Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
This updates the network drivers so that they don't access the
ethtool_cmd::speed field directly, but use ethtool_cmd_speed()
instead.
For most of the drivers, these changes are purely cosmetic and don't
fix any problem, such as for those 1GbE/10GbE drivers that indirectly
call their own ethtool get_settings()/mii_ethtool_gset(). The changes
are meant to enforce code consistency and provide robustness with
future larger throughputs, at the expense of a few CPU cycles for each
ethtool operation.
All drivers compiled with make allyesconfig ion x86_64 have been
updated.
Tested: make allyesconfig on x86_64 + e1000e/bnx2x work
Signed-off-by: David Decotigny <decot@google.com>
From Stephen Rothwell:
After merging the final tree, today's linux-next build (powerpc chrp32_defconfig)
failed like this:
drivers/net/mv643xx_eth.c: In function 'port_start':
drivers/net/mv643xx_eth.c:2250: error: 'dev' undeclared (first use in this function)
Caused by commit aad59c431b77 ("net: mv643xx: convert to hw_features").
Side effect: don't reenable RXCSUM on every ifdown/ifup.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Use the current logging styles.
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
flush_scheduled_work() is on its way out. This patch contains simple
conversions to replace flush_scheduled_work() usage with direct
cancels and flushes.
Directly cancel the used works on driver detach and flush them in
other cases.
The conversions are mostly straight forward and the only dangers are,
* Forgetting to cancel/flush one or more used works.
* Cancelling when a work should be flushed (ie. the work must be
executed once scheduled whether the driver is detaching or not).
I've gone over the changes multiple times but it would be much
appreciated if you can review with the above points in mind.
Cc: Jay Cliburn <jcliburn@gmail.com>
Cc: Michael Chan <mchan@broadcom.com>
Cc: Divy Le Ray <divy@chelsio.com>
Cc: e1000-devel@lists.sourceforge.net
Cc: Vasanthy Kolluri <vkolluri@cisco.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Andrew Gallatin <gallatin@myri.com>
Cc: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com>
Cc: Matt Carlson <mcarlson@broadcom.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: netdev@vger.kernel.org
Various drivers are using implementations of ethtool_ops::get_link
that are equivalent to the default ethtool_op_get_link(). Change
them to use that instead.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
We assume that "pd" can be null on the previous line, and throughout the
function so we should check it here as well. This was introduced by
9b2c2ff7a1c0 "mv643xx_eth: use sw csum for big packets"
The phy_mii_ioctl() function unnecessarily throws away the original ifreq.
We need access to the ifreq in order to support PHYs that can perform
hardware time stamping.
Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl().
This is unnecessary since phylib will check the command in any case.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
ethtool_op_set_flags() does not check for unsupported flags, and has
no way of doing so. This means it is not suitable for use as a
default implementation of ethtool_ops::set_flags.
Add a 'supported' parameter specifying the flags that the driver and
hardware support, validate the requested flags against this, and
change all current callers to pass this parameter.
Change some other trivial implementations of ethtool_ops::set_flags to
call ethtool_op_set_flags().
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Some controllers (KW, Dove) limits the TX IP/layer4 checksum offloading to a max size.
Signed-off-by: Saeed Bishara <saeed@marvell.com>
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
if (x == NULL) S
-memset(x, 0, size);
// </smpl>
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
removed some needless checks and also corrected bug in lp486e (dmi was passed
instead of dmi->dmi_addr)
Fix missing validate_addr hook.
Signed-off-by: Denis Kirjanov <kirjanov@gmail.com>
This patch introduces three macros to work with uc list from net drivers.
If NET_SKB_PAD is not a multiple of the cache line size, mv643xx_eth
allocates a couple of extra bytes at the start of each receive buffer
to make the data payload end up on a cache line boundary.
These extra bytes are skb_reserve()'d before DMA mapping, so they
should not be included in the DMA map byte count (as the mapping is
done starting at skb->data), nor should they be included in the
receive descriptor buffer size field, or the hardware can end up
DMAing beyond the end of the buffer, which can happen if someone
sends us a larger-than-MTU sized packet.
