Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in
the pcmcia_config_loop() callback function. Therefore, factor it out.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Use the config loop helper in (some) net pcmcia drivers.
CC: netdev@vger.kernel.org
keep bit7,8 of XIRCREG42_SWC1 in set_multicast_list.
Signed-off-by: Komuro <komurojun-mbn@nifty.com>
Remove kio_addr_t, and replace it with unsigned int. No known architecture
needs more than 32 bits for IO addresses and ports and having a separate type
for it is just messy.
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
The drivers below support IRQ-sharing.
3c574_cs, 3c589_cs, pcnet_cs,
axnet_cs, smc91c92_cs, fmvj18x_cs.
xirc2ps_cs, serial_cs.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
This is nicer than the MAC_FMT stuff.
It's been a useless no-op for long enough in 2.6 so I figured it's time to
remove it. The number of people that could object because they're
maintaining unified 2.4 and 2.6 drivers is probably rather small.
[ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ]
Dear Jeff
Subject: [PATCH] xirc2ps_cs: bugfix of multicast code
One less thing for drivers writers to worry about.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Setting .ConfigBase and .Present is now done at the pcmcia core.
The driver cleanup missed a few places where the driver did set .Present
to PRESENT_OPTION and later to the values from the CIS. Setting to
PRESENT_OPTION now overrides the values from the CIS. So just remove
those lines.
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/pcmcia/ds.c
Fix up merge failures with Linus's head and fix new compile failures.
Signed-Off-By: David Howells <dhowells@redhat.com>
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost
all PCMICA driver right at the beginning, using the same calls but slightly
different implementations. Unfiy this in the PCMCIA core.
Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused
label") from and Signed-off-by Adrian Bunk <bunk@stusta.de>
As we read out the product information strings (VERS_1) from the PCMCIA device
in the PCMCIA core, and device drivers can access those reliably in struct
pcmcia_device's fields prod_id[], remove additional product information string
detection logic from PCMCIA device drivers.
Fix up for make allyesconfig.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
I am using a Xircom CEM33 pcmcia NIC which has occasional hardware problems.
If the netdev watchdog detects a transmit timeout, do_reset is called which
msleeps - this is illegal in atomic context.
This patch schedules the timeout handling as a workqueue item.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
First of all it is unnecessary to allocate a new skb in skb_pad since
the existing one is not shared. More importantly, our hard_start_xmit
interface does not allow a new skb to be allocated since that breaks
requeueing.
This patch uses pskb_expand_head to expand the existing skb and linearize
it if needed. Actually, someone should sift through every instance of
skb_pad on a non-linear skb as they do not fit the reasons why this was
originally created.
Incidentally, this fixes a minor bug when the skb is cloned (tcpdump,
TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because
of the position of the write it is unlikely to cause problems but still
it's best if we don't do it.
hi,
coverity choked at this check (id #223), assuming that
skb might be NULL and used anyways later. Since
start_hard_xmit() always gets called with a valid
skb, the check is useless and this patch removes it.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
* master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (33 commits)
[PATCH] pcmcia: declare pccard_iodyn_ops (fix m8xx_pcmcia.c compilation error)
[PATCH] pcmcia: fix pcmcia_device_remove oops
[PATCH] pcmcia: Add support for Possio GCC AKA PCMCIA Siemens MC45
[PATCH] pcmcia: pseudo device handling update
[PATCH] pcmcia: convert DEV_OK to pcmcia_dev_present
[PATCH] pcmcia: use bitfield instead of p_state and state
[PATCH] pcmcia: remove unused p_dev->state flags
[PATCH] pcmcia: make pcmcia_release_{io,irq} static
[PATCH] pcmcia: add return value to _config() functions
[PATCH] pcmcia: remove dev_link_t and client_handle_t indirection
[PATCH] pcmcia: embed dev_link_t into struct pcmcia_device
[PATCH] pcmcia: rename pcmcia_device.state
[PATCH] pcmcia: remove unneeded Vcc pseudo setting
[PATCH] pcmcia: remove export of pcmcia_release_configuration
[PATCH] pcmcia: default suspend and resume handling
[PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irq
[PATCH] pcmcia: add pcmcia_disable_device
[PATCH] serial_cs: add Merlin U630 IDs
[PATCH] pcmcia: AT91RM9200 Compact Flash driver
[PATCH] pcmcia: socket.functions starts with 1
The boot cmdline is parsed in parse_early_param() and
parse_args(,unknown_bootoption).
