path: root/drivers/net/ps3_gelic_wireless.c
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1674 commits) qlcnic: adding co maintainer ixgbe: add support for active DA cables ixgbe: dcb, do not tag tc_prio_control frames ixgbe: fix ixgbe_tx_is_paused logic ixgbe: always enable vlan strip/insert when DCB is enabled ixgbe: remove some redundant code in setting FCoE FIP filter ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddp ixgbe: fix header len when unsplit packet overflows to data buffer ipv6: Never schedule DAD timer on dead address ipv6: Use POSTDAD state ipv6: Use state_lock to protect ifa state ipv6: Replace inet6_ifaddr->dead with state cxgb4: notify upper drivers if the device is already up when they load cxgb4: keep interrupts available when the ports are brought down cxgb4: fix initial addition of MAC address cnic: Return SPQ credit to bnx2x after ring setup and shutdown. cnic: Convert cnic_local_flags to atomic ops. can: Fix SJA1000 command register writes on SMP systems bridge: fix build for CONFIG_SYSFS disabled ARCNET: Limit com20020 PCI ID matches for SOHARD cards ... Fix up various conflicts with pcmcia tree drivers/net/ {pcmcia/3c589_cs.c, wireless/orinoco/orinoco_cs.c and wireless/orinoco/spectrum_cs.c} and feature removal (Documentation/feature-removal-schedule.txt). Also fix a non-content conflict due to pm_qos_requirement getting renamed in the PM tree (now pm_qos_request) in net/mac80211/scan.c
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-03-29Fix comment and Kconfig typos for 'require' and 'fragment'Gilles Espinasse
Signed-off-by: Gilles Espinasse <g.esp@free.fr> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-24net/ps3_gelic: remove trailing space in messagesFrans Pop
ps3_gelic_wireless.c: also remove a stray "p" after a newline. Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: linuxppc-dev@ozlabs.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-23drivers/net: Remove local #define IW_IOCTL, use IW_HANDLERJoe Perches
Use #define IW_HANDLER from wireless.h instead Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-01ps3_gelic_wireless: Remove superfluous debug infoHamish Guthrie
2010-02-01ps3_gelic_wireless: fix format warningJohn W. Linville
2010-01-28ps3_gelic_wireless: fix directed ssid scanHamish Guthrie
If the association worker requests a directed ssid scan and a bss list already exists, the directed scan is not done. This patch corrects this and cleans up a few typos and debug messages. Signed-off-by: Hamish Guthrie <hamish.guthrie@sonycom.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-28ps3_gelic_wireless: Remove PS3 gelic legacy wpa supportHamish Guthrie
The current PS3 gelic wireless driver has support for wireless extensions. The original PS3 gelic wireless driver exposed a dedicated API for a dedicated wpa_supplicant driver. This old API could be enabled with CONFIG_GELIC_WIRELESS_OLD_PSK_INTERFACE, however, as this is not being used by any distros, and it is being removed from the driver and from wpa_supplicant. Signed-off-by: Hamish Guthrie <hamish.guthrie@sonycom.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12netdev: restore MAC address set and validate operationsBen Hutchings
alloc_etherdev() used to install default implementations of these operations, but they must now be explicitly installed in struct net_device_ops. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16net/ps3: gelic - Add missing annotationsGeert Uytterhoeven
probe functions should be __devinit Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-04-16net/ps3: Fix wireless AP connect error handlingMasakazu Mokuno
This patch fixes the bug that the driver tries to continue to connect(associate) to AP even if gelic_wl_do_{wpa,wep}_setup() fails, Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/Kconfig
2009-02-02powerpc/ps3: Printing fixups for l64 to ll64 convserion drivers/netStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-21PS3: gelic: wireless: convert the wireless part to net_device_opsMasakazu Mokuno
Convert the gelic wireless driver to net_device_ops Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-10don't use net/ieee80211.hJohannes Berg
Convert all the drivers using net/ieee80211.h to use linux/ieee80211.h. Contains a bugfix in libertas where the SSID parsing could overrun the buffer when the AP sends invalid information. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Dan Williams <dcbw@redhat.com> [airo, libertas] Acked-by: Pavel Roskin <proski@gnu.org> [orinoco] Acked-by: David Kilroy <kilroyd@googlemail.com> [orinoco] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27net: convert more to %pMJohannes Berg
A number of places still use %02x:...:%02x because it's in debug statements or for no real reason. Make a few of them use %pM. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-29PS3: gelic: use unsigned long for irqflagsVegard Nossum
