path: root/drivers/net/s2io.h
2011-04-12s2io: Fix warnings due to -Wunused-but-set-variable.David S. Miller
Most of these are cases where we are trying to read back a register after a write to ensure completion. Simply pre-fixing the readl() or readq() with "(void)" is sufficient because these are volatile operations and the compiler cannot eliminate them just because no real assignment takes place. The case of free_rxd_blk()'s assignments to "struct buffAdd *ba" is a real spurious assignment as this variable is completely otherwise unused. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jon Mason <jdmason@kudzu.us>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-06s2io: convert to set_phys_id (v2)stephen hemminger
Convert to new ethtool set physical id model. Remove no longer used timer, and fix docbook comment. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-11s2io: make strings at tables constJon Mason
Put immutable data in read/only section. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-11s2io: rx_ring_sz bounds checkingJon Mason
modparm rx_ring_sz can be set to be greater than the maximum allowable number of blocks. This results in an array overrun when probing the driver, and causes memory corruption. Also, the MAX_RX_DESC_1 multiply the max number of rings by max number of blocker per ring by 127, but the driver does the same calculation with 127+1. This results in the possibility of the value being set being larger than the maximum allowable value. Finally, clean-up the s2io_ethtool_gringparam code to be more intuitive. Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25s2io: remove lro parameterAmerigo Wang
Remove "lro" parameter of s2io driver. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: jon.mason@exar.com Acked-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-18s2io: remove unused codeJon Mason
usr_addrs is never referenced outside the initial struct population during open, thus making it unnecessary. Remove it, the code that references it, and the struct that it is the only user of. Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x_main.c Merge bnx2x bug fixes in by hand... :-/ Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-26s2io: fixing DBG_PRINT() macroBreno Leitao
Patch 9e39f7c5b311a306977c5471f9e2ce4c456aa038 changed the DBG_PRINT() macro and the if clause was wrongly changed. It means that currently all the DBG_PRINT are being printed, flooding the kernel log buffer with things like: s2io: eth6: Next block at: c0000000b9c90000 s2io: eth6: In Neterion Tx routine Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Sreenivasa Honnur <Sreenivasa.Honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-15vxge: Update copyright informationJon Mason
Update copyright information to reflect the Exar purchase of Neterion Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@exar.com> Signed-off-by: Ramkrishna Vepa <ramkrishna.vepa@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-02s2io: resolve statistics issuesJon Mason
This patch resolves a number of issues in the statistics gathering of the s2io driver. On Xframe adapters, the received multicast statistics counter includes pause frames which are not indicated to the driver. This can cause issues where the multicast packet count is higher than what has actually been received, possibly higher than the number of packets received. The driver software counters are replaced with the adapter hardware statistics for rx_packets, rx_bytes, and tx_bytes. It also uses the overflow registers to determine if the statistics wrapped the 32bit register (removing the window of having a statistic value less than the previous call). rx_length_errors statistic now includes undersized packets in addition to oversized packets in its counting. Finally, rx_crc_errors are now being counted. Signed-off-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-30s2io: Generate complete messages using single line DBG_PRINTsJoe Perches
Single line log messages should be emitted by a single call where possible. Converted multiple calls to DBG_PRINT to single call form. Removed "s2io:" preface from DBG_PRINTs. The DBG_PRINT macro now emits a log level and is surrounded by a do {...} while (0) All s2io log output is now prefaced with KBUILD_MODNAME ": " via pr_fmt. The DBG_PRINT macro should probably be converted to use the dev_<level> form eventually. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08s2io: Remove private boolean definitionsTobias Klauser
Remove the private definition of TRUE/FALSE and use the ones from linux/stddef.h. Also remove the definition of BOOL which is not referenced inside the driver anyway. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24s2io: Fix enabling VLAN tag stripping at driver initializationBreno Leitao
VLAN doesn't work except if you'd opened the interface in promiscuous mode before. This happens because VLAN tag stripping is not correctly marked as enabled at device startup Also, the vlan_strip_flag field was moved to the private network structure. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-11S2io: Enable msi-x link interrupts.Sreenivasa Honnur
