[ Upstream commit fdfdf86720a34527f777cbe0d8599bf0528fa146 ]
marvell_get_sset_count() returns how many statistics counters there
are. If the PHY supports fibre, there are 3, otherwise two.
marvell_get_strings() does not make this distinction, and always
returns 3 strings. This then often results in writing past the end
of the buffer for the strings.
Fixes: 2170fef78a40 ("Marvell phy: add field to get errors from fiber link.")
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit c505873eaece2b4aefd07d339dc7e1400e0235ac ]
88E1145 also need this autoneg errata.
Fixes: f2899788353c ("net: phy: marvell: Limit errata to 88m1101")
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
[ Upstream commit a13c06525ab9ff442924e67df9393a5efa914c56 ]
When an Marvell 88E1512 PHY is connected to a nic in SGMII mode, the
fiber page is used for the SGMII host-side connection. The PHY driver
notices that SUPPORTED_FIBRE is set, so it tries reading the fiber page
for the link status, and ends up reading the MAC-side status instead of
the outgoing (copper) link. This leads to incorrect results reported
via ethtool.
If the PHY is connected via SGMII to the host, ignore the fiber page.
However, continue to allow the existing power management code to
suspend and resume the fiber page.
Fixes: 6cfb3bcc0641 ("Marvell phy: check link status in case of fiber link.")
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 898805e0cdf7fd860ec21bf661d3a0285a3defbd upstream.
The Marvell driver incorrectly provides phydev->lp_advertising as the
logical and of the link partner's advert and our advert. This is
incorrect - this field is supposed to store the link parter's unmodified
advertisment.
This allows ethtool to report the correct link partner auto-negotiation
status.
Fixes: be937f1f89ca ("Marvell PHY m88e1111 driver fix")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
[ Upstream commit f2899788353c13891412b273fdff5f02d49aa40f ]
The 88m1101 has an errata when configuring autoneg. However, it was
being applied to many other Marvell PHYs as well. Limit its scope to
just the 88m1101.
Fixes: 76884679c644 ("phylib: Add support for Marvell 88e1111S and 88e1145")
Reported-by: Daniel Walker <danielwa@cisco.com>
Acked-by: Harini Katakam <harinik@xilinx.com>
copper links.
These functions used standards registers in a different page
for both interfaces: copper and fiber.
Signed-off-by: Charles-Antoine Couret <charles-antoine.couret@nexvision.fr>
To be correctly initilized, the fiber interface needs
to be configured via autonegociation registers which use
some customs options or registers.
Add support for the fiber receiver error counter in the
statistics. Rename the current counter which is for copper errors to
phy_receive_errors_copper, so it is easy to distinguish copper from
fiber.
For concerned phy, the fiber link is checked before the copper link.
According to datasheet, the link which is up is enabled.
If both links are down, copper link would be used.
To detect fiber link status, we used the real time status
because of troubles with the copper method.
Tested with Marvell 88E1512.
Marvell 88E1111 currently uses the generic marvell config ANEG function.
This function has a sequence accessing Page 5 and Register 31,
both of which are not defined or reserved for this PHY.
Hence this patch adds a new config ANEG function for Marvell 88E1111
without these erroneous accesses.
Signed-off-by: Harini Katakam <harinik@xilinx.com>
Configuring the PHY LED registers for the Marvell 88E1510 and others is
not possible, because regardless of the values in marvell,reg-init, it
is later overridden in m88e1121_config_aneg with a non-standard default.
This patch moves that default configuration to .config_init to allow
setting the LED configuration through marvell,reg-init in the device
tree, which should override said default if it exists.
Signed-off-by: Clemens Gruber <clemens.gruber@pqgruber.com>
A bug was introduced in the merge commit b633353115e3 ("Merge
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net")
The generic marvell_config_init (and therefore marvell_of_reg_init) is
not called anymore for the Marvell 88E1510 (in net-next).
This patch calls marvell_config_init and moves the specific init
function for the 88E1510 below the marvell_config_init function to avoid
adding a function predeclaration.
drivers/net/phy/bcm7xxx.c
drivers/net/phy/marvell.c
drivers/net/vxlan.c
All three conflicts were cases of simple overlapping changes.
commit 2b2427d06426 ("phy: micrel: Add ethtool statistics counters")
from Dec 30, 2015, leads to the following static checker
warning:
drivers/net/phy/micrel.c:609 kszphy_get_stat()
warn: unsigned 'val' is never less than zero.
