path: root/drivers/net/qlge
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-18net: qlge: convert to hw_featuresMichał Mirosław
Another simple conversion. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14qlge: make nic_operations struct conststephen hemminger
The struct nic_operations is just function pointers and should be declared const for added security. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-11qlge: use ethtool set_phys_idstephen hemminger
This is a stab at replacing old ethtool phys_id with set_phys_id on the Qlogic 10Gb driver. Compile tested only. Not sure if set_led_cfg will flash continuously, or needs to be replaced by ETHTOOL_ID_ON/ETHTOOL_ID_OFF Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-21drivers/net/*/: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. Signed-off-by: Joe Perches <joe@perches.com>
2010-12-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h drivers/net/wireless/iwlwifi/iwl-1000.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/vhost/vhost.c
2010-12-12qlge: Fix deadlock when cancelling worker.Ron Mercer
Removing usage of rtnl_lock() to protect firmware interface registers. These registers are accessed in some worker threads and can create a deadlock if rtnl_lock is taken by upper layers while the worker is still pending. We remove rtnl_lock and use a driver mutex just while mailboxes are accessed. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-11-22qlge: Fix incorrect usage of module parameters and netdev msg levelSonny Rao
Driver appears to be mistaking the permission field with default value in the case of debug and qlge_irq_type. Driver is also passing debug as a bitmask into netif_msg_init() which wants a number of bits. Ron Mercer suggests we should change this to pass in -1 so the defaults get used instead, which makes the default much less verbose. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Sonny Rao <sonnyrao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17drivers/net/qlge: Remove unnecessary casts of netdev_privJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-10qlge: Version change to v1.00.00.27Ron Mercer
Signed-off-by: Jitendra Kalsaria <jitendra.kalsaria@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-10qlge: Add firmware info to ethtool get regs.Ron Mercer
By default we add firmware information to ethtool get regs. Optionally firmware info can instead be sent to log. Signed-off-by: Jitendra Kalsaria <jitendra.kalsaria@qlogic.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27qlge: bugfix: Restoring the vlan setting.Ron Mercer
2010-10-24qlge: disable unsed dump codestephen hemminger
The driver has lots of unused code to dump data structures to console. Use existing simple way to remove the code with ifdef. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-24qlge: make local functions staticstephen hemminger
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26qlge: reset the chip before freeing the buffersBreno Leitao
Qlge is freeing the buffers before stopping the card DMA, and this can cause some severe error, as a EEH event on PPC. This patch just stop the card and then free the resources. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25qlge: Fix a deadlock when the interface is going downBreno Leitao
Currently qlge can deadlock when the interface is going down, and the mpi_port_cfg_work() is executing on another processor. It happens because unregister_netdev() holds the rtnl lock, and the mpi_port_cfg_work() also request this lock. Since unregiter_netdev() may wait mpi_port_cfg_work(), who also request the holding lock, it can cause an deadlock, displaying the following error: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. rmmod D 00000080c6c1d190 0 3993 2081 0x00008080 Call Trace: [c000000975f56ee0] [c0000000000152a0] .__switch_to+0x100/0x1d0 [c000000975f56f70] [c0000000005781b4] .schedule+0x3a4/0x8c0 [c000000975f570c0] [c000000000578e8c] .schedule_timeout+0x24c/0x350 [c000000975f571e0] [c000000000578a88] .wait_for_common+0x198/0x210 [c000000975f572c0] [c0000000000abbb4] .__cancel_work_timer+0x2c4/0x2e0 [c000000975f57400] [d0000000078e7a20] .ql_adapter_down+0x80/0x260 [qlge] [c000000975f574b0] [d0000000078e7d80] .qlge_close+0x70/0x130 [qlge] [c000000975f57540] [c000000000497ef8] .__dev_close+0x98/0xf0 [c000000975f575d0] [c000000000497f74] .dev_close+0x24/0x60 [c000000975f57650] [c000000000498080] .rollback_registered_many+0xd0/0x2b0 [c000000975f576f0] [c000000000498338] .rollback_registered+0x38/0x50 [c000000975f57780] [c0000000004983d8] .unregister_netdevice_queue+0x88/0xe0 [c000000975f57810] [c000000000498574] .unregister_netdev+0x24/0x40 [c000000975f57890] [d0000000078f6f38] .qlge_remove+0x3c/0x78 [qlge] [c000000975f57920] [c0000000002d9298] .pci_device_remove+0x48/0x90 [c000000975f579a0] [c000000000372850] .__device_release_driver+0xa0/0x130 [c000000975f57a30] [c000000000372a08] .driver_detach+0x128/0x150 [c000000975f57ad0] [c000000000371134] .bus_remove_driver+0xc4/0x1a0 [c000000975f57b70] [c00000000037357c] .driver_unregister+0x8c/0xd0 [c000000975f57c00] [c0000000002d968c] .pci_unregister_driver+0x5c/0x110 [c000000975f57ca0] [d0000000078f6ee4] .qlge_exit+0x1c/0x34 [qlge] Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19qlge: pull NULL check ahead of dereferenceDan Carpenter