- Enable msi-x link interrupts because the timer based scheduler was getting cancelled causing the link state to be lost with repetitive card up/downs when changing the mtu. - Unmask mac_rmac_link interrupts only for Xframe I and prevent a spurious link interrupt in Xframe II. - Stop the tx queue and indicate link down when card is down Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl4965-base.c
2008-06-27[netdrvr] Fix IOMMU overflow checking in s2io.cAndi Kleen
s2io has IOMMU overflow checking, but unfortunately it is wrong. It didn't use the standard macros, which meant that it only worked on POWER and SPARC because only those define DMA_ERROR_CODE. Convert it to use the standard macros instead. I also commented two more bugs in the IOMMU handling. It assumes that 0 DMA addresses cannot happen, but that's not true in all IOMMU setups. The information if a buffer has been already mapped needs to be stored elsewhere. Didn't fix those because it needs careful checking of the buffer handling by the maintainers. Cc: ram.vepa@neterion.com Cc: santosh.rastapur@neterion.com Cc: sivakumar.subramani@neterion.com Cc: sreenivasa.honnur@neterion.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
2008-05-22S2io: Added napi support when MSIX is enabled.Sreenivasa Honnur
- Added napi support when MSIX is enabled. - Moved test_msi function from s2io_open to probe function. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22S2io: Move all the transmit completions to a single msi-x (alarm) vectorSreenivasa Honnur
- Move all the transmit completions to a single msi-x (alarm) vector. - Enable the continuous timer interrupt for only one transmit fifo. Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13[netdrvr] Trim trailing whitespace for several driversJeff Garzik
2008-04-29S2io: Enable multi ring supportSreenivasa Honnur
- Seperate ring specific data - Initialize all configured rings with equal priority. - Updated boundary check for number of Rings. - Updated per ring statistics of rx_bytes and rx_packets. - Moved lro struct from struct s2io_nic to struct ring_info. - Access respective rx ring directly in fill_rx_buffers. - Moved rx_bufs_left struct s2io_nic to struct ring_info. - Added per ring variables - rxd_mode, rxd_count, dev, pdev. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25S2io: Removed rx_lock and put_lockSreenivasa Honnur
- Removed rx_lock and put_lock as the buffer replenishment and receive completion is handled serially. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-04-25S2io: Removed receive buffer replenishment taskletSreenivasa Honnur
- Removed receive buffer replenishment tasklet s2io_tasklet and instead allocating the receive buffers in either the interrupt handler (no napi) or the napi handler (napi enabled). Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-17S2io: Support for vlan_rx_kill_vid entry pointSreenivasa Honnur
- Resubmit #3 - Added s2io_vlan_rx_kill_vid entry point function for unregistering vlan. - Fix to aggregate vlan packets. IP offset is incremented by 4 bytes if the packet contains vlan header. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17S2io: Multiqueue network device support - FIFO selection based on L4 portsSreenivasa Honnur
- Resubmit #2 - Transmit fifo selection based on TCP/UDP ports. - Added tx_steering_type loadable parameter for transmit fifo selection. 0x0 NO_STEERING: Default FIFO is selected. 0x1 TX_PRIORITY_STEERING: FIFO is selected based on skb->priority. 0x2 TX_DEFAULT_STEERING: FIFO is selected based on L4 Ports. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-17S2io: Multiqueue network device support implementationSreenivasa Honnur
- Resubmit #3 Multiqueue netwrok device support implementation. - Added a loadable parameter "multiq" to enable/disable multiqueue support, by default it is disabled. - skb->queue_mapping is not used for queue/fifo selection. FIFO selection is based on skb->priority. - Added per FIFO flags FIFO_QUEUE_START and FIFO_QUEUE_STOP. Check this flag for starting and stopping netif queue and update the flags accordingly. - In tx_intr_handler added a check to ensure that we have free TXDs before wak- ing up the queue. - Added helper functions for queue manipulation(start/stop/wakeup) to invoke appropriate netif_ functions. - Calling netif_start/stop for link up/down case respectively. - As per Andi kleen's review comments, using skb->priority field for FIFO selection. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-03S2io: Fix for LRO BugsSurjit Reang
Resubmitting patch from Al Viro <viro@zeniv.linux.org.uk>, with subject - [PATCH] s2io LRO bugs. a) initiate_new_session() sets ->tcp_ack to ntohl(...); everything else stores and expects to find there the net-endian value. b) check for monotonic timestamps in verify_l3_l4_lro_capable() compares the value sitting in TCP option (right there in the skb->data, net-endian 32bit) with the value picked from earlier packet. Doing that without ntohl() is an interesting idea and it might even work occasionally; unfortunately, it's quite broken. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28S2io: Fixes to enable multiple transmit fifo supportSurjit Reang
