Merge error.
See CFG_METHOD_8 (0x3c800000 + 0x00300000) since version 8.002.00
of Realtek's driver.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Hayes <hayeswang@realtek.com>
Realtek confirmed that a 20us delay is needed after mdio_read and
mdio_write operations. Reduce the delay in mdio_write, and add it
to mdio_read too. Also add a comment that the 20us is from hw specs.
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
Some configurations need delay between the "write completed" indication
and new write to work reliably.
Realtek driver seems to use longer delay when polling the "write complete"
bit, so it waits long enough between writes with high probability (but
could probably break too). This patch adds a new udelay to make sure we
wait unconditionally some time after the write complete indication.
This caused a regression with XID 18000000 boards when the board specific
phy configuration writing many mdio registers was added in commit
2e955856ff (r8169: phy init for the 8169scd). Some of the configration
mdio writes would almost always fail, and depending on failure might leave
the PHY in non-working state.
Acked-off-by: Francois Romieu <romieu@fr.zoreil.com>
drivers/net/e100.c
drivers/net/e1000e/netdev.c
78f1cd02457252e1ffbc6caa44a17424a45286b8 ("fix broken register writes")
does not work for Al Viro's r8169 (XID 18000000).
Few (6) network drivers enable mwi explicitly. Fewer worry about a
failure.
It is not a fix but it should avoid some annoyance like
http://bugzilla.kernel.org/show_bug.cgi?id=15454
Cc: Conrad Kostecki <conikost@gmx.de>
drivers/net/bonding/bond_main.c
drivers/net/via-velocity.c
drivers/net/wireless/iwlwifi/iwl-agn.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Fix formatting on r8169 printk
Brandon Philips noted that I had a spacing issue in my printk for the
last r8169 patch that made it quite ugly. Fix that up and add the PFX
macro to it as well so it looks like the other r8169 printks
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
In case a reset is performed, rtl8169_rx_interrupt() is called from
process context instead of softirq context. Special care must be taken
to call appropriate network core services (netif_rx() instead of
netif_receive_skb()). VLAN handling also corrected.
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Diagnosed-by: Oleg Nesterov <oleg@redhat.com>
Official patch to fix the r8169 frame length check error.
Based on this initial thread:
http://marc.info/?l=linux-netdev&m=126202972828626&w=1
This is the official patch to fix the frame length problems in the r8169
driver. As noted in the previous thread, while this patch incurs a performance
hit on the driver, its possible to improve performance dynamically by updating
the mtu and rx_copybreak values at runtime to return performance to what it was
for those NICS which are unaffected by the ideosyncracy (if there are any).
Summary:
A while back Eric submitted a patch for r8169 in which the proper
allocated frame size was written to RXMaxSize to prevent the NIC from dmaing too
much data. This was done in commit fdd7b4c3302c93f6833e338903ea77245eb510b4. A
long time prior to that however, Francois posted
126fa4b9ca5d9d7cb7d46f779ad3bd3631ca387c, which expiclitly disabled the MaxSize
setting due to the fact that the hardware behaved in odd ways when overlong
frames were received on NIC's supported by this driver. This was mentioned in a
security conference recently:
http://events.ccc.de/congress/2009/Fahrplan//events/3596.en.html
It seems that if we can't enable frame size filtering, then, as Eric correctly
noticed, we can find ourselves DMA-ing too much data to a buffer, causing
corruption. As a result is seems that we are forced to allocate a frame which
is ready to handle a maximally sized receive.
This obviously has performance issues with it, so to mitigate that issue, this
patch does two things:
1) Raises the copybreak value to the frame allocation size, which should force
appropriately sized packets to get allocated on rx, rather than a full new 16k
buffer.
2) This patch only disables frame filtering initially (i.e., during the NIC
open), changing the MTU results in ring buffer allocation of a size in relation
to the new mtu (along with a warning indicating that this is dangerous).
Because of item (2), individuals who can't cope with the performance hit (or can
otherwise filter frames to prevent the bug), or who have hardware they are sure
is unaffected by this issue, can manually lower the copybreak and reset the mtu
such that performance is restored easily.
Signed-off-by: Neil Horman <nhorman@redhat.com>
This is quite similar to b39fe41f481d20c201012e4483e76c203802dda7
though said registers are not even documented as 64-bit registers
- as opposed to the initial TxDescStartAddress ones - but as single
bytes which must be combined into 32 bits at the MMIO read/write
level before being merged into a 64 bit logical entity.