This problem was introduced in commit 7fd96ce47ff ("mv643xx_eth:
rework receive skb cache alignment", May 6 2009), but hasn't appeared
to be problematic so far, probably as the main users of mv643xx_eth
all have NET_SKB_PAD == L1_CACHE_BYTES.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Check for valid hw address.
The txq_set_wrr() function in drivers/net/mv643xx_eth.c is
unused, not even referenced under #if 0 or something like that,
which results in a compile-time warning:
drivers/net/mv643xx_eth.c:1070: warning: 'txq_set_wrr' defined but not used
Fix: remove it.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
The Unicast Promiscious Mode (UPM) bit in the mv643xx_eth port
configuration register doesn't do exactly what its name would suggest:
setting this bit merely enables reception of all unicast frames with a
destination address that differs from our local MAC address in bits
[47:4]. In particular, it doesn't have any effect on unicast frames
with a destination address that matches our MAC address in bits [47:4]
-- these will still be tested against the 16-entry unicast address
filter table.
Therefore, if the interface is set to promiscuous mode, just setting
the unicast promiscuous bit isn't enough -- we need to set all filter
bits in the unicast filter table to 1 as well.
Reported-by: Sachin Sanap <ssanap@marvell.com>
Signed-off-by: Prabhanjan Sarnaik <sarnaik@marvell.com>
Tested-by: Siddarth Gore <gores@marvell.com>
Tested-by: Mahavir Jain <mjain@marvell.com>
Cc: stable@kernel.org
This patch is inspired by patch recently posted by Johannes Berg. Basically what
my patch does is to group list and a count of addresses into newly introduced
structure netdev_hw_addr_list. This brings us two benefits:
1) struct net_device becames a bit nicer.
2) in the future there will be a possibility to operate with lists independently
on netdevices (with exporting right functions).
I wanted to introduce this patch before I'll post a multicast lists conversion.
drivers/net/bnx2.c | 4 +-
drivers/net/e1000/e1000_main.c | 4 +-
drivers/net/ixgbe/ixgbe_main.c | 6 +-
drivers/net/mv643xx_eth.c | 2 +-
drivers/net/niu.c | 4 +-
drivers/net/virtio_net.c | 10 ++--
drivers/s390/net/qeth_l2_main.c | 2 +-
include/linux/netdevice.h | 17 +++--
net/core/dev.c | 130 ++++++++++++++++++--------------------
9 files changed, 89 insertions(+), 90 deletions(-)
This patch converts unicast address list to standard list_head using
previously introduced struct netdev_hw_addr. It also relaxes the
locking. Original spinlock (still used for multicast addresses) is not
needed and is no longer used for a protection of this list. All
reading and writing takes place under rtnl (with no changes).
I also removed a possibility to specify the length of the address
while adding or deleting unicast address. It's always dev->addr_len.
The convertion touched especially e1000 and ixgbe codes when the
change is not so trivial.
drivers/net/bnx2.c | 13 +--
drivers/net/e1000/e1000_main.c | 24 +++--
drivers/net/ixgbe/ixgbe_common.c | 14 ++--
drivers/net/ixgbe/ixgbe_common.h | 4 +-
drivers/net/ixgbe/ixgbe_type.h | 4 +-
drivers/net/macvlan.c | 11 +-
drivers/net/mv643xx_eth.c | 11 +-
drivers/net/niu.c | 7 +-
drivers/net/virtio_net.c | 7 +-
drivers/s390/net/qeth_l2_main.c | 6 +-
drivers/scsi/fcoe/fcoe.c | 16 ++--
include/linux/netdevice.h | 18 ++--
net/8021q/vlan.c | 4 +-
net/8021q/vlan_dev.c | 10 +-
net/core/dev.c | 195 +++++++++++++++++++++++++++-----------
net/dsa/slave.c | 10 +-
net/packet/af_packet.c | 4 +-
18 files changed, 227 insertions(+), 137 deletions(-)
After 2.6.29, PPC no more admits passing NULL to the dev parameter of
the DMA API. The result is a BUG followed by solid lock-up when the
mv643xx_eth driver brings an interface up. The following patch makes
the driver work on my Pegasos again; it is mostly a search and replace
of NULL by mp->dev->dev.parent in dma allocation/freeing/mapping/unmapping
functions.
