path: root/drivers/net/phy/phy_device.c
2014-08-22phylib: use MDIO_DEVS[12]Sergei Shtylyov
The bare register numbers are used despite <uapi/linux/mdio.h> has MDIO_DEVS[12] #define'd for those. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-07-29net: phy: re-apply PHY fixups during phy_register_deviceFlorian Fainelli
Commit 87aa9f9c61ad ("net: phy: consolidate PHY reset in phy_init_hw()") moved the call to phy_scan_fixups() in phy_init_hw() after a software reset is performed. By the time phy_init_hw() is called in phy_device_register(), no driver has been bound to this PHY yet, so all the checks in phy_init_hw() against the PHY driver and the PHY driver's config_init function will return 0. We will therefore never call phy_scan_fixups() as we should. Fix this by calling phy_scan_fixups() and check for its return value to restore the intended functionality. This broke PHY drivers which do register an early PHY fixup callback to intercept the PHY probing and do things like changing the 32-bits unique PHY identifier when a pseudo-PHY address has been used, as well as board-specific PHY fixups that need to be applied during driver probe time. Reported-by: Hauke Merthens <hauke-m@hauke-m.de> Reported-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-24net: phy: Ensure the MDIO bus module is heldEzequiel Garcia
This commit adds proper module_{get,put} to prevent the MDIO bus module from being unloaded while the phydev is connected. By doing so, we fix a kernel panic produced when a MDIO driver is removed, but the phydev that relies on it is attached and running. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-08net: phy: export phy_suspend and phy_resumeFlorian Fainelli
phy_suspend and phy_resume are two commonly used helper functions that need to be exported for Ethernet drivers to be built as modules Fixes: 40755a0fce17 ("net: systemport: add suspend and resume support") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/bonding/bond_alb.c drivers/net/ethernet/altera/altera_msgdma.c drivers/net/ethernet/altera/altera_sgdma.c net/ipv6/xfrm6_output.c Several cases of overlapping changes. The xfrm6_output.c has a bug fix which overlaps the renaming of skb->local_df to skb->ignore_df. In the Altera TSE driver cases, the register access cleanups in net-next overlapped with bug fixes done in net. Similarly a bug fix to send ALB packets in the bonding driver using the right source address overlaps with cleanups in net-next. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-22net: phy: make of_set_phy_supported work with genphy driverSascha Hauer
of_set_phy_supported allows overwiting hardware capabilities of a phy with values from the devicetree. of_set_phy_supported is called right after phy_device_register in the assumption that phy_probe is called from phy_device_register and the features of the phy are already initialized. For the genphy driver this is not true, here phy_probe is called later during phy_connect time. phy_probe will then overwrite all settings done from of_set_phy_supported Fix this by moving of_set_phy_supported to the core phy code and calling it from phy_probe. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-22net: phy: genphy: Allow overwriting featuresSascha Hauer
of_set_phy_supported allows overwiting hardware capabilities of a phy with values from the devicetree. This does not work with the genphy driver though because the genphys config_init function will overwrite all values adjusted by of_set_phy_supported. Fix this by initialising the genphy features in the phy_driver struct and in config_init just limit the features to the ones the hardware can actually support. The resulting features are a subset of the devicetree specified features and the hardware features. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-15net: phy: Don't call phy_resume if phy_init_hw failedGuenter Roeck
After the call to phy_init_hw failed in phy_attach_direct, phy_detach is called to detach the phy device from its network device. If the attached driver is a generic phy driver, this also detaches the driver. Subsequently phy_resume is called, which assumes without checking that a driver is attached to the device. This will result in a crash such as Unable to handle kernel paging request for data at address 0xffffffffffffff90 Faulting instruction address: 0xc0000000003a0e18 Oops: Kernel access of bad area, sig: 11 [#1] ... NIP [c0000000003a0e18] .phy_attach_direct+0x68/0x17c LR [c0000000003a0e6c] .phy_attach_direct+0xbc/0x17c Call Trace: [c0000003fc0475d0] [c0000000003a0e6c] .phy_attach_direct+0xbc/0x17c (unreliable) [c0000003fc047670] [c0000000003a0ff8] .phy_connect_direct+0x28/0x98 [c0000003fc047700] [c0000000003f0074] .of_phy_connect+0x4c/0xa4 Only call phy_resume if phy_init_hw was successful. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-20net: phy: export genphy_config_init()Daniel Mack
