path: root/drivers/net/phy/mdio_bus.c
2010-09-14phylib: fix PAL state machine restart on resumeSimon Guinot
On resume, before starting the PAL state machine, check if the adjust_link() method is well supplied. If not, this would lead to a NULL pointer dereference in the phy_state_machine() function. This scenario can happen if the Ethernet driver call manually the PHY functions instead of using the PAL state machine. The mv643xx_eth driver is a such example. Signed-off-by: Simon Guinot <sguinot@lacie.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16NET: Support clause 45 MDIO commands at the MDIO bus levelJason Gunthorpe
IEEE 802.3ae clause 45 specifies a somewhat modified MDIO protocol for use by 10GIGE phys. The main change is a 21 bit address split into a 5 bit device ID and a 16 bit register offset. The definition is designed so that normal and extended devices can run on the same MDIO bus. Extend mdio-bitbang to do the new protocol. At the MDIO bus level the protocol is requested by or'ing MII_ADDR_C45 into the register offset. Make phy_read/phy_write/etc pass a full 32 bit register offset. This does not attempt to make the phy layer support C45 style PHYs, just to provide the MDIO bus support. Tested against a Broadcom 10GE phy with ID 0x206034, and several Broadcom 10/100/1000 Phys in normal mode. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-30phylib: Properly reinitialize PHYs after hibernationAnton Vorontsov
Since hibernation assumes power loss, we should fully reinitialize PHYs (including platform fixups), as if PHYs were just attached. This patch factors phy_init_hw() out of phy_attach_direct(), then converts mdio_bus to dev_pm_ops and adds an appropriate restore() callback. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-30phylib: Fix deadlock on resumeAnton Vorontsov
Sometimes kernel hangs on resume with the following trace: ucc_geth e0102000.ucc: resume INFO: task bash:1764 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. bash D 0fecf43c 0 1764 1763 0x00000000 Call Trace: [cf9a7c10] [c0012868] ret_from_except+0x0/0x14 (unreliable) --- Exception: cf9a7ce0 at __switch_to+0x4c/0x6c LR = 0xcf9a7cc0 [cf9a7cd0] [c0008c14] __switch_to+0x4c/0x6c (unreliable) [cf9a7ce0] [c028bcfc] schedule+0x158/0x260 [cf9a7d10] [c028c720] __mutex_lock_slowpath+0x80/0xd8 [cf9a7d40] [c01cf388] phy_stop+0x20/0x70 [cf9a7d50] [c01d514c] ugeth_resume+0x6c/0x13c [...] Here is why. On suspend: - PM core starts suspending devices, ucc_geth_suspend gets called; - ucc_geth calls phy_stop() on suspend. Note that phy_stop() is mostly asynchronous so it doesn't block ucc_geth's suspend routine, it just sets PHY_HALTED state and disables PHY's interrupts; - Suddenly the state machine gets scheduled, it grabs the phydev->lock mutex and tries to process the PHY_HALTED state, so it calls phydev->adjust_link(phydev->attached_dev). In ucc_geth case adjust_link() calls msleep(), which reschedules the code flow back to PM core, which now finishes suspend and so we end up sleeping with phydev->lock mutex held. On resume: - PM core starts resuming devices (notice that nobody rescheduled the state machine yet, so the mutex is still held), the core calls ucc_geth's resume routine; - ucc_geth_resume restarts the PHY with phy_stop()/phy_start() sequence, and the phy_*() calls are trying to grab the phydev->lock mutex. Here comes the deadlock. This patch fixes the issue by stopping the state machine on suspend and starting it again on resume. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27phylib: rework to prepare for OF registration of PHYsGrant Likely
This patch makes changes in preparation for supporting open firmware device tree descriptions of MDIO busses. Changes include: - Cleanup handling of phy_map[] entries; they are already NULLed when registering and so don't need to be re-cleared, and it is good practice to clear them out when unregistering. - Split phy_device registration out into a new function so that the OF helpers can do two stage registration (separate allocation and registration steps). Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26mdio: fix non-constant printk warningsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01phylib: Rework suspend/resume code to check netdev wakeup capabilityAnton Vorontsov
