path: root/drivers/net/phy/broadcom.c
2012-07-09phylib: Support registering a bunch of driversChristian Hohnstaedt
If registering of one of them fails, all already registered drivers of this module will be unregistered. Use the new register/unregister functions in all drivers registering more than one driver. amd.c, realtek.c: Simplify: directly return registration result. Tested with broadcom.c All others compile-tested. Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-13drivers/net: Remove boolean comparisons to true/falseJoe Perches
Booleans should not be compared to true or false but be directly tested or tested with !. Done via cocci script: @@ bool t; @@ - t == true + t @@ bool t; @@ - t != true + !t @@ bool t; @@ - t == false + !t @@ bool t; @@ - t != false + t Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-27treewide: Correct spelling of successfully in commentsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-05net/phy: fix many "defined but unused" warningsUwe Kleine-König
MODULE_DEVICE_TABLE only expands to something if it's compiled for a module. So when building-in support for the phys, the mdio_device_id tables are unused. Marking them with __maybe_unused fixes the following warnings: drivers/net/phy/bcm63xx.c:134: warning: 'bcm63xx_tbl' defined but not used drivers/net/phy/broadcom.c:933: warning: 'broadcom_tbl' defined but not used drivers/net/phy/cicada.c:162: warning: 'cicada_tbl' defined but not used drivers/net/phy/davicom.c:222: warning: 'davicom_tbl' defined but not used drivers/net/phy/et1011c.c:114: warning: 'et1011c_tbl' defined but not used drivers/net/phy/icplus.c:137: warning: 'icplus_tbl' defined but not used drivers/net/phy/lxt.c:226: warning: 'lxt_tbl' defined but not used drivers/net/phy/marvell.c:724: warning: 'marvell_tbl' defined but not used drivers/net/phy/micrel.c:234: warning: 'micrel_tbl' defined but not used drivers/net/phy/national.c:154: warning: 'ns_tbl' defined but not used drivers/net/phy/qsemi.c:141: warning: 'qs6612_tbl' defined but not used drivers/net/phy/realtek.c:82: warning: 'realtek_tbl' defined but not used drivers/net/phy/smsc.c:257: warning: 'smsc_tbl' defined but not used drivers/net/phy/ste10Xp.c:135: warning: 'ste10Xp_tbl' defined but not used drivers/net/phy/vitesse.c:195: warning: 'vitesse_tbl' defined but not used Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24broadcom: Add 5241 supportDmitry Baryshkov
This patch adds the 5241 PHY ID to the broadcom module. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-24broadcom: move all PHY_ID's to headerDmitry Baryshkov
Move all PHY IDs to brcmphy.h header for completeness and unification of code. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-02phylib: Add module table to all existing phy driversDavid Woodhouse
Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17tg3: Push phylib definitions to phylibMatt Carlson
This patch pushes phylib definitions out to phylib headers. For phy IDs, this removes some code duplication. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03broadcom: Fix &&/|| confusion in bcm54xx_adjust_rxrefclk()roel kluin
This always evaluates to true. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18broadcom: bcm54xx_shadow_read() errors ignored in bcm54xx_adjust_rxrefclk()Roel Kluin
If not signed read errors are ignored. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Optionally disable TXC if no linkMatt Carlson
This patch adds code to disable the TXC and RXC reference clocks if link is not available. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add APD support for GPHYsMatt Carlson
This patch adds an RXC auto power-down feature to the code that supports the gphys. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add code to disable rxc refclkMatt Carlson
The 5785 does not use the RXC reference clock. Turning it off is desirable as it saves power. By default, the 50610 enables the RXC reference clock and the 50610M disables it. Presumably this is one of the reasons why the hardware architect chose one over the other. Adding a "rx reference clock disable" flag is not the ideal way to describe the option, as it would force the MAC using a 50610M to set the flag. Ideally we want the flags to represent opt-in behavior that deviates from hardware defaults. Furthermore, the lack of a "disable" flag implies that the requester wants the rx reference clock enabled, which doesn't necessarily follow. By presenting the option as a passive statement (rx reference clock unused) rather than a command, I hope to convey an opt-in option to disable the rx reference clock that falls back to hardware defaults if not set. A secondary benefit of this is that it keeps the intelligence about phy defaults in the broadcom module where it belongs and allows the broadcom module more latitude should a bug arise. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Refine AC131 APD supportMatt Carlson
