As some C45 10G PHYs(e.g. Cortina CS4315/CS4340 PHY) have
zero Devices In package, current driver can't get correct
devices_in_package value by non-zero Devices In package.
so let's probe more with zero Devices In package to support
more C45 PHYs.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
When limiting phy link speed using "max-speed" to 100mbps or less on a
giga bit phy, phy never completes auto negotiation and phy state
machine is held in PHY_AN. Fixing this issue by comparing the giga
bit advertise though phydev->supported doesn't have it but phy has
BMSR_ESTATEN set. So that auto negotiation is restarted as old and
new advertise are different and link comes up fine.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
In order to avoid double calls to phydev->drv->suspend and resume, keep
track of whether the PHY has already been suspended as a consequence of
a successful call to phy_suspend(). We will use this in our MDIO bus
suspend/resume hooks to avoid a double suspend call.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
The bare register numbers are used despite <uapi/linux/mdio.h> has MDIO_DEVS[12]
#define'd for those.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Commit 87aa9f9c61ad ("net: phy: consolidate PHY reset in phy_init_hw()")
moved the call to phy_scan_fixups() in phy_init_hw() after a software
reset is performed.
By the time phy_init_hw() is called in phy_device_register(), no driver
has been bound to this PHY yet, so all the checks in phy_init_hw()
against the PHY driver and the PHY driver's config_init function will
return 0. We will therefore never call phy_scan_fixups() as we should.
Fix this by calling phy_scan_fixups() and check for its return value to
restore the intended functionality.
This broke PHY drivers which do register an early PHY fixup callback to
intercept the PHY probing and do things like changing the 32-bits unique
PHY identifier when a pseudo-PHY address has been used, as well as
board-specific PHY fixups that need to be applied during driver probe
time.
Reported-by: Hauke Merthens <hauke-m@hauke-m.de>
Reported-by: Jonas Gorski <jogo@openwrt.org>
This commit adds proper module_{get,put} to prevent the MDIO bus module
from being unloaded while the phydev is connected. By doing so, we fix
a kernel panic produced when a MDIO driver is removed, but the phydev
that relies on it is attached and running.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Tested-by: Florian Fainelli <f.fainelli@gmail.com>
phy_suspend and phy_resume are two commonly used helper functions that
need to be exported for Ethernet drivers to be built as modules
Fixes: 40755a0fce17 ("net: systemport: add suspend and resume support")
drivers/net/bonding/bond_alb.c
drivers/net/ethernet/altera/altera_msgdma.c
drivers/net/ethernet/altera/altera_sgdma.c
net/ipv6/xfrm6_output.c
Several cases of overlapping changes.
The xfrm6_output.c has a bug fix which overlaps the renaming
of skb->local_df to skb->ignore_df.
In the Altera TSE driver cases, the register access cleanups
in net-next overlapped with bug fixes done in net.
Similarly a bug fix to send ALB packets in the bonding driver using
the right source address overlaps with cleanups in net-next.
of_set_phy_supported allows overwiting hardware capabilities of
a phy with values from the devicetree. of_set_phy_supported is
called right after phy_device_register in the assumption that
phy_probe is called from phy_device_register and the features
of the phy are already initialized. For the genphy driver this
is not true, here phy_probe is called later during phy_connect
time. phy_probe will then overwrite all settings done from
Fix this by moving of_set_phy_supported to the core phy code
and calling it from phy_probe.
a phy with values from the devicetree. This does not work with
the genphy driver though because the genphys config_init function
will overwrite all values adjusted by of_set_phy_supported. Fix
this by initialising the genphy features in the phy_driver struct
and in config_init just limit the features to the ones the hardware
can actually support. The resulting features are a subset of the
devicetree specified features and the hardware features.
After the call to phy_init_hw failed in phy_attach_direct, phy_detach is called
to detach the phy device from its network device. If the attached driver is a
generic phy driver, this also detaches the driver. Subsequently phy_resume
is called, which assumes without checking that a driver is attached to the
device. This will result in a crash such as
Unable to handle kernel paging request for data at address 0xffffffffffffff90
Faulting instruction address: 0xc0000000003a0e18
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c0000000003a0e18] .phy_attach_direct+0x68/0x17c
LR [c0000000003a0e6c] .phy_attach_direct+0xbc/0x17c
Call Trace:
[c0000003fc0475d0] [c0000000003a0e6c] .phy_attach_direct+0xbc/0x17c (unreliable)
[c0000003fc047670] [c0000000003a0ff8] .phy_connect_direct+0x28/0x98
[c0000003fc047700] [c0000000003f0074] .of_phy_connect+0x4c/0xa4
Only call phy_resume if phy_init_hw was successful.