In most cases (e.g. PCI drivers) MDIO and MAC controllers are represented by the same device. But for SOC ethernets we have separate devices. So, in SOC case, checking whether MDIO controller may wakeup is not only makes little sense, but also prevents us from doing per-netdevice wakeup management. This patch reworks suspend/resume code so that now it checks for net device's wakeup flags, not MDIO controller's ones. Each netdevice should manage its wakeup flags, and phylib will decide whether suspend an attached PHY or not. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22phylib: Fix oops in suspend/resume pathsAnton Vorontsov
Suspend/resume routines check for phydrv != NULL, but that is wrong because "phydrv" comes from container_of(drv). If drv is NULL, then container_of(drv) will return non-NULL result, and the checks won't work. The Freescale TBI PHYs are driver-less, so "drv" is NULL, and that leads to the following oops: Unable to handle kernel paging request for data at address 0xffffffe4 Faulting instruction address: 0xc0215554 Oops: Kernel access of bad area, sig: 11 [#1] [...] NIP [c0215554] mdio_bus_suspend+0x34/0x70 LR [c01cc508] suspend_device+0x258/0x2bc Call Trace: [cfad3da0] [cfad3db8] 0xcfad3db8 (unreliable) [cfad3db0] [c01cc508] suspend_device+0x258/0x2bc [cfad3dd0] [c01cc62c] dpm_suspend+0xc0/0x140 [cfad3e20] [c01cc6f4] device_suspend+0x48/0x5c [cfad3e40] [c0068dd8] suspend_devices_and_enter+0x8c/0x148 [cfad3e60] [c00690f8] enter_state+0x100/0x118 [cfad3e80] [c00691c0] state_store+0xb0/0xe4 [cfad3ea0] [c018c938] kobj_attr_store+0x24/0x3c [cfad3eb0] [c00ea9a8] flush_write_buffer+0x58/0x7c [cfad3ed0] [c00eadf0] sysfs_write_file+0x58/0xa0 [cfad3ef0] [c009e810] vfs_write+0xb4/0x16c [cfad3f10] [c009ed40] sys_write+0x4c/0x90 [cfad3f40] [c0014954] ret_from_syscall+0x0/0x38 [...] This patch fixes the issue, plus removes unneeded parentheses and fixes indentation level in mdio_bus_suspend(). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25net: PHYLIB mdio fixes #2Krzysztof Halasa
The PHYLIB mdio code has more problems in error paths: - mdiobus_release can be called before bus->state is set to MDIOBUS_REGISTERED - mdiobus_scan allocates resources which need to be freed - the comment is wrong, the resistors used are actually pull-ups. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ppp_generic.c
2008-12-17net: kernel BUG at drivers/net/phy/mdio_bus.c:165!Krzysztof Halasa
kernel BUG at drivers/net/phy/mdio_bus.c:165! Unable to handle kernel NULL pointer dereference at virtual address 00000000 How? mdiobus_alloc() sets bus->state = MDIOBUS_ALLOCATED. mdiobus_register() sets bus->state = MDIOBUS_REGISTERED but then can fail (mdiobus_scan()) returning an error to the caller. The caller aborts correctly with mdiobus_free() which does: if (bus->state == MDIOBUS_ALLOCATED) { kfree(bus); return; } BUG_ON(bus->state != MDIOBUS_UNREGISTERED); Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-28phy: power management supportGiuseppe Cavallaro
This patch adds the power management support into the physical abstraction layer. Suspend and resume functions respectively turns on/off the bit 11 into the PHY Basic mode control register. Generic PHY device starts supporting PM. In order to support the wake-on LAN and avoid to put in power down the PHY device, the MDIO is aware of what the Ethernet device wants to do. Voluntary, no CONFIG_PM defines were added into the sources. Also generic suspend/resume functions are exported to allow other drivers use them (such as genphy_config_aneg etc.). Within the phy_driver_register function, we need to remove the memset. It overrides the device driver owner and it is not good. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-14phylib: fix premature freeing of struct mii_busLennert Buytenhek
Commit 46abc02175b3c246dd5141d878f565a8725060c9 ("phylib: give mdio buses a device tree presence") added a call to device_unregister() in a situation where the caller did not intend for the device to be freed yet, but apart from just unregistering the device from the system, device_unregister() does an additional put_device() that is intended to free it. The right function to use in this situation is device_del(), which unregisters the device from the system like device_unregister() does, but without dropping the reference count an additional time. Bug report from Bryan Wu <cooloney@kernel.org>. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Tested-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-10net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13net/phy: add missing kernel-docRandy Dunlap
