o Enable/disable LRO in device based on NETIF_F_LRO flag, instead of using
driver private flag.
o Disable LRO, if rx csum offloading is off.
David Miller,
You should use netdev_info() instead of dev_info().
Signed-off-by: Sucheta Chakraborty <sucheta.chakraborty@qlogic.com>
Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com>
Using static const generally increases object text and decreases data size.
It also generally decreases overall object size.
HW workaround:
Disable logging of correctable error for some NX3031 based adapter.
There is race between netif_stop_queue and netif_stopped_queue
check.So check once again if buffers are available to avoid race.
With above logic we can also get rid of tx lock in process_cmd_ring.
Signed-off-by: Rajesh Borundia <rajesh.borundia@qlogic.com>
CRB window register is not per pci-func for NX3031,
so caching can result in incorrect values.
Check the access by tools for hardware queue engine and handle it
separately than other block registers, otherwise incorrect data
is returned.
Support for only NX3031 based cards.
Acked-by: Dhananjay Phadke <dhananjay.phadke@qlogic.com>
Remove unnecessary remap of the region in bar 0 to access onhip memory
for NX3031.
NX3031 have 64bit on card memory. Fix the limit check to
64MB and remove unnecessary 128bit read/write check.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
removed some needless checks and also corrected bug in lp486e (dmi was passed
instead of dmi->dmi_addr)
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
GNU General Public License is in file "COPYING".
Before sending Interrupt coalesce parameters to device,
convert them in little endian.
In netxen_read_mac_addr, mac_addr should be declared
u64 instead of __le64, used by host only.
o If tx and rx resources are not available, during set mac request.
Then this request wont be passed to firmware and it will be added to
driver mac list and will never make it to firmware.
So if resources are not available, don't add it to driver mac list.
o Fix pointless assignments
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
Driver maps only some part of the MMIO bar 0 in case of
NX2031. This is sufficient for tx and rx by the driver.
When debug tools need to access resources in
unmapped regions, driver needs to map these on the fly
in order to complete read/write request.
Signed-off-by: Narender Kumar <narender.kumar@qlogic.com>
Signed-off-by: Dhananjay Phadke <dhananjay.phadke@qlogic.com>
drivers/ieee802154/fakehard.c
drivers/net/e1000e/ich8lan.c
drivers/net/e1000e/phy.c
drivers/net/netxen/netxen_nic_init.c
drivers/net/wireless/ath/ath9k/main.c
o Along with netdev->perm_addr, mac address will be
maintained in device private structure.
o Device limitation: We need to set mac address when ever
interface comes up.
In ALB/TAL mode, bonding driver calls set_mac for all slave with bond mac address.
But bonding driver set netdev->dev_addr field to its original value,
after enslaving interfaces.
When ever active slave changes, it swap dev_addr of inactive slave with active.
Yet it doesn't notify driver about change in netdev->dev_addr.
As netxen driver need to set mac addr when ever interface comes up,
it can't rely on netdev->dev_addr field. Specially in case of bonding mode ALB/TLB.
Kernel crashes, if promisc mode set without disabling rx queue.
Before changing mode in NX2031 chip, wait till rx queue drains.
Refactor code to calculate and set indirect access
window for control registers in 2MB address space
(NX3031 or newer). Use void __iomem * data type for
absolute pci addresses.
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com>
drivers/net/sh_eth.c
Old code assumed board config version in the flash to be 1.
When this will get changed by tools, driver just refuses to
attach. This is unnecessary since driver does not have to
parse board config structure directly (maintained by firmware).
Use -EIO or -EINVAL as error codes, these can get passed up
to applications (tools).
Add support for different windowing scheme for on chip
memory in future chip revisions. This is required by
diagnostic tools.
Signed-off-by: Amit Kumar Salecha <amit@netxen.com>
Future revisions of the chip have 128 bit memory
transactions. Require drivers to implement rmw
in case of sub-128 bit accesses by driver. This
is mostly used by diagnostic tools.
