path: root/drivers/net/ne3210.c
2011-05-31Revert "net: fix section mismatches"David S. Miller
This reverts commit e5cb966c0838e4da43a3b0751bdcac7fe719f7b4. It causes new build regressions with gcc-4.2 which is pretty common on non-x86 platforms. Reported-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-18net: fix section mismatchesMichał Mirosław
Fix build warnings like the following: WARNING: drivers/net/built-in.o(.data+0x12434): Section mismatch in reference from the variable madgemc_driver to the variable .init.data:madgemc_adapter_ids And add some consts to EISA device ID tables along the way. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-01net: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Cc: netdev@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-11ne3210.c fix compilation warning for phys_addr_tJaswinder Singh Rajput
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-25ne3210: convert to net_device_opsStephen Hemminger
By having common code in 8390.o don't need net_dev_ops in the driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] severing skbuff.h -> mm.hAl Viro
2006-09-27[PATCH] EISA bus MODALIAS attributes supportMichael Tokarev
Add modalias attribute support for the almost forgotten now EISA bus and (at least some) EISA-aware modules. The modalias entry looks like (for an 3c509 NIC): eisa:sTCM5093 and the in-module alias like: eisa:sTCM5093* The patch moves struct eisa_device_id declaration from include/linux/eisa.h to include/linux/mod_devicetable.h (so that the former now #includes the latter), adds proper MODULE_DEVICE_TABLE(eisa, ...) statements for all drivers with EISA IDs I found (some drivers already have that DEVICE_TABLE declared), and adds recognision of __mod_eisa_device_table to scripts/mod/file2alias.c so that proper modules.alias will be generated. There's no support for /lib/modules/$kver/modules.eisamap, as it's not used by any existing tools, and because with in-kernel modalias mechanism those maps are obsolete anyway. The rationale for this patch is: a) to make EISA bus to act as other busses with modalias support, to unify driver loading b) to foget about EISA finally - with this patch, kernel (who still supports EISA) will be the only one who knows how to choose the necessary drivers for this bus ;) [akpm@osdl.org: fix the kbuild bit] Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Acked-the-net-bits-by: Jeff Garzik <jeff@garzik.org> Acked-the-tulip-bit-by: Valerie Henson <val_henson@linux.intel.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2005-09-05[PATCH] drivers/net/ne3210.c: cleanupsAdrian Bunk
- make two needlessly global functions static - kill an ancient version variable Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
