path: root/drivers/net/phy/marvell.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-21phy: add RTBI mode for m88e1111Liu Yu-B13201
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYsAnton Vorontsov
According to specs, when auto-negotiation is disabled, Marvell PHYs need a software reset after changing speed/duplex forcing bits. Otherwise, the modified bits have no effect. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net/phy/marvell: update m88e1111 support for SGMII modeHaiying Wang
Disable fiber/copper auto selection for Marvell m88e1111 SGMII support. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13phylib: Add interrupt source check function to M88E1121R driverAnatolij Gustschin
Add did_interrupt() function to check if a PHY port really caused an interrupt. This is needed in the case of shared PHY interrupt pin configuration to stop interrupt event processing for PHY ports which didn't cause an interrupt. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13phylib: Basic support for the M88E1121R Marvell chipSergei Poselenov
Add support for the Marvell M88E1121R Dual GigE PHY Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-15phy: Add support for Marvell 88E1118 PHYRon Madrid
This patch will add support for the Marvell 88E1118 PHY which supports gigabit ethernet among other things. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22net/phy: Fix 88e1111 copper/fiber selection in RGMII modeWang Jian
MII_M1111_HWCFG_FIBER_COPPER_RES is a bit of MII_M1111_PHY_EXT_SR, not MII_M1111_PHY_EXT_CR. Signed-off-by: Wang Jian <lark@linux.net.cn> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22net/phy: Fix copper/fiber auto-selection for 88e1111Wang Jian
The 27.15 bit (MII_M1111_HWCFG_FIBER_COPPER_AUTO) is disable bit. When set to 1, copper/fiber auto selection is disabled. The current code to enable but actually disable auto selection. Signed-off-by: Wang Jian <lark@linux.net.cn> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-04net: marvell.c fix sparse shadowed variable warningHarvey Harrison
The other if blocks don't redeclare temp, remove the redeclaration in the final if() block. drivers/net/phy/marvell.c:214:7: warning: symbol 'temp' shadows an earlier one drivers/net/phy/marvell.c:160:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-25netxen, phy/marvell, skge: minor checkpatch fixesJeff Garzik
2008-03-25Marvell PHY m88e1111 driver fixAlexandr Smirnov
Marvell PHY m88e1111 (not sure about other models, but think they too) works in two modes: fiber and copper. In Marvell PHY driver (that we have in current community kernels) code supported only copper mode, and this is not configurable, bits for copper mode are simply written in registers during PHY initialization. This patch adds support for both modes. Signed-off-by: Alexandr Smirnov <asmirnov@ru.mvista.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01phylib: marvell: add support for TX-only and RX-only Internal DelayKim Phillips
Previously, Internal Delay specification implied the delay be applied to both TX and RX. This patch allows for separate TX/RX-only internal delay specification. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Tested-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-05phylib: Add ID for Marvell 88E1240Olof Johansson
Add PHY IDs for Marvell 88E1240. It seems to have close enough programming models to 1111/1112 for basic support at least. Also clean up whitespace in the ID list a bit. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10phylib: Add Marvell 88E1112 phy idOlof Johansson
Add 88E1112 PHY ID to the marvell driver. Seems to do fine with the 88E1111 inits. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10phylib: cleanup marvell.c a bitOlof Johansson
Simplify the marvell driver init a bit: Make the supported devices an array instead of explicitly registering each structure. This makes it considerably easier to add new devices down the road. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-08phylib: m88e1111: enable SGMII modeKapil Juneja
If connected via SGMII, initialize with SGMII mode configured. Signed-off-by: Kapil Juneja <Kapil.Juneja@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-09phylib: add RGMII-ID mode to the Marvell m88e1111 PHY to fix broken ucc_gethKim Phillips
Support for configuring RGMII-ID (RGMII with internal delay) mode on the 88e1111 and 88e1145. Ucc_geth on MPC8360EMDS(the main user of ucc_geth) is broken after changed to use phylib. It is fixed by adding this internal delay. Also renamed 88e1111s -> 88e1111 (no references to an 88e1111s part were found), and fixed some whitespace. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-17phylib: Add support for Marvell 88e1111S and 88e1145Andy Fleming
Changes include: * New support for 88e1145 * New support for 88e111s * Fixing 88e1101 driver to not match non-88e1101 PHYs * Increases in feature support across Marvell PHY product line * Fixes a bunch of whitespace issues found by Lindent Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-05Remove linux/version.h include from drivers/net/phy/* and net/ieee80211/*.Jeff Garzik
Unused, and causes the files to be needlessly rebuilt in some cases.
2005-07-30This patch adds a PHY Abstraction Layer to the Linux Kernel, enablingAndy Fleming
ethernet drivers to remain as ignorant as is reasonable of the connected PHY's design and operation details. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