Fix kernel-doc warning, missing description: Warning(lin2627-g3-kdocfixes//drivers/net/phy/mdio_bus.c:63): No description found for parameter 'd' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08phylib: add mdiobus_{read,write}Lennert Buytenhek
Add mdiobus_{read,write} routines to allow direct reading/writing of registers on an mii bus without having to go through the PHY abstraction, and make phy_{read,write} use these primitives. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08phylib: give mdio buses a device tree presenceLennert Buytenhek
Introduce the mdio_bus class, and give each 'struct mii_bus' its own 'struct device', so that mii_bus objects are represented in the device tree and can be found by querying the device tree. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08phylib: move to dynamic allocation of struct mii_busLennert Buytenhek
This patch introduces mdiobus_alloc() and mdiobus_free(), and makes all mdio bus drivers use these functions to allocate their struct mii_bus'es dynamically. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-08phylib: rename mii_bus::dev to mii_bus::parentLennert Buytenhek
In preparation of giving mii_bus objects a device tree presence of their own, rename struct mii_bus's ->dev argument to ->parent, since having a 'struct device *dev' that points to our parent device conflicts with introducing a 'struct device dev' representing our own device. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Andy Fleming <afleming@freescale.com>
2008-09-19phylib: allow incremental scanning of an mii busLennert Buytenhek
This patch splits the bus scanning code in mdiobus_register() off into a separate function, and makes this function available for calling from external code. This allows incrementally scanning an mii bus, e.g. as information about which addresses are 'safe' to scan becomes available. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-04-25phylib: Add support for board-level PHY fixupsAndy Fleming
Sometimes the specific interaction between the platform and the PHY requires special handling. For instance, to change where the PHY's clock input is, or to add a delay to account for latency issues in the data path. We add a mechanism for registering a callback with the PHY Lib to be called on matching PHYs when they are brought up, or reset. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-23net/phy/mdio_bus.c: fix a check-after-useAdrian Bunk
This patch fixes a check-after-use spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03PHYLIB: Locking fixes for PHY I/O potentially sleepingNate Case
PHY read/write functions can potentially sleep (e.g., a PHY accessed via I2C). The following changes were made to account for this: * Change spin locks to mutex locks * Add a BUG_ON() to phy_read() phy_write() to warn against calling them from an interrupt context. * Use work queue for PHY state machine handling since it can potentially sleep * Change phydev lock from spinlock to mutex Signed-off-by: Nate Case <ncase@xes-inc.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-04PHY: Add the phy_device_release device method.Anton Vorontsov
Lately I've got this nice badness on mdio bus removal: Device 'e0103120:06' does not have a release() function, it is broken and must be fixed. ------------[ cut here ]------------ Badness at drivers/base/core.c:107 NIP: c015c1a8 LR: c015c1a8 CTR: c0157488 REGS: c34bdcf0 TRAP: 0700 Not tainted (2.6.23-rc5-g9ebadfbb-dirty) MSR: 00029032 <EE,ME,IR,DR> CR: 24088422 XER: 00000000 ... [c34bdda0] [c015c1a8] device_release+0x78/0x80 (unreliable) [c34bddb0] [c01354cc] kobject_cleanup+0x80/0xbc [c34bddd0] [c01365f0] kref_put+0x54/0x6c [c34bdde0] [c013543c] kobject_put+0x24/0x34 [c34bddf0] [c015c384] put_device+0x1c/0x2c [c34bde00] [c0180e84] mdiobus_unregister+0x2c/0x58 ... Though actually there is nothing broken, it just device subsystem core expects another "pattern" of resource managment. This patch implement phy device's release function, thus we're getting rid of this badness. Also small hidden bug fixed, hope none other introduced. ;-) Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-28phy: Fix phy_id for Vitesse 824x PHYKumar Gala