Signed-off-by: Gabriel Paubert <paubert@iram.es>
Acked-by: Lennert Buytenhek <buytenh@marvell.com>
It is not a good idea to blindly unmask the RX and TX_END interrupts
for all eight queues on all mv643xx_eth hardware, since some variations
of the hardware have less than eight transmit/receive queues, and the
RX/TX_END interrupts for the queues they don't have can be in use by
other interrupt sources.
On the platforms that mv643xx_eth is used on, the manual skb->data
alignment logic in mv643xx_eth can be simplified, as the only case we
need to handle is where NET_SKB_PAD is not a multiple of the cache
line size. If this is the case, the extra padding we need can be
computed at compile time, while if NET_SKB_PAD _is_ a multiple of
the cache line size, the code can be optimised out entirely.
Move the definitions for the SDMA and port serial configuration
register values to where all the other register definitions live,
and expand the shifts to 32 bit constants.
On several mv643xx_eth hardware versions, the two 64bit mib counters
for 'good octets received' and 'good octets sent' are actually 32bit
counters, and reading from the upper half of the register has the same
effect as reading from the lower half of the register: an atomic
read-and-clear of the entire 32bit counter value. This can under heavy
traffic occasionally lead to small numbers being added to the upper
half of the 64bit mib counter even though no 32bit wrap has occured.
Since we poll the mib counters at least every 30 seconds anyway, we
might as well just skip the reads of the upper halves of the hardware
counters without breaking the stats, which this patch does.
Currently, when OOM occurs during rx ring refill, mv643xx_eth will get
into an infinite loop, due to the refill function setting the OOM bit
but not clearing the 'rx refill needed' bit for this queue, while the
calling function (the NAPI poll handler) will call the refill function
in a loop until the 'rx refill needed' bit goes off, without checking
the OOM bit.
This patch fixes this by checking the OOM bit in the NAPI poll handler
before attempting to do rx refill. This means that once OOM occurs,
we won't try to do any memory allocations again until the next invocation
of the poll handler.
While we're at it, change the OOM flag to be a single bit instead of
one bit per receive queue since OOM is a system state rather than a
per-queue state, and cancel the OOM timer on entry to the NAPI poll
handler if it's running to prevent it from firing when we've already
come out of OOM.
Move SDMA configuration from interface up to port probe, to prevent
overwriting the receive coalescing timer value on interface up.
drivers/net/igb/igb_main.c
drivers/net/qlge/qlge_main.c
drivers/net/wireless/ath9k/ath9k.h
drivers/net/wireless/ath9k/core.h
drivers/net/wireless/ath9k/hw.c
When mv643xx_eth_open() is called to up an interface, port_start()
will first re-program the unicast address filter, and then
re-initialise the PORT_CONFIG register, but that will disable unicast
promiscuous mode if it was enabled by the unicast address filter setup.
This isn't a problem on ifconfig up, as ->set_rx_mode() will be called
shortly afterwards which will program the filters again, but it does
trigger when changing the MTU, which calls mv643xx_eth_stop() and then
mv643xx_eth_open() by hand to repopulate the receive rings with skbuffs
of the new size.
Swap the initialisation of the PORT_START register and the call to
the unicast filter setup function to fix this.
A receive coalescing timeout of 250 usec appears to strike a good
balance between allowing enough received frames to be aggregated for
LRO to do its job and not allowing the connection to stall due to
delaying ACKs to the remote end for too long.
Move the netif_carrier_off() call in ->open() to port probe, so that
ethtool doesn't report the link as being up before we have up'd the
interface.