Credits go to Ben Hutchings <ben@decadent.org.uk> for the MAR
registers (aka "multicast is broken for ages on ARM) and to
Timo Teräs <timo.teras@iki.fi> for the MAC registers.
This reverts commit 353176888386d9025062a12dcec08d49af10cf2c.
People are reporting problems due to this change and there
is no anticipation that the cause will be tracked down
any time soon.
We can try next time to selectively re-enable this based upon chip
type, or have a black list of some sort.
Use the PCI runtime power management framework to add basic PCI
runtime PM support to the r8169 driver. Namely, make the driver
suspend the device when the link is not present and set it up for
generating a wakeup event after the link has been detected again.
[This feature is disabled until the user space enables it with the
help of the /sys/devices/.../power/contol device attribute.]
r8169 needs certain writes to be visible to other CPUs or the NIC before
touching the hardware, but was using smp_wmb() which is only required to
order cacheable memory access. Switch to wmb() which is required to
order both cacheable and non-cacheable memory.
Noticed by Catalin Marinas and Paul Mackerras.
Signed-off-by: David Dillow <dave@thedillows.org>
removed some needless checks and also corrected bug in lp486e (dmi was passed
instead of dmi->dmi_addr)
Currently use of 64-bit DMA is disabled in r8169 unless the user passes the
use_dac module option. This is reasonable for conventional PCI devices where
broken chipsets may not handle dual-address-cycle transfers properly for
32-bit slots and so this may not be safe. However, PCI Express should not have
this problem and not using 64-bit DMA results in DMA transfers needlessly using
the IOMMU or SWIOTLB. Set the use_dac module parameter to a new default value of
-1 which results in 64-bit DMA being enabled by default for PCI Express devices
only.
Signed-off-by: Robert Hancock <hancockrwd@gmail.com>
Simplify the logic a bit, make the message logs a bit more consistent.
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss
anything). Used spatch and did small tweaks and conding style changes when
it was suitable.
Jirka
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
Use the %pM kernel extension to display the MAC address.
Only files where David Miller is the primary git-signer.
wireless, wimax, ixgbe, etc are not modified.
Compile tested x86 allyesconfig only
Not all files compiled (not x86 compatible)
Added a few > 80 column lines, which I ignored.
Existing checkpatch complaints ignored.
net/mac80211/ht.c
The newer chipsets (all PCI-E) are known that they need full power cycle
(AC or battery removal) to reset MAC address to a hardwired one. Previous
patch to address this problem loads the original MAC address from EEPROM.
But it brought other problem for which it is necessary to introduce a new
module parameter.
However, it might suffice to restore the initial MAC address before
shutdown/reboot/kexec and when removing the module.
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
As side effect, consume less stack.
-rtl8169_get_mac_version [vmlinux]: 432
-rtl8169_init_one [vmlinux]: 376
+rtl8169_init_one [vmlinux]: 136
drivers/net/can/Kconfig
In r8169 driver MTU is used to calculate receive buffer size.
Receive buffer size is used to configure hardware incoming packet filter.
For jumbo frames:
Receive buffer size = Max frame size = MTU + 14 (ethernet header) + 4
(vlan header) + 4 (ethernet checksum) = MTU + 22
Bug:
driver for all MTU up to 1536 use receive buffer size 1536
As you can see from formula, this mean all IP packets > 1536 - 22
(for vlan tagged, 1536 - 18 for not tagged) are dropped by hardware
filter.
Example:
host_good> ifconfig eth0 mtu 1536
host_r8169> ifconfig eth0 mtu 1536
host_good> ping host_r8169
Ok
host_good> ping -s 1500 host_r8169
Fail
host_good> ifconfig eth0 mtu 7000
host_r8169> ifconfig eth0 mtu 7000
Ok
Bonus: got rid of magic number 8
Signed-off-by: Raimonds Cicans <ray@apollo.lv>
drivers/net/usb/cdc_ether.c
All CDC ethernet devices of type USB_CLASS_COMM need to use
'&mbm_info'.
r8169 card drop incoming VLAN tagged MTU byte large jumbo frames
It looks to compare current and maximal packet sizes hardware use
'<' operator, not '<='.