This enables other drivers to call this generic implementation, and then only do specific details on top of it. Signed-off-by: Daniel Mack <zonque@gmail.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: Documentation/devicetree/bindings/net/micrel-ks8851.txt net/core/netpoll.c The net/core/netpoll.c conflict is a bug fix in 'net' happening to code which is completely removed in 'net-next'. In micrel-ks8851.txt we simply have overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14net: phy: fix uninitalized ethtool_wolinfo in phy_suspendSebastian Hesselbarth
Callers of phy_ethtool_get_wol are supposed to provide a properly cleared struct ethtool_wolinfo. Therefore, fix phy_suspend to clear it before passing it to phy_ethtool_get_wol. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c net/ipv6/sit.c The SIT driver conflict consists of a bug fix being done by hand in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper was created (netdev_alloc_pcpu_stats()) which takes care of this. The two wireless conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-25phy: unmask link partner capabilitiesCristian Bercaru
Masking the link partner's capabilities with local capabilities can be misleading in autonegotiation scenarios such as PAUSE frame autonegotiation. This patch calculates the join between the local capabilities and the link parner capabilities, when it determines the speed and duplex settings, but does not mask any of the link partner capabilities when it calculates PAUSE frame settings. Signed-off-by: Cristian Bercaru <cristian.bercaru@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17net: phy: allow PHY drivers to implement their own software resetFlorian Fainelli
As pointed out by Shaohui, most 10G PHYs out there have a non-standard compliant software reset sequence, eventually something much more complex than just toggling the BMCR_RESET bit. Allow PHY driver to implement their own soft_reset() callback to deal with that. If no callback is provided, call into genphy_soft_reset() which makes sure the existing behavior is kept intact. Reported-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-17net: phy: move PHY software reset to genphy_soft_resetFlorian Fainelli
As pointed out by Shaohui, this function is generic for 10/100/1000 PHYs, but 10G PHYs might have a slightly different reset sequence which prevents most of them from using this function. Move the BMCR_RESET based software resent sequence to genphy_soft_reset() in preparation for allowing PHY drivers to implement a soft_reset() callback. Reported-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-12net: phy: add "has_fixups" boolean propertyFlorian Fainelli
Add a boolean property which indicates if the PHY has had any fixup routine ran on it. We are later going to use that boolean to expose it as a sysfs property to help troubleshooting. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-12net: phy: allow driver to implement their own aneg_doneFlorian Fainelli
Some PHYs out there can be very quirky with respect to how they would report the auto-negotiation is completed. Allow drivers to override the generic aneg_done() implementation by providing their own. Since not all drivers have been updated yet to use genphy_aneg_done() as aneg_done() callback, we explicitely check that this callback is valid before calling into it. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-12net: phy: add genphy_aneg_done()Florian Fainelli
In preparation for allowing PHY drivers to potentially override their auto-negotiation done callback, move the contents of phy_aneg_done() to genphy_aneg_done() since that function really is the generic implementation based on the BMSR_ANEGCOMPLETE status. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-04net: phy: ensure Gigabit features are masked off if requestedFlorian Fainelli
When a Gigabit PHY device is connected to a 10/100Mbits capable Ethernet MAC, the driver will restrict the phydev->supported modes to mask off Gigabit. If the Gigabit PHY comes out of reset with the Gigabit features set by default in MII_CTRL1000, it will keep advertising these feature, so by the time we call genphy_config_advert(), the condition on phydev->supported having the Gigabit features on is false, and we do not update MII_CTRL1000 with updated values, and we keep advertising Gigabit features, eventually configuring the PHY for Gigabit whilst the Ethernet MAC does not support that. This patches fixes the problem by ensuring that the Gigabit feature bits are always cleared in MII_CTRL1000, if the PHY happens to be a Gigabit PHY, and then, if Gigabit features are supported, setting those and updating MII_CTRL1000 accordingly. Reported-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-19phy: cleanup 10g codestephen hemminger
