path: root/drivers/net/pcmcia
2007-07-023c589_cs: fix local_bh_enable warningPatrick McHardy
Russell King wrote: > Having upgraded from 2.6.16 to 2.6.22-rc6, I'm now seeing the following. > > Looks like netfilter is calling local_bh_enable() with IRQs disabled, > which would appear to be illegal. Thankfully, this is a warn-once > warning. > > WARNING: at /home/rmk/git/linux-2.6-rmk/kernel/softirq.c:138 local_bh_enable() > [...] > [<c01447fc>] (nf_conntrack_destroy+0x0/0x2c) from [<c012c05c>] (__kfree_skb+0xd0/0x100) > [<c012bf8c>] (__kfree_skb+0x0/0x100) from [<c012c0d8>] (kfree_skb+0x4c/0x50) > r5:c12a3800 r4:00000300 > [<c012c08c>] (kfree_skb+0x0/0x50) from [<bf03cbb0>] (el3_start_xmit+0xb8/0xd0 [3c589_cs]) > [<bf03caf8>] (el3_start_xmit+0x0/0xd0 [3c589_cs]) from [<c01324dc>] (dev_hard_start_xmit+0x1a8/0x244) > r7:c12a3800 r6:c1a9aa00 r5:c1a9aa00 r4:c12a3800 > [<c0132334>] (dev_hard_start_xmit+0x0/0x244) from [<c013fcc0>] (__qdisc_run+0xb0/0x198) Thats a bug in the 3c589_cs driver. Patch attached. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-28Fix Kconfig dependency problems wrt boolean menuconfigsTrent Piepho
If one has a dependency chain (tristate)FOO depends on (bool)BAR depends on (tristate)BAZ, build problems will result. If BAZ=m, then BAR can be set y, which allows FOO=y. It's possible to have FOO=y && BAZ=m, which wouldn't be allowed if FOO depended directly on BAZ. In effect, the bool promotes the tristate from m to y. This ends up causing a problem with several menuconfigs that look like: menuconfig BAR bool depends on BAZ [tristate] if BAR config FOO tristate endif The solution used here is to add the dependencies of BAR to the if statement, so that items in the if block will gain a direct non-bool-promoted dependency on BAZ. This is how it would work if a menu was used instead of an if block. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Use menuconfig objects II - netdev/pcmciaJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09Fix hang on IBM Token Ring PCMCIA card ejectionPaul Walmsley
Ejecting a PCMCIA IBM Token Ring card that has not had its dev->open() called will reliably trigger an uninitialized spinlock oops when spinlock debugging is enabled. The system then hangs, occasionally softlockup oopsing. Apparently ibmtr.c:tok_interrupt() doesn't expect to be called before tok_open(), but tok_interrupt() gets called anyway when the card is ejected. So, set an already-existing flag which causes tok_interrupt() to bail out early upon card ejection. Tested by inserting and removing the PCMCIA card several times. Signed-off-by: Paul Walmsley <paul@booyaka.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08PCMCIA-NETDEV : xirc2ps_cs: bugfix of multicast codeKomuro
Dear Jeff Subject: [PATCH] xirc2ps_cs: bugfix of multicast code Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-14[PATCH] ibmtr probe is __devinit, not __initAl Viro
used by ->attach() in pcmcia analog Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17PCMCIA-NETDEV : the 2nd argument of el3_interrrupt and smc_interrupt is ↵Komuro
struct net_device* Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-23modify 3c589_cs to be SMP safeKomuro
1. EL3WINDOW is always 1 when lock is not held. 2. The second argument of el3_interrupt is 'void *dev_id', not 'struct el3_private *lp'. Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-11[PATCH] PCMCIA: fix drivers broken by recent cleanupDaniel Ritz
Setting .ConfigBase and .Present is now done at the pcmcia core. The driver cleanup missed a few places where the driver did set .Present to PRESENT_OPTION and later to the values from the CIS. Setting to PRESENT_OPTION now overrides the values from the CIS. So just remove those lines. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-09pcnet_cs : add new idKomuro
pcnet_cs: add new id. corega K.K. (CG-LAPCCTXD) Logitec LPM-LN10TE Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-06Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/pcmcia/ds.c Fix up merge failures with Linus's head and fix new compile failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] pcmcia: remove prod_id indirectionDominik Brodowski
As we read out the product information strings (VERS_1) from the PCMCIA device in the PCMCIA core, and device drivers can access those reliably in struct pcmcia_device's fields prod_id[], remove additional product information string detection logic from PCMCIA device drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] pcmcia: remove manf_id and card_id indirectionDominik Brodowski
As we read out the manufactor and card_id from the PCMCIA device in the PCMCIA core, and device drivers can access those reliably in struct pcmcia_device's fields manf_id and card_id, remove additional (and partly broken) manf_id and card_id detection logic from PCMCIA device drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-02[PATCH] network: pcnet_cs: remove the code to change the E8390_CMD register ↵Komuro
from ei_watchdog() Remove the code to change the E8390_CMD register from ei_watchdog(). The 8390-page is always 0 outside the spin_lock. Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-13drivers/net: const-ify ethtool_ops declarationsJeff Garzik
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-24Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-08-24[PATCH] xirc2ps_cs: Cannot reset card in atomic contextJoerg Ahrens
I am using a Xircom CEM33 pcmcia NIC which has occasional hardware problems. If the netdev watchdog detects a transmit timeout, do_reset is called which msleeps - this is illegal in atomic context. This patch schedules the timeout handling as a workqueue item. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] network: axnet_cs.c: add new id (0x021b, 0x0202)Komuro