602 static u64 kszphy_get_stat(struct phy_device *phydev, int i)
603 {
604 struct kszphy_hw_stat stat = kszphy_hw_stats[i];
605 struct kszphy_priv *priv = phydev->priv;
606 u64 val;
607
608 val = phy_read(phydev, stat.reg);
609 if (val < 0) {
Unpossible!
610 val = UINT64_MAX;
611 } else {
612 val = val & ((1 << stat.bits) - 1);
613 priv->stats[i] += val;
614 val = priv->stats[i];
615 }
616
617 return val;
618 }
The same problem exists in the Marvell driver. Fix both.
Fixes: 2b2427d06426 ("phy: micrel: Add ethtool statistics counters")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reported-by: Julia.Lawall <julia.lawall@lip6.fr>
Add code to select SGMII-to-copper mode upon SGMII interface selection.
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Florian Fainelli <f.fainelli@gmail.com>
For the Marvell 88E1510, marvell_of_reg_init was called too late, in the
config_aneg function.
Since commit 113c74d83eef ("net: phy: turn carrier off on phy attach"),
this lead to the link not coming up at boot anymore, due to the phy
state machine being stuck at waiting for interrupts (off by default on
the 88E1510).
For seven other Marvell PHYs, marvell_of_reg_init was not called at all.
Add a generic marvell_config_init function, which in turn calls
marvell_of_reg_init.
PHYs, which already have a specific config_init function with a call to
marvell_of_reg_init, are left untouched. The generic marvell_config_init
function is called for all the others, to get consistent behavior across
all Marvell PHYs.
Fixes: 113c74d83eef ("net: phy: turn carrier off on phy attach")
Rather than have each driver set the driver owner field, do it once in
the core code. This will also help with later changes, when the device
structure will move.
Not all devices attached to an MDIO bus are phys. So add an
mdio_device structure to represent the generic parts of an mdio
device, and place this structure into the phy_device.
The PHY counters receiver errors and errors while idle.
The 88E1540 can be found embedded in the Marvell 88E6352 switch. It
is compatible with the 88E1510, so add support for it, using the
88E1510 specific functions.
Read the standard link partner advertisment registers and store it in
phydev->lp_advertising, so ethtool can report this information to
userspace via ethtool. Zero it as per genphy if autonegotiation is
disabled. Tested with a Marvell 88E1512 PHY.
For the Marvel 88e1111 PHY only two SGMII modes are available, both
allowing only SGMII to copper mode (with or without clock). SGMII
to fiber mode is not supported. Make sure the fiber/copper registers
selector bits are cleared for selecting copper mode.
Signed-off-by: Madalin Bucur <madalin.bucur@freescale.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Support manually setting the polarity to mdi or mdix
Signed-off-by: David Thomson <david.thomson@alliedtelesis.co.nz>
Update all open-coded tests for all 4 PHY_INTERFACE_MODE_RGMII* values
to use the newly introduced helper: phy_interface_is_rgmii.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Replace module init/exit which only calls phy_drivers_register with
module_phy_driver macro.
Tested using Micrel driver, and otherwise compile-tested only.
Signed-off-by: Johan Hovold <johan@kernel.org>
Simple overlapping changes in drivers/net/phy/marvell.c
Marvell phy 88E1145 configuration & initialization was missing a case
for initializing SGMII mode. This patch adds that case.
Signed-off-by: Vince Bridgers <vbridger@opensource.altera.com>
Additional code to m88e1145_config_init function to allow the driver to
support SGMII mode.
Signed-off-by: Viet Nga Dao <vndao@altera.com>
Marvell 88E3016 is a FastEthernet PHY that also can be found in Marvell
Berlin SoCs as integrated PHY.
Tested-by: Antoine Ténart <antoine.tenart@free-electrons.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Marvell PHYs support generic PHY suspend/resume, so provide those
callbacks to all marvell specific drivers.
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
removes following warnings-
drivers/net/phy/marvell.c:37: WARNING: Use #include <linux/io.h> instead of <asm/io.h>
drivers/net/phy/marvell.c:39: WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
Signed-off-by: Avinash Kumar <avi.kp.137@gmail.com>
Add support for this new phy ID.