Code should avoid needless exports, don't export something unless it used. Make local functions static and remove unused stubs. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13phylib: Support attaching to generic 10g driverAndy Fleming
phy_attach_direct() may now attach to a generic 10G driver. It can also be used exactly as phy_connect_direct(), which will be useful when using of_mdio, as phy_connect (and therefore of_phy_connect) start the PHY state machine, which is currently irrelevant for 10G PHYs. Signed-off-by: Andy Fleming <afleming@gmail.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13phylib: Add generic 10G driverAndy Fleming
Very incomplete, but will allow for binding an ethernet controller to it. Signed-off-by: Andy Fleming <afleming@gmail.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-13phylib: turn genphy_driver to an arrayShaohui Xie
Then other generic phy driver such as generic 10g phy driver can join it. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04phylib: make phy_scan_fixups() staticSergei Shtylyov
phy_scan_fixups() isn't and shouldn't be called by the drivers directly, so unexport it. And since Florian Fainelli's recent patches, the function is only called locally, so we can make it static as well. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04phylib: remove unused adjust_state() callbackSergei Shtylyov
Remove adjust_state() callback from 'struct phy_device' since it seems to have never been really used from the inception: phy_start_machine() has been always called with 2nd argument equal to NULL. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04phy: kill excess empty linesSergei Shtylyov
Remove excess empty lines such as those between a function call and its result check and just duplicate ones between functions. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04phy: kill excess codeSergei Shtylyov
Remove some excess code: - convert assignments to initializers; - kill useless assignments before *return*. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04phy: kill useless local variablesSergei Shtylyov
A number of functions (especially in phy.c) has local variables that were hardly needed in the first place -- remove them. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-04phy: coding style fixesSergei Shtylyov
The recent patch from Florian Fainelli fixed all 'checkpatch.pl' errors but left the numerous warnings: - including <asm/io.h> instead of <linux/io.h>; - including <asm/uaccess.h> instead of <linux/uaccess.h>; - *extern* declaration in .c file; - block comments using empty /* line; - block comments not starting with * on the middle lines; - block comments not having trailing */ on a separate line; - EXPORT_SYMBOL() not immediately following its function; - unnecessary {} for signle statement block; - spaces before tabs. While fixing these, also fix the following style issues (some of which were found running 'checkpatch.pl --strict'): - alignment not matching open paren; - missing {} on one of the *if* arms where another has them; - use of sizeof(struct structure) instead of sizeof(*variable); - multiple assignments on one line; - empty line before }; - file names in the heading comments; - missing spaces around operators; - no {} around multi-line *if* operator's arm; - unneeded () around subexpressions; - incomplete kernel-doc comment style; - comment line exceeding 80 characters; - missing empty line after declarations. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-18net: phy: fix checkpatch errorsFlorian Fainelli
checkpatch spotted a few checkpatch errors such as whitespace damages and switch/case labels not being on the same column, fix them. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17net: phy: resume/suspend PHYs on attach/detachSebastian Hesselbarth
This ensures PHYs are resumed on attach and suspended on detach. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-17net: phy: provide phy_resume/phy_suspend helpersSebastian Hesselbarth
This adds helper functions to resume and suspend a given phy_device by calling the corresponding driver callbacks if available. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09net: phy: consolidate PHY reset in phy_init_hw()Florian Fainelli