This enables other drivers to call this generic implementation, and then
only do specific details on top of it.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Documentation/devicetree/bindings/net/micrel-ks8851.txt
net/core/netpoll.c
The net/core/netpoll.c conflict is a bug fix in 'net' happening
to code which is completely removed in 'net-next'.
In micrel-ks8851.txt we simply have overlapping changes.
Callers of phy_ethtool_get_wol are supposed to provide a properly
cleared struct ethtool_wolinfo. Therefore, fix phy_suspend to clear
it before passing it to phy_ethtool_get_wol.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
net/ipv6/sit.c
The SIT driver conflict consists of a bug fix being done by hand
in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper
was created (netdev_alloc_pcpu_stats()) which takes care of this.
The two wireless conflicts were overlapping changes.
Masking the link partner's capabilities with local capabilities can be
misleading in autonegotiation scenarios such as PAUSE frame
autonegotiation.
This patch calculates the join between the local capabilities and the
link parner capabilities, when it determines the speed and duplex
settings, but does not mask any of the link partner capabilities when
it calculates PAUSE frame settings.
Signed-off-by: Cristian Bercaru <cristian.bercaru@freescale.com>
As pointed out by Shaohui, most 10G PHYs out there have a non-standard
compliant software reset sequence, eventually something much more
complex than just toggling the BMCR_RESET bit. Allow PHY driver to
implement their own soft_reset() callback to deal with that. If no
callback is provided, call into genphy_soft_reset() which makes sure the
existing behavior is kept intact.
Reported-by: Shaohui Xie <Shaohui.Xie@freescale.com>
As pointed out by Shaohui, this function is generic for 10/100/1000
PHYs, but 10G PHYs might have a slightly different reset sequence which
prevents most of them from using this function.
Move the BMCR_RESET based software resent sequence to
genphy_soft_reset() in preparation for allowing PHY drivers to implement
a soft_reset() callback.
Add a boolean property which indicates if the PHY has had any fixup
routine ran on it. We are later going to use that boolean to expose it
as a sysfs property to help troubleshooting.
Some PHYs out there can be very quirky with respect to how they would
report the auto-negotiation is completed. Allow drivers to override the
generic aneg_done() implementation by providing their own.
Since not all drivers have been updated yet to use genphy_aneg_done() as
aneg_done() callback, we explicitely check that this callback is valid
before calling into it.
In preparation for allowing PHY drivers to potentially override their
auto-negotiation done callback, move the contents of phy_aneg_done() to
genphy_aneg_done() since that function really is the generic
implementation based on the BMSR_ANEGCOMPLETE status.
When a Gigabit PHY device is connected to a 10/100Mbits capable Ethernet
MAC, the driver will restrict the phydev->supported modes to mask off
Gigabit. If the Gigabit PHY comes out of reset with the Gigabit features
set by default in MII_CTRL1000, it will keep advertising these feature,
so by the time we call genphy_config_advert(), the condition on
phydev->supported having the Gigabit features on is false, and we do not
update MII_CTRL1000 with updated values, and we keep advertising Gigabit
features, eventually configuring the PHY for Gigabit whilst the Ethernet
MAC does not support that.
This patches fixes the problem by ensuring that the Gigabit feature bits
are always cleared in MII_CTRL1000, if the PHY happens to be a Gigabit
PHY, and then, if Gigabit features are supported, setting those and
updating MII_CTRL1000 accordingly.
Reported-by: Max Filippov <jcmvbkbc@gmail.com>
Tested-by: Max Filippov <jcmvbkbc@gmail.com>
Code should avoid needless exports, don't export something unless it used.
Make local functions static and remove unused stubs.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
phy_attach_direct() may now attach to a generic 10G driver. It can
also be used exactly as phy_connect_direct(), which will be useful
when using of_mdio, as phy_connect (and therefore of_phy_connect)
start the PHY state machine, which is currently irrelevant for 10G
PHYs.
