path: root/drivers/net/pppoe.c
2010-05-23pppoe: uninitialized variable in pppoe_flush_dev()Dan Carpenter
This assignment got deleted along with the checks by mistake. This comes from: 8753d29fd "pppoe: remove unnecessary checks in pppoe_flush_dev" Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17cleanup: remove pppoe_ioctl() declaration.Rami Rosen
Hi, - This patch removes pppoe_ioctl() declaration in drivers/net/pppoe.c as it is unneeded. Regards, Rami Rosen Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05pppoe: remove unnecessary checks in pppoe_flush_devJiri Pirko
pernet memory is guaranteed to exist when notifiers are called. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26pppoe: use pppoe_pernet instead of directly net_genericJiri Pirko
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Simplify pppoe pernet operations.Eric W. Biederman
Take advantage of the new pernet automatic storage management, and stop using compatibility network namespace functions. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18netns: net_identifiers should be read_mostlyEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-01pppoe: RCU locking in get_item_by_addr()Eric Dumazet
Use dev_get_by_name_rcu() instead of dev_get_by_name(), to avoid touching device refcount in hotpath. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-26PPPoE: Fix flush/close races.Michal Ostrowski
Be more careful about the state of pointers during tear-down. The "pppoe_dev" field can only be looked at safely while holding socket locks. This subsequently allows for the flush_lock to be killed. We depend on the PPPOX_CONNECTED state to tell us that that those fields are valid, so whoever clears that state (pppox_unbind_sock()) is responsible for the dev_put() call. We also have to ensure that we delete_item() on all sockets before they are cleaned up. The need for these changes has been exposed by scenarios wherein namespace bindings of ethernet devices change while there are ongoing PPPoE sessions, which resulted in oopses due to unusual socket connection termination paths, exposing these issues. Signed-off-by: Michal Ostrowski <mostrows@gmail.com> Reviewed-by: Cyril Gorcunov <gorcunov@gmail.com> Reported-by: Denys Fedoryschenko <denys@visp.net.lb> Tested-by: Denys Fedoryschenko <denys@visp.net.lb>
2009-08-12net,pppoe: fixup module init/exit subsequent callsCyrill Gorcunov
pernet data should allocated first and freed last on module init/exit routines otherwise it's possible to have unserialized calls to packet handling routines. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30pppoe: fix /proc/net/pppoeEric Dumazet
If a socket is hashed in last slot of pppoe hash table (PPPOE_HASH_SIZE-1) we report it many times (up to filling seq buffer) (Only the last socket of last slot) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/ppp*.c: fix sparse warnings: fix signednessHannes Eder
Fix this sparse warnings: drivers/net/ppp_generic.c:919:43: warning: incorrect type in argument 1 (different signedness) drivers/net/pppoe.c:1195:43: warning: incorrect type in argument 1 (different signedness) drivers/net/pppol2tp.c:2666:43: warning: incorrect type in argument 1 (different signedness) Signed-off-by: Hannes Eder <hannes@hanneseder.net> Acked-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-09ppp: section fixes re netnsAlexey Dobriyan
PPP is modular code so no initdata on netns hooks. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26net: pppoe - stop using proc internalsCyrill Gorcunov
Alexey Dobriyan pointed that using PDE_NET outside the proc code is plain bogus (thanks Alexey!). Fix it. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22net: pppoe - get rid of DECLARE_MAC_BUFCyrill Gorcunov
While was playing with PPP namespaces I occasionally brought back DECLARE_MAC_BUF which is not needed (we have %pM here). Fix it. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: pppoe,pppol2tp - register channels with explicit netCyrill Gorcunov
In PPPo[E|L2TP] we could explicitly point which net namespace we're going to use for channels - make it so. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: pppoe - introduce net-namespace functionalityCyrill Gorcunov
- each net-namespace for pppoe module is having own hash table and appropriate locks wich are allocated at time of namespace intialization. It requires about 140 bytes of memory for every new namespace but such approach allow us to escape from hash chains growing and additional lock contends (especially in SMP environment). - pppox code allows to create per-namespace sockets for PX_PROTO_OE protocol only (since at this moment support for pppol2tp net-namespace is not implemented yet). Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: pppoe - code cleanup and helpersCyrill Gorcunov
- Introduce PPPOE_HASH_MASK. - Remove redundant declaration of pppoe_chan_ops. - Introduce stage_session helper. - Tabs, space, long-line-split cleanup. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: constify VFTsJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-31Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/p54/p54common.c
2008-10-30pppoe: Fix socket leak.David S. Miller
Move SKB trim before we lookup the socket so we don't have to put it on failure. Based upon an initial patch by Jarek Poplawski and suggestions from Herbert Xu. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-20pppoe: warning fixStephen Hemminger
Fix warning: drivers/net/pppoe.c: In function 'pppoe_recvmsg': drivers/net/pppoe.c:945: warning: comparison of distinct pointer types lacks a cast because skb->len is unsigned int and total_len is size_t Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10pppoe: Unshare skb before anything elseHerbert Xu
We need to unshare the skb first as otherwise pskb_may_pull may write to a shared skb which could be bad. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10net pppoe: Check packet length on all receive pathsHerbert Xu