There was a dereference before NULL check issue introduced in 1e213303d "qlge: Add tx multiqueue support." I've pulled the NULL check of "net_rsp" forward a couple lines to avoid that. Also Ron Mercer says that the early exit should be above the index write. ql_write_cq_idx(rx_ring); Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-21drivers/net/qlge: Use pr_<level>, shrink text a bitJoe Perches
Add and use a few neatening macros Remove PFX Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Convert printk(KERN_ERR to pr_err( $ size drivers/net/qlge/built-in.o.* text data bss dec hex filename 116456 2312 25712 144480 23460 drivers/net/qlge/built-in.o.old 114909 2312 25728 142949 22e65 drivers/net/qlge/built-in.o.new Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-07Merge branch 'master' of ↵David S. Miller
2010-07-05qlge: Change version to v1.00.00.25.00.00-01.Ron Mercer
2010-07-05qlge: Make adapter drop frame errors and pass up csum errors.Ron Mercer
Statistics are available and the driver doesn't need the actual frame. This TCP/UDP and IP headers checksum errors will still be passed to the driver. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05qlge: Fix possible endian issue for rx UDP csum.Ron Mercer
2010-07-05qlge: Reduce print level in data path statements.Ron Mercer
2010-07-05qlge: Don't use firmware when forcing firmware dump.Ron Mercer
In some cases the firmware may be dead. Instead we dump the firmware parameters and then restart it. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05qlge: Restore promiscuous setting after reset.Ron Mercer
2010-07-02qlge: fix a eeh handler to not add a pending timerBreno Leitao
On some ocasions the function qlge_io_resume() tries to add a pending timer, which causes the system to hit the BUG() on add_timer() function. This patch removes the timer during the EEH recovery. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-02qlge: Replacing add_timer() to mod_timer()Breno Leitao
Currently qlge driver calls add_timer() instead of mod_timer(). This patch changes add_timer() to mod_timer(), which seems a better solution. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13qlge: use the DMA state API instead of the pci equivalentsFUJITA Tomonori
This replace the PCI DMA state API (include/linux/pci-dma.h) with the DMA equivalents since the PCI DMA state API will be obsolete. No functional change. For further information about the background: http://marc.info/?l=linux-netdev&m=127037540020276&w=2 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24net/various: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part5 V2Jiri Pirko
removed some needless checks and also corrected bug in lp486e (dmi was passed instead of dmi->dmi_addr) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17qlge: Fix occasional loopback test failure.Ron Mercer
On some servers we see the cleaning of the RX queue finish before all the loopback packets are sent out. This delay allows the queues to settle before checking for successful completion. Also, delay completion so link has time to come back up. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17qlge: Fix bonding mac address bug.Ron Mercer
Use local copy of current mac address when initializing. In bonding testing we saw cases where dev_addr was out of data causing failover errors. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17qlge: Fix dropping of large non-TCP/UDP frames.Ron Mercer
This was found with pings that were large enough to span multiple rx buffers. The split frame logic handles this case nicely. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12drivers/net/qlge: Use netif_printk helpersJoe Perches
Convert QPRINTK macros to netif_<level> equivalents. Expands and standardizes the logging message output. Removes __func__ from most logging messages. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-04qlge: Code clean upBreno Leitao
Just reordering this assignment that doesn't depend on any condition. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