Fixes to enable multiple transmit fifos (upto a maximum of eight). - Moved single tx_lock from struct s2io_nic to struct fifo_info. - Moved single ufo_in_band_v structure from struct s2io_nic to struct fifo_info. - Assign the respective interrupt number for the transmitting fifo in the transmit descriptor (TXD). - Added boundary checks for number of FIFOs enabled and FIFO length. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[S2IO]: Support for add/delete/store/restore ethernet addressesSreenivasa Honnur
- Support to add/delete/store/restore 64 and 128 Ethernet addresses for Xframe I and Xframe II respectively. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19s2io, rename BIT macroJiri Slaby
s2io, rename BIT macro BIT macro will be global definiton of (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ramkrishna Vepa <ram.vepa@neterion.com> Cc: Rastapur Santosh <santosh.rastapur@neterion.com> Cc: Sivakumar Subramani <sivakumar.subramani@neterion.com> Cc: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10S2io: Added support set_mac_address driver entry pointSivakumar Subramani
- Added set_mac_address driver entry point - Copying permanent mac address to dev->perm_addr - Incorporated following review comments from Jeff - Converted the macro to a function and removed call to memset - regarding function naming convention, for all callbacks and entry points will have 's2io_' prefix and helper functions will have 'do_s2io_' prefix. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10S2io: Removed unused feature - bimodal interruptsSivakumar Subramani
Removed bimodal interrupt support - unused feature Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> [also, trim trailing whitespace]
2007-10-10S2io: code Optimization of isr functionSivakumar Subramani
- Code Optimization of s2io_isr function. - Isr check using per device napi variable instead of driver global. - Reduced from 3 to 1 if condition before check for processing packet receive packets. - Implemented Jeff's comment to use synchronize_irq. Removed the isr_cnt variable as it became redundant. - One time de assert the interrupts by writing all F's to the general_int_mask register instead of de asserting by clearing the source of interrupts with multiple writes which causes loss of interrupts (race conditions). It is entirely possible that before the driver has a chance to mask the asserted alarm bit, another alarm/traffic interrupt bit gets asserted as well. In this case Herc will keep the INTA line asserted and the bridge will not send a new Assert_INTA message upstream. [ Resolved conflicts due to napi_struct changes... -DaveM ] Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10S2io: Check for device state before handling trafficSivakumar Subramani
- Added check to return from the traffic handling function, if the card status is DOWN. - Implemented Jeff's comments on incorrect return value in s2io_poll function. Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10S2io: Cleanup - removed unused variable intr_typeSivakumar Subramani
- Removed the unused variable, intr_type, in device private structure. [ Resolve conflicts with napi_struct changes... -DaveM ] Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[S2IO]: Handle and monitor all of the device errors and alarmsSivakumar Subramani
- Added support to poll entire set of device errors and alarams. - A note on how device errors and alarms are handled: - The adapter will automatically recover from uncorrectable ECC errors. Packets containing corrupted data will be dropped (not transmitted) or tagged as invalid before being passed to the host. - The adapter cannot recover from any internal state machine errors. A state machine error requires a device reset. - Any internal error that could potentially result in .store trampling. (undesirable PCI behaviour)is tagged as a "serious error". In such cases the adapter will give up its ability to be a bus master. In this situation the host will still be able to read internal device registers in order to generate an error report. A device reset is necessary to return to normal operation. - In the event of a pcix data parity error, the adapter will automatically disable itself. Adapter_En will automatically transition from '1' to '0' and the adapter will enter its clean-up routine. Once the device has achieved quiescence, an adapter reset should be performed. - Replaced alarm_intr_handler() with s2io_handle_errors(). - Added statistic counters to monitor the alarms. [ Fix warnings wrt. do_s2io_chk_alarm_bit(), Callers pass in an "unsigned long long *" but the function takes a "u64 *" which is different on many 64-bit platforms. -DaveM ] Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10S2io: Enable all the error and alarm indicationsSivakumar Subramani
