path: root/drivers/net/octeon
2010-07-18net: preserve ifreq parameter when calling generic phy_mii_ioctl().Richard Cochran
The phy_mii_ioctl() function unnecessarily throws away the original ifreq. We need access to the ifreq in order to support PHYs that can perform hardware time stamping. Two maverick drivers filter the ioctl commands passed to phy_mii_ioctl(). This is unnecessary since phylib will check the command in any case. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-28netdev: octeon_mgmt: Fix section mismatch errors.David Daney
We started getting: WARNING: drivers/net/built-in.o(.data+0x10f0): Section mismatch in reference from the variable octeon_mgmt_driver to the function .init.text:octeon_mgmt_probe() This fixes it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05netdev: octeon_mgmt: Remove some gratuitous blank lines.David Daney
2010-05-05netdev: octeon_mgmt: Try not to drop TX packets when stopping the queue.David Daney
Stop the queue when we add the packet that will fill it instead of dropping the packet Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05netdev: octeon_mgmt: Free TX skbufs in a timely manner.David Daney
We also reduce the high water mark to 1 so skbufs are not stranded for long periods of time. Since we are cleaning after each packet, no need to do it in the transmit path. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05netdev: octeon_mgmt: Fix race manipulating irq bits.David Daney
Don't re-read the interrupt status register, clear the exact bits we will be testing. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05netdev: octeon_mgmt: Fix race condition freeing TX buffers.David Daney
Under heavy load the TX cleanup tasklet and xmit threads would race and try to free too many buffers. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05netdev: octeon_mgmt: Use proper MAC addresses.David Daney
The original implementation incorrectly uses netdev->dev_addrs. Use netdev->uc instead. Also use netdev_for_each_uc_addr to iterate over the addresses. Fix comment. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13drivers: net: last_rx eliminationEric Dumazet
Network drivers do not have to update last_rx, unless they need it for their private use. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26octeon: convert to use netdev_for_each_mc_addrJiri Pirko
Hmm so actually my original patch including this bit was correct, "list = list->next;" confused me :) - will send patch correcting that in a few. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-29drivers/net/octeon/octeon_mgmt.c: use %pM to shown MAC addressH Hartley Sweeten
Use the %pM kernel extension to display the MAC address. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-17NET: Add Ethernet driver for Octeon MGMT devices.David Daney
The Octeon MGMT Ethernet ports are present in some members of the Octeon SOC family (cn52XX and cn56XX have them). The mdio bus connected to the MGMT PHYs is shared with the main octeon-ethernet driver, we force it to be loaded first by calling octeon_mdiobus_force_mod_depencency. The platform devices for the MGMT Ethernet ports are added in arch/mips/cavium-octeon/octeon-platform.c, and the register definitions for the ports live in arch/mips/include/asm/octeon/ along with their ilk. Although it currently is the only driver in drivers/net/octeon, the directory was created looking forward to the day that octeon-ethernet will move there from its current home in drivers/staging. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
