path: root/drivers/net/myri10ge/myri10ge.c
2011-06-29myri10ge: update versionJon Mason
Update version and copyright Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29myri10ge: misc style cleanupsJon Mason
Miscellaneous white space, style, and other cleanups v2 includes corrections from Joe Perches Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29myri10ge: remove unnecessary read of PCI_CAP_ID_EXPJon Mason
The PCIE capability offset is saved during PCI bus walking. It will remove an unnecessary search in the PCI configuration space if this value is referenced instead of reacquiring it. Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29myri10ge: add support for set_phys_idJon Mason
Add myri10ge driver support for the ethtool identify operation. NOTE: Rather than blinking (which is the normal case), when identify is used, the yellow LED turns solid. Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29myri10ge: allow small_bytes = 0Jon Mason
Allow page-based receive to work when small_bytes is set to 0. Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29myri10ge: rework parity error check and cleanupJon Mason
Clean up watchdog reset code: - move code that checks for stuck slice to a common routine - unless there is a confirmed h/w fault, verify that a stuck slice is still stuck in the watchdog worker; if the slice is no longer stuck, abort the reset. - this removes an egregious 2000ms pause in the watchdog worker that was a diagnostic aid (to look for spurious resets) the snuck into production code. v3 includes corrections from Joe Perches Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29myri10ge: Mask PCI Surprise Link Down EventsJon Mason
A SRAM parity error can cause a surprise link down. Since We can recover from SRAM parity errors, mask PCI surprise down events. Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-29myri10ge: ensure tx queues remain stoppedJon Mason
Ensure that our tx queues remain stopped when we stop them in myri10ge_close(). Not doing so can potentially lead to traffic being transmitted when the interface is removed, which can lead to NULL pointer dereferences. Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21ip: introduce ip_is_fragment helper inline functionPaul Gortmaker
There are enough instances of this: iph->frag_off & htons(IP_MF | IP_OFFSET) that a helper function is probably warranted. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20myricom: remove stats_lockEric Dumazet
stats_lock is non useless, lets remove it. Also, ndo_get_stats64() doesnt have to clear the stats, caller takes care of this. Note: folding 32bit fields in 64bit one is problematic when one of 32bit values wraps : SNMP reader will see a ~2^32 back change in a 64bit value. A future patch should fix this. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Andrew Gallatin <gallatin@myri.com> CC: Brice Goglin <brice@myri.com> Acked-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-08myricom: update to 64 bit statsstephen hemminger
Driver was already keeping 64 bit counters, just not using the new interface. Ps: IMHO drivers should not be duplicating network device stats into ethtool stats. It is useless duplication. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-05drivers/net: Remove unnecessary semicolonsJoe Perches
Semicolons are not necessary after switch/while/for/if braces so remove them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-18net: myri10ge: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Jon Mason <jon.mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27myri10ge: small rx_done refactoringStanislaw Gruszka
Avoid theoretical race condition regarding accessing dev->features NETIF_F_LRO flag, which is illustrated below. CPU1 CPU2 myri10ge_clean_rx_done(): myri10ge_set_flags(): or myri10ge_set_rx_csum(): if (dev->features & NETIF_F_LRO) setup lro dev->features |= NETIF_F_LRO or dev->features &= ~NETIF_F_LRO; if (dev->features & NETIF_F_LRO) flush lro On the way reduce myri10ge_rx_done() number of arguments and calls by moving mgp->small_bytes check into that function. That reduce code size from: text data bss dec hex filename 36644 248 100 36992 9080 drivers/net/myri10ge/myri10ge.o to: text data bss dec hex filename 36037 247 100 36384 8e20 drivers/net/myri10ge/myri10ge.o on my i686 system, what should also make myri10ge_clean_rx_done() being faster. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-23myri10ge: fix rmmod crashStanislaw Gruszka
Rmmod myri10ge crash at free_netdev() -> netif_napi_del(), because napi structures are already deallocated. To fix call netif_napi_del() before kfree() at myri10ge_free_slices(). Cc: stable@kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-24net: change netdev->features to u32Michał Mirosław
Quoting Ben Hutchings: we presumably won't be defining features that can only be enabled on 64-bit architectures. Occurences found by `grep -r` on net/, drivers/net, include/ [ Move features and vlan_features next to each other in struct netdev, as per Eric Dumazet's suggestion -DaveM ] Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-14Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI/PM: Report wakeup events before resuming devices PCI/PM: Use pm_wakeup_event() directly for reporting wakeup events PCI: sysfs: Update ROM to include default owner write access x86/PCI: make Broadcom CNB20LE driver EMBEDDED and EXPERIMENTAL x86/PCI: don't use native Broadcom CNB20LE driver when ACPI is available PCI/ACPI: Request _OSC control once for each root bridge (v3) PCI: enable pci=bfsort by default on future Dell systems PCI/PCIe: Clear Root PME Status bits early during system resume PCI: pci-stub: ignore zero-length id parameters x86/PCI: irq and pci_ids patch for Intel Patsburg PCI: Skip id checking if no id is passed PCI: fix __pci_device_probe kernel-doc warning PCI: make pci_restore_state return void PCI: Disable ASPM if BIOS asks us to PCI: Add mask bit definition for MSI-X table PCI: MSI: Move MSI-X entry definition to pci_regs.h Fix up trivial conflicts in drivers/net/{skge.c,sky2.c} that had in the meantime been converted to not use legacy PCI power management, and thus no longer use pci_restore_state() at all (and that caused trivial conflicts with the "make pci_restore_state return void" patch)
2010-12-23PCI: make pci_restore_state return voidJon Mason
