path: root/drivers/net/netxen/netxen_nic_ethtool.c
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-06net: netxen: convert to hw_featuresMichał Mirosław
Rather simple conversion to hw_features. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27net: fix ethtool->set_flags not intended -EINVAL return valueStanislaw Gruszka
After commit d5dbda23804156ae6f35025ade5307a49d1db6d7 "ethtool: Add support for vlan accleration.", drivers that have NETIF_F_HW_VLAN_TX, and/or NETIF_F_HW_VLAN_RX feature, but do not allow enable/disable vlan acceleration via ethtool set_flags, always return -EINVAL from that function. Fix by returning -EINVAL only if requested features do not match current settings and can not be changed by driver. Change any driver that define ethtool->set_flags to use ethtool_invalid_flags() to avoid similar problems in the future (also on drivers that do not have the problem). Tested with modified (to reproduce this bug) myri10ge driver. Cc: stable@kernel.org # 2.6.37+ Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15netxen: support for GbE port settingsSony Chacko
o Enable setting speed and auto negotiation parameters for GbE ports. o Hardware do not support half duplex setting currently. David Miller: Amit please update your patch to silently reject link setting attempts that are unsupported by the device. Signed-off-by: Sony Chacko <sony.chacko@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-03netxen: enable LRO based on NETIF_F_LROSucheta Chakraborty
o Enable/disable LRO in device based on NETIF_F_LRO flag, instead of using driver private flag. o Disable LRO, if rx csum offloading is off. David Miller, You should use netdev_info() instead of dev_info(). Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30netdev: Make ethtool_ops::set_flags() return -EINVAL for unsupported flagsBen Hutchings
The documented error code for attempts to set unsupported flags (or to clear flags that cannot be disabled) is EINVAL, not EOPNOTSUPP. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-29netxen: fail when try to setup unsupported featuresStanislaw Gruszka
2010-05-12netxen: fix register usageAmit Kumar Salecha
o For NX3031, MSI_MODE, CAPABILITIES_FW and SCRATCHPAD registers are obsolete. These register addresses can be used for different purpose. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-29netxen: fix tx csum statusSucheta Chakraborty
Kernel default tx csum function (ethtool_op_get_tx_csum) doesn't show correct csum status. It takes various FLAGS (NETIF_F_ALL_CSUM) in account to show tx csum status, which driver doesn't set while disabling tx csum. Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-15netxen: fix license headerAmit Kumar Salecha
GNU General Public License is in file "COPYING". Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03netxen: fix ethtool link testSucheta Chakraborty
o Fix ethtool link test for NX3031 chip. o Remove unused code from phy interrupt callback Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03netxen: fix ethtool register dumpSucheta Chakraborty
o Dump registers such as tx ring and rx ring counter, firmware state, niu regs, etc. which can be useful for debugging purpose. Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com> Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-28netxen: add PCI IDs for new chipDhananjay Phadke
Add PCI vendor and device IDs for QLE8240 and QLE8242 CNA devices. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13netxen: separate register and memory access lockDhananjay Phadke
Since register and onboard memory access has separate window registers, they need not be kept under same lock. Also, memory is always accessed from process context (mostly for firmware init and diagnostic tools). Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11netxen: update copyrightDhananjay Phadke
o Add QLogic copyright, add linux-driver@qlogic.com to MAINTAINERS. o Delete old contact information. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-07netxen: pre calculate register addressesAmit Kumar Salecha
For registers accessed in fast path (interrupt / softirq) avoid expensive I/O address translation. These registers are directly mapped in PCI bar 0 and do not require any window checks. Signed-off-by: Amit Kumar Salecha <amit@netxen.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23netxen: remove netxen_nic_phan_reg.hDhananjay Phadke
Consolidate register definitions in netxen_nic_hdr.h Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23netxen: ethtool statistics and control for LRONarender Kumar
Add ethtool -K knob to control LRO in firmware. LRO path is completely separated from GRO, LRO packets are still fed with netif_receive_skb(). Also fix ethtool statistics to include LRO packets. Also use correct message type while configuring interrupt coalescing. Signed-off-by: Narender Kumar <narender.kumar@qlogic.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27netxen: support for ethtool set ringparamAmit Kumar Salecha
Add support for ethtool -G to tune rx and tx ring sizes per interface basis. This is only supported for NX3031 based cards. Signed-off-by: Amit Kumar Salecha <amit@netxen.com> Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27netxen: Add default and limit macros for ring sizes.Dhananjay Phadke
2009-04-28netxen: fix link event handlingDhananjay Phadke
Firmware starting 4.0.402 started supporting link events, disable it for older firmwares. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08netxen: sanitize function namesDhananjay Phadke
Replace superfluous wrapper functions with two macros: NXWR32 replaces netxen_nic_reg_write, netxen_nic_write_w0, netxen_nic_read_w1, netxen_crb_writelit_adapter. NXRD32 replaces netxen_nic_reg_read, netxen_nic_read_w0, netxen_nic_read_w1. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08netxen: annotate register access functionsDhananjay Phadke