Auto power-down (APD) support is a power-saving feature. It should be selectively enabled since it might expose MAC bugs. This patch changes the code to enable APD only if the PHY_BRCM_AUTO_PWRDWN_ENABLE flag is set. The tg3 driver was changed to set this bit. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add PHY_BRCM_CLEAR_RGMII_MODE flagMatt Carlson
Broadcom 50610M parts changed the default definitions of the RGMII mode shadow register. The 5785 needs the RGMII mode selection bits [4:3] cleared. The default value of the remaining bits in this register are zero. Rather than unnecessarily burn an extra bit in the dev_flags member in an attempt to enumerate all possible combinations, this patch take a more course grained approach and labels the option as "clear all bits". Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Consolidate dev_flags definitionsMatt Carlson
This patch moves all the dev_flags enumerations outside the broadcom.c file to include/linux/brcmphy.h. The existing flags were not used yet and have been re-enumerated to avoid conflicts. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Fix slow link problemMatt Carlson
When a 50610 or 50610M is paired against particular remote partners, link is slow to come up. This patch works around the problem. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Isolate phy dsp accessesMatt Carlson
This patch consolidates the code that requires the SMDSP clock to be enabled into a single function that (hopefully) makes the dependency obvious. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26broadcom: Make the 57780 IEEE compliantMatt Carlson
This brings the 57780's phy into IEEE compliance by suppressing the common mode oscillation. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26broadcom: Add AC131 phy supportMatt Carlson
This patch adds support for the AC131 fast ethernet transceiver. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26broadcom: Add BCM50610M supportMatt Carlson
This patch adds support for the BCM50610M phy ID. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21broadcom: Add 57780 supportMatt Carlson
This patch adds the 57780 PHY ID to the broadcom module. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03broadcom: Add support for BCM50610Matt Carlson
This patch adds the BCM50610 to the list of phys supported by the broadcom driver. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03broadcom: Refine expansion register access routineMatt Carlson
This patch makes the expansion register access routines a little more formal. They will be used by the following bcm50610 support patch. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03broadcom: Add flow control supportMatt Carlson
This patch adds flow control support to Broadcom phys. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-22PHYLIB: Add 1000Base-X support for Broadcom bcm5482Nate Case
Configure the BCM5482S secondary SerDes for 1000Base-X mode when the appropriate dev_flags are passed in to phy_connect(). This is needed when the PHY is used for fiber and backplane connections. Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-17PHY: add BCM5464 support to broadcom PHY driverPaul Gortmaker
The BCM5464 can be used with the current broadcom PHY driver by just adding the appropriate chip ID and using the existing support within. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-26phy/broadcom: add support for BCM5481 PHYAnton Vorontsov
This patch adds support for BCM5481 PHY. Unfortunately it's hard to get specifications for this PHY, so its special register 0x18 isn't annotated properly (but we know it's used to set up the delays). I've kept the magic numbers, so we'll not forget to fix it at the first opportunity, and will name that register and its bits correctly. p.s. also fixed the line with broken indention, introduced by commit 03157ac31eb4a8883382a212b161d2e6c5059fbf PHYLIB: Add BCM5482 PHY support Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03PHYLIB: Add BCM5482 PHY supportNate Case
This Broadcom PHY is similar to other bcm54xx devices. Signed-off-by: Nate Case <ncase@xes-inc.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[PATCH] 2.6.18: sb1250-mac: Broadcom PHY supportMaciej W. Rozycki
This patch adds support for interrupt-driven operation of the Broadcom Gigabit Ethernet PHYs. I have included device IDs for the parts used on Broadcom SiByte evaluation boards; more can be added as a need arises. They are apparently generally software-compatible with one another. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> patch-mips-2.6.18-20060920-broadcom-phy-15 Signed-off-by: Jeff Garzik <jeff@garzik.org>