The length field in the PPPOE header wasn't checked completely. This patch causes all packets shorter than the declared length to be dropped. It also changes the memcpy_toiovec call to skb_copy_datagram_iovec so that paged packets (rare for PPPOE) are handled properly. Thanks to Ilja of the Netric Security Team for discovering and reporting this bug, and Chris Wright for the total_len check. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29netdev: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[PPP]: Sparse warning fixes.Stephen Hemminger
Fix a bunch of warnings in PPP and related drivers. Mostly because sparse doesn't like it when the the function is only marked private in the forward declaration. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10pppoe: endiannessAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-20[PPP] pppoe: Fix double-free on skb after transmit failureHerbert Xu
When I got rid of the second packet in __pppoe_xmit I created a double-free on the skb because of the goto abort on failure. This patch removes that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[NET] skbuff: Add skb_cow_headHerbert Xu
This patch adds an optimised version of skb_cow that avoids the copy if the header can be modified even if the rest of the payload is cloned. This can be used in encapsulating paths where we only need to modify the header. As it is, this can be used in PPPOE and bridging. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] pppoe: Fill in header directly in __pppoe_xmitHerbert Xu
This patch removes the hdr variable (which is copied into the skb) and instead sets the header directly in the skb. It also uses __skb_push instead of skb_push since we've just checked using skb_cow for enough head room. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] pppoe: Fix data clobbering in __pppoe_xmit and return valueHerbert Xu
The function __pppoe_xmit modifies the skb data and therefore it needs to copy and skb data if it's cloned. In fact, it currently allocates a new skb so that it can return 0 in case of error without freeing the original skb. This is totally wrong because returning zero is meant to indicate congestion whereupon pppoe is supposed to wake up the upper layer once the congestion subsides. This makes sense for ppp_async and ppp_sync but is out-of-place for pppoe. This patch makes it always return 1 and free the skb. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[PPP] pppoe: Fix skb_unshare_check call positionHerbert Xu
The skb_unshare_check call needs to be made before pskb_may_pull, not after. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[PPPOE]: Improve hashing function in hash_item().Florian Zumbiehl
The new code produces the same results as the old version and is ~ 3 to 6 times faster for 4-bit hashes on the CPUs I tested. Signed-off-by: Florian Zumbiehl <florz@florz.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[PPPoE]: move lock_sock() in pppoe_sendmsg() to the right locationFlorian Zumbiehl
and the last one for now: Acquire the sock lock in pppoe_sendmsg() before accessing the sock - and in particular avoid releasing the lock even though it hasn't been acquired. Signed-off-by: Florian Zumbiehl <florz@florz.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[PPPoX/E]: return ENOTTY on unknown ioctl requestsFlorian Zumbiehl
here another patch for the PPPoX/E code that makes sure that ENOTTY is returned for unknown ioctl requests rather than 0 (and removes another unneeded initializer which I didn't bother creating a separate patch for). Signed-off-by: Florian Zumbiehl <florz@florz.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PPPOE]: Fix device tear-down notification.Michal Ostrowski
pppoe_flush_dev() kicks all sockets bound to a device that is going down. In doing so, locks must be taken in the right order consistently (sock lock, followed by the pppoe_hash_lock). However, the scan process is based on us holding the sock lock. So, when something is found in the scan we must release the lock we're holding and grab the sock lock. This patch fixes race conditions between this code and pppoe_release(), both of which perform similar functions but would naturally prefer to grab locks in opposing orders. Both code paths are now going after these locks in a consistent manner. pppoe_hash_lock protects the contents of the "pppox_sock" objects that reside inside the hash. Thus, NULL'ing out the pppoe_dev field should be done under the protection of this lock. Signed-off-by: Michal Ostrowski <mostrows@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PPPOE]: race between interface going down and connect()Florian Zumbiehl
below you find a patch that (hopefully) fixes a race between an interface going down and a connect() to a peer on that interface. Before, connect() would determine that an interface is up, then the interface could go down and all entries referring to that interface in the item_hash_table would be marked as ZOMBIEs and their references to the device would be freed, and after that, connect() would put a new entry into the hash table referring to the device that meanwhile is down already - which also would cause unregister_netdevice() to wait until the socket has been release()d. This patch does not suffice if we are not allowed to accept connect()s referring to a device that we already acked a NETDEV_GOING_DOWN for (that is: all references are only guaranteed to be freed after NETDEV_DOWN has been acknowledged, not necessarily after the NETDEV_GOING_DOWN already). And if we are allowed to, we could avoid looking through the hash table upon NETDEV_GOING_DOWN completely and only do that once we get the NETDEV_DOWN ... mostrows: pppoe_flush_dev is called on NETDEV_GOING_DOWN and NETDEV_DOWN to deal with this "late connect" issue. Ideally one would hope to notify users at the "NETDEV_GOING_DOWN" phase (just to pretend to be nice). However, it is the NETDEV_DOWN scan that takes all the responsibility for ensuring nobody is hanging around at that time. Signed-off-by: Florian Zumbiehl <florz@florz.de> Acked-by: Michal Ostrowski <mostrows@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