There are quite a lot of drivers touching a PHY device MII_BMCR register to reset the PHY without taking care of: 1) ensuring that BMCR_RESET is cleared after a given timeout 2) the PHY state machine resuming to the proper state and re-applying potentially changed settings such as auto-negotiation Introduce phy_poll_reset() which will take care of polling the MII_BMCR for the BMCR_RESET bit to be cleared after a given timeout or return a timeout error code. In order to make sure the PHY is in a correct state, phy_init_hw() first issues a software reset through MII_BMCR and then applies any fixups. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-09net: phy: report link partner features through ethtoolFlorian Fainelli
The PHY library already reads the MII_STAT1000 and MII_LPA registers in genphy_read_status(), so extend it to also populate the PHY device link partner advertised features such that we can feed this back into ethtool when asked for it in phy_ethtool_gset(). Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net/phy: Add the autocross feature for forced links on VSC82x4Madalin Bucur
Add auto-MDI/MDI-X capability for forced (autonegotiation disabled) 10/100 Mbps speeds on Vitesse VSC82x4 PHYs. Exported previously static function genphy_setup_forced() required by the new config_aneg handler in the Vitesse PHY module. Signed-off-by: Madalin Bucur <madalin.bucur@freescale.com> Signed-off-by: Shruti Kanetkar <Shruti@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27phy: allow drivers to flag a PHY device as internalFlorian Fainelli
libphy currently always reports a PHY as an external transceiver from the ethtool output. This is inaccurate, because some drivers should be able to tell that a PHY device is an internal transceiver of an Ethernet MAC. Add a new flag (PHY_IS_INTERNAL) which can be set by PHY drivers just like other flags, and a corresponding helper: phy_is_internal() which can be used by networking drivers to query if a given PHY device is internal. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-20phy: add phy_mac_interrupt() to use with PHY_IGNORE_INTERRUPTFlorian Fainelli
There is currently no way for an Ethernet MAC driver servicing PHY link interrupts to notify this to the PHY state machine without defining its own state machine. Since most drivers are not so special, introduce a helper: phy_mac_interrupt() which can be called from a link up/down interrupt routine to update the PHY state machine. To avoid code duplication some refactoring has been done to expose the workqueue and its corresponding callback internally. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-20phy: fix the use of PHY_IGNORE_INTERRUPTFlorian Fainelli
When a PHY device is registered with the special IRQ value PHY_IGNORE_INTERRUPT (-2) it will not properly be handled by the PHY library: - it continues to poll its register, while we do not want this because such PHY link events or register changes are serviced by an Ethernet MAC - it will still try to configure PHY interrupts at the PHY level, such interrupts do not exist at the PHY but at the MAC level - the state machine only handles PHY_POLL, but should also handle PHY_IGNORE_INTERRUPT similarly This patch updates the PHY state machine and initialization paths to account for the specific PHY_IGNORE_INTERRUPT. Based on an earlier patch by Thomas Petazzoni, and reworked to add the missing bits. Add a helper phy_interrupt_is_valid() which specifically tests for a PHY interrupt not to be PHY_POLL or PHY_IGNORE_INTERRUPT and use it throughout the code. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-28phy: Fix phy_device_free memory leakPetr Malat
Fix memory leak in phy_device_free() for the case when phy_device* returned by phy_device_create() is not registered in the system. Bug description: phy_device_create() sets name of kobject using dev_set_name(), which allocates memory using kvasprintf(), but this memory isn't freed if the underlying device isn't registered properly, because kobject_cleanup() is not called in that case. This can happen (and actually is happening on our machines) if phy_device_register(), called by mdiobus_scan(), fails. Patch description: Embedded struct device is initialized in phy_device_create() and it counterpart phy_device_free() just drops one reference to the device, which leads to proper deinitialization including releasing the kobject name memory. Signed-off-by: Petr Malat <oss@malat.biz> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-14net: phy: remove flags argument from phy_{attach, connect, connect_direct}Florian Fainelli