Signed-off-by: Andy Fleming <afleming@gmail.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Very incomplete, but will allow for binding an ethernet controller
to it.
Then other generic phy driver such as generic 10g phy driver can join it.
phy_scan_fixups() isn't and shouldn't be called by the drivers directly, so
unexport it. And since Florian Fainelli's recent patches, the function is only
called locally, so we can make it static as well.
Remove adjust_state() callback from 'struct phy_device' since it seems to have
never been really used from the inception: phy_start_machine() has been always
called with 2nd argument equal to NULL.
Remove excess empty lines such as those between a function call and its result
check and just duplicate ones between functions.
Remove some excess code:
- convert assignments to initializers;
- kill useless assignments before *return*.
A number of functions (especially in phy.c) has local variables that were hardly
needed in the first place -- remove them.
The recent patch from Florian Fainelli fixed all 'checkpatch.pl' errors but left
the numerous warnings:
- including <asm/io.h> instead of <linux/io.h>;
- including <asm/uaccess.h> instead of <linux/uaccess.h>;
- *extern* declaration in .c file;
- block comments using empty /* line;
- block comments not starting with * on the middle lines;
- block comments not having trailing */ on a separate line;
- EXPORT_SYMBOL() not immediately following its function;
- unnecessary {} for signle statement block;
- spaces before tabs.
While fixing these, also fix the following style issues (some of which were
found running 'checkpatch.pl --strict'):
- alignment not matching open paren;
- missing {} on one of the *if* arms where another has them;
- use of sizeof(struct structure) instead of sizeof(*variable);
- multiple assignments on one line;
- empty line before };
- file names in the heading comments;
- missing spaces around operators;
- no {} around multi-line *if* operator's arm;
- unneeded () around subexpressions;
- incomplete kernel-doc comment style;
- comment line exceeding 80 characters;
- missing empty line after declarations.
checkpatch spotted a few checkpatch errors such as whitespace damages
and switch/case labels not being on the same column, fix them.
This ensures PHYs are resumed on attach and suspended on detach.
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
This adds helper functions to resume and suspend a given phy_device
by calling the corresponding driver callbacks if available.
There are quite a lot of drivers touching a PHY device MII_BMCR
register to reset the PHY without taking care of:
1) ensuring that BMCR_RESET is cleared after a given timeout
2) the PHY state machine resuming to the proper state and re-applying
potentially changed settings such as auto-negotiation
Introduce phy_poll_reset() which will take care of polling the MII_BMCR
for the BMCR_RESET bit to be cleared after a given timeout or return a
timeout error code.
In order to make sure the PHY is in a correct state, phy_init_hw() first
issues a software reset through MII_BMCR and then applies any fixups.
The PHY library already reads the MII_STAT1000 and MII_LPA registers in
genphy_read_status(), so extend it to also populate the PHY device link
partner advertised features such that we can feed this back into ethtool
when asked for it in phy_ethtool_gset().
Add auto-MDI/MDI-X capability for forced (autonegotiation disabled)
10/100 Mbps speeds on Vitesse VSC82x4 PHYs. Exported previously static
function genphy_setup_forced() required by the new config_aneg handler
in the Vitesse PHY module.
Signed-off-by: Madalin Bucur <madalin.bucur@freescale.com>
Signed-off-by: Shruti Kanetkar <Shruti@freescale.com>
libphy currently always reports a PHY as an external transceiver from
the ethtool output. This is inaccurate, because some drivers should be
able to tell that a PHY device is an internal transceiver of an Ethernet
MAC. Add a new flag (PHY_IS_INTERNAL) which can be set by PHY drivers
just like other flags, and a corresponding helper: phy_is_internal()
which can be used by networking drivers to query if a given
PHY device is internal.
There is currently no way for an Ethernet MAC driver servicing PHY link
interrupts to notify this to the PHY state machine without defining its
own state machine. Since most drivers are not so special, introduce a
helper: phy_mac_interrupt() which can be called from a link up/down
interrupt routine to update the PHY state machine. To avoid code
duplication some refactoring has been done to expose the workqueue and
its corresponding callback internally.
