path: root/drivers/net/niu.h
2010-04-22niu: Add skb->rxhash support.David S. Miller
2009-06-12trivial: typo (en|dis|avail|remove)bale -> (en|dis|avail|remove)ableThadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-20niu: Add TCAM classification configurationSantwona Behera
Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18niu: improve ethtool support for gigabit copper cardsConstantin Baranov
Introduced support for link speed and duplex setting (ethtool -s), link advertising parameters and autonegotiation (ethtool -r): - struct niu_link_config: split advertising and autoneg fields into active and target values (similar to speed and duplex fields) - mii_init_common(): rewrite function to actually apply requested niu_link_config parameters instead of providing default initialization - link_status_1g(): move parsing of MII registers into new link_status_mii() function (link_status_1g_rgmii() could possibly use this new implementation too) - introduce simple nway_reset method - fix incorrect XMAC_CONFIG_MODE selection for 10Mbps case Signed-off-by: Constantin Baranov <baranov@mercdev.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-28niu: use net_device_stats nowadays available in net_deviceIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25niu: Naming interrupt vectors.Robert Olsson
A patch to put names on the niu interrupt vectors according the syntax below. This is needed to assign correct affinity. > So on a multiqueue card with 2 RX queues and 2 TX queues we'd > have names like: > > eth0-rx-0 > eth0-rx-1 > eth0-tx-0 > eth0-tx-1 Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Tested-by: Jesper Dangaard Brouer <jdb@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14NIU: Add Sun CP3260 ATCA blade supportSantwona Behera
This patch adds support for the Sun CP3260 ATCA blade which is a N2 based ATCA blade with 2 NIU ports. The NIU ports do not have on-board PHY. Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-4965-rs.c drivers/net/wireless/rt2x00/rt61pci.c
2008-05-13[netdrvr] Trim trailing whitespace for several driversJeff Garzik
2008-05-12niu: Determine the # of ports from the card's VPD dataMatheos Worku
Determine the number of physical ports from the card's VPD data. Previous fix failed on Maramba platform which doesn't have the "board-model" property. This fix uses the "model" property which exists on all cards and Neptune based motherboards. cstyle cleanup included. Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24niu: Add support for Neptune FEM/NEM cards for C10 server bladesMatheos Worku
[ Minor coding style and whitespace corrections, also bump driver version and release date. -DaveM ] Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24niu: Determine the # of ports from the card's VPD dataMatheos Worku
[ Fix minor whitespace and coding style stuff... -DaveM ] Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NIU]: Add Support for Sun ATCA Blade Server.Matheos Worku
Ports 0 and 1 of the NIU device are connected to extended fabric through SERDES. Ports 2 and 3 are connected using RGMII Fiber mode. [ Coding style cleanups... -DaveM ] Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-20[NIU]: More BMAC alt MAC address fixes.Matheos Worku
From: Matheos Worku <Matheos.Worku@Sun.COM> 1) niu_enable_alt_mac() needs to be adjusted so that the mask is computed properly for the BMAC case. 2) BMAC has 6 alt MAC addresses available, not 7. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-10[NIU]: Support for Marvell PHYMirko Lindner
From: Mirko Lindner <mlindner@marvell.com> This patch makes necessary changes in the Neptune driver to support the new Marvell PHY. It also adds support for the LED blinking on Neptune cards with Marvell PHY. All registers are using defines in the niu.h header file as is already done for the BCM8704 registers. [ Coding style, etc. cleanups -DaveM ] Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NIU]: Add Sun Neptune ethernet driver.David S. Miller
With cleanup suggestions and bugs spotted by Stephen Hemminger, Ingo Oeser, Matheos Worku, and Oliver Hartkopp. Signed-off-by: David S. Miller <davem@davemloft.net>