Since register and onboard memory access has separate
window registers, they need not be kept under same lock.
Also, memory is always accessed from process context
(mostly for firmware init and diagnostic tools).
Use common variables crb_win, ocm_win for all revisions of chip.
Add access to on chip memory, this is used by
debug and diagnostic tools only.
Sub 64-bit / unaligned access to oncard memory was only used
by old diagnostic tools, causes some intermittent issues when
memory controller agent is used. The new access method was
added by commit ea6828b8aa3a8ebae8d7740f32f212ba1d2f0742
("netxen: improve pci memory access"). Firmware init anyway
uses 8-byte strides.
This also fixes address/offset calculation for NX2031 context
memory (SIU). For NX3031, SIU uses same register offsets
as packet memory (MIU).
o Add QLogic copyright, add linux-driver@qlogic.com to
MAINTAINERS.
o Delete old contact information.
o Access on card memory through memory controller (agent)
rather than moving small pci window around. Clean up the
code for moving windows around.
o Restrict memory accesss to 64 bit, currently only firmware
download uses this.
o Combine netxen_get_firmware_info(), netxen_check_options()
so that they are updated every time firmware is reset.
o Set dma mask everytime firmware is reset.
For registers accessed in fast path (interrupt / softirq)
avoid expensive I/O address translation. These registers
are directly mapped in PCI bar 0 and do not require
any window checks.
Unwind allocations and release file firmware when
when firmware load fails.
When the interface is put in bridged mode, destination mac
addresses are unknown to firmware. So packets take a slow
path (lower priority) in firmware reducing performance.
Firmware can cache limited number of remote unicast mac
addresses for certain interval, if "dynamic mac learning"
mode is enabled.
Driver needs to enable this "mac learning" mode in firmware.
Currently this is done through net device class sysfs entry,
possibly this can also be done upon netlink notifications to
from bridge.
Consolidate all MAC/PHY access functions into netxen_nic_hw.c
Implement common function for locking/unlocking 8 hardware
semaphores used for serializing access to shared resouces
on a NIC board by different PCI functions.
As by definition, callers of these semaphore API can be
put to sleep till the semaphore is locked.
Consolidate register definitions in netxen_nic_hdr.h
Add ethtool -K knob to control LRO in firmware.
LRO path is completely separated from GRO, LRO packets
are still fed with netif_receive_skb().
Also fix ethtool statistics to include LRO packets.
Also use correct message type while configuring interrupt coalescing.
Remove unnecessary offsetof calulations on these structures:
netxen_board_info, netxen_user_old_info, netxen_new_user_info.
The offsets into the flash are fixed, don't need to be calculated.
NX2031 firmware version will never be > 4.0.0, so replace
(adapter->fw_major < 4) checks with pci revision ID check.
NX3031 hardware requires local IP addresses for packet
accumulation (LRO). IP address hashing is required to
distinguish a local TCP flow from others (forwarded or
guest).
This patch adds listener for IP and netdev events and
configures IP address in the firmware.
o move dma mask update to netxen_start_firmware() so that
if firmware changes across suspend (e.g. file -> flash)
it reflects right dma mask.
o re-read firmware capabilities after firmware reset.
netxen: fix deadlock on dev close
The tx ring accounting fix in commit cb2107be43d2fc5eadec58b92b
("netxen: fix tx ring accounting") introduced intermittent
deadlock when inteface is going down.
This was possibly combined effect of speculative tx pause,
calling netif_tx_lock instead of queue lock and unclean
synchronization with napi which could end up unmasking
interrupt.
This forces every update of tx ring producer to check for
availability of space for next full TSO command. Earlier
firmware control commands didn't care to pause tx queue.
Stop the tx queue if there's not enough space to transmit one full
LSO command left on the tx ring after current transmit. This avoids
returning NETDEV_TX_BUSY after checking distance between producer
and consumer on every cpu.
Restart the tx queue only if we have cleaned up enough tx
descriptors.
