path: root/drivers/net/ns83820.c
2008-01-28NET: ns83820.c remove fastcall macroDavid Miller
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28[NET]: fix drivers/net/ns83820.c buildAndrew Morton
Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Remove FASTCALL macroHarvey Harrison
X86_32 was the last user of the FASTCALL macro, now that it uses regparm(3) by default, this macro expands to nothing. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[netdrvr] ns83820: add ethtool media supportJeff Garzik
Split out from patch authored by Dan Faerch <dan@hacker.dk>. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-18NS83820: Handle multicast frames.YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> -- Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-02drivers/net/ns83820.c: fix a check-after-useAdrian Bunk
This patch fixes a check-after-use spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-03network drivers: eliminate unneeded kill_vid codeStephen Hemminger
Many drivers had code that did kill_vid, but they weren't doing vlan filtering. With new API the stub is unneeded unless device sets NETIF_F_HW_VLAN_FILTER. Bad habit: I couldn't resist fixing a couple of nearby style things in acenic, and forcedeth. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[VLAN]: Avoid a 4-order allocation.Dan Aloni
This patch splits the vlan_group struct into a multi-allocated struct. On x86_64, the size of the original struct is a little more than 32KB, causing a 4-order allocation, which is prune to problems caused by buddy-system external fragmentation conditions. I couldn't just use vmalloc() because vfree() cannot be called in the softirq context of the RCU callback. Signed-off-by: Dan Aloni <da-x@monatomic.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-07Merge branch 'master' into upstreamJeff Garzik
Conflicts: drivers/net/netxen/netxen_nic.h drivers/net/netxen/netxen_nic_main.c
2006-12-04[PATCH] ns83820 annotationsAl Viro
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[PATCH] lock validator: fix ns83820.c irq-flags bugIngo Molnar
Barry K. Nathan reported the following lockdep warning: [ 197.343948] BUG: warning at kernel/lockdep.c:1856/trace_hardirqs_on() [ 197.345928] [<c010329b>] show_trace_log_lvl+0x5b/0x105 [ 197.346359] [<c0103896>] show_trace+0x1b/0x20 [ 197.346759] [<c01038ed>] dump_stack+0x1f/0x24 [ 197.347159] [<c012efa2>] trace_hardirqs_on+0xfb/0x185 [ 197.348873] [<c029b009>] _spin_unlock_irq+0x24/0x2d [ 197.350620] [<e09034e8>] do_tx_done+0x171/0x179 [ns83820] [ 197.350895] [<e090445c>] ns83820_irq+0x149/0x20b [ns83820] [ 197.351166] [<c013b4b8>] handle_IRQ_event+0x1d/0x52 [ 197.353216] [<c013c6c2>] handle_level_irq+0x97/0xe1 [ 197.355157] [<c01048c3>] do_IRQ+0x8b/0xac [ 197.355612] [<c0102d9d>] common_interrupt+0x25/0x2c this is caused because the ns83820 driver re-enables irq flags in hardirq context. While legal in theory, in practice it should only be done if the hardware is really old and has some very high overhead in its ISR. (such as PIO IDE) For modern hardware, running ISRs with irqs enabled is discouraged, because 1) new hardware is fast enough to not cause latency problems 2) allowing the nesting of hardware interrupts only 'spreads out' the handling of the current ISR, causing extra cachemisses that would otherwise not happen. Furthermore, on architectures where ISRs share the kernel stacks, enabling interrupts in ISRs introduces a much higher kernel-stack-nesting and thus kernel-stack-overflow risk. 3) not managing irq-flags via the _irqsave / _irqrestore variants is dangerous: it's easy to forget whether one function nests inside another, and irq flags might be mismanaged. In the few cases where re-enabling interrupts in an ISR is considered useful (and unavoidable), it has to be taught to the lock validator explicitly (because the lock validator needs the "no ISR ever enables hardirqs" artificial simplification to keep the IRQ/softirq locking dependencies manageable). This teaching is done via the explicit use local_irq_enable_in_hardirq(). On a stock kernel this maps to local_irq_enable(). If the lock validator is enabled then this does not enable interrupts. Now, the analysis of drivers/net/ns83820.c's irq flags use: the irq-enabling in irq context seems intentional, but i dont think it's justified. Furthermore, the driver suffers from problem #3 above too, in ns83820_tx_timeout() it disables irqs via local_irq_save(), but then it calls do_tx_done() which does a spin_unlock_irq(), re-enabling for a function that does not expect it! While currently this bug seems harmless (only some debug printout seems to be affected by it), it's nevertheless something to be fixed. So this patch makes the ns83820 ISR irq-flags-safe, and cleans up do_tx_done() use and locking to avoid the ns83820_tx_timeout() bug. From: Arjan van de Ven <arjan@linux.intel.com> ns83820_mib_isr takes the misc_lock in IRQ context. All other places that do this in the ISR already use _irqsave versions, make this consistent at least. At some point in the future someone should audit the driver to see if all _irqsave's in the ISR can go away, this is generally an iffy/fragile proposition though; for now get it safe, simple and consistent. From: Arjan van de Ven <arjan@linux.intel.com> ok this is a real driver deadlock: The ns83820 driver enabled interrupts (by unlocking the misc_lock with _irq) while still holding the rx_info.lock, which is required to be irq safe since it's used in the ISR like this: writel(1, dev->base + IER); spin_unlock_irq(&dev->misc_lock); kick_rx(ndev); spin_unlock_irq(&dev->rx_info.lock); This is can cause a deadlock if an irq was pending at the first spin_unlock_irq already, or if one would hit during kick_rx(). Simply remove the first _irq solves this Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Benjamin LaHaise <bcrl@kvack.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] use dev_xxx() printk helpers, rather than dev_printk(KERN_xxx, ...Jeff Garzik
Suggested by Jiri Slaby. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-05[netdrvr] Use dev_printk() when ethernet interface isn't availableJeff Garzik
For messages prior to register_netdev(), prefer dev_printk() because that prints out both our driver name and our [PCI | whatever] bus id. Updates: 8139{cp,too}, b44, bnx2, cassini, {eepro,epic}100, fealnx, hamachi, ne2k-pci, ns83820, pci-skeleton, r8169. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02BUG_ON() Conversion in drivers/net/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-03Merge branch 'net-const'Jeff Garzik
2006-03-03Massive net driver const-ification.Arjan van de Ven
2006-01-17[PATCH] drivers/net/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Also make jiffies-holding variables unsigned long. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] kill include/linux/eeprom.hAdrian Bunk
This patch kills include/linux/eeprom.h . Rationale: - it was only used by one single driver - even this driver didn't do anything useful with it - most of this file are non-inline and non-static functions (sic) This removes include/linux/eeprom.h and cleans drivers/net/ns83820.c up. If you think eeprom.h should be used more extensively, please consider: - the code has to be moved from the header file to a .c file - the currently empty write function has to be implemented - ns83820.c or any other driver should actually use it Noone did any of these during the more than 3 years eeprom.h already exists... Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-10-13Merge branch 'master'Jeff Garzik
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04Merge branch 'upstream-fixes'Jeff Garzik
2005-10-04[PATCH] ns83820: fix gfp flags typeRandy Dunlap
Fix implicit nocast warnings in ns83820 code, including __nocast: drivers/net/ns83820.c:603:46: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03Merge branch 'upstream-fixes'Jeff Garzik
2005-10-03[PATCH] ns83820: fix gfp flags typeRandy Dunlap
Fix implicit nocast warnings in ns83820 code: drivers/net/ns83820.c:603:46: warning: implicit cast to nocast type Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-14[PATCH] drivers/net: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-28[NET]: Remove gratuitous use of skb->tail in network drivers.David S. Miller
Many drivers use skb->tail unnecessarily. In these situations, the code roughly looks like: dev = dev_alloc_skb(...); [optional] skb_reserve(skb, ...); ... skb->tail ... But even if the skb_reserve() happens, skb->data equals skb->tail. So it doesn't make any sense to use anything other than skb->data in these cases. Another case was the s2io.c driver directly mucking with the skb->data and skb->tail pointers. It really just wanted to do an skb_reserve(), so that's what the code was changed to do instead. Another reason I'm making this change as it allows some SKB cleanups I have planned simpler to merge. In those cleanups, skb->head, skb->tail, and skb->end pointers are removed, and replaced with skb->head_room and skb->tail_room integers. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com>
2005-06-26drivers/net/: Use the DMA_{64,32}BIT_MASK constantsDomen Puncer
Use the DMA_{64,32}BIT_MASK constants from dma-mapping.h when calling pci_set_dma_mask() or pci_set_consistent_dma_mask() This patch includes dma-mapping.h explicitly because it caused errors on some architectures otherwise. See http://marc.theaimsgroup.com/?t=108001993000001&r=1&w=2 for details Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org>
2005-05-15[PATCH] ns83820 updateBenjamin LaHaise
Changes: - improved DAC ifdefs from Andi Kleen - removal of dead code from Adrian Bunk - fix half duplex collision behaviour
