR to serve for blue flame if the
number of available UARs gets below MLX4_NUM_RESERVED_UARS (currently 8). This
will allow userspace apps to open a device file and run things like
ibv_devinfo.
Signed-off-by: Eli Cohen <eli@mellanox.co.il>
Add mlx4_bitmap_avail() to give the number of available resources. We want to
use this as a hint to whether to allocate a resources or not. This patch is
introduced to be used with allocation blue flame registers.
Using blue flame can improve latency by allowing the HW to more efficiently
access the WQE. This patch presents two functions that are used to allocate or
release HW resources for using blue flame; the caller need to supply a struct
mlx4_bf object when allocating resources. Consumers that make use of this API
should post doorbells to the UAR object pointed by the initialized struct
mlx4_bf;
The mlx4_en module now uses the new steering mechanism.
The RX packets are now steered through the MCG table instead
of Mac table for unicast, and default entry for multicast.
The feature is enabled through INIT_HCA
For Ethernet mode only,
When we want to register QP as promiscuous, it must be added to all the
existing steering entries and also to the default one.
The promiscuous QP might also be on of "real" QPs,
which means we need to monitor every entry to avoid duplicates and ensure
we close an entry when all it has is promiscuous QPs.
Same mechanism both for unicast and multicast.
The same packet steering mechanism would be used both for IB and Ethernet,
Both multicasts and unicasts.
This commit prepares the general infrastructure for this.
HW revision is derived from device ID and rev id.
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.co.il>
The driver queries the FW for WOL support.
Ethtool get/set_wol is implemented accordingly.
Only magic packets are supported at the time.
Signed-off-by: Igor Yarovinsky <igory@mellanox.co.il>
Each RX ring will have its own interrupt vector, and TX rings will share one
(we mostly use polling for TX completions).
The vectors are assigned first time device is opened, and its name includes
the interface name and ring number.
Signed-off-by: Markuze Alex <markuze@mellanox.co.il>
Adding a pool of MSI-X vectors and EQs that can be used explicitly by mlx4_core
customers (mlx4_ib, mlx4_en). The consumers will assign their own names to the
interrupt vectors. Those vectors are not opened at mlx4 device initialization,
opened by demand.
Changed the max number of possible EQs according to the new scheme, no longer relies on
on number of cores.
The new functionality is exposed through mlx4_assign_eq() and mlx4_release_eq().
Customers that do not use the new API will get completion vectors as before.
Instead of reseting the module parameters each ifup or mtu change,
they are being set once at device initialization
By default, each device is assumed to be able only handle 64 KB chunks
during DMA. By giving the segment size a larger value, the block layer
will coalesce more S/G entries together for SRP, allowing larger
requests with the same sg_tablesize setting. The block layer is the
only direct user of it, though a few IOMMU drivers reference it as
well for their *_map_sg coalescing code. pci-gart_64 on x86, and a
smattering on on sparc, powerpc, and ia64.
Since other IB protocols could potentially see larger segments with
this, let's check those:
- iSER is fine, because you limit your maximum request size to 512
KB, so we'll never overrun the page vector in struct iser_page_vec
(128 entries currently). It is independent of the DMA segment size,
and handles multi-page segments already.
- IPoIB is fine, as it maps each page individually, and doesn't use
ib_dma_map_sg().
- RDS appears to do the right thing and has no dependencies on DMA
segment size, but I don't claim to have done a complete audit.
- NFSoRDMA and 9p are OK -- they do not use ib_dma_map_sg(), so they
doesn't care about the coalescing.
- Lustre's ko2iblnd does not care about coalescing -- it properly
walks the returned sg list.
This patch ups the value on Mellanox hardware to 1 GB, which matches
reported firmware limits on mlx4.
Signed-off-by: David Dillow <dillowda@ornl.gov>
...as already added to pci.ids.
The newest device firmware stores IB vs. Ethernet protocol in two bits
in members_count field of multicast group table (0: Infiniband, 1:
Ethernet). When changing the QP members count for a multicast group,
it important not to reset this information. When calling multicast
attach first time, the protocol type should be specified. In this
patch we always set it IB, but in the future we will handle Ethernet
too. When looking for a QP, the protocol type shoud be checked too.
Signed-off-by: Aleksey Senin <alekseys@voltaire.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Some systems have PCI addresses that don't fit in unsigned long (eg some
32-bit PowerPC 440 systems have 36-bit bus addresses). Fix up mlx4 drivers
by using phys_addr_t where appropriate, so we don't truncate any PCI
resource addresses before ioremapping them.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (67 commits)
cxgb4vf: recover from failure in cxgb4vf_open()
netfilter: ebtables: make broute table work again
netfilter: fix race in conntrack between dump_table and destroy
ah: reload pointers to skb data after calling skb_cow_data()
ah: update maximum truncated ICV length
xfrm: check trunc_len in XFRMA_ALG_AUTH_TRUNC
ehea: Increase the skb array usage
net/fec: remove config FEC2 as it's used nowhere
pcnet_cs: add new_id
tcp: disallow bind() to reuse addr/port
net/r8169: Update the function of parsing firmware
net: ppp: use {get,put}_unaligned_be{16,32}
CAIF: Fix IPv6 support in receive path for GPRS/3G
arp: allow to invalidate specific ARP entries
net_sched: factorize qdisc stats handling
mlx4: Call alloc_etherdev to allocate RX and TX queues
net: Add alloc_netdev_mqs function
caif: don't set connection request param size before copying data
cxgb4vf: fix mailbox data/control coherency domain race
qlcnic: change module parameter permissions
Signed-off-by: Ali Ayoub <ali@mellanox.com>
The kernel warning message added in commit 58d74bb1d9f7 ("mlx4_core:
Workaround firmware bug in query dev cap") about mlx4 reporting the
wrong number of "blue flame registers" doesn't really help anyone, since
the firmware bug is known and fixed and the bug is pretty much harmless
to users. So just get rid of the warning.
