path: root/drivers/net/ps3_gelic_net.h
2011-04-12net: ps3_gelic: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02net/ps3: Add support for gelic link negotiationHideyuki Sasaki
Add ethtool_ops.set_settings support to the PS3 gelic network driver. Allows manual setting of ethernet link speed. Signed-off-by: Hideyuki Sasaki <xhide@rd.scei.sony.co.jp> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02net/ps3: Cleanup gelic enumsGeoff Levand
Cleanup of the gelic driver enumerations: o Add some missing commas. o Add an Ether port post fix (PS3 currently only supports PORT_0). o Add a new enum gelic_lv1_phy to use when interacting with the PHY. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-30ps3: gelic: updown_lock semaphore to mutexDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-01[POWERPC] PS3: Gelic network driver Wake-on-LAN supportMasakazu Mokuno
Add Wake-on-LAN support to the PS3 Gelic network driver. Other OS WOL support was introduced in PS3 system firmware 2.20. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-11PS3: gelic: Add wireless support for PS3Masakazu Mokuno
Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Acked-by: Dan Williams <dcbw@redhat.com> Acked-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11PS3: gelic: Add support for dual network interfaceMasakazu Mokuno
Add support for dual network (net_device) interface so that ethernet and wireless can own separate ethX interfaces. V2 - Fix the bug that bringing down and up the interface keeps rx disabled. - Make 'gelic_net_poll_controller()' extern , as David Woodhouse pointed out at the previous submission. - Fix weird usage of member names for the rx descriptor chain V1 - Export functions which are convenient for both interfaces - Move irq allocation/release code to driver probe/remove handlers because interfaces share interrupts. - Allocate skbs by using dev_alloc_skb() instead of netdev_alloc_skb() as the interfaces share the hardware rx queue. - Add gelic_port struct in order to abstract dual interface handling - Change handlers for hardware queues so that they can handle dual {source,destination} interfaces. - Use new NAPI functions This is a prerequisite for the new PS3 wireless support. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11PS3: gelic: add support for port link statusMasakazu Mokuno
Add support for interrupt driven port link status detection. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11PS3: gelic: code cleanupMasakazu Mokuno
Code cleanup: - Use appropriate prefixes for names instead of fixed 'gelic_net' so that objects of the functions, variables and constants can be estimated. - Remove definitions for IPSec offload to the gelic hardware. This functionality is never supported on PS3. - Group constants with enum. - Use bitwise constants for interrupt status, instead of bit numbers to eliminate shift operations. - Style fixes. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11PS3: gelic: Add endianness macrosMasakazu Mokuno
Mark the members of the structure for DMA descriptors with proper endian annotations and use the appropriate accessor macros. As the gelic driver works only on PS3, all these macros will be expanded to null. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-24ps3: reduce allocation size of rx skb buffersMasakazu Mokuno
Reduced allocation size for rx skb buffers, from 2308 bytes to 1356 per buffer. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24ps3: fix rare issue that reenabling rx DMA failsMasakazu Mokuno
Fixed rare issue that 'lv1_net_start_rx_dma failed, status=-9" was shown in dmesg. This meant restarting rx DMA had been rejected by the hypervisor. This issue would caused if the guest os requested starting DMA when the hypervisor thought the DMA was in progress. The state machine for DMA status of the hypervisor would be updated by processing interrupt in the hypervisor. Thus we should wait for the interrupt delivery before restarting DMA. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24ps3: use net_device_stats of net_device structureMasakazu Mokuno
Removed the statistics information from private structre. Instead, use net_device_stats in net_device structure. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24ps3: removed conditional ethtool supportMasakazu Mokuno
Removed conditional ethtool support. Always enabled. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24ps3: removed defines no longer usedMasakazu Mokuno
Removed defines no longer used. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-24ps3: some minor cleanupsMasakazu Mokuno
- Removed the embarrassing definition which was used in only one place. - Fixed wrong initialization of dmac_cmd_status. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10ps3: gigabit ethernet driver for PS3, take3Masakazu Mokuno
Hi, This is the third submission of the network driver for PS3. The differences from the previous one are: - renamed source file names so that their prefix can match with the module name - added cbe-oss-dev@ozlabs.org line for MAINTAINER file - changed some in copyright comments If there are no more comments, please apply for 2.6.23. Thank you -- Subject: PS3: Ethernet driver From: Masakazu Mokuno <mokuno@sm.sony.co.jp> Add Gigabit Ethernet support for the PS3 game console. The module will be called ps3_gelic. CC: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