- Added support to unmask entire set of device errors and alarams. Alarm interrupts are generated for a myriad of purposes, ranging from illegal operations or requests to internal state machine errors and uncorrectable data corruption errors. In several cases the adapter can recover gracefully from unexpected events; however, in some cases, a device reset may be necessary. This patch handles alarms generated by all the blocks within the device. The adapter generates the following types of alarms: 1. Link state transitions (local/remote fault) or other link-related problems. 2. Problems with any device peripherals, including the EEPROM, FLASH, etc. 3. Correctable ECC errors (single-bit errors) on internal data structures or frame data. 4. Uncorrectable ECC errors (multi-bit errors) on internal data structures or frame data. 5. State machine errors, which indicate that internal control structures have become corrupted. 6. PCI related errors, including parity errors or illegal transactions. 7. Other unexpected events. - Implemented Jeff's review comments to use do_s2io_write_bits function to avoid duplicate codes. Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Santosh Rastapur <santosh.rastapur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10S2IO: Fixes in MSIX related code.Sivakumar Subramani
- Calling store_xmsi_data to store the MSI-X datas during initialization in s2io-init_nic function - Disabling NAPI when MSI-X is enabled - Freeing sp->entries and sp->s2io_entries in s2io_rem_isr Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[S2IO]: Making MSIX as default intr_typeSivakumar Subramani
- Making MSIX as default intr_type - Driver will test MSI-X by issuing test MSI-X vector and if fails it will fallback to INTA Signed-off-by: Sivakumar Subramani <sivakumar.subramani@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make NAPI polling independent of struct net_device objects.Stephen Hemminger
Several devices have multiple independant RX queues per net device, and some have a single interrupt doorbell for several queues. In either case, it's easier to support layouts like that if the structure representing the poll is independant from the net device itself. The signature of the ->poll() call back goes from: int foo_poll(struct net_device *dev, int *budget) to int foo_poll(struct napi_struct *napi, int budget) The caller is returned the number of RX packets processed (or the number of "NAPI credits" consumed if you want to get abstract). The callee no longer messes around bumping dev->quota, *budget, etc. because that is all handled in the caller upon return. The napi_struct is to be embedded in the device driver private data structures. Furthermore, it is the driver's responsibility to disable all NAPI instances in it's ->stop() device close handler. Since the napi_struct is privatized into the driver's private data structures, only the driver knows how to get at all of the napi_struct instances it may have per-device. With lots of help and suggestions from Rusty Russell, Roland Dreier, Michael Chan, Jeff Garzik, and Jamal Hadi Salim. Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra, Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan. [ Ported to current tree and all drivers converted. Integrated Stephen's follow-on kerneldoc additions, and restored poll_list handling to the old style to fix mutual exclusion issues. -DaveM ] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30S2IO: Checking for the return value of pci map functionVeena Parat
- Checking for the return value of pci map function - Implemented Francois Romieu's comments on eliminating code duplication using goto - Implemented Francois Romieu's comments on using a temporary variable for accessing statistics structure Signed-off-by: Veena Parat <veena.parat@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-30S2IO: Removing MSI support from driverVeena Parat
- Removed MSI support from driver - unused feature - Replaced request_mem_region with pci_request_regions Signed-off-by: Veena Parat <veena.parat@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-30S2IO: Removing 3 buffer mode support from the driverVeena Parat
- Removed 3 buffer mode support from driver - unused feature - Incorporated Jeff Garzik's comments on elimination of inline typecasting - Code cleanup : Removed a few extra spaces Signed-off-by: Veena Parat <veena.parat@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-08s2io: add PCI error recovery supportLinas Vepstas
s2io cleanup suggestions, per discussion on mailing lists. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
This patch adds PCI error recovery support to the s2io 10-Gigabit ethernet device driver. Third revision, blocks interrupts and the watchdog. Tested, seems to work well. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: Ramkrishna Vepa <Ramkrishna.Vepa@neterion.com> Cc: Raghavendra Koushik <raghavendra.koushik@neterion.com> Cc: Wen Xiong <wenxiong@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11S2IO: Statistics for link up/down and memory allocated/freedSreenivasa Honnur
1. Added statistics for link up/down, last link up/down. 2. Statistics for memory allocated/freed. 3. Changed level of some DBG_PRINTs. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-11S2IO: statistics for memory allocation failuersSreenivasa Honnur
1. Added code to count the number of memory failures. 2. Added watchdog_timer counter. 3. Changed debug level for some DBG_PRINTS. Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