When a PHY device is registered with the special IRQ value
PHY_IGNORE_INTERRUPT (-2) it will not properly be handled by the PHY
library:
- it continues to poll its register, while we do not want this
because such PHY link events or register changes are serviced by an
Ethernet MAC
- it will still try to configure PHY interrupts at the PHY level, such
interrupts do not exist at the PHY but at the MAC level
- the state machine only handles PHY_POLL, but should also handle
PHY_IGNORE_INTERRUPT similarly
This patch updates the PHY state machine and initialization paths to
account for the specific PHY_IGNORE_INTERRUPT. Based on an earlier patch
by Thomas Petazzoni, and reworked to add the missing bits. Add a helper
phy_interrupt_is_valid() which specifically tests for a PHY interrupt
not to be PHY_POLL or PHY_IGNORE_INTERRUPT and use it throughout the
code.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Fix memory leak in phy_device_free() for the case when phy_device*
returned by phy_device_create() is not registered in the system.
Bug description:
phy_device_create() sets name of kobject using dev_set_name(), which
allocates memory using kvasprintf(), but this memory isn't freed if
the underlying device isn't registered properly, because kobject_cleanup()
is not called in that case. This can happen (and actually is happening on
our machines) if phy_device_register(), called by mdiobus_scan(), fails.
Patch description:
Embedded struct device is initialized in phy_device_create() and it
counterpart phy_device_free() just drops one reference to the device,
which leads to proper deinitialization including releasing the kobject
name memory.
Signed-off-by: Petr Malat <oss@malat.biz>
The flags argument of the phy_{attach,connect,connect_direct} functions
is then used to assign a struct phy_device dev_flags with its value.
All callers but the tg3 driver pass the flag 0, which results in the
underlying PHY drivers in drivers/net/phy/ not being able to actually
use any of the flags they would set in dev_flags. This patch gets rid of
the flags argument, and passes phydev->dev_flags to the internal PHY
library call phy_attach_direct() such that drivers which actually modify
a phy device dev_flags get the value preserved for use by the underlying
phy driver.
Acked-by: Kosta Zertsekel <konszert@marvell.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
If registering of one of them fails, all already registered drivers
of this module will be unregistered.
Use the new register/unregister functions in all drivers
registering more than one driver.
amd.c, realtek.c: Simplify: directly return registration result.
Tested with broadcom.c
All others compile-tested.
Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com>
drivers/net/phy/phy_device.c: In function ‘get_phy_device’:
drivers/net/phy/phy_device.c:340:14: warning: ‘phy_id’ may be used uninitialized in this function [-Wmaybe-uninitialized]
GCC can't see that when we return zero we always initialize
phy_id and that's the only path where we use it.
Initialize phy_id to zero to shut it up.
The IEEE802.3 clause 45 MDIO bus protocol allows for directly
addressing PHY registers using a 21 bit address, and is used by many
10G Ethernet PHYS. Already existing is the ability of MDIO bus
drivers to use clause 45, with the MII_ADDR_C45 flag. Here we add
struct phy_c45_device_ids to hold the device identifier registers
present in clause 45. struct phy_device gets a couple of new fields:
c45_ids to hold the identifiers and is_c45 to signal that it is clause
45.
get_phy_device() gets a new parameter is_c45 to indicate that the PHY
device should use the clause 45 protocol, and its callers are adjusted
to pass false. The follow-on patch to of_mdio.c will pass true where
appropriate.
EXPORT phy_device_create() so that the follow-on patch to of_mdio.c
can use it to create phy devices for PHYs, that have non-standard
device identifier registers, based on the device tree bindings.
Signed-off-by: David Daney <david.daney@cavium.com>
Use a more current logging style.
Add pr_fmt and missing newlines.
Remove embedded prefixes.
Neaten phy_print_status to avoid using KERN_CONT.
This function is only referenced from within phy_device.c, so there is
no reason to export it. In fact, we can make it static.
Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com>
As part of the removal of get_driver()/put_driver(), this patch
(as1512) gets rid of various useless and unnecessary calls in several
drivers. In some cases it may be desirable to pin the driver by
calling try_module_get(), but that can be done later.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: "David S. Miller" <davem@davemloft.net>
CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
CC: Michael Buesch <m@bues.ch>
CC: Joerg Roedel <joerg.roedel@amd.com>
