path: root/drivers/net/s6gmac.c
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net: remove redundant codeEric Dumazet
eth_type_trans(skb, netdev) does the "skb->dev = netdev;" initialization, we can remove it from various network drivers. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-02s6gmac: Read buffer overflowroel kluin
Check whether index is within bounds before testing the element. In the last iteration i is PHY_MAX_ADDR. the condition `!(p = pd->mii.bus->phy_map[PHY_MAX_ADDR])' is undefined and may evaluate to false, which leads to a dereference of this invalid phy_map in the phy_connect() below. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-22s6gmac: xtensa s6000 on-chip ethernet driverOskar Schirmer
The s6000 on-chip MAC supports 10/100/1000Mbit and is connected to an external PHY via MII or RGMII interface. [jw@emlix.com: don't use device->bus_id directly] Signed-off-by: Oskar Schirmer <os@emlix.com> Signed-off-by: Daniel Glockner <dg@emlix.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Johannes Weiner <jw@emlix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Zankel <chris@zankel.net>