The phy_id specified for the Vitesse 824x PHY would never match because it was expecting bits to be set that would be masked by the phy_id_mask. Fix the phy_id so it will match properly, and changed the mdio_bus_match to mask both the driver and devices phy_id with the mask so we dont have this issue in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-28phy layer: add kernel-doc + DocBookRandy Dunlap
Convert function documentation in drivers/net/phy/ to kernel-doc and add it to DocBook. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-19[PATCH] PAL: Support of the fixed PHYVitaly Bordug
This makes it possible for HW PHY-less boards to utilize PAL goodies. Generic routines to connect to fixed PHY are provided, as well as ability to specify software callback that fills up link, speed, etc. information into PHY descriptor (the latter feature not tested so far). Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-10phy: mdiobus_register(): initialize all phy_map entriesHerbert Valerio Riedel
make sure phy_map entries whose PHY address is masked are initialized to NULL, given that other code (such as mdiobus_unregister for instance) assumes that non-NULL phy_map entries are allocated phy_devices Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-01-12[PATCH] phy: Added a macro to represent the string format used to match a ↵Kumar Gala
phy device Add the PHY_ID_FMT macro to ensure that the format of the id string used by a driver to match to its specific phy is consistent between the mdio_bus and the driver. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05Remove linux/version.h include from drivers/net/phy/* and net/ieee80211/*.Jeff Garzik
Unused, and causes the files to be needlessly rebuilt in some cases.
2005-11-05[PATCH] phy address mask support for generic phy layerMatt Porter
Adds a phy_mask field to struct mii_bus and uses it. This field indicates each phy address to be ignored when probing the mdio bus. This support is needed for the fs_enet and ibm_emac drivers to be converted to the generic phy layer among other drivers. Many systems lock up on probing certain phy addresses or probing doesn't return 0xffff when nothing is found at the address. A new driver I'm working on also makes use of this mask. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] 'mdio_bus_exit' in discarded section .text.exitPeter Chubb
When building with CONFIG_PHYLIB=y on Itanium, I see: `mdio_bus_exit' referenced in section `.init.text' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o I believe that mdio_bus_exit should not be declared __exit, because it is referencesd from __init sections in, say, phy_init(). Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-05[PATCH] swsusp: fix remaining u32 vs. pm_message_t confusionPavel Machek
Fix remaining bits of u32 vs. pm_message confusion. Should not break anything. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-28[PATCH] PHY Layer fixupAndy Fleming
This patch adds back the code that was taken out, thus re-enabling: * The PHY Layer to initialize without crashing * Drivers to actually connect to PHYs * The entire PHY Control Layer This patch is used by the gianfar driver, and other drivers which are in development. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11phy subsystem: more cleanupsJeff Garzik
- unexport symbols never used outside of home module - remove dead code - remove CONFIG_PHYCONTROL, make it unconditionally enabled
2005-08-11Fix numerous minor problems with new phy subsystem.Jeff Garzik
Includes fixes for problems noted by Adrian Bunk, Andrew Morton, and one other person lost in the annals of history (and email folders).
2005-07-30This patch adds a PHY Abstraction Layer to the Linux Kernel, enablingAndy Fleming
ethernet drivers to remain as ignorant as is reasonable of the connected PHY's design and operation details. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