pci_restore_state only ever returns 0, thus there is no benefit in having it return any value. Also, a large majority of the callers do not check the return code of pci_restore_state. Make the pci_restore_state a void return and avoid the overhead. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-12-16net: Fix drivers advertising HW_CSUM feature to use csum_startMichał Mirosław
Some drivers are using skb_transport_offset(skb) instead of skb->csum_start for NETIF_F_HW_CSUM offload. This does not matter now, but if someone implements checksumming of encapsulated packets then this will break silently. TSO output paths are left as they are, since they are for IP+TCP only (might be worth converting though). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12drivers/net: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is on its way out. This patch contains simple conversions to replace flush_scheduled_work() usage with direct cancels and flushes. Directly cancel the used works on driver detach and flush them in other cases. The conversions are mostly straight forward and the only dangers are, * Forgetting to cancel/flush one or more used works. * Cancelling when a work should be flushed (ie. the work must be executed once scheduled whether the driver is detaching or not). I've gone over the changes multiple times but it would be much appreciated if you can review with the above points in mind. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: e1000-devel@lists.sourceforge.net Cc: Vasanthy Kolluri <vkolluri@cisco.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com> Cc: Matt Carlson <mcarlson@broadcom.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Shreyas Bhatewara <sbhatewara@vmware.com> Cc: netdev@vger.kernel.org
2010-09-29myri10ge: DCA update (resubmit)Andrew Gallatin
This patch contains the following DCA improvements to myri10ge: 1) Finally move myri10ge to use dca3 API 2) Disable PCIe relaxed ordering when enabling DCA on myri10ge. This provides a performance boost on Nehalem based Xeons 3) Make sure to properly initialize NIC's DCA state when it is enabled, rather than giving the NIC a bogus tag (0) and waiting for the first received packet to trigger an update. Not using a real tag can cause hardware exceptions on some motherboards when a CPU socket is empty. 3) Always update the cached CPU when our interrupt affinity changes so as to avoid excessive calls to dca3_get_tag() Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Loic Prylli <loic@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27myri10ge: Use netif_set_real_num_{rx, tx}_queues()Ben Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17drivers/net: Convert unbounded kzalloc calls to kcallocJoe Perches
These changes may be slightly safer in some instances. There are other kzalloc calls with a multiply, but those calls are typically "small fixed #" * sizeof(some pointer)" and those are not converted. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-11param: lock myri10ge_fw_name against sysfs changes.Rusty Russell
Since it can be changed via sysfs, we need to make a copy. This most generic way of doing this is to keep a flag so we know when to free it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Brice Goglin <brice@myri.com> Cc: netdev@vger.kernel.org
2010-06-30ethtool: Change ethtool_op_set_flags to validate flagsBen Hutchings
ethtool_op_set_flags() does not check for unsupported flags, and has no way of doing so. This means it is not suitable for use as a default implementation of ethtool_ops::set_flags. Add a 'supported' parameter specifying the flags that the driver and hardware support, validate the requested flags against this, and change all current callers to pass this parameter. Change some other trivial implementations of ethtool_ops::set_flags to call ethtool_op_set_flags(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14drivers: net: use skb_headlen()Eric Dumazet
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13myri10ge: use the DMA state API instead of the pci equivalentsFUJITA Tomonori
This replace the PCI DMA state API (include/linux/pci-dma.h) with the DMA equivalents since the PCI DMA state API will be obsolete. No functional change. For further information about the background: http://marc.info/?l=linux-netdev&m=127037540020276&w=2 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-07myri10ge: fix rx_pause in myri10ge_set_pauseparamBrice Goglin
Fix rx_pause management in myri10ge_set_pauseparam(). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15myri: remove dead codeDan Carpenter
We can never reach the return statement. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26myri10ge: optimize 4k-boundary check when stocking rx pagesBrice Goglin
Small optimization to the code which checks to see if we'd cross a 4K boundary when stocking RX ring. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Guillaume Morin <guillaume@morinfr.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part5 V2Jiri Pirko
removed some needless checks and also corrected bug in lp486e (dmi was passed instead of dmi->dmi_addr) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26drivers/net/myri10ge: Use pr_<level> and netdev_<level>Joe Perches
Add #define pr_fmt(fmt) Convert logging messages to pr_<level> and netdev_<level> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08myri10ge: use src+dst for rss hashingBrice Goglin
Use a more effective rss hash by default (src + dst, rather than just src). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10myri10ge: declare MODULE_FIRMWAREBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-22myri10ge: improve port type reporting in ethtoolBrice Goglin
Improve the reporting of myri10ge port type in ethtool, and update for new boards. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07myri10ge: Use the instance of net_device_stats from net_device.Ajit Khaparde
Since net_device has an instance of net_device_stats, we can remove the instance of this from the private myri10ge_priv structure. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12myri10ge: improve parity error detection and recoveryBrice Goglin
Improve myri10ge parity error detection and recovery: 1) Don't restore PCI config space to a rebooted NIC until AFTER the host is quiescent. 2) Let myri10ge_close() know the NIC is dead, so it won't waste time waiting for a dead nic to respond to MXGEFW_CMD_ETHERNET_DOWN 3) When the NIC is quiet (link down, or otherwise idle link) use a pci config space read to detect a rebooted NIC. Otherwise we might never notice that a NIC rebooted Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