2006-08-08[PATCH] network: pcnet_cs.c: remove unnecessary 'mdio_reset'Komuro
'mdio_reset' has bad side effects that moves the phy_id. DL10022-based cards work properly without 'mdio_reset'. Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] com20020_cs: more device supportMarc Sowen
Enable the com20020_cs arcnet driver to see the SoHard (now Mercury Computer Systems Inc.) SH ARC-PCMCIA card. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-23[NET]: Avoid allocating skb in skb_padHerbert Xu
First of all it is unnecessary to allocate a new skb in skb_pad since the existing one is not shared. More importantly, our hard_start_xmit interface does not allow a new skb to be allocated since that breaks requeueing. This patch uses pskb_expand_head to expand the existing skb and linearize it if needed. Actually, someone should sift through every instance of skb_pad on a non-linear skb as they do not fit the reasons why this was originally created. Incidentally, this fixes a minor bug when the skb is cloned (tcpdump, TCP, etc.). As it is skb_pad will simply write over a cloned skb. Because of the position of the write it is unlikely to cause problems but still it's best if we don't do it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-22[PATCH] Remove useless check in drivers/net/pcmcia/xirc2ps_cs.cEric Sesterhenn
hi, coverity choked at this check (id #223), assuming that skb might be NULL and used anyways later. Since start_hard_xmit() always gets called with a valid skb, the check is useless and this patch removes it. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-08Merge branch 'master' into upstreamJeff Garzik
2006-06-05[PATCH] nmclan_cs: dereferencing skb after netif_rx()Florin Malita
From: Florin Malita <fmalita@gmail.com> The skb may be gone after netif_rx(), we can't use 'skb->len' to update the stats. 'pkt_len' should work instead. Coverity CID: 911. Signed-off-by: Florin Malita <fmalita@gmail.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-24[netdrvr pcnet_cs, myri] trim trailing whitespaceJeff Garzik
2006-05-24[PATCH] pcnet_cs: Add TRENDnet TE-CF100 ethernet adapter IDMarcin Juszkiewicz
Add TRENDnet TE-CF100 ethernet adapter to pcnet_cs list. product info: "Fast Ethernet", "CF Size PC Card", "1.0", "" manfid: 0x0149, 0xc1ab Signed-off-by: Marcin Juszkiewicz <openembedded@hrw.one.pl> drivers/net/pcmcia/pcnet_cs.c | 2 ++ 1 file changed, 2 insertions(+) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-20[PATCH] network: axnet_cs: bug fix multicast code (support older ax88190 ↵Komuro
chipset) Dear Jeff axnet_cs: bug fix multicast code (support older ax88190 chipset) Signed-off-by: komurojun-mbn@nifty.com Best Regards Komuro Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-04-22[PATCH] pcmcia: add new ID to pcnet_csDominik Brodowski
This adds a new ID to pcnet_cs, as noted by Kuro Moji. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-04-12[PATCH] network: axnet_cs.c: add missing 'PRIV' in ei_rx_overrunKomuro
2006-04-02Merge master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (33 commits) [PATCH] pcmcia: declare pccard_iodyn_ops (fix m8xx_pcmcia.c compilation error) [PATCH] pcmcia: fix pcmcia_device_remove oops [PATCH] pcmcia: Add support for Possio GCC AKA PCMCIA Siemens MC45 [PATCH] pcmcia: pseudo device handling update [PATCH] pcmcia: convert DEV_OK to pcmcia_dev_present [PATCH] pcmcia: use bitfield instead of p_state and state [PATCH] pcmcia: remove unused p_dev->state flags [PATCH] pcmcia: make pcmcia_release_{io,irq} static [PATCH] pcmcia: add return value to _config() functions [PATCH] pcmcia: remove dev_link_t and client_handle_t indirection [PATCH] pcmcia: embed dev_link_t into struct pcmcia_device [PATCH] pcmcia: rename pcmcia_device.state [PATCH] pcmcia: remove unneeded Vcc pseudo setting [PATCH] pcmcia: remove export of pcmcia_release_configuration [PATCH] pcmcia: default suspend and resume handling [PATCH] pcmcia: convert remaining users of pcmcia_release_io and _irq [PATCH] pcmcia: add pcmcia_disable_device [PATCH] serial_cs: add Merlin U630 IDs [PATCH] pcmcia: AT91RM9200 Compact Flash driver [PATCH] pcmcia: socket.functions starts with 1 ...
2006-03-31[PATCH] Don't pass boot parameters to argv_init[]OGAWA Hirofumi
The boot cmdline is parsed in parse_early_param() and parse_args(,unknown_bootoption). And __setup() is used in obsolete_checksetup(). start_kernel() -> parse_args() -> unknown_bootoption() -> obsolete_checksetup() If __setup()'s callback (->setup_func()) returns 1 in obsolete_checksetup(), obsolete_checksetup() thinks a parameter was handled. If ->setup_func() returns 0, obsolete_checksetup() tries other ->setup_func(). If all ->setup_func() that matched a parameter returns 0, a parameter is seted to argv_init[]. Then, when runing /sbin/init or init=app, argv_init[] is passed to the app. If the app doesn't ignore those arguments, it will warning and exit. This patch fixes a wrong usage of it, however fixes obvious one only. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] pcmcia: convert DEV_OK to pcmcia_dev_presentDominik Brodowski
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present(). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove export of pcmcia_release_configurationDominik Brodowski
Handle the _modifying_ operation sm91c92_cs requires in pcmcia_modify_configuration, so that the only remaining users of pcmcia_release_configuration() are within the pcmcia core module. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