The flags argument of the phy_{attach,connect,connect_direct} functions is then used to assign a struct phy_device dev_flags with its value. All callers but the tg3 driver pass the flag 0, which results in the underlying PHY drivers in drivers/net/phy/ not being able to actually use any of the flags they would set in dev_flags. This patch gets rid of the flags argument, and passes phydev->dev_flags to the internal PHY library call phy_attach_direct() such that drivers which actually modify a phy device dev_flags get the value preserved for use by the underlying phy driver. Acked-by: Kosta Zertsekel <konszert@marvell.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-09phylib: Support registering a bunch of driversChristian Hohnstaedt
If registering of one of them fails, all already registered drivers of this module will be unregistered. Use the new register/unregister functions in all drivers registering more than one driver. amd.c, realtek.c: Simplify: directly return registration result. Tested with broadcom.c All others compile-tested. Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-27phy: Fix warning in get_phy_device().David S. Miller
drivers/net/phy/phy_device.c: In function ‘get_phy_device’: drivers/net/phy/phy_device.c:340:14: warning: ‘phy_id’ may be used uninitialized in this function [-Wmaybe-uninitialized] GCC can't see that when we return zero we always initialize phy_id and that's the only path where we use it. Initialize phy_id to zero to shut it up. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-27netdev/phy: Handle IEEE802.3 clause 45 Ethernet PHYsDavid Daney
The IEEE802.3 clause 45 MDIO bus protocol allows for directly addressing PHY registers using a 21 bit address, and is used by many 10G Ethernet PHYS. Already existing is the ability of MDIO bus drivers to use clause 45, with the MII_ADDR_C45 flag. Here we add struct phy_c45_device_ids to hold the device identifier registers present in clause 45. struct phy_device gets a couple of new fields: c45_ids to hold the identifiers and is_c45 to signal that it is clause 45. get_phy_device() gets a new parameter is_c45 to indicate that the PHY device should use the clause 45 protocol, and its callers are adjusted to pass false. The follow-on patch to of_mdio.c will pass true where appropriate. EXPORT phy_device_create() so that the follow-on patch to of_mdio.c can use it to create phy devices for PHYs, that have non-standard device identifier registers, based on the device tree bindings. Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-11phy: Use pr_<level>Joe Perches
Use a more current logging style. Add pr_fmt and missing newlines. Remove embedded prefixes. Neaten phy_print_status to avoid using KERN_CONT. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16netdev/phy: Make get_phy_id() static and quit EXPORTing it.David Daney
This function is only referenced from within phy_device.c, so there is no reason to export it. In fact, we can make it static. Signed-off-by: David Daney <david.daney@cavium.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-24Remove useless get_driver()/put_driver() callsAlan Stern
As part of the removal of get_driver()/put_driver(), this patch (as1512) gets rid of various useless and unnecessary calls in several drivers. In some cases it may be desirable to pin the driver by calling try_module_get(), but that can be done later. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: "David S. Miller" <davem@davemloft.net> CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: Michael Buesch <m@bues.ch> CC: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-21net: Change mii to ethtool advertisement function namesMatt Carlson
This patch implements advice by Ben Hutchings to change the mii side of the function names to look more like the register whose values they convert. New LPA translation functions have been added as well. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-16net: Add ethtool to mii advertisment conversion helpersMatt Carlson
Translating between ethtool advertisement settings and MII advertisements are common operations for ethernet drivers. This patch adds a set of helper functions that implements the conversion. The patch then modifies a couple of the drivers to use the new functions. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-30netdev/phy: Use mdiobus_read() so that proper locks are taken.David Daney
Accesses to the mdio busses must be done with the mdio_lock to ensure proper operation. Conveniently we have the helper function mdiobus_read() to do that for us. Lets use it in get_phy_id() instead of accessing the bus without the lock held. Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: David S. Miller <davem@davemloft.net>