Signed-off-by: Rick Hoover <RHoover@digilentinc.com>
Signed-off-by: Steven Wang <steven.wang@digilentinc.com>
This phy is on Xilinx ZC702 zynq development board.
Signed-off-by: Anirudha Sarangi <anirudh@xilinx.com>
Use macros from linux/marvell_phy.h instead of duplicate
magic phy ID in the driver.
This has been tested on a qnap TS-119P II. Note that enabling WOL with
"ethtool -s eth0 wol g" is not enough; you also need to tell the PIC
microcontroller inside the qnap that WOL should be enabled by sending
0xF2 with qcontrol(1) and you have to disable EUP ("Energy-using
Products", a European power-saving thing) by sending 0xF4.
Signed-off-by: Michael Stapelberg <michael@stapelberg.de>
Remove the code that always enables copper/fiber autoselect,
ignoring the DIS_FC strapping pin. The default value for this
register is autoselect on anyway, and if you explicitly disable
autoselect via strapping you probably really don't want
autoselect.
Signed-off-by: Stef van Os <stef.van.os@prodrive.nl>
If registering of one of them fails, all already registered drivers
of this module will be unregistered.
Use the new register/unregister functions in all drivers
registering more than one driver.
amd.c, realtek.c: Simplify: directly return registration result.
Tested with broadcom.c
All others compile-tested.
Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com>
Compile tested.
remove unnecessary code that matches this coccinelle pattern
ret = phy_write(x, y , z)
if (ret < 0)
return ret;
return 0;
As phy_write returns error code, we dont need to do not need extra check
before returning.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Some aspects of PHY initialization are board dependent, things like
indicator LED connections and some clocking modes cannot be determined
by probing. The dev_flags element of struct phy_device can be used to
control these things if an appropriate value can be passed from the
Ethernet driver. We run into problems however if the PHY connections
are specified by the device tree. There is no way for the Ethernet
driver to know what flags it should pass.
If we are using the device tree, the struct phy_device will be
populated with the device tree node corresponding to the PHY, and we
can extract extra configuration information from there.
The next question is what should the format of that information be?
It is highly device specific, and the device tree representation
should not be tied to any arbitrary kernel defined constants. A
straight forward representation is just to specify the exact bits that
should be set using the "marvell,reg-init" property:
phy5: ethernet-phy@5 {
reg = <5>;
compatible = "marvell,88e1149r";
marvell,reg-init =
/* led[0]:1000, led[1]:100, led[2]:10, led[3]:tx */
<3 0x10 0 0x5777>, /* Reg 3,16 <- 0x5777 */
/* mix %:0, led[0123]:drive low off hiZ */
<3 0x11 0 0x00aa>, /* Reg 3,17 <- 0x00aa */
/* default blink periods. */
<3 0x12 0 0x4105>, /* Reg 3,18 <- 0x4105 */
/* led[4]:rx, led[5]:dplx, led[45]:drive low off hiZ */
<3 0x13 0 0x0a60>; /* Reg 3,19 <- 0x0a60 */
phy6: ethernet-phy@6 {
reg = <6>;
compatible = "marvell,88e1118";
marvell,reg-init =
/* Fix rx and tx clock transition timing */
<2 0x15 0xffcf 0>, /* Reg 2,21 Clear bits 4, 5 */
/* Adjust LED drive. */
<3 0x11 0 0x442a>, /* Reg 3,17 <- 0442a */
/* irq, blink-activity, blink-link */
<3 0x10 0 0x0242>; /* Reg 3,16 <- 0x0242 */
The Marvell PHYs have a page select register at register 22 (0x16), we
can specify any register by its page and register number. These are
the first and second word. The third word contains a mask to be ANDed
with the existing register value, and the fourth word is ORed with the
result to yield the new register value. The new marvell_of_reg_init
function leaves the page select register unchanged, so a call to it
can be dropped into the .config_init functions without unduly
affecting the state of the PHY.
If CONFIG_OF_MDIO is not set, there is no of_node, or no
"marvell,reg-init" property, the PHY initialization is unchanged.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Cyril Chemparathy <cyril@ti.com>
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Reviewed-by: Grant Likely <grant.likely@secretlab.ca>
The 88E1149R is 10/100/1000 quad-gigabit Ethernet PHY. The
.config_aneg function can be shared with 88E1118, but it needs its own
.config_init.