And __setup() is used in obsolete_checksetup().
start_kernel()
-> parse_args()
-> unknown_bootoption()
-> obsolete_checksetup()
If __setup()'s callback (->setup_func()) returns 1 in
obsolete_checksetup(), obsolete_checksetup() thinks a parameter was
handled.
If ->setup_func() returns 0, obsolete_checksetup() tries other
->setup_func(). If all ->setup_func() that matched a parameter returns 0,
a parameter is seted to argv_init[].
Then, when runing /sbin/init or init=app, argv_init[] is passed to the app.
If the app doesn't ignore those arguments, it will warning and exit.
This patch fixes a wrong usage of it, however fixes obvious one only.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present().
Instead of the two status values struct pcmcia_device->p_state and state,
use descriptive bitfields. Most value-checking in drivers was invalid, as
the core now only calls the ->remove() (a.k.a. detach) function in case the
attachement _and_ configuration was successful.
Most of the driver initialization isn't done in the .probe function, but in
the internal _config() functions. Make them return a value, so that .probe
can properly report whether the probing of the device succeeded or not.
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now.
Therefore, remove all such indirections.
Embed dev_link_t into struct pcmcia_device(), as they basically address the
same entity. The actual contents of dev_link_t will be cleaned up step by step.
This patch includes a bugfix from and signed-off-by Andrew Morton.
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and
Vpp2 can only be set to the same value, a lot of code can be
streamlined.
In all but one case, the suspend and resume functions of PCMCIA drivers
contain mostly of calls to pcmcia_release_configuration() and
pcmcia_request_configuration(). Therefore, move this code out of the
drivers and into the core.
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary
cleanups upon device or driver removal: it calls the appropriate
pcmcia_release_* functions, and can replace (most) of the current drivers'
_release() functions.
Additionally, one comment was reformulated by Joe Perches <joe@perches.com>.
callback
Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified
probe() callback. As all in-kernel drivers are changed to this new
callback, there will be no temporary backwards-compatibility. Inside a
probe() function, each driver _must_ set struct pcmcia_device
*p_dev->instance and instance->handle correctly.
With these patches, the basic driver interface for 16-bit PCMCIA drivers
now has the classic four callbacks known also from other buses:
int (*probe) (struct pcmcia_device *dev);
void (*remove) (struct pcmcia_device *dev);
int (*suspend) (struct pcmcia_device *dev);
int (*resume) (struct pcmcia_device *dev);
The linked list of devices managed by each PCMCIA driver is, in very most
cases, unused. Therefore, remove it from many drivers.
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function.
Old functionality is preserved, for the moment.
Move the suspend and resume methods out of the event handler, and into
special functions. Also use these functions for pre- and post-reset, as
almost all drivers already do, and the remaining ones can easily be
converted.
Bugfix to include/pcmcia/ds.c
If the product-id-string contains the '+' , '&' ,'_', it was not converted
properly from the /etc/pcmcia/config(pcmcia-cs config file).
As a follow-up, remove the inclusion of pcmcia/version.h in many files.
Move the "event handler" to struct pcmcia_driver -- the unified event handler
will disappear really soon, but switching it to struct pcmcia_driver in the
meantime allows for better "step-by-step" patches.
Add pcmcia_device_id table.
infrastructure for it.
Let it rip!
