path: root/drivers/net/r6040.c
2010-05-17r6040: fix link checking with switchesFlorian Fainelli
The current link checking logic only works for one port, which is not correct for swiches were multiple ports can have different link status. As a result we would only check for link status on port 1 of the switch. Move the calls to mii_check_media in r6040_timer which will be polling a single PHY chip correctly and assume link is up for switches. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13r6040: use (dev|netdev)_<level> macros helpersFlorian Fainelli
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-07r6040: fix r6040_multicast_listFlorian Fainelli
As reported in <https://bugzilla.kernel.org/show_bug.cgi?id=15355>, r6040_ multicast_list currently crashes. This is due a wrong maximum of multicast entries. This patch fixes the following issues with multicast: - number of maximum entries if off-by-one (4 instead of 3) - the writing of the hash table index is not necessary and leads to invalid values being written into the MCR1 register, so the MAC is simply put in a non coherent state - when we exceed the maximum number of mutlticast address, writing the broadcast address should be done in registers MID_1{L,M,H} instead of MID_O{L,M,H}, otherwise we would loose the adapter's MAC address Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part5 V2Jiri Pirko
removed some needless checks and also corrected bug in lp486e (dmi was passed instead of dmi->dmi_addr) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net/r6040.c: remove exceptional & on function nameJulia Lawall
In this file, function names are otherwise used as pointers without &. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-15r6040: fix version printingFlorian Fainelli
The version string already contains the printk level specifying it again results in the following message being printed: <6>r6040: RDC R6040 NAPI ... Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23r6040: bump to version 0.25 and 20 August 2009 release dateFlorian Fainelli
2009-08-23r6040: move down second PHY detection to r6040_init_oneMark Kelly
Instead of fully initializing an unusable second r6040 device, perform the PHY detection earlier and bail out in r6040_init_one when we could not read the PHY identifier. Signed-off-by: Mark Kelly <mark@bifferos.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-23r6040: remove unused pioaddr variableMark Kelly
This patch removes the unused pioaddr variable. Signed-off-by: Mark Kelly <mark@bifferos.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09Merge branch 'master' of ↵David S. Miller
2009-07-08r6040: bump driver version to 0.24 and date to 08 July 2009Florian Fainelli
2009-07-08r6040: restore MIER register correctly when IRQ line is sharedFlorian Fainelli
When the r6040 device IRQ line is shared we will enter the driver interrupt service routine, mask off the device interrupt enable register (MIER) and return with IRQ_NONE, we would then leave the device with interrupts disabled, this patch fixes that issue. Reported-by: Steve Holland <sdh4@iastate.edu> Signed-off-by: Joe Chou <joe.chou@rdc.com.tw> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05Minor code cleanup in drivers/net/r6040.cMichael Opdenacker
Replaced '0' by 'bar' in the probe function. The 'bar' variable was already set to '0' and is already used in pci_iomap(). This is cleaner and improves code consistency. Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-27r6040: check and update media statusFlorian Fainelli
This patch removes the not-that-useful message in the r6040_timer which prints the PHY status. Instead replace it with a call to mii_check_media which will update the link status and print it on startup. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-05r6040: bump version to 0.23 and date to 05May2009Florian Fainelli
Bump version to 0.23 and date to 05May2009. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-05r6040: check for absent PHYFlorian Fainelli
Some devices have two R6040 MACs but the second one is not wired to any PHY, therefore the interface is just unusable. Warn the user about that and prevent device from registering. Tested-by: bifferos <bifferos@yahoo.co.uk> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08r6040: set MODULE_VERSIONFlorian Fainelli
This patch sets MODULE_VERSION in order to help users track changes to this module. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-25Bump release date to 25Mar2009 and version to 0.22Florian Fainelli
This patch bumps the driver release date to March 25th 2009 and release version to 0.22. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-25r6040: Fix second PHY addressFlorian Fainelli
This patch fixes the second PHY address which is strapped to be at PHY address 3 instead of 2. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/r6040.c: fix sparse warning: Using plain integer as NULL pointerHannes Eder
Fix this sparse warnings: drivers/net/r6040.c:487:31: warning: Using plain integer as NULL pointer drivers/net/r6040.c:492:31: warning: Using plain integer as NULL pointer Signed-off-by: Hannes Eder <hannes@hanneseder.net> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000/e1000_main.c
2009-01-26r6040: Remove unused variable pdev from drivers/net/r6040.cManish Katiyar
drivers/net/r6040.c:441: warning: unused variable 'pdev' Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11netdev: add missing set_mac_address hookStephen Hemminger
Many drivers lost the ability to set ethernet address accidently during the net_device_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11r6040: bump release to 0.21Florian Fainelli
Bump version to 0.21 and release date to 09Jan2009. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11r6040: generate random ethernet MAC address when not initializedFlorian Fainelli
This patch makes the ethernet driver assign a random ethernet MAC address when the bootloader does not set it. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-11r6040: fix ifconfig down and freeing of tx/rx descriptorsFlorian Fainelli
This patch fixes warnings and such traces that appear when doing an ifconfig down on the interface: WARNING: at arch/x86/kernel/pci-dma.c:376 dma_free_coherent+0x40/0x7d() Modules linked in: Signed-off-by: Joe Chou <joe.chou@rdc.com.tw> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08r6040: bump release number to 0.20Florian Fainelli
This patch bumps release number to 0.20 and 07Jan2009. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08r6040: warn about MAC address being unsetFlorian Fainelli
Some bootloader/BIOSes do not set the MAC address, warn about that. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08r6040: check PHY status when bringing interface upFlorian Fainelli
This patch makes the driver properly initialize the PHY status if not correctly set by the bootloader/BIOS. It prevents some boards to bring up the link on boot. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08r6040: make printks consistent with DRV_NAMEFlorian Fainelli
This patch fixes some printks which were not prefixed with DRV_NAME, useful when having multiple cards/drivers on the system. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22r6040: bump release number to 0.19Florian Fainelli
This patch bumps the release number of the driver. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22r6040: save and restore MIER correctly in the interrupt routineJoe Chou
This patch saves the MIER register contents before treating interrupts, then restores them correcty at the end of the interrupt routine. Signed-off-by: Joe Chou <Joe.Chou@rdc.com.tw> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22r6040: fix wrong logic in mdio codeJoe Chou
This patch fixes a reverse logic in the MDIO code. Signed-off-by: Joe Chou <Joe.Chou@rdc.com.tw> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21r6040: convert to net_device_opsStephen Hemminger
Convert driver to new net_device_ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24r6040: fix wrong assignment in r6040_free_txbufsFlorian Fainelli
This patch fixes a wrong assignment in r6040_free_txbufs on a receive skb pointer while we should actually do this on the transmit skb pointer. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24r6040: fix bad usage of udelayFlorian Fainelli
This patch fixes the bad usage of udelay(5000), which in turns is a mdelay(5). It causes compilation for ARM where udelay maximum value is checked. Reported-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-14[netdrvr] remove unnecessary #includeHuang Weiyi
The drivers below do not use LINUX_VERSION_CODE nor KERNEL_VERSION. drivers/net/acenic.c drivers/net/bnx2x_link.c drivers/net/bnx2x_main.c drivers/net/cpmac.c drivers/net/gianfar_sysfs.c drivers/net/ipg.h drivers/net/ppp_mppe.c drivers/net/pppol2tp.c drivers/net/r6040.c drivers/net/sh_eth.c drivers/net/sky2.c drivers/net/tehuti.h drivers/net/typhoon.c This patch removes the said #include <linux/version.h>. Signed-off-by: Huang Weiyi <hwy@cn.fujitsu.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