o remove unnecessary length parameter since register access width is fixed 4 byte. o remove superfluous pci_read_normalize and pci_write_normalize functions. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08netxen: async link event handlingDhananjay Phadke
Add support for asynchronous events from firmware, received over one of the rx rings. Add support for event based phy interrupts, enhanced links status reporting from firmware. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08netxen: code cleanupDhananjay Phadke
o remove unused structure defs. o remove unnecessary includes. o replace enums with specific #defines. o reduce footprint of stats structure. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-14netxen: sanitize variable namesDhananjay Phadke
o remove max_ prefix from ring sizes, since they don't really represent max possible sizes. o cleanup naming of rx ring types (normal, jumbo, lro). o simplify logic to choose rx ring size, gig ports get half rx ring of 10 gig ports. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10netxen: annotate board_config and board_typeDhananjay Phadke
Remove huge board config structure from each instance, read only necessary fields from flash. Replace board_type with port_type (1G/10G), there's another board_type field describing card type (SFP/XFP/CX4). Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10netxen: cleanup superfluous multi-context codeDhananjay Phadke
MAX_RCV_CTX was set to 1, there's only rx context per PCI function. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-27netxen: update copyrightDhananjay Phadke
Extend copyright into 2009 and update address. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24netxen: cleanup unused codeDhananjay Phadke
2009-02-24netxen: advertise wake-on-lan supportDhananjay Phadke
Add ethtool wake on lan support. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26netxen: reduce memory footprintDhananjay Phadke
o reduce rx ring size from 8192 to 4096. o cut down old huge lro buffers. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14netxen: fix link speed reporting for some boardsDhananjay Phadke
o Read negotiated link speed when link state changes. o Fix link speed reporting for hybrid nic boards, which have both 1Gbps and 10Gbps ports. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21netxen: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. Had to do some refactoring on multicast_list. Fix ethtool restart to propogate error code. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07netxen: add new board typesDhananjay Phadke
Add couple of new board configurations based on NX3031 chip. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07netxen: fix link status, link speedDhananjay Phadke
For NX3031, the phy is managed by firmware, so driver should avoid setting any phy registers. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22netxen: enable tso6, intr coalescing.Dhananjay Phadke
Enable tso6 and ipv6 checksum, interrupt coalescing for NX3031. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22netxen: add netxen_nic_ctx.cDhananjay Phadke
Contains rx and tx ring context management and certain firmware commands for netxen firmware v4.0.0+. This patch gathers all HW context management code into netxen_nic_ctx.c. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22netxen: add 2MB PCI memory supportDhananjay Phadke
New revision of netxen chip has 2MB PCI memory. Older chips had 128MB addressable PCI memory. To retain compatibility, this patch adds function pointers based on pci bar0 size. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22netxen: add defs for new chip/boardsDhananjay Phadke
Add macros for new chip revision and board configurations. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22netxen: cleanup unused variables/functionsDhananjay Phadke
o Reduce access to global arrays in data path. o Remove duplicate/unused variables, unecessary alignment constraints. o Use correct pci_dev instead of fallback device for consistent allocations. o Disable ethtool set_eeprom functionality for now, it was only used for flashing firmware. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17netxen: remove global physical_port arrayDhananjay Phadke
Store physical port number in netxen_adapter structure. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-25netxen: fix rx dropped statsDhananjay Phadke
Don't count rx dropped packets based on return value of netif_receive_skb(), which is misleading. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Tested-by: Vernon Mauery <mauery@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-25netxen: remove low level tx lockDhananjay Phadke
o eliminate tx lock in netxen adapter struct, instead pound on netdev tx lock appropriately. o remove old "concurrent transmit" code that unnecessarily drops and reacquires tx lock in hard_xmit_frame(), this is already serialized the netdev xmit lock. o reduce scope of tx lock in tx cleanup. tx cleanup operates on different section of the ring than transmitting cpus and is guarded by producer and consumer indices. This fixes a race caused by rx softirq preemption on realtime kernels. Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com> Tested-by: Vernon Mauery <mauery@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[netdrvr] netxen: checkpatch fixes (98% trim trailing whitespace)Jeff Garzik
2008-01-28netdev: use ARRAY_SIZE() instead of sizeof(array) / ETH_GSTRING_LENAlejandro Martinez Ruiz
Using ARRAY_SIZE() on arrays of the form array[][K] makes it unnecessary to know the value of K when checking its size. Signed-off-by: Alejandro Martinez Ruiz <alex@flawedcode.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
