path: root/drivers/net/qla3xxx.h
2007-03-28qla3xxx: bugfix: Jumbo frame handling.Ron Mercer
Fixed rx checksum bits. Turn on TCP processing for rx checksum. Fixed max frame length register write. It wasn't getting set in multi-port system. Set rx buffer queue length properly for jumbo frames. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Kernic Panic on pSeries under stress conditionsBenjamin Li
To reproduce this panic consistently, we run an intensive network application like 'netperf'. After waiting for a couple of seconds, you will see a stack trace and a kernel panic where we are calling pci_unmap_single() in ql_poll(). Changes: 1) Check the flags on the Response MAC IO Control block to check for errors 2) Ensure that if we are on the 4022 we only use one segment 3) Before, we were reading the memory mapped producer index register everytime we iterated in the loop when clearing the queue. We should only be iterating to a known point, not as the producer index is being updated. Signed-off-by: Benjamin Li <benjamin.li@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: bugfix: Fixed jumbo frame handling for 3032 chip.Ron Mercer
The scatter/gather lists were not being build correctly. When large frames spanned several buffers the chip would panic. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27qla3xxx: Dynamically size the rx buffer queue based on the MTU.Ron Mercer
This change removes use of constants for rx buffer queue size and instead calculates the queue length based on what he MTU is set to. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-05qla3xxx: Add support for Qlogic 4032 chip.Ron Mercer
Qlogic 4032 chip is an incremental change from the 4022. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-24[PATCH] qla3xxx iomem annotationsAl Viro
the driver is still shite, though... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] qla3xxx NIC driverRon Mercer
This is a complementary network driver for our ISP4XXX parts. There is a concurrent effort underway to get the iSCSI driver (qla4xxx) integrated upstream as well. I have been through several iterations with the linux-netdev list and have had much response from Stephen Hemminger. - Built and tested using kernel 2.6.17-rc4. - The chip supports two ethernet and two iSCSI functions. - The functions ql_sem_lock, ql_sem_spinlock, ql_sem_unlock, and ql_wait_for_drvr_lock are used to protect resources that are shared across the network and iSCSI functions. This protection is mostly during chip initialization and resets, but also include link management. - The PHY/MII are not exported through ethtool due to the fact that the iSCSI function will control the common link at least 50% of the time. This driver has been through several iterations on the netdev list and we feel this driver is ready for inclusion in the upstream kernel. It has been built and tested on x86 and PPC64 platforms. Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