Cc: Wolfram Sang <w.sang@pengutronix.de>
The definition of the Marvell PHY page register is not specific to
88E1121, so rename the macro to MII_MARVELL_PHY_PAGE, and use it
throughout.
Suggested-by: Cyril Chemparathy <cyril@ti.com>
The marvell 88ec048's official part number is 88e1318s. This patch renames
definitions in the driver to reflect this.
In addition, a minor bug fix has been added to write back the MSCR1 register
value properly.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
Commit c477d0447db08068a497e7beb892b2b2a7bff64b added support for RGMII
rx/tx delays except that it ends up clearing rx/tx delays bit for modes
differents that RGMII*ID. Due to this, ethernet is not working anymore
on my guruplug server +. This patch is fixing that.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
MODULE_DEVICE_TABLE only expands to something if it's compiled
for a module. So when building-in support for the phys, the
mdio_device_id tables are unused. Marking them with __maybe_unused
fixes the following warnings:
drivers/net/phy/bcm63xx.c:134: warning: 'bcm63xx_tbl' defined but not used
drivers/net/phy/broadcom.c:933: warning: 'broadcom_tbl' defined but not used
drivers/net/phy/cicada.c:162: warning: 'cicada_tbl' defined but not used
drivers/net/phy/davicom.c:222: warning: 'davicom_tbl' defined but not used
drivers/net/phy/et1011c.c:114: warning: 'et1011c_tbl' defined but not used
drivers/net/phy/icplus.c:137: warning: 'icplus_tbl' defined but not used
drivers/net/phy/lxt.c:226: warning: 'lxt_tbl' defined but not used
drivers/net/phy/marvell.c:724: warning: 'marvell_tbl' defined but not used
drivers/net/phy/micrel.c:234: warning: 'micrel_tbl' defined but not used
drivers/net/phy/national.c:154: warning: 'ns_tbl' defined but not used
drivers/net/phy/qsemi.c:141: warning: 'qs6612_tbl' defined but not used
drivers/net/phy/realtek.c:82: warning: 'realtek_tbl' defined but not used
drivers/net/phy/smsc.c:257: warning: 'smsc_tbl' defined but not used
drivers/net/phy/ste10Xp.c:135: warning: 'ste10Xp_tbl' defined but not used
drivers/net/phy/vitesse.c:195: warning: 'vitesse_tbl' defined but not used
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits)
phy/marvell: add 88ec048 support
igb: Program MDICNFG register prior to PHY init
e1000e: correct MAC-PHY interconnect register offset for 82579
hso: Add new product ID
can: Add driver for esd CAN-USB/2 device
l2tp: fix export of header file for userspace
can-raw: Fix skb_orphan_try handling
Revert "net: remove zap_completion_queue"
net: cleanup inclusion
phy/marvell: add 88e1121 interface mode support
u32: negative offset fix
net: Fix a typo from "dev" to "ndev"
igb: Use irq_synchronize per vector when using MSI-X
ixgbevf: fix null pointer dereference due to filter being set for VLAN 0
e1000e: Fix irq_synchronize in MSI-X case
e1000e: register pm_qos request on hardware activation
ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice
net: Add getsockopt support for TCP thin-streams
cxgb4: update driver version
cxgb4: add new PCI IDs
Manually fix up conflicts in:
- drivers/net/e1000e/netdev.c: due to pm_qos registration
infrastructure changes
- drivers/net/phy/marvell.c: conflict between adding 88ec048 support
and cleaning up the IDs
- drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req
conflict (registration change vs marking it static)
Marvell 88ec048 is a derivative of its 88e1121r device. From the programmer's
perspective, the one major difference is the addition of an additional control
bit in Page 2 Register 16 - used to control the padding of odd nibble
preambles.
This patch adds support for this new device, while inheriting as much code as
possible from the existing 88e1121r implementation.
This patch adds support for RGMII RX/TX delay configuration on marvell 88e1121
and derivatives. With this patch, PHY_INTERFACE_MODE_RGMII_*ID modes are now
supported on these devices.
This moves the various known Marvell PHY IDs to include/linux/marvell_phy.h
along with dev_flags definitions for use by the driver.
I then added a flag that changes the PHY init code to setup the LEDs
config to the values needed to operate a dns323 rev C1 NAS.
I moved the existing "resistance" flag to the .h as well, though I've
been unable to find whoever sets this to convert it to use that constant.
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