Bug introduced by commit fdd7b4c3302c93f6833e338903ea77245eb510b4
("r8169: fix crash when large packets are received")
drivers/net/sh_eth.c
The 8110SC rev d chip on our board shows a regression which the 8110SB chip
did not have. When inbound traffic is overflowing the receive descriptor queue,
"holes" in the ring buffer may occur which lead to a hangup until the buffer
is filled again. The packets are than completely processed, but the ring
remains porous and no packets are processed until the next overflow. Setting
the interface down and up can fix the problem temporary from userspace.
For some reason we don't know, this behaviour is not occuring if the RxVlan
bit for hardware VLAN untagging is set. There is another "Work around for
AMD plateform" in the current code which checks the VLAN status
word in receive descriptors, but does never come to effect when hardware
VLAN support is enabled. We assume that this is a bug in the chip.
The following patch fixes the problem. Without the patch we could reproduce
the hang within minutes (given other devices also generating lots of
interrupts), without we couldn't reproduce within a few days of long term
testing.
This version contains minor style adjustments and is sent with mutt which
will hopefully not destroy the formatting again.
Signed-off-by: Bernhard Schmidt <bernhard.schmidt@saxnet.de>
Signed-off-by: Simon Wunderlich <simon.wunderlich@saxnet.de>
Acked-by: Francois Romieu <romieu@zoreil.com>
Extracted from Realtek's 8.012.00 r8168 driver.
Tested-by: Simon Farnsworth <simon.farnsworth@onelan.com>
Cc: Edward Hsu <edward_hsu@realtek.com.tw>
Reported by Stephen Rothwell:
drivers/net/r8169.c: In function 'rtl8169_start_xmit':
drivers/net/r8169.c:3421: warning: label 'out' defined but not used
Introduced by commit 61357325f377889a1daffa14962d705dc814dd0e ("netdev:
convert bulk of drivers to netdev_tx_t").
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the
driver's implementation of MDIO ioctls.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
In a couple of cases collapse some extra code like:
int retval = NETDEV_TX_OK;
return retval;
into
return NETDEV_TX_OK;
Synced with Realtek's 1.013.00 r8101 driver.
Synced with Realtek's 6.011.00 r8169 driver.
The driver displays the same 0x18000000 xid for RTL_GIGA_MAC_VER_06
and RTL_GIGA_MAC_VER_05 whereas the former ought to be identified as
0x98000000.
Noticed by Vincent Pelletier <plr.vincent@gmail.com>.
More stuff for http://bugzilla.kernel.org/show_bug.cgi?id=9512
Some 8168 are unable to WoL when receiving is not enabled (plain
old 8169 do not seem to care).
It is not exactly pretty to leave the receiver enabled but we
should now enable DMA late enough for it to be safe. Some late
stage boot failure due to pxe and friends may benefit from the
delayed enabling of bus-mastering as well.
Tested-by: Jaromír Cápík <tavvva@volny.cz>
all references got removed by 865c652d6be9929927cabdc54b137b7541eb6612
(r8169: remove non-napi code).
Signed-off-by: Florian Westphal <fwestphal@astaro.com>
Stopping all activity through ChipCmd and blindly acking the irqs
is neither nice nor completely needed: the transition to low-power
mode does enough work and it apparently keeps the device in a sane
state.
Patch suggested by a fix for http://bugzilla.kernel.org/show_bug.cgi?id=9512
The rtl_shutdown path is kept unchanged so far.
Tested-by: Anders Eriksson <aeriksson@fastmail.fm>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
rtl8169_tx_interrupt() is used from NAPI context, it can
directly free skbs. dev_kfree_skb_irq() is a leftover from
pre-NAPI times of this driver.
Michael Tokarev reported receiving a large packet could crash
a machine with RTL8169 NIC.
( original thread at http://lkml.org/lkml/2009/6/8/192 )
Problem is this driver tells that NIC frames up to 16383 bytes
can be received but provides skb to rx ring allocated with
smaller sizes (1536 bytes in case standard 1500 bytes MTU is used)
When a frame larger than what was allocated by driver is received,
dma transfert can occurs past the end of buffer and corrupt
kernel memory.
Fix is to tell to NIC what is the maximum size a frame can be.
This bug is very old, (before git introduction, linux-2.6.10), and
should be backported to stable versions.
Reported-by: Michael Tokarev <mjt@tls.msk.ru>
Tested-by: Michael Tokarev <mjt@tls.msk.ru>