The semantic patch I used was this: @@ expression lock; identifier flags; expression subclass; @@ - unsigned int flags; + unsigned long flags; ... <+... ( spin_lock_irqsave(lock, flags) | _spin_lock_irqsave(lock) | spin_unlock_irqrestore(lock, flags) | _spin_unlock_irqrestore(lock, flags) | read_lock_irqsave(lock, flags) | _read_lock_irqsave(lock) | read_unlock_irqrestore(lock, flags) | _read_unlock_irqrestore(lock, flags) | write_lock_irqsave(lock, flags) | _write_lock_irqsave(lock) | write_unlock_irqrestore(lock, flags) | _write_unlock_irqrestore(lock, flags) | spin_lock_irqsave_nested(lock, flags, subclass) | _spin_lock_irqsave_nested(lock, subclass) | spin_unlock_irqrestore(lock, flags) | _spin_unlock_irqrestore(lock, flags) | _raw_spin_lock_flags(lock, flags) | __raw_spin_lock_flags(lock, flags) ) ...+> This patch was generated using the Coccinelle framework. Cc: Masakazu Mokuno <mokuno@sm.sony.co.jp> Cc: Julia Lawall <julia@diku.dk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-16wext: Emit event stream entries correctly when compat.David S. Miller
Three major portions to this change: 1) Add IW_EV_COMPAT_LCP_LEN, IW_EV_COMPAT_POINT_OFF, and IW_EV_COMPAT_POINT_LEN helper defines. 2) Delete iw_stream_check_add_*(), they are unused. 3) Add iw_request_info argument to iwe_stream_add_*(), and use it to size the event and pointer lengths correctly depending upon whether IW_REQUEST_FLAG_COMPAT is set or not. 4) The mechanical transformations to the drivers and wireless stack bits to get the iw_request_info passed down into the routines modified in #3. Also, explicit references to IW_EV_LCP_LEN are replaced with iwe_stream_lcp_len(info). With a lot of help and bug fixes from Masakazu Mokuno. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-03PS3: gelic: Add support for ESSID scanMasakazu Mokuno
This adds the support for ESSID scanning Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03PS3: gelic: Deprecate the private ioctls in the gelic driverMasakazu Mokuno
As the driver has the standard way to handle PSK, deprecate the old interface. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03PS3: gelic: Use the new PMK interface in the gelic driverMasakazu Mokuno
With the new WEXT flags, the PS3 wireless driver can tell the user space that it would do handle 4-way handshake by itself and needs the PSK without private ioctls. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03PS3: gelic: Kill the static bounce bufferMasakazu Mokuno
As the bounce buffer is allocaetd dynamically, kill the static bounce buffer. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03PS3: gelic: Allocate the bounce buffer dynamicallyMasakazu Mokuno
Allocate the bouce buffer for the wireless command dynamically. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03ps3: gelic: assoc_stat_lock semaphore to mutexDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Acked-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03ps3: gelic: scan_lock semaphore to mutexDaniel Walker
2008-05-12PS3: gelic: fix memory leakMasakazu Mokuno
This fixes the bug that the I/O buffer is not freed at the driver removal. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-15PS3: gelic: fix the oops on the broken IE returned from the hypervisorMasakazu Mokuno
This fixes the bug that the driver would try to over-scan the memory if the sum of the length field of every IEs does not match the length returned from the hypervisor. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-25PS3: gelic: Add support for separate cipher selectionMasakazu Mokuno
From version 2.20 of the PS3 system software, the hypervisor allows the guest OSes to specify separate cipher for group and pairwise. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13PS3: gelic: change the prefix of the net interface for wirelessMasakazu Mokuno
The gelic driver uses two net interfaces, one for ethernet and the other for wireless. They share same MAC address and use 'eth' prefix for the name. As udev uses the MAC address to check uniqueness, this is somewhat problematic. So change the prefix of the network interface name for the wireless so that udev can have an easy way to distinguish interfaces. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13PS3: gelic: ignore scan info from zero SSID beaconsMasakazu Mokuno
Some implementations of the hidden SSID APs emit beacons which have the zero length SSID information element instead of SSID padded by null (\0) characters. If the firmware of the PS3 wireless hardware meets these beacons, it abandons parsing IEs. Thus guest OSes get the invalid scan information for the AP. To work around this, ignore these scan informations from the list. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28PS3: gelic: Link the wireless net_device structure to the corresponding ↵Masakazu Mokuno
device structure Link the net_device structure of the wireless part to the corresponding device structure. Without this, the sysfs node for this net_device would not have 'device' link. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-11PS3: gelic: Add wireless support for PS3Masakazu Mokuno
Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Acked-by: Dan Williams <dcbw@redhat.com> Acked-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