Move initialisation of the rx/tx coalescing timers from ->open() to
port probe, so that we don't reset the coalescing timers every time
the interface is up'd.
mib_counters_update() also restarts the timer.
So the timer is dequeued, the stats are read and then the timer is
enqueued again. This is "okay" unless someone unloads the module.
The locking here is also broken:
mib_counters_update() grabs just a simple spinlock. The only thing the
lock is good for is to protect the timer func against other callers
namely mv643xx_eth_stop() && mv643xx_eth_get_ethtool_stats(). That means
if the spinlock is taken via the ethtool path and than the timer kicks
in then the box will lock up.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
dev_set_rx_mode() grabs netif_addr_lock_bh():
|BUG: sleeping function called from invalid context at /home/bigeasy/git/cryptodev-2.6/mm/slub.c:1599
|in_atomic(): 1, irqs_disabled(): 0, pid: 859, name: ifconfig
|2 locks held by ifconfig/859:
| #0: (rtnl_mutex){--..}, at: [<c0239ccc>] rtnl_lock+0x18/0x20
| #1: (_xmit_ETHER){-...}, at: [<c022d094>] dev_set_rx_mode+0x1c/0x30
|[<c029f118>] (dump_stack+0x0/0x14) from [<c003df28>] (__might_sleep+0x11c/0x13c)
|[<c003de0c>] (__might_sleep+0x0/0x13c) from [<c00a8854>] (kmem_cache_alloc+0x30/0xd4)
| r5:c78093a0 r4:c034a47c
|[<c00a8824>] (kmem_cache_alloc+0x0/0xd4) from [<c01a5fd0>] (mv643xx_eth_set_rx_mode+0x70/0x188)
|[<c01a5f60>] (mv643xx_eth_set_rx_mode+0x0/0x188) from [<c022ced0>] (__dev_set_rx_mode+0x40/0xac)
|[<c022ce90>] (__dev_set_rx_mode+0x0/0xac) from [<c022d09c>] (dev_set_rx_mode+0x24/0x30)
| r6:00001043 r5:c78090f8 r4:c7809000
|[<c022d078>] (dev_set_rx_mode+0x0/0x30) from [<c02304c4>] (dev_open+0xe4/0x114)
| r5:c7809350 r4:c7809000
|[<c02303e0>] (dev_open+0x0/0x114) from [<c022fd18>] (dev_change_flags+0xb0/0x190)
| r5:00000041 r4:c7809000
|[<c022fc68>] (dev_change_flags+0x0/0x190) from [<c0270250>] (devinet_ioctl+0x2f0/0x710)
| r7:c7221e70 r6:c7aadb00 r5:00000000 r4:00000001
|[<c026ff60>] (devinet_ioctl+0x0/0x710) from [<c02717c8>] (inet_ioctl+0xd4/0x110)
|[<c02716f4>] (inet_ioctl+0x0/0x110) from [<c021fb74>] (sock_ioctl+0x1f4/0x254)
| r4:c7242b40
|[<c021f980>] (sock_ioctl+0x0/0x254) from [<c00b8160>] (vfs_ioctl+0x38/0x98)
| r6:beec9bb8 r5:00008914 r4:c7242b40
|[<c00b8128>] (vfs_ioctl+0x0/0x98) from [<c00b873c>] (do_vfs_ioctl+0x484/0x4d4)
| r6:00008914 r5:c7242b40 r4:c74db1c0
|[<c00b82b8>] (do_vfs_ioctl+0x0/0x4d4) from [<c00b87cc>] (sys_ioctl+0x40/0x64)
|[<c00b878c>] (sys_ioctl+0x0/0x64) from [<c00269a0>] (ret_fast_syscall+0x0/0x2c)
|[42949399.520000] r7:00000036 r6:beec9c80 r5:00000041 r4:beec9bb8
Controlled by a compile-time (Kconfig) option for now, since it
isn't a win in all cases.
